  4. extra term twophasesystem.C
20 帖子 4 发布者 22.7k 浏览
  • K 离线
    K 离线
    kimy
    anybody wish to give some suggestions?
    The equation you posted is not correct. Also, it looks like a constrain condition rather than a transport equation.
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    在 中回复了 李东岳 最后由 kimy 编辑
    @东岳 Thanks dongyue. I am not sure you are saying which transport equation. However the equation in the image, this is the continuity equation in spalding's IPSA method and we published a lot of paper in which this equation used.
    替代文字
    The first term is a second rank tensor, the second term is a scalar, they are inconsistent.
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
  • K 离线
    K 离线
    kimy
    Dongyue, I understood what you mean but I also found the solution procedure of alpha transport equation in Passalacqua's paper, like following, both of them include the term of fraction gradient.
    @kimy You can have a look at alphaEqn of driftFluxFoam. A similar alpha equation with diffusion term was implemented.
  • K 离线
    K 离线
    kimy
    @东岳 在 extra term twophasesystem.C 中说:
    driftFluxFoam
    Thank you for your advice. The problem is that there is no alphaEqu.H in twophaseeulerfoam and only the code lines related to "alpha1Eqn" are given in twophasesystem.C file as I mentioned in top. I am confused that why no convective term in that equation. And after I compile this twophasesystem.C file, how can I link it to the solver file?
    Don't bother with the convection term. It was handled by explicit FCT scheme. So if you manage to add the diffusion term, it should work.
    If you modify the original file, you dont need to link it, it is linked automatically
  • K 离线
    K 离线
    kimy
    Really thank you. Usually, if we would like to add a new model, such as a turbulence model, we need to compile it as a user's library and then include the path "lib***" in the system/controdict. Here, I am not sure what I should do agter I compile "twophasesysterm.C".
    Yes you can do it. twoPhaseSystem is a combined lib. It combines lots of class into one lib. Its difficult to explain here. I would suggest you modify the original file directly to see if it works. If it works, then you can consider to build your own lib.
    K 2 条回复 最后回复
  • K 离线
    K 离线
    kimy
    I see. Great!
    Grazie mille.
  • K 离线
    K 离线
    kimy
    @东岳 Hi Dongyue, it works. Now I am trying to add it into user's library. I changed the Make/files as following and I include "libmycompressibleTwoPhaseSystem" in system/controDict, but the solver neglect it. I really don't know how to make the solver to call the modified "twophasesystem.C", or I need to change the name of "twophasesystem.C". Do you have any suggestion? Thanks.
    LIB = $(FOAM_USER_LIBBIN)/libmycompressibleTwoPhaseSystem
    在 中回复了 kimy 最后由 编辑
    @kimy 在 extra term twophasesystem.C 中说:
    Is there any error message, like "cannot find dynamic library..." or "duplicate entry ..." ?
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    在 中回复了 xpqiu 最后由 编辑
    @xpqiu Thanks for your reply. In fact, There is no error for the compilation and simulation. I don't know how to link the new modified twophasesystem.C to the solver.
  • K 离线
    K 离线
    kimy
    Anyone has suggestion about how to link the revised twophasesystem.C to the solver as a user's library?
  • K 离线
    K 离线
    kimy
    @东岳 Hi, dongyue. I tried many ways to reach my goal, such as create a newtwophasesystem.C (I found this file in the reactingtwophaseeulerfoam, so it should be possible to use a new one) and compile. But I still cannot link the new file to the solver if I put it in the user's library. Do you have any suggestion? Many Thanks.
    the easy way:
    cd \$FOAM_LIBBIN/
    mv libcompressibleTwoPhaseSystem.so libcompressibleTwoPhaseSystem.so.bk
    cp \$FOAM_USER_LIBBIN/libmycompressibleTwoPhaseSystem.so ./libcompressibleTwoPhaseSystem.so
    the best best way:
    add below line in solver's Make/options file
    -L$(FOAM_USER_LIBBIN) \
    -lmycompressibleTwoPhaseSystem
    make sure every line have "\" end except last line.
  • K 离线
    K 离线
    kimy
    Thanks a lot. The problem was solved.
