87 帖子 14 发布者 192.7k 浏览
    在 中回复了 香柏树 最后由 编辑
    #53
    @香柏树 请问100%?和200% 空气是什么意思?另外空气的速度有变化么?你有没有用碰撞模型?
    香柏树香 1 条回复 最后回复
  • 香柏树香 离线
    香柏树香 离线
    香柏树
    在 中回复了 星星星星晴 最后由 编辑
    #54
    @星星星星晴 谢谢前辈!100%和200%代表计算域进口空气流量的相对值,比如100%是1kg/s的话,200%就是2kg/s。流场内空气速度增大了两倍左右,没有开启碰撞模型,sprayCloudProperties文件内容具体如下:
    FoamFile
        version     2.0;
        format      binary;
        class       dictionary;
        location    "constant";
        object      SprayCloudProperties;
    solution
        active          true;
        coupled         true;
        transient       yes;
        cellValueSourceCorrection on;
        maxCo           0.3;
        sourceTerms
            schemes
                rho             explicit 1;
                U               explicit 1;
                Yi              explicit 1;
                h               explicit 1;
                radiation       explicit 1;
        interpolationSchemes
            rho             cell;
            U               cellPoint;
            thermo:mu       cell;
            T               cell;
            Cp              cell;
            kappa           cell;
            p               cell;
        integrationSchemes
            U               Euler;
            T               analytical;
    constantProperties
        T0              300;
        // place holders for rho0 and Cp0
        // - reset from liquid properties using T0
        rho0            744;
        Cp0             2090;
        Tvap            298;
        Tbp             489;
        constantVolume  false;
    subModels
        particleForces
            sphereDrag;
        injectionModels
            model1
                type            coneNozzleInjection;
                SOI             0.029;
                massTotal       0.0044166;
                parcelBasisType mass;
                injectionMethod disc;
                flowType        constantVelocity;
                UMag            33.0;
                outerDiameter   0.0007;
                innerDiameter   0;
                duration        1.0;
                position        (0 0 -0.03584797);
                direction       (0 0 1);
                parcelsPerSecond 2000000;
                massFlowRate    0.0044166;
                flowRateProfile table
                    (0              0.0044166)
                    (1              0.0044166)
                    (2              0.0044166)
                    (3              0.0044166)
                    (4              0.0044166)
                    (5              0.0044166)
                    (6              0.0044166)
                    (7              0.0044166)
                    (8              0.0044166)
                    (9              0.0044166)
                    (10              0.0044166)
                Cd              constant 0.9;
                thetaInner      constant 25;
                thetaOuter      constant 30;
                sizeDistribution
                    type        RosinRammler;
                    RosinRammlerDistribution
                        minValue        1e-05;
