  4. OpenFOAM小代码
OpenFOAM小代码
41 帖子 15 发布者 89.5k 浏览
    Zhy2022
    @东岳 东岳老师,问题已解决!无法编译与文件路径有关
  • V 离线
    V 离线
    veen
    fvOption小工具
    根据GitHub上一个python脚本改写了一个生成fvOption的小工具 https://github.com/Veenxz/fvSchemes
    用Foam没有多久,各位大佬可以多提提意见。
    # version 2.0
    # Based on https://github.com/Carlopasquinucci/fvSchemes
    # Generation by Veenxz
    # relaesed under license GPL GNU 3.0
    steady = True
    pseudo_transient = False
    precision = 2    # First order 1 or Second order 2
    unbounded = False
    LUST = False
    secondorder = True
    maxOrtho = 80
    maxSkew = 20
    # Header and Footer
    h = [
        "/*--------------------------------*- C++ -*----------------------------------*|",
        "| \\\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |",
        "|  \\\    /   O peration     | Website:  https://openfoam.org                  |",
        "|   \\\  /    A nd           | Version:  7                                     |",
        "|    \\\/     M anipulation  |                                                 |",
        "FoamFile", "{", "    version     2.0;", "    format      ascii;",
        "    class       dictionary;", '    location    "system";', "    object      fvSchemes;",
    footer = '\n// ************************************************************************* //'
    nonOrthogonalCorrectors = 1
    if (maxOrtho) > 80:
        print(
            'Warning: mesh is not so nice. Use 3 nonOrthogonalCorrectors in fvSolution file'
        nonOrthogonalCorrectors = 3
    if (maxSkew) > 8:
        print('Warning: mesh is not so nice')
    if (maxOrtho) > 80:
        gradSchemes = (
            '{\n    default          cellLimited Gauss linear 0.5;\n'
               '    grad(U)          faceLimited Gauss linear 1.0;\n}'
        divSchemes = (
            '{\n    div(phi,U)       Gauss linearUpwind grad(U);\n'
               '    div(phi,omega)   Gauss upwind;\n'
               '    div(phi,k)       Gauss upwind;\n'
               '    div(phi,e)       Gauss upwind;\n'
               '    div((nuEff*dev(T(grad(U))))) Gauss linear;\n}'
        laplacianSchemes = (
            '{\n    default          Gauss linear limited 0.333;\n}'
        snGradSchemes = (
        blending = 0.2
    if (maxOrtho) > 70:
        gradSchemes = (
               '    grad(U)          cellLimited Gauss linear 1.0;\n}'
        divSchemes = (
               '    div(phi,omega)   Gauss linearUpwind grad(omega);\n'
               '    div(phi,k)       Gauss linearUpwind grad(k);\n'
               '    div(phi,e)       Gauss linearUpwind grad(e);\n'
            '{\n    default          Gauss linear limited 0.5;\n}'
        snGradSchemes = (
        blending = 0.5
    if (maxOrtho) > 60:
        gradSchemes = (
            '{\n    default          cellMDLimited Gauss linear 0.5;\n'
               '    grad(U)          cellMDLimited Gauss linear 0.5;\n}'
        divSchemes = (
            '{\n    default          Gauss linear limited 0.777;\n} '
        snGradSchemes = (
        blending = 0.7
        nonOrthogonalCorrectors = 2
    if (maxOrtho) > 0:
        gradSchemes = (
            '{\n    default          cellMDLimited Gauss linear 0;\n'
               '    grad(U)          cellMDLimited Gauss linear 0.333;\n}'
        divSchemes = (
            '{\n    default          Gauss linear limited 0.95;\n}'
        snGradSchemes = (
        blending = 0.8
    if (LUST):
        gradSchemes = (
            '{\n    default          Gauss linear;\n'
               '    grad(U)          cellMDLimited leastSquares 1;\n}'
        divSchemes = (
            '{\n    div(phi,U)       Gauss LUST grad(U);\n'
               '    div(phi,omega)   Gauss LUST grad(omega);\n'
               '    div(phi,k)       Gauss LUST grad(k);\n'
               '    div(phi,e)       Gauss LUST grad(e);\n'
            '{\n    default          Gauss linear corrected;\n}'
        snGradSchemes = (
        blending = 0.9
    if (steady):
        ddtSchemes = (
            '{\n    default          steadyState;\n}'
        if (pseudo_transient):
                    ddtSchemes = (
                        '{\n    default          localEuler;\n}'
    else:
        ddtSchemes = (
            '{\n    default           CrankNicolson ' + str(blending) + ' ;\n}'
        if precision == 1:
            ddtSchemes = (
                '{\n    default           Euler;\n}'
        if (unbounded):
            ddtSchemes = (
                '{\n    default           backward;\n}'
    wallDist = (
        "{\n    method           meshWave;\n}"
    #open fvSchemes and write inside
