  4. reactingtwophaseeulerfoam?
23 帖子 2 发布者 31.4k 浏览
  • K 离线
    K 离线
    kimy
    This is the mass conservation equation I am using. The sign of laplacian term here is minus. However, as your page http://dyfluid.com/reactingTwoPhaseEulerFoam.html in equation(24), it should be plus I think if I understand well. I am confused that the sign of source term will induce large different result or no?
    The source term in Eq. (24) does not come from the laplacian term. It comes from the convection term. Eq. (24) is not related to your posted equations. The laplacian terms in your posted image are turbulent dispersion terms. In OpenFOAM they are not implemented in this manner.
    K 2 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳 If I understand well, equation (24) was changed by the sum of two mass conservation equation. However I must add that term in the mass conservation equation. So the position I implemented the laplacian term is right? The mass conservation equation shown in picture is our own equation.
    If you sum them up, $-\nabla\cdot(\nabla\alpha_l+\nabla\alpha_s)=0$ This term disappears.
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳 Thanks, if the sum of that two term is zero, so there cannot exist any problem during the simulation. why I use the sign "plus", it crashed while 'minus' run well? And if I changed the phase2.turbulence.nut() to be nu() a constant, "plus" has no problem?
    Do you obtain physically reasonable results? or just not blowing up.
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳 Frankly, I use the minus sign and I got the results however they doesn't agree well with the results from PHOENICS. The velocity profile seems shift in some degree. So I would like to try "plus" this term. I am not sure the place I added is right or not. When I change one to be plus and the other to be minus, it runs well and the results seems better.
    You cannot implement equations as you want. What you implement should obey physics. Otherwise even you get "reasonable" results, its just coincidence.
    K 2 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳 I see. That is the reason why I post here. I wanna be sure that term should be implemented in which place. This is what I expect. Do you have any idea?
  • K 离线
    K 离线
    kimy
    @东岳 I am using IPSA model (lauder and spalding). In all of equation used, the alpha term has been introduced inside.
    http://www.cham.co.uk/phoenics/d_polis/d_lecs/ipsa/ipsa.htm#11
  • K 离线
    K 离线
    kimy
    @东岳 Sorry. I am still confused that how the equation(24) mentioned in your page could be solved in OpenFoam. In the source code:
            solve
                pEqnComp1() + pEqnComp2() + pEqnIncomp,
                mesh.solver(p_rgh.select(pimple.finalInnerIter()))
    why pEqnComp1() + pEqnComp2() + pEqnIncomp ranther than - pEqnComp1() - pEqnComp2() + pEqnIncomp. Because in your equation(24), pEqnComp1() + pEqnComp2() in the right side while pEqnIncomp in the left side.
    Thanks for your feedback. The R.H.S. of the following equation should be a - sign. It was corrected.
    \begin{equation}\label{comp_nablaU}
    \underset{\mathrm{pEqnIncomp}}{\underbrace{\nabla\cdot\left(\alpha_\rd\bfU_\rd+\alpha_\rc\bfU_\rc\right)}}=\underset{\mathrm{\color{red}{-}pEqnComp1\color{red}{-}pEqnComp2}}{\underbrace{-\frac{\alpha_\rd}{\rho_\rd}\frac{\rD\rho_\rd}{\rD t}-\frac{\alpha_\rc}{\rho_\rc}\frac{\rD\rho_\rc}{\rD t} }}.
    What is the first term? Its a second order tensor which is not consistent with the second term (scalar).
    替代文字
    K 2 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳 So if I wanna add the term related to the gradient alpha in the continuity equation, in which place should I put the term?
  • K 离线
    K 离线
    kimy
    @东岳 Thanks, Dongyue. I am still confused that why I add the same term in the pEqnComp1 and pEqnComp2, or pEqnIncomp leads to the different results?
    You should implement it in the alpha equation.
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳 Sorry, to my knowledge alpha equation dosn't exsist in the twophaseeulerfoam? How can I realize it?
    alpha field was solved by MULES algorithm. You can add something after MULES procedure as follows:
    solve(fvm::ddt(alpha) - fvm::laplacian(D, alpha) = fvc::ddt(alpha);
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳Thanks. however MULES is not implemented in twophaseeulerfoam. As mentioned before, the term must be added into the continuity equation rather than alpha equa, which is the Spalding's IPSA solver in PHOENICS.
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    在 中回复了 kimy 最后由 编辑
    @kimy Sorry, I mean where is the MULES in the twophaseeulerfoam, which I did not find but I found MULES in the terminal during calculation.
    alpha was solved in twoPhaseSystem.C