                        maxValue        6e-05;
                        d               4e-05;
                        n               3;
        dispersionModel none;
        patchInteractionModel standardWallInteraction;
        heatTransferModel RanzMarshall;
        compositionModel singlePhaseMixture;
        phaseChangeModel liquidEvaporationBoil;
        surfaceFilmModel none;
        atomizationModel none;
        breakupModel    ReitzDiwakar; // ReitzKHRT;
        stochasticCollisionModel none;
        radiation       off;
        standardWallInteractionCoeffs
            type            rebound;
        RanzMarshallCoeffs
            BirdCorrection  true;
        singlePhaseMixtureCoeffs
            phases
                liquid
                    C12H26               1;
        liquidEvaporationBoilCoeffs
            enthalpyTransfer enthalpyDifference;
            activeLiquids    ( C12H26 );
        ReitzDiwakarCoeffs
            solveOscillationEq yes;
            Cbag            6;
            Cb              0.785;
            Cstrip          0.5;
            Cs              10;
        ReitzKHRTCoeffs
            B0              0.61;
            B1              40;
            Ctau            1;
            CRT             0.1;
            msLimit         0.2;
            WeberLimit      6;
        TABCoeffs
            y0              0;
            yDot0           0;
            Cmu             10;
            Comega          8;
            WeCrit          12;
    cloudFunctions
        voidFraction
            type   voidFraction;
    在 中回复了 香柏树 最后由 编辑
    #55
    @香柏树
    1. 首先你Euler那边速度发生了变化,自然Lagrange这边也会收到影响,我看你的parcel size 是10-60um, 然后parcel的初始速度就是33m/s,不知道你空气速度如何,自然drag的区别很大,然后parcel就可能很快的飞出去了。
    2. 在此之上,你有破碎模型,如果气液相对速度过大,自然会破碎,你要具体看一下你的破碎模型是怎么处理质量的。
    3. 其次,你的问题中“Case2的液滴数目(nParticles)比Case1少了近一半” 我没有get到,如果指的是particle per parcel的话,自然是受到其他模型的影响, 我看你这边有涉及到热,破碎等模型。这些模型也会影响nParticles,在使用这些模型的时候,你也是需要知道这些模型是怎么算的,算什么的,怎么处理mass/momentum balance的。
    4. 另外flowrateprofile constant就行,我看你这个flowrate不是随时间变化的,而且就喷1秒。
    香柏树香 1 条回复 最后回复
  • 香柏树香 离线
    香柏树香 离线
    香柏树
    在 中回复了 星星星星晴 最后由 编辑
    #56
    @星星星星晴 感谢前辈悉心指导!关于您说的问题,我今天查阅了一些公式,关于您提的四个问题,具体回复如下:
    1. 根据图1中液滴阻力的公式,在100%和200%air中的阻力分别为3.7e-6N和2.3e-5N,也就是液滴受到的阻力变大了,是不是说明液滴更倾向于保持目前的球形状态呢?
    2. 破碎模型用的是ReitzDiwakar model,具体公式如图中所示,计算得到100%和200%air中的rstable分别为18μm和1.2μm,也就是说后者的液滴粒径更小。这里您说的破碎模型如何处理质量是什么意思呢?是指公式中的密度么?
    3. “Case2中的液滴数目(nParticles)”说错了,应该是流域内的parcels的数目,也就是图2中的8370.计算结果显示200%air case中的parcels数目比100%air case少了近一半。
    4. Flowrateprofile constant已经改正。
      再次感谢前辈指点!
    在 中回复了 香柏树 最后由 编辑
    #57
    @香柏树
    1. spheredrag的前提就是假设所有的parcel 保持球形,所以根据阻力计算公式你可以自己推导一下,到底怎么回事。。严格来说drag 不一定是阻力吧,要看相对速度方向。
    2. 你需要查一下关于破碎模型的原始论文,破碎同样也涉及到计算相对速度。在破碎模型中到底是如何假设破碎的,ReitzDiwakar 我不太了解,但是比如TAB,要计算一个y,KHRT也要计算波动的,而且是否生成了child parcel,生成的值是什么,你要看code的。单纯问,没办法解释,看code看原始论文,看of是如何implement的
    3. 这个不难理解,如果你流场的速度增加了,那你喷雾的parcel也是收到流场影响的啊,自然可能会发生parcel被加速,如果被加速了的话,有些parcel离开的快也可以理解,你也没有具体描述你的case,所以我只能根据你当前的描述说了。
    香柏树香 1 条回复 最后回复
  • 香柏树香 离线
    香柏树香 离线
    香柏树
    在 中回复了 星星星星晴 最后由 编辑
    #58
    @星星星星晴 好的 我查下原始文献。谢谢前辈!
