  4. snappyHexMesh定义了多域网格(MultiRegion)失败。
11 帖子 4 发布者 15.1k 浏览
  • 李子橙李 离线
    李子橙李 离线
    李子橙
    在 中回复了 李子橙 最后由 编辑
    另外,执行完splitMeshRegions -cellZones后,还会生成一个不知怎么切出来的的网格区域(蓝色部分),我很疑惑:135:
    你这个不是正好分为了固体域和流体域了么
    李子橙李 2 条回复 最后回复
  • 李子橙李 离线
    李子橙李 离线
    李子橙
    @东岳 找到问题所在了,因为球体无特征边缘,所以将球体的特征边缘删除即可。
    这是我修改后的SnappyHexMeshDict文件
    |  \\    /   O peration     | Version:  6                                     |
    |   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      snappyHexMeshDict;
    // Which of the steps to run
    castellatedMesh true;
    snap            true;
    addLayers       false;
    // Optional
    singleRegionName false;
    // Geometry. Definition of all surfaces.
    geometry
        solid.stl
            type triSurfaceMesh;
            regions
                solid {name solid_to_fluid;}
        fluid.stl
            regions
                inlet {name inlet;}
                outlet {name outlet;}
                top {name top;}
                bottom {name bottom;}
                front {name front;}
                back {name back;}
    // Settings for the castellatedMesh generation.
    castellatedMeshControls
        // Refinement parameters
        maxLocalCells 10000000;
        maxGlobalCells 20000000;
        minRefinementCells 0;
        maxLoadUnbalance 0;
        nCellsBetweenLevels 1;
        // Explicit feature edge refinement
        features
                file "fluid.eMesh";
                level 1;
        // Surface based refinement
    	refinementSurfaces
            solid.stl
                // Surface-wise min and max refinement level
                level (0 0);
                regions
                    solid {level (3 3);}
                faceZone solid;
                cellZone solid;
                cellZoneInside inside;
            fluid.stl
                level (0 0);
                regions
                    inlet {level (0 0);}
                    outlet {level (0 0);}
                    top {level (0 0);}
                    bottom {level (0 0);}
                    front {level (0 0);}
                    back {level (0 0);}
                faceZone fluid;
                cellZone fluid;
        // Feature angle:
        resolveFeatureAngle 20;
        // Region-wise refinement
        refinementRegions
            solid.stl
               mode inside;
               levels ((0 3));
            fluid.stl
               mode inside;
               levels ((0 1));
        // Mesh selection
        locationInMesh (31.76 17.64 31.56);
        // free-standing zone faces. Not used if there are no faceZones.
        allowFreeStandingZoneFaces true;
    snapControls
        nSmoothPatch 3;
        tolerance 3;
        nSolveIter 30;
        nRelaxIter 10;
        nFeatureSnapIter 10;
    // Settings for the layer addition.
    addLayersControls
        relativeSizes true;
        expansionRatio 1.2;
        finalLayerThickness 0.5;
        minThickness 0.1;
        // Per final patch (so not geometry!) the layer information
        // Note: This behaviour changed after 21x. Any non-mentioned patches
        //       now slide unless:
        //          - nSurfaceLayers is explicitly mentioned to be 0.
        //          - angle to nearest surface < slipFeatureAngle (see below)
        layers
        // If points get not extruded do nGrow layers of connected faces that are
        // also not grown. This helps convergence of the layer addition process
        // close to features.
        // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
        nGrow 0;
            featureAngle 130;		//default
            //featureAngle 180;
            //featureAngle 270;
            // Stop layer growth on highly warped cells
            maxFaceThicknessRatio 0.5;
            nSmoothSurfaceNormals 1;
            // Smooth layer thickness over surface patches
            nSmoothThickness 10;
        // Medial axis analysis
            // Angle used to pick up medial axis points
            // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130
            // in 17x.
            minMedialAxisAngle 90;
            minMedianAxisAngle 90;
            // Reduce layer growth where ratio thickness to medial
            // distance is large
            maxThicknessToMedialRatio 0.3;
            // Number of smoothing iterations of interior mesh movement direction
            nSmoothNormals 3;
            // Optional: limit the number of steps walking away from the surface.