    f = open("fvSchemes", "w")
    for i in h:
    	f.write(i + "\n")
    f.write("ddtSchemes" + "\n")
    f.write(ddtSchemes + "\n")
    f.write("\n")
    f.write("gradSchemes" + "\n")
    f.write(gradSchemes + "\n")
    f.write("\n")
    f.write("divSchemes" + "\n")
    f.write(divSchemes + "\n")
    f.write("\n")
    f.write("laplacianSchemes" + "\n")
    f.write(laplacianSchemes + "\n")
    f.write("\n")
    f.write("snGradSchemes" + "\n")
    f.write(snGradSchemes + "\n")
    f.write("\n")
    f.write("wallDist" + "\n")
    f.write(wallDist + "\n")
    f.write(footer)
    f.close()
    print('File fvSchemes created')
    李东岳李 V 2 条回复 最后回复
    在 中回复了 veen 最后由 编辑
    @veen 厉害厉害 :146: :146:
  • V 离线
    V 离线
    veen
    在 中回复了 veen 最后由 编辑
    @veen 这个代码还有些格式没法用……我回头测试了再放到github大家看仓库里边的代码就好了。
    hongjiewang
    @李东岳 在 OpenFOAM小代码 中说:
    IOField<scalar> utau
    "utau",
    runTime.constant(),
    "../postProcessing",
    mesh,
    IOobject::NO_READ,
    IOobject::AUTO_WRITE
    scalarField(totalFSize,0.0)
    请问老师,如果我想要在postProcessing中输出一个标量,他只是一个数,并不是场量,我应该怎么定义他的类型。上面这种方法是不是只适应于场量的输出。我想输出的是下面c的数值。
    const volScalarField& b = mesh().lookupObject<volScalarField>("alpha.liquid");
    scalar c= b.weightedAverage(mesh().V()).value();
    在 中回复了 hongjiewang 最后由 编辑
    @hongjiewang
        IOList<scalar> utau
                "utau",
                runTime.constant(),
                mesh,
                IOobject::NO_READ,
        utau[0] = b.weightedAverage(mesh().V()).value();
    H vbcwlV 3 条回复 最后回复
    hongjiewang
      totalLiquid
            libs            (utilityFunctionObjects);
            type            coded;
            name            totalLiquid;
            enabled         true;
            writeControl    timeStep;
            writeInterval   1;
            codeOptions
            codeExecute
                IOList<scalar> liquidFraction
                        "liquidFraction",
                        mesh().time().constant(),
                        mesh(),
                        IOobject::NO_READ,
                liquidFraction[0] = b.weightedAverage(mesh().V()).value();
    东岳老师,我这样添加到controlDict里,运行后postProcessing里并没有出现liquidFraction的值。
    hongjiewang
    在 中回复了 hongjiewang 最后由 hongjiewang 编辑
    @hongjiewang 在 OpenFOAM小代码 中说:
      totalLiquid
            type            coded;
            name            totalLiquid;
            enabled         true;
            writeInterval   1;
            codeOptions
            codeExecute
                        "liquidFraction",
                        mesh(),
                        IOobject::NO_READ,
    需要修改两个部分,
    1.在下方添加 .write()
    2.将codeExecute改为codeWrite
    之后就可以得到想要的相含量结果。
    hongjiewang
    FoamFile
        version     2.0;
        format      ascii;
        class       scalarField;
        location    "constant/../postProcessing";
        object      totalLiquid;
    1(0.2)
    麻烦老师再帮我看一下,为什么每次都只会输出一个时刻的值,不会随时间增加输出的
    meanDiameter
            type            coded;
            name            error;
            codeExecute
                const volScalarField& d =
                    mesh().lookupObject<volScalarField>("d.alpha.oil");
                scalar d32 = d.weightedAverage(mesh().V()).value();
                if (Pstream::master())
                    std::ofstream file;
                    file.open ("d32", std::ofstream::out | std::ofstream::app);
                    file << mesh().time().timeName() << " " << d32 << "\n";
                    file.close();
    我最近也凑巧要用这个,我用的上面这种方式。
  • 五好青年五 离线
    五好青年五 离线
    五好青年
    请问东岳老师:135:
    (1) 东岳老师,您上面写的:codedFixedValue
    (2) yfclark朋友,上面写的:CodeStream
    在自定义边界条件方面,这两个有啥区别啊,我研究了几天没想明白
    五好青年五 1 条回复 最后回复
  • 五好青年五 离线
    五好青年五 离线
    五好青年
    在 中回复了 五好青年 最后由 编辑
    @yfclark
    朋友,您好:
    codedFixedValue和CodeStream
    你知道在自定义边界条件方面,这两个有啥区别啊,我研究了几天没想明白
    在 中回复了 五好青年 最后由 编辑
    codedFixedValue更简单,直接用
    code
                operator==(min(10, 0.1*this->db().time().value()));
    就可以赋值。CodeStream更普适性,我见过一些代码用CodeStream对内部场进行初始化。比如建立U的内部场与空间的函数。
    hongjiewang
    @李东岳 目前我需要将温度边界和压力边界定义为随相含量变化的一个场。我只可以做到变化之后的也是同一类边界条件,但是像下图中的气相区压力是第一类边界条件,液相区温度是第二类边界条件。请问这种变边界类型的边界应该怎么定义~1632279639(1).png
    hongjiewang
    已解决压力的~但是温度的第二类和第三类的转换还没有解决~
  • 李东岳李 李东岳 被引用 于这个主题
  • 疏影横斜水清浅疏 离线
    疏影横斜水清浅疏 离线
    疏影横斜水清浅
    你好,请问const polyPatch& cPatch = mesh.boundaryMesh()[patchID];与const fvPatch& cPatch = mesh.boundary()[patchID];有什么不同?
    Dingcy
    我希望我得到的少一点,少一点,再少一点......
    在 中回复了 Dingcy 最后由 编辑
    @dingcy
    类似这个?
    D 1 条回复 最后回复
    Dingcy
  • vbcwlV 离线
    vbcwlV 离线
    vbcwl
    LBE
