  4. MPPICInterFoam中的bug?
35 帖子 7 发布者 52.5k 浏览
    现在手头没有DPM算例,要不你测试一下 :quwan:
    简单测试了一下,alphac.oldTime() = alphac不能解决,留给其他感兴趣的朋友们,谁有兴趣修复一下。
    但是DPMFoam中没有这个问题。
  • 溯 离线
    溯 离线
    溯光
    在 中回复了 linhan.ge 最后由 编辑
    @linhan-ge 请问这是哪篇文献中的控制方程
    linhan.geL 1 条回复 最后回复
  • linhan.geL 离线
    linhan.geL 离线
    linhan.ge
    在 中回复了 溯光 最后由 编辑
    @溯光 Jing, L., Kwok, C.Y., Leung, Y.F., Sobral, Y.D., 2016. Extended CFD-DEM for free-surface flow with multi-size granules. International Journal for Numerical and Analytical Methods in Geomechanics 40, 62-79.
    Working on CFDEM project.
    溯 1 条回复 最后回复
  • 溯 离线
    溯 离线
    溯光
    @linhan-ge 在 MPPICInterFoam中的bug? 中说:
    谢谢
  • 白 离线
    白 离线
    白礼耕
    东岳老师,我的印度同事也经常逛CFD中文网,平时都是用谷歌翻译阅读。他也发现了这个问题(气泡不会让交界面的位置升高),想问您下面的问题:
    When particles are injected, the liquid level is not changing. What could be the reason? Is it the ddt(alphac)=zero the reason?
    多谢您了!
    在 中回复了 白礼耕 最后由 李东岳 编辑
    @白礼耕 Check the alpha.Eqn and p.Eqn:
    fvScalarMatrix p_rghEqn
        fvm::laplacian(Dp, p_rgh)
        fvc::ddt(alphac) + fvc::div(alphacf*phiHbyA)
    even ddt(alphac)=0, it considers only the continuous phase (water) because alphac = 1 - alpha.air. It makes sense if you do the following to address the effects of particles: 1) include the sink terms in alpha.Eqn, 2) alphac = 1 - alpha.air - alpha.particle 3) manage the momentum interface exchange terms in U.Eqn. In this way a two-way coupling can be implemented, but not quite easy. Currently the implementation is quite simple, but it only works for dilute particle flow (one-way coupling).
    白 1 条回复 最后回复
  • 白 离线
    白 离线
    白礼耕
    @东岳 Thanks for your help!
    In the paper given above, the definition of alphac (=alpha.air + alpha.water) is different. I want to confirm exactly what it is. Is it not following the paper?
    comment on 3rd point: I have already done that.
    @白礼耕 在 MPPICInterFoam中的bug? 中说:
    What is different?
    白 1 条回复 最后回复
  • 白 离线
    白 离线
    白礼耕
    @东岳 The expression in the paper (Fig. 2 in paper "Extended CFD–DEM for free-surface flow with multi-size granules", which is given as alphaf) is alphac = 1-alpha.particle which is different from what you provided (alphac = 1 - alpha.air - alpha.particle). I just wanted to clarify which one is in the code?
    Thank you again!
    code: alpha.water = 1-alpha.air. Particles play no role
    白 zheZ 2 条回复 最后回复
  • 白 离线
    白 离线
    白礼耕
    @东岳 Thanks again for your help! 谢谢
  • zheZ 离线
    zheZ 离线
    zhe
    @东岳 Currently, I am working on MPPICInterFoam. I thought alphac is the volume fraction of fluid ( not just water or air). If there is no particles in the system, alphac = alpha1 + alpha 2 = alpha.water + alpha.air=1. If with particles, alphac = 1-theta = 1- alpha.particles. The particles are accounted up. We can not just say alphac is alpha.water (which alphac = 1 - alpha.air - alpha.particle). Please fix it if I said wrong. Thank you.
    AppleKiller
    @linhan-ge 我觉得也应该是这样,但我还没理解李老师说的,您理解了吗?