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    在 中回复了 星星星星晴 最后由 编辑
    #59
    if(p.position(2)<1 & p.position(2)>0)
    输出
    您好,我按照您的提示,思路如下:
    先是定义了三维空间的范围,以及坐标质量的数组。
            scalar xmin = -0.01;
            scalar xmax = 0.01;
            scalar ymin = 0;
            scalar ymax = 0.1;
            scalar zmin = -0.01;
            scalar zmax = 0.01;
            scalar dxyz = 5e-3;
            const int nx = floor((xmax - xmin)/dxyz);
            const int ny = floor((ymax - ymin)/dxyz);
            const int nz = floor((zmax - zmin)/dxyz);
            int nxc;
            int nyc;
            int nzc;
            scalar xc[nx];
            scalar yc[ny];
            scalar zc[nz];
            scalar mass3D[nx][ny][nz] = {0};
    我只想最后时刻输出结果,所以先用if条件判断是否要输出数据
        if ((this->owner().db().time().value()) == 0.02)
            for (int i=0; i<nx; i++)
                xc[i] = i*dxyz+xmin;
            for (int j=0; j<ny; j++)
                yc[j] = j*dxyz+ymin;
            for (int k=0; k<nz; k++)
                zc[k] = k*dxyz+zmin;
            nxc = floor((p.position().component(0) - xmin)/dxyz);
            nyc = floor((p.position().component(1) - ymin)/dxyz);
            nzc = floor((p.position().component(2) - zmin)/dxyz);
            mass3D[nxc][nyc][nzc] += p.nParticle()*p.mass();
            std::ofstream outfile;
            outfile.precision(8);
            outfile.open("postProcessingWCA/Mass3D.txt", ios_base::app);
                        outfile << xc[i] << tab << yc[j] << tab << zc[k] << mass3D[i][j][k] << tab << tab  << nl;
    之后我的想法就是根据粒子的位置计算索引位置 nxc nyc nzc,带入到mass3D[nxc][nyc][nzc] 相应的位置。
    但是存在两个问题:
    1. 每一个粒子统计之后都输出到了Mass3D.txt,数据量非常大,而我是想把所有的粒子质量统计到相应的空间点上累积;
    2. 另外就是定义方式scalar mass3D[nx][ny][nz] = {0}; 以及累积方法mass3D[nxc][nyc][nzc] += p.nParticle()*p.mass();感觉有问题,从结果上看感觉没有把相同位置的粒子质量加到一起。
    想麻烦您帮忙看看,谢谢
    在 中回复了 chengan.wang 最后由 编辑
    #60
    @chengan-wang
    1. 数据量极大就是这个方法最大的问题,没办法。
    2. 你的mass3D没有输出,在结束这一步的迭代以后,在下一步迭代会被清空的。
      你这一步已经很靠近方法1了,你不要用什么mass3D这个变量,你在solver中建立一个field, 比如叫summass,然后在cloudfunction的postmove 这个function中直接通过,就可以对一下field进行赋值了。
    cellI = p.cell();
    scalar& PPC = summass_->primitiveFieldRef() [cellI];
    PPC += p.nParticle()*p.mass();
    我的技能也是有限,所以没有办法给你解决所有问题,你可以自己试试,找找资料,如果发现更好的办法,也希望你分享出来。
    对于方法2,我个人有个想法,你获得你所要区域的cell number, 然后仅仅对这些cell进行输出也可以的。我自己没做过,大家都是摸着石头过河,可能每个人的解决方法并不通用,很case- sensitive,这也是开源的一个弊端。。
    祝你好运~
    chengan.wangC 1 条回复 最后回复
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    在 中回复了 星星星星晴 最后由 chengan.wang 编辑
    #61
    @chengan-wang
    cellI = p.cell();
    祝你好运~
    谢谢。我在createFields.H建立了一个field:
        volScalarField summass
                "summass",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            mesh,
            dimensionedScalar ("zero", dimMass, 0.0)
    我没有理解“在cloudfunction的postmove 这个function中直接通过”是啥意思呢?麻烦了
  • 流 离线
    流 离线
    流体中二少年
    刚接触sprayfoam,请教三个个问题:
    1. 初始场指定区域怎么布置液滴?setFields?
    2. 液滴的喷射位置和喷射速度怎么设置为跟随inlet边界?
    3. 我模拟的是预气化的液滴,比如C7H16既有液滴也有气体,我在算例里面该怎么区分他们?
    谢谢前辈,希望解答或者提供一些解决问题的方向:140:
    lyc
    #63
    @chengan-wang 前辈想问一下,GOFUN后来再没出particle simulation的第二讲了么,我看2019年本来有但是取消了
    youhaoyu
    在 中回复了 星星星星晴 最后由 编辑
    #64
    @星星星星晴 你好,最近想向DPMFoam添加一些气泡长大方程,比如RP方程,如何去添加啊,有没有什么思路推荐啊,因为本人实在是太不会编程这些东西了。
    最近看了篇博士论文,《水质对梢涡空化初生的影响研究》,上面有一些源文件不知道能不能用,意思是在运动包裹源文件中,添加一些颗粒体积更新代码,再植入自己方程什么的。这个思路能行吗?
