  4. sprayFoam计算等压环境下点火延迟时间
8 帖子 4 发布者 10.2k 浏览
  • 香柏树香 离线
    香柏树香 离线
    香柏树
    目前在尝试使用sprayFoam等压环境下的C12H26点火延迟时间,由于sprayFoam中通过泊松方程求解压力(见原始pEqn.H),网格内监测压力显示不能保持等压状态。因此参考chemFoam的源代码,想把泊松方程改为完全气体状态方程P=rhoRT(见修改的pEqn.H),同时在sprayFoam.C中注释掉压力修正的过程(见修改的sprayFoam.C)。另外能量方程也改为求解Enthalpy的形式。在OpenFOAM6环境下编译没问题,但是计算两个时间步后即浮点溢出了,计算设置见下楼的图1,错误提示下楼的图2。请问各位前辈有没有解决方法啊?
    原始pEqn.H
    rho = thermo.rho();
    rho = max(rho, rhoMin);
    rho = min(rho, rhoMax);
    rho.relax();
    volScalarField rAU(1.0/UEqn.A());
    surfaceScalarField rhorAUf("rhorAUf", fvc::interpolate(rho*rAU));
    volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
    if (pimple.nCorrPISO() <= 1)
        tUEqn.clear();
    if (pimple.transonic())
        surfaceScalarField phid
            "phid",
            fvc::interpolate(psi)
                fvc::flux(HbyA)
              + MRF.zeroFilter
                    rhorAUf*fvc::ddtCorr(rho, U, phi)/fvc::interpolate(rho)
        MRF.makeRelative(fvc::interpolate(psi), phid);
        while (pimple.correctNonOrthogonal())
            fvScalarMatrix pEqn
                fvm::ddt(psi, p)
              + fvm::div(phid, p)
              - fvm::laplacian(rhorAUf, p)
                parcels.Srho()
              + fvOptions(psi, p, rho.name())
            pEqn.solve(mesh.solver(p.select(pimple.finalInnerIter())));
            if (pimple.finalNonOrthogonalIter())
                phi == pEqn.flux();
    else
        surfaceScalarField phiHbyA
            "phiHbyA",
                fvc::flux(rho*HbyA)
              + rhorAUf*fvc::ddtCorr(rho, U, phi)
        MRF.makeRelative(fvc::interpolate(rho), phiHbyA);
        // Update the pressure BCs to ensure flux consistency
        constrainPressure(p, rho, U, phiHbyA, rhorAUf, MRF);
            fvScalarMatrix pEqn
                fvm::ddt(psi, p)
              + fvc::div(phiHbyA)
                parcels.Srho()
                phi = phiHbyA + pEqn.flux();
    #include "rhoEqn.H"
    #include "compressibleContinuityErrs.H"
    // Explicitly relax pressure for momentum corrector
    p.relax();
    // Recalculate density from the relaxed pressure
    rho = thermo.rho();
    rho.relax();
    Info<< "rho max/min : " << max(rho).value()
        << " " << min(rho).value() << endl;
    U = HbyA - rAU*fvc::grad(p);
    fvOptions.correct(U);
    K = 0.5*magSqr(U);
    if (thermo.dpdt())
        dpdt = fvc::ddt(p);
    修改的pEqn.H
        rho = thermo.rho();
        p = rho*Rspecific*thermo.T();
    修改的sprayFoam.C
        \\  /    A nd           | Copyright (C) 2011-2018 OpenFOAM Foundation
         \\/     M anipulation  |
    License
        for more details.
    Application
        sprayFoam
    Description
        Transient solver for compressible, turbulent flow with a spray particle
        cloud.
    #include "fvCFD.H"
    #include "turbulentFluidThermoModel.H"
    #include "basicSprayCloud.H"
    #include "psiReactionThermo.H"
    #include "CombustionModel.H"
    #include "radiationModel.H"
    #include "SLGThermo.H"
    #include "pimpleControl.H"
    #include "fvOptions.H"
        #include "postProcess.H"
        #include "setRootCaseLists.H"
        #include "createTime.H"
        #include "createMesh.H"
        #include "createControl.H"
        #include "createTimeControls.H"
        #include "createFields.H"
        #include "createFieldRefs.H"
        #include "compressibleCourantNo.H"
        #include "setInitialDeltaT.H"
        turbulence->validate();
        while (runTime.run())
            #include "readTimeControls.H"
            #include "setDeltaT.H"
            runTime++;
            parcels.evolve();
            #include "rhoEqn.H"
            #include "YEqn.H"
            #include "EEqn.H"
            #include "pEqn.H"
            if (!pimple.frozenFlow())
                #include "rhoEqn.H"
                // --- Pressure-velocity PIMPLE corrector loop
                while (pimple.loop())
                    // #include "UEqn.H"
                    #include "YEqn.H"
                    #include "EEqn.H"
                    // --- Pressure corrector loop
                    while (pimple.correct())
                        #include "pEqn.H"
                    if (pimple.turbCorr())
                        turbulence->correct();
                rho = thermo.rho();
                if (runTime.write())
                    combustion->Qdot()().write();
            else
                if (runTime.writeTime())
                    parcels.write();
            Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
                << nl << endl;
        Info<< "End\n" << endl;
        return 0;
    香柏树香 1 条回复 最后回复
  • 香柏树香 离线
    香柏树香 离线
    香柏树
    在 中回复了 香柏树 最后由 编辑
    @香柏树 在 sprayFoam计算等压环境下点火延迟时间 中说:
    你说的点火之类我不太熟悉。但针对你的这方面描述,chemFoam不涉及到整个场的连续性。sprayFoam要满足质量守恒。你这样做从算法上有点奇怪。
    后续的截图看起来发散了,除以0了,当然原因肯定是非常本质的。
    香柏树香 1 条回复 最后回复
  • 香柏树香 离线
    香柏树香 离线
    香柏树
    @李东岳 谢谢李老师指导,这么修改确实不太正确。我从算法上看看如何能够合理些。
    星 2 条回复 最后回复
    在 中回复了 香柏树 最后由 编辑
    @香柏树 除以0可能是最大的问题,但是0在哪呢,请问你怎么处理parcel 极小的部分的,会不会是parcel部分,因为你点火了,就出现了这种情况,在clockTime以后就是计算Co 然后solving parcel了,也有可能是你parcel的maxCo=1, parcel在你计算的时候已经飞出了对应的cell 也有可能报错,尝试分析分析这俩地方,看看你的parcel都什么样,看看你的MaxCo减小到0.1或者0.01看看,还是turbulence爆了
    在 中回复了 香柏树 最后由 编辑
    @香柏树 另外你直接把整个PIMPLE循环给关掉了,是不是保留一下然后PISO模式运行就行呢, 瞬态
    香柏树香 1 条回复 最后回复
  • 香柏树香 离线
    香柏树香 离线
    香柏树
    在 中回复了 星星星星晴 最后由 编辑
    @星星星星晴 谢谢前辈!我尝试下。
  • 流 离线
    流 离线
    流体中二少年
    前辈,你好!请问sprayFoam中的液滴蒸发率怎么获得?