            // Default is unlimited.
            //nMedialAxisIter 10;
            // Optional: smooth displacement after medial axis determination.
            // default is 0.
            //nSmoothDisplacement 90;
            // (wip)Optional: do not extrude a point if none of the surrounding points is
            // not extruded. Default is false.
            //detectExtrusionIsland true;
        // Mesh shrinking
            // Optional: at non-patched sides allow mesh to slip if extrusion
            // direction makes angle larger than slipFeatureAngle. Default is
            // 0.5*featureAngle.
            slipFeatureAngle 30;
            // Maximum number of snapping relaxation iterations. Should stop
            // before upon reaching a correct mesh.
            nRelaxIter 5;
            // Create buffer region for new layer terminations
            nBufferCellsNoExtrude 0;
            // Overall max number of layer addition iterations. The mesher will
            // exit if it reaches this number of iterations; possibly with an
            // illegal mesh.
            nLayerIter 50;
            // Max number of iterations after which relaxed meshQuality controls
            // get used. Up to nRelaxedIter it uses the settings in
            // meshQualityControls,
            // after nRelaxedIter it uses the values in
            // meshQualityControls::relaxed.
            nRelaxedIter 20;
            // Additional reporting: if there are just a few faces where there
            // are mesh errors (after adding the layers) print their face centres.
            // This helps in tracking down problematic mesh areas.
            additionalReporting true;
    // Generic mesh quality settings. At any undoable phase these determine
    // where to undo.
    meshQualityControls
        // Specify mesh quality constraints in separate dictionary so can
        // be reused (e.g. checkMesh -meshQuality)
        #include "meshQualityDict"
        // Optional : some meshing phases allow usage of relaxed rules.
        // See e.g. addLayersControls::nRelaxedIter.
        relaxed
            // Maximum non-orthogonality allowed. Set to 180 to disable.
            maxNonOrtho 75;
        //minFlatness 0.5;
        // Advanced
            // Number of error distribution iterations
            nSmoothScale 4;
            // amount to scale back displacement at error points
            errorReduction 0.75;
    // Advanced
    //debug 0;
    //debug 3;
    //// Debug flags
    debugFlags
        mesh            // write intermediate meshes
        intersections   // write current mesh intersections as .obj files
        featureSeeds    // write information about explicit feature edge
                        // refinement
        attraction      // write attraction as .obj files
        layerInfo       // write information about layers
    //// Write flags
    writeFlags
        scalarLevels    // write volScalarField with cellLevel for postprocessing
        layerSets       // write cellSets, faceSets of faces in layer
        layerFields     // write volScalarField for layer coverage
    // Merge tolerance. Is fraction of overall bounding box of initial mesh.
    // Note: the write tolerance needs to be higher than this.
    mergeTolerance 1e-6;
    J 1 条回复 最后回复
  • 李子橙李 离线
    李子橙李 离线
    李子橙
    @东岳 此外,谢谢东岳老师的回复。
    感谢分享 :146:
    jpzhao
    在 中回复了 李子橙 最后由 编辑
    @李子橙 你好,我想请教一下snoppyHexMesh就可以分切多域网格吗?那么topoSet的功能也跟snappyHexMesh一样吗?
    李子橙李 1 条回复 最后回复
  • 李子橙李 离线
    李子橙李 离线
    李子橙
    在 中回复了 jpzhao 最后由 编辑
    @jpzhao 是的,但是交界面网格质量不是很好,建议使用 mergeMeshes,但是tposet好像无法做出光滑的曲面。
    J 1 条回复 最后回复
    jpzhao
    在 中回复了 李子橙 最后由 编辑
    @李子橙 所以你的意思是如果是多个域计算传热,就每个域单独画网格,然后再将这几个网格合并?
    李子橙李 H 2 条回复 最后回复
  • 李子橙李 离线
    李子橙李 离线
    李子橙
    @jpzhao 我没有试过cht用这样网格,应该是没有问题的。
    hachikoi
    @jpzhao 在 snappyHexMesh定义了多域网格(MultiRegion)失败。 中说:
    请问这个问题解决了吗 mergeMeshes的关键问题是子域网格的边界如何设定或者如何取消呢?