    在 中回复了 youhaoyu 最后由 编辑
    #65
    @youhaoyu
    你好,
    我不知道你说的RP方程是什么。
    但是如果你是用欧拉拉格朗日法做气泡的话,其实很简单,就是调整parcel的直径就可以了p.d()。
    当然你需要在合适的位置去调整。
    另外如果欧拉拉格朗日的话,你要考虑cell中parcel的体积,这个是有限制的。我也不记得那个参数是什么了,论坛里之前我好像有聊过。
    如果做OpenFOAM的话,不懂编程其实是不行的。
    当然你也不需要懂得多深,多看,多想,有基础的方法就行。
    祝收敛
    在 中回复了 流体中二少年 最后由 编辑
    #66
    @流体中二少年
    我刚看到,相信一年多过去你肯定已经解决了。
    1. 在0/ 文件夹中,添加lagrangian的文件夹,提供parcel所需的相关信息即可。setFields 应该也行,但是我的第一反应是这个方案。
    2. 随inlet边界?就是patchinjection, PatchFlowRateInjection 等喷射模型吧。
    3. 在spraycloudproperties中设置的C7H16是parcel的,在外面的/constant文件夹中是外面的气体。在paraview中,parcel是parcel,流场是流场。你可以轻松的看出来。在时间步中的lagrangian文件夹中也能看到每个物质的量的
    youhaoyu
    在 中回复了 星星星星晴 最后由 编辑
    #67
    @星星星星晴 您好,大佬,我最近潜心修心了一个月,了解了拉格朗日源文件里面一些大概的东西,我目前打算根据一个方程更新我的拉格朗日颗粒的直径,所以我根据一篇名叫“水质对梢涡空化初生的影响研究”的博士论文在修改拉格朗日的源文件库,最近遇到了很多问题,不知道您能否给我指引一点方向来学习。
    这个代码原理就是在KinematicParcel.C中按照他原本的calcVelocity,自己定义一个气泡长大方程取名为calcDimater,但是这篇博士论文的代码似乎有点不全,我一直在修改。目前改的文件有以下这6个基础文件
    KinematicCloud.C
    KinematicCloud.H
    KinematicCloudI.H
    KinematicParcel.C
    KinematicParcel.H
    KinematicParcelI.H
    我能编译成功源文件库,但是在编译求解器时候会有报错,于是我又简单更改了这三个文件夹
    CollidingCloud.C
    CollidingCloud.H
    CollidingCloudI.H
    目前我的库能够编译成功,就是存在warning。但是当我编译我的新的newDPMFoam时候总是有很多奇奇怪怪报错,目前我的报错就很奇怪。总而言之就是说我有一些参数我定义错误
    g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I./DPMTurbulenceModels/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/lagrangian/basic/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/lagrangian/intermediate/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/thermophysicalModels/specie/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/transportModels/compressible/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/thermophysicalModels/basic/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/thermophysicalModels/radiation/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/transportModels -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/transportModels/incompressible/singlePhaseTransportModel -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/TurbulenceModels/incompressible/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/TurbulenceModels/phaseIncompressible/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/regionModels/regionModel/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/regionModels/surfaceFilmModels/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/finiteVolume/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/OpenFOAM/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/ppDPMFoam.o -L/home/zly/OpenFOAM/OpenFOAM-3.0.0/platforms/linux64GccDPInt32Opt/lib \
        -llagrangian -llagrangianIntermediate -llagrangianTurbulence -lthermophysicalFunctions -lspecie -lradiationModels -lincompressibleTransportModels -lturbulenceModels -lincompressibleTurbulenceModels -lDPMTurbulenceModels -lregionModels -lsurfaceFilmModels -lsampling -lfiniteVolume -lmeshTools -lOpenFOAM -ldl  \
         -lm -o /home/zly/OpenFOAM/zly-3.0.0/platforms/linux64GccDPInt32Opt/bin/ppDPMFoam
    Make/linux64GccDPInt32Opt/ppDPMFoam.o: In function `Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > >::setParcelThermoProperties(Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> >&, double) [clone .isra.656]':
    ppDPMFoam.C:(.text+0x1377): undefined reference to `Foam::KinematicParcel<Foam::particle>::Ro()'
    ppDPMFoam.C:(.text+0x13c9): undefined reference to `Foam::KinematicParcel<Foam::particle>::pgo()'
    Make/linux64GccDPInt32Opt/ppDPMFoam.o: In function `void Foam::KinematicParcel<Foam::particle>::setCellValues<Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > > >(Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > >&, double, int)':
