pointwise划分了地形网格计算域为3000*3000*1000 ,用openFoam中simpleFoam求解计算错误?
我在这个问题这儿卡了2个月了,我用pointwise划分了一个复杂地型网格,计算域300030001000,最小网格长宽为30*30,第一层网格高度为50cm,我计算的时候出现如下现象,到最后一行,算例自动停止。
我最初的想法是将of自带的一个例子里的网格替换成用pointwise生成的网格,进行计算,不知道出了什么问题,希望能得到各位老师的帮助,谢谢!/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-e29811f5dff8 Exec : simpleFoam Date : Jun 07 2019 Time : 18:39:08 Host : "DESKTOP-K2TDLI2" PID : 434 I/O : uncollated Case : /home/dyb/turbineSiting nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: Convergence criteria found p: tolerance 0.001 U: tolerance 0.0001 "(k|epsilon)": tolerance 0.0001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.11; C3 0; sigmak 1; } No MRF models present No finite volume options present Starting time loop Time = 0.5 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.130925946068, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.305787562946, No Iterations 1000 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 1.18059515052, No Iterations 1000
如下是我的一些设置
fvSolution/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-7; relTol 0.1; smoother GaussSeidel; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } k { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } epsilon { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 0; residualControl { p 1e-3; U 1e-4; "(k|epsilon)" 1e-4; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; epsilon 0.7; } } cache { grad(U); } // ************************************************************************* //
fvSchemes
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited corrected 0.33; } interpolationSchemes { default linear; } snGradSchemes { default limited corrected 0.33; } // ************************************************************************* //
controlDict
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 1000; deltaT 0.5; writeControl timeStep; writeInterval 50; purgeWrite 0; writeFormat binary; writePrecision 12; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; libs ("libatmosphericModels.so"); // ************************************************************************* //
李老师,我把我的边界条件发过来,您帮忙看一下。大概是压力项可能出错了
epsilon
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; #include "include/initialConditions" internalField uniform $turbulentEpsilon; boundaryField { terrain { type epsilonWallFunction; Cmu 0.09; kappa 0.4; E 9.8; value $internalField; } outlet { type inletOutlet; inletValue uniform $turbulentEpsilon; value $internalField; } inlet { type atmBoundaryLayerInletEpsilon; #include "include/ABLConditions" } ground { type zeroGradient; } top { type slip; } sides { type slip; } } // ************************************************************************* //
k
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $turbulentKE; boundaryField { outlet { type inletOutlet; inletValue uniform $turbulentKE; value $internalField; } inlet { type atmBoundaryLayerInletK; #include "include/ABLConditions" } terrain { type kqRWallFunction; value uniform 0.0; } ground { type zeroGradient; } top { type slip; } sides { type slip; } } // ************************************************************************* // nut /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { #include "include/ABLConditions" inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } terrain { type nutkAtmRoughWallFunction; z0 $z0; value uniform 0.0; } ground { type calculated; value uniform 0; } top { type slip; } sides { type slip; } } // ************************************************************************* //
P
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $pressure; boundaryField { inlet { type zeroGradient; } outlet { type uniformFixedValue; uniformValue $internalField; } terrain { type zeroGradient; } ground { type zeroGradient; } top { type slip; } sides { type slip; } } // ************************************************************************* //
u
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 1 -1 0 0 0 0]; internalField uniform $flowVelocity; boundaryField { outlet { type inletOutlet; inletValue uniform (0 0 0); value $internalField; } inlet { type atmBoundaryLayerInletVelocity; #include "include/ABLConditions" } terrain { type uniformFixedValue; uniformValue (0 0 0); value uniform (0 0 0); } ground { type uniformFixedValue; value uniform (0 0 0); uniformValue constant (0 0 0); } top { type slip; } sides { type slip; } } // ************************************************************************* //
说明文件ABL
========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Uref 10.0; Zref 20; zDir (0 0 1); flowDir (1 0 0); z0 uniform 0.1; zGround uniform 0; // ************************************************************************* //
initialConditions
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ flowVelocity (0 0 0); pressure 0; turbulentKE 1.3; turbulentEpsilon 0.01; // ************************************************************************* //
fixedInlet
inlet { type fixedValue; value $internalField; }
解决了,不同尺度的网格对应压力求解方法的平滑smoother有问题,初始条件也没有错,
@dyb 在 pointwise划分了地形网格计算域为3000*3000*1000 ,用openFoam中simpleFoam求解计算错误? 中说:
大佬您好,
我最近也在学习复杂地形上风场的模拟,使用的也是turbinesiting这个算例,请问这个算例有没有比较好的教程?
目前还是小白,总是会报错 -
@wsy11 你好,我最初用的方法比较笨,你可以之直接用pointwise绘制计算域,把边界层加大一些,我最初近地1m高,这个我没有制作教程,一般你只需要改fvSolution,我的主要是这样的,再就是时间步长要小
code_textsolvers { p { solver GAMG; tolerance 1e-8; relTol 0.01; smoother DIC; } pFinal { $p; smoother DIC; tolerance 1e-06; relTol 0; } "(U|k|nuTilda)" { solver smoothSolver; smoother DILU; tolerance 1e-05; relTol 0.1; } "(U|k|nuTilda)Final" { $U; tolerance 1e-05; relTol 0; } } PIMPLE { nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 1001; pRefValue 0; }
大佬您好,我想再请教一个问题
turbinesiting算例中的地形的stl文件是怎么生成的?我用自己的stl文件(用GlobalMapper裁剪ASTER GDEM地形高程数据)时,会存在两个底面,terrian面和ground面都会存在。
5/9
