  4. LHS and RHS of + have different dimensions
16 帖子 4 发布者 30.8k 浏览
    mark
    很感谢!
    mark
    @Aeronastro @administrators 试了一下,好像不行哦
    Aeronastro
    在 中回复了 mark 最后由 编辑
    @mark 什么错误?可以附图吗?
    mark
    Create time
    Create mesh for time = 0
    Reading g
    PIMPLE: Operating solver in PISO mode
    Reading field p_rgh
    Reading field U
    Constructing twoPhaseMixtureThermo
        type            heRhoThermo;
        mixture         pureMixture;
        transport       sutherland;
        thermo          hConst;
        equationOfState PengRobinsonGas;
        specie          specie;
        energy          sensibleEnthalpy;
        type            heRhoThermo;
        thermo          hConst;
        specie          specie;
    --> FOAM Warning :
        From function GeometricField<Type, PatchField, GeoMesh>::readIfPresent()
        in file /opt/openfoam240/src/OpenFOAM/lnInclude/GeometricField.C at line 108
        read option IOobject::MUST_READ or MUST_READ_IF_MODIFIED suggests that a read constructor for field rho1 would be more appropriate.
    --> FOAM Warning :
        read option IOobject::MUST_READ or MUST_READ_IF_MODIFIED suggests that a read constructor for field rho2 would be more appropriate.
    Creating phaseChangeTwoPhaseMixture
    Selecting phaseChange model SchnerrSauer
    Calculating field g.h
    Selecting turbulence model type LESModel
    Selecting LES turbulence model oneEqEddy
    Selecting LES delta type smooth
    Selecting LES delta type cubeRootVol
    oneEqEddyCoeffs
        ce              1.048;
        Prt             1;
        ck              0.094;
    Creating field kinetic energy K
    Courant Number mean: 4.9504176e-07 max: 1.9500023e-05
    Starting time loop
    Courant Number mean: 4.9014036e-07 max: 1.9306953e-05
    deltaT = 9.9009901e-09
    Time = 9.90099e-09
    PIMPLE: iteration 1
    --> FOAM FATAL ERROR:
         dimensions : [1 -3 0 0 0 0 0] + [0 0 0 0 0 0 0]
        From function operator+(const dimensionSet&, const dimensionSet&)
        in file dimensionSet/dimensionSet.C at line 478.
    FOAM aborting
    #2  Foam::operator+(Foam::dimensionSet const&, Foam::dimensionSet const&) at ??:?
    #3  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator+<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) at ??:?
    #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator+<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, double const&) at ??:?
    #5  Foam::phaseChangeTwoPhaseMixture::vDotAlphal() const at ??:?
    #6  ? at ??:?
    #7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #8  ? at ??:?
    已放弃 (核心已转储)
    zhubin@zhubin-System-Product-Name:~/OpenFOAM/zhubin-2.4.0/run/tutorials/myFoam$
    Aeronastro
    在 中回复了 mark 最后由 编辑
    @mark 还是dimension不匹配,你在代码里把rho2()+VSMALL改成rho2()+zeroField了吗?
    mark
    @Aeronastro
    防止分母为0 ,我设置一个dimensionedScalar small_ ,
    small = 1.0e-36 这样一个非常小的数可以吗?
    volScalarField alphalCoeff(1.0/rho1() - alpha1_*(1.0/rho1() - 1.0/(rho2() + small())));
    这样就可以算了:sunglasses: 请指教..
    Aeronastro
    在 中回复了 mark 最后由 编辑
    @mark 嗯嗯,只要给定量纲就可以了,dimensionedScalar设置了量纲,而且operator+可以使volscalarField和dimensionedScalar可以相加就没问题了
    我不明白,为什么设置新的volScalarField这样的场不行呢?你试过不行是吗?
    mark
    @Aeronastro 应该也可以的,刚才我忘记wmake那个库文件,直接wmake求解器了,先这样算着,我改天再试一下
  • F 离线
    F 离线
    Foamer24
    在 中回复了 Aeronastro 最后由 编辑
    @Aeronastro dimesionedScalar拼写错了,是dimensionedScalar;结尾还有分号“;”。
    在 中回复了 Foamer24 最后由 编辑
    @Foamer24
    你回贴的这俩位我还有点印象,2016年的时候他们俩研究的还很深刻,后来就没怎么来过。不知道最近怎么样了,有没有在CFD。我有种预感他俩是不是转行了...