    ppDPMFoam.C:(.text._ZN4Foam15KinematicParcelINS_8particleEE13setCellValuesINS2_12TrackingDataINS_14CollidingCloudINS_14KinematicCloudINS_5CloudINS_15CollidingParcelIS2_EEEEEEEEEEEEvRT_di[_ZN4Foam15KinematicParcelINS_8particleEE13setCellValuesINS2_12TrackingDataINS_14CollidingCloudINS_14KinematicCloudINS_5CloudINS_15CollidingParcelIS2_EEEEEEEEEEEEvRT_di]+0x23c): undefined reference to `Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > >::PInterp() const'
    make: *** [/home/zly/OpenFOAM/zly-3.0.0/platforms/linux64GccDPInt32Opt/bin/ppDPMFoam] Error 1
    我这个原理上我感觉我的代码基本上都能说得通,但是报错经常就提醒我缺少一些东西,我现在就有一点迷茫,不知道怎么前进了,请大佬指点下迷津。我这个方法是否有可行性 附上一部分我的代码(//- myadd部分即为我添加部分)
    KinematicParcel.C(这是方程的核心部分在里面,其他文件我只是按照原有的模板照猫画虎定义了一些参数,例如压力场的插值)
    template<class ParcelType>
    template<class TrackData>
    void Foam::KinematicParcel<ParcelType>::setCellValues
        TrackData& td,
        const scalar dt,
        const label cellI
        tetIndices tetIs = this->currentTetIndices();
        rhoc_ = td.rhoInterp().interpolate(this->position(), tetIs);
        if (rhoc_ < td.cloud().constProps().rhoMin())
            if (debug)
                WarningIn
                    "void Foam::KinematicParcel<ParcelType>::setCellValues"
                        "TrackData&, "
                        "const scalar, "
                        "const label"
                )   << "Limiting observed density in cell " << cellI << " to "
                    << td.cloud().constProps().rhoMin() <<  nl << endl;
            rhoc_ = td.cloud().constProps().rhoMin();
        Uc_ = td.UInterp().interpolate(this->position(), tetIs);
        muc_ = td.muInterp().interpolate(this->position(), tetIs);
        // Apply dispersion components to carrier phase velocity
        Uc_ = td.cloud().dispersion().update
            dt,
            cellI,
            U_,
            Uc_,
            UTurb_,
            tTurb_
        Pc_ = td.PInterp().interpolate(this->position(), tetIs);  //- myadd
    void Foam::KinematicParcel<ParcelType>::cellValueSourceCorrection
        TrackData& td,
        const scalar dt,
        const label cellI
        Uc_ += td.cloud().UTrans()[cellI]/massCell(cellI);
    void Foam::KinematicParcel<ParcelType>::calc
        TrackData& td,
        const scalar dt,
        const label cellI
        // Define local properties at beginning of time step
        const scalar np0 = nParticle_;
        const scalar mass0 = mass();
        // Reynolds number
        const scalar Re = this->Re(U_, d_, rhoc_, muc_);
        // Sources
        // Explicit momentum source for particle
        vector Su = vector::zero;
        // Linearised momentum source coefficient
        scalar Spu = 0.0;
        // Momentum transfer from the particle to the carrier phase
        vector dUTrans = vector::zero;
        //- myadd
        if(Ro_>0)
        vector storeddRt = calcDiameter(td, dt, cellI, muc_, rhoc_, Pc_);
        this->dRt_=storeddRt[0];
        this->d_=storeddRt[1];
        // Motion
        // Calculate new particle velocity
        this->U_ = calcVelocity(td, dt, cellI, Re, muc_, mass0, Su, dUTrans, Spu);
        // Accumulate carrier phase source terms
        if (td.cloud().solution().coupled())
            // Update momentum transfer
            td.cloud().UTrans()[cellI] += np0*dUTrans;
            // Update momentum transfer coefficient
            td.cloud().UCoeff()[cellI] += np0*Spu;
    const Foam::vector Foam::KinematicParcel<ParcelType>::calcVelocity
        TrackData& td,
        const scalar dt,
        const label cellI,
        const scalar Re,
        const scalar mu,
        const scalar mass,
        const vector& Su,
        vector& dUTrans,
        scalar& Spu
    ) const
        typedef typename TrackData::cloudType cloudType;
        typedef typename cloudType::parcelType parcelType;
        typedef typename cloudType::forceType forceType;
        const forceType& forces = td.cloud().forces();
        // Momentum source due to particle forces
        const parcelType& p = static_cast<const parcelType&>(*this);
        const forceSuSp Fcp = forces.calcCoupled(p, dt, mass, Re, mu);
        const forceSuSp Fncp = forces.calcNonCoupled(p, dt, mass, Re, mu);
        const forceSuSp Feff = Fcp + Fncp;
        const scalar massEff = forces.massEff(p, mass);
        // New particle velocity
        // Update velocity - treat as 3-D
        const vector abp = (Feff.Sp()*Uc_ + (Feff.Su() + Su))/massEff;
        const scalar bp = Feff.Sp()/massEff;
        Spu = dt*Feff.Sp();
        IntegrationScheme<vector>::integrationResult Ures =
            td.cloud().UIntegrator().integrate(U_, dt, abp, bp);
        vector Unew = Ures.value();
        // note: Feff.Sp() and Fc.Sp() must be the same
        dUTrans += dt*(Feff.Sp()*(Ures.average() - Uc_) - Fcp.Su());
        // Apply correction to velocity and dUTrans for reduced-D cases
        const polyMesh& mesh = td.cloud().pMesh();
        meshTools::constrainDirection(mesh, mesh.solutionD(), Unew);
        meshTools::constrainDirection(mesh, mesh.solutionD(), dUTrans);
        return Unew;
    //- myadd
    const Foam::vector Foam::KinematicParcel<ParcelType>::calcDiameter
        TrackData& td,
        const scalar dt,
        const label cellI,
        const scalar mu,
        const scalar rhoc,
        const scalar Pc
    ) const
        // Saturated vapor pressure
        const scalar pv=0;
        //surface tension
        const scalar sigma=0.0712;
        scalar R=d_/2;
        //The fourth-order Rungekuta method solves second-order differential equations
        const scalar k1=dRt_;
        const scalar h1=-3*pow(k1,2)/2/R-(4*mu*k1+2*sigma)/rhoc/pow(R,2)+(pv-Pc_+pgo_*pow(Ro_,4.2)*pow(R,-4.2))/rhoc/R;
        const scalar k2=k1+0.5*dt*h1;
        const scalar h2=-3*pow(k2,2)/2/(R+0.5*dt*k1)-(4*mu*k2+2*sigma)/rhoc/pow(R+0.5*dt*k1,2)+(pv-Pc_+pgo_*pow(Ro_,4.2)*pow(R+0.5*dt*k1,-4.2))/rhoc/(R+0.5*dt*k1);
        const scalar k3=k1+0.5*dt*h2;
        const scalar h3=-3*pow(k3,2)/2/(R+0.5*dt*k2)-(4*mu*k3+2*sigma)/rhoc/pow(R+0.5*dt*k2,2)+(pv-Pc_+pgo_*pow(Ro_,4.2)*pow(R+0.5*dt*k2,-4.2))/rhoc/(R+0.5*dt*k2);
        const scalar k4=k1+dt*h3;
        const scalar h4=-3*pow(k4,2)/2/(R+0.5*dt*k3)-(4*mu*k4+2*sigma)/rhoc/pow(R+0.5*dt*k3,2)+(pv-Pc_+pgo_*pow(Ro_,4.2)*pow(R+0.5*dt*k3,-4.2))/rhoc/(R+0.5*dt*k3);
        vector Rtvector(0,0,0);
        Rtvector[0]=k1+dt/6*(h1+2*h2+2*h3+h4);
        Rtvector[1]=2*(R+dt/6*(k1+2*k2+2*k3+k4));
        return Rtvector;
    KinematicParcel.H
    class KinematicParcel
        public ParcelType
        // Private data
            //- Size in bytes of the fields
            static const std::size_t sizeofFields_;
            //- Number of particle tracking attempts before we assume that it stalls
            static label maxTrackAttempts;
    public:
        //- Class to hold kinematic particle constant properties
        class constantProperties
        protected:
            // Protected data
                //- Constant properties dictionary
                const dictionary dict_;
        private:
            // Private data
                //- Parcel type id - used for post-processing to flag the type
                //  of parcels issued by this cloud
                demandDrivenEntry<label> parcelTypeId_;
                //- Minimum density [kg/m3]
                demandDrivenEntry<scalar> rhoMin_;
                //- Particle density [kg/m3] (constant)
                demandDrivenEntry<scalar> rho0_;
                //- Minimum parcel mass [kg]
                demandDrivenEntry<scalar> minParcelMass_;
                //- myadd Particle initial radius [m]
                demandDrivenEntry<scalar> Ro0_;
                //- myadd Particle initial pressure inside [kg/m/s2]
                demandDrivenEntry<scalar> pgo0_;
        public:
            // Constructors
                //- Null constructor
                constantProperties();
                //- Copy constructor
                constantProperties(const constantProperties& cp);
                //- Construct from dictionary
                constantProperties(const dictionary& parentDict);
            // Member functions
                //- Return const access to the constant properties dictionary
                inline const dictionary& dict() const;
                //- Return const access to the parcel type id
                inline label parcelTypeId() const;
                //- Return const access to the minimum density
                inline scalar rhoMin() const;
                //- Return const access to the particle density
                inline scalar rho0() const;
                //- Return const access to the minimum parcel mass
                inline scalar minParcelMass() const;
                //- myadd Return const access to the particle intitial radius
                inline scalar Ro0() const;
                //- myadd Return const access to the particle initial pressure
                inline scalar pgo0() const;
        template<class CloudType>
        class TrackingData
            public ParcelType::template TrackingData<CloudType>
        public:
            enum trackPart
                tpVelocityHalfStep,
                tpLinearTrack,
                tpRotationalTrack
        private:
            // Private data
                // Interpolators for continuous phase fields
                    //- Density interpolator
                    autoPtr<interpolation<scalar> > rhoInterp_;
                    //- Velocity interpolator
                    autoPtr<interpolation<vector> > UInterp_;
                    //- Dynamic viscosity interpolator
                    autoPtr<interpolation<scalar> > muInterp_;
                    //-myadd Pressure interpolator
                    autoPtr<interpolation<scalar> > PInterp_;
                //- Local gravitational or other body-force acceleration
                const vector& g_;
                // label specifying which part of the integration
                // algorithm is taking place
                trackPart part_;
        public:
            // Constructors
                //- Construct from components
                inline TrackingData
                    CloudType& cloud,
                    trackPart part = tpLinearTrack
            // Member functions
                //- Return conat access to the interpolator for continuous
                //  phase density field
                inline const interpolation<scalar>& rhoInterp() const;
                //  phase velocity field
                inline const interpolation<vector>& UInterp() const;
                //  phase dynamic viscosity field
                inline const interpolation<scalar>& muInterp() const;
                // Return const access to the gravitational acceleration vector
                inline const vector& g() const;
                //- Return the part of the tracking operation taking place
                inline trackPart part() const;
                //- Return access to the part of the tracking operation taking place
                inline trackPart& part();
                //- myadd Return const access to the interpolator for continuous phase pressure field
                inline const interpolation<scalar>& PInterp() const;
    protected:
        // Protected data
            // Parcel properties
                //- Active flag - tracking inactive when active = false
                bool active_;
                //- Parcel type id
                label typeId_;
                //- Number of particles in Parcel
                scalar nParticle_;
                //- Diameter [m]
                scalar d_;
                //- Target diameter [m]
                scalar dTarget_;
                //- Velocity of Parcel [m/s]
                vector U_;
                //- Density [kg/m3]
                scalar rho_;
                //- Age [s]
                scalar age_;
                //- Time spent in turbulent eddy [s]
                scalar tTurb_;
                //- Turbulent velocity fluctuation [m/s]
                vector UTurb_;
                //- myadd change rate of bubble radius [m/s]
                scalar dRt_;
                //- myadd initial bubble radius [m]
                scalar Ro_;
                //- myadd initial bubble pressuer [Pa]
                scalar pgo_;
            // Cell-based quantities
                //- Density [kg/m3]
                scalar rhoc_;
                //- Velocity [m/s]
                vector Uc_;
                //- Viscosity [Pa.s]
                scalar muc_;
                //- myadd Pressure [Pa]
                scalar Pc_;
        // Protected Member Functions
            //- Calculate new particle velocity
            const vector calcVelocity
                TrackData& td,
                const scalar dt,           // timestep
                const label cellI,         // owner cell
                const scalar Re,           // Reynolds number
                const scalar mu,           // local carrier viscosity
                const scalar mass,         // mass
                const vector& Su,          // explicit particle momentum source
                vector& dUTrans,           // momentum transfer to carrier
                scalar& Spu                // linearised drag coefficient
            ) const;
            //- myadd Calculate new particle Diameter
            const vector calcDiameter
                TrackData& td,
                const scalar dt,
                const label cellI,
                const scalar mu,
                const scalar rhoc,
                const scalar Pc
            ) const;
    public:
        // Static data members
            //- Runtime type information
            TypeName("KinematicParcel");
            //- String representation of properties
            AddToPropertyList
                ParcelType,
                " active"
              + " typeId"
              + " nParticle"
              + " d"
              + " dTarget "
              + " (Ux Uy Uz)"
              + " rho"
              + " age"
              + " tTurb"
              + " (UTurbx UTurby UTurbz)"
              //- myadd
              + " dRt"
              + " Ro"
              + " pgo"
    #68
    @youhaoyu
    hi,我已经好久没碰OF了。
    但是我看起来 你可以先将calcDiameter 不要用function的方式植入,先用最简单的方式直接添加到 calc中。你把Ro()也转换成类似Re的那种简单的定义方式。
    scalar Ro = xxxx
    因为OF是一层一层的按照template编译的,所以你现在这个处理办法要一层一层往上走,改了底层的,你先按照简单植入办法植入,然后当你发现你不得不突破OF的限制了以后,再考虑其他的办法。
    dxl
    您好想请教一下,关于颗粒的碰撞OF中是怎么检测的呢,感觉不是通过两个循环对每两个颗粒做一次检测,您对OF中采用的方法了解吗,具体是在哪部分中体现的呢
    在 中回复了 dxl 最后由 编辑
    #70
    @dxl 首先要看你基于的哪个cloud做的,并不是所有的cloud都真实的包含了颗粒碰撞。要查一下code确认你的程序是不是真正的引用了碰撞模型。
    其次,OF中的碰撞模型是O'Rourke的碰撞模型,是计算碰撞概率的,不是deteministic的(不知道中文怎么说)。即不是追踪所有颗粒,计算两个颗粒的路径,判断两个颗粒是否会发生碰撞的方法。
    基于OF10的话,你可以在下面找到具体的源程序。
    OpenFOAM-10/src/lagrangian/parcel/submodels/Spray/StochasticCollision
    /ORourkeCollision/
    ann
    @星星星星晴 您好 想要请教一下flowRateProfile table里面的数值是怎么计算出来的,我的模型中将总喷射质量改为了3.6e-6,时长改为了1.54ms,之前想要简单地把时长均匀扩充到1.54ms,但是计算结果相差较大,想要问一下文档中提到的基于TimeFunction1是需要加一个boundaryField文件,在其中计算,还是通过函数拟合?
    在 中回复了 ann 最后由 编辑
    #72
    @ann Hi 我好久没有碰OF了,没有办法给你精准的结果。
    但是我建议你查一下源程序, 看看哪一项是控制质量流量,np是怎么计算的,尺寸分布是怎么算的等。
    建议你可以先从最简单的情况,比如喷射多少个尺寸多大的particle,然后一点一点 你就知道什么是什么了。
