  4. 关于VOF模型中相体积分数方程的疑问。
关于VOF模型中相体积分数方程的疑问。
12 帖子 2 发布者 14.0k 浏览
  • T 离线
    T 离线
    Tens 神
    @李东岳 李老师有时间帮忙解惑吗
    你用VOF算的什么工况?
    T 1 条回复 最后回复
  • T 离线
    T 离线
    Tens 神
    @李东岳 4atm 555K的横向射流
    泥沙两相流么,LES还是RANS
  • T 离线
    T 离线
    Tens 神
    气液两相流,RANS
  • T 离线
    T 离线
    Tens 神
    写于 最后由 Tens 编辑
    虽然相体积分数是一个标量,但是是根据液相的质量守恒推导出来的
    对于可压缩流动,最多在加上右边这一项吧
    @Tens 在 关于VOF模型中相体积分数方程的疑问。 中说:
    I encourage the authors to add all turbulent contributions: for the liquid volume fraction, as it is a scalar, it is possible to add an eddy-diffusivity model to the volume fraction equation(which will certainly remove any need for an artificial compression model required in DNS)
    We agree with the reiviewer that the turbulent contribution should be added in the phase fraction transported equation. In our work, RANS model was used and the phase fraction equation can be written as the following:
    \frac{\p \overline{\alpha+\alpha'}}{\p t}+\nabla\cdot(\overline{\bfU}\overline{\alpha+\alpha'}) =0
    where $\alpha'$ is a fluctuating component for the phase fraction and the second term of the equation can be calculated by Reynolds decomposition:
    \overline{\bfU}\overline{\alpha+\alpha'}=\overline{\bfU}\overline{\alpha}+\overline{\bfU}\alpha'
    in which the $\overline{\bfU}\alpha'$ is the so-called turbulent flux of the phase fraction. When a gradient-diffusion model is enplyed, it can be written as
    \overline{\bfU}\alpha'=-D_{\alpha}\nabla \overline{\alpha}
    where $D_{\alpha}$ is the modelled diffusion. In this way, the phase fraction can be written as
    \frac{\p \overline{\alpha+\alpha'}}{\p t}+\nabla\cdot(\overline{\bfU}\overline{\alpha}) -\nabla\cdot(D_{\alpha}\nabla \overline{\alpha})=0
    and the thrid term is the turbulent contribution as said by the reviewer. The turbulent contribution was proven to be important for slurry flow simulations [1,2,3,4]. However, in our work it was used to simulate gas-liquid flow and its contribution was typically neglected [5,6,7].
    1. Numerical prediction of fully-suspended slurry flow in horizontal pipes
    2. Improvements in the numerical prediction of fully-suspended slurry flow
    3. Analysis and discussion of two fluid modelling of pipe flow of fully suspended slurry
    4. A general two-phase turbulent flow model applied to the study of sediment
    5. Computational Models for Turbulent Reacting Flows
    6. Computational Models for Polydisperse Particulate and Multiphase Systems
    T 1 条回复 最后回复
  • T 离线
    T 离线
    Tens 神
    @李东岳 李老师真是太宠粉丝了,爱了:140:
    怎么样,后续这个稿件接收了么
    T 1 条回复 最后回复
  • T 离线
    T 离线
    Tens 神
    @李东岳 谢谢李老师挂念,两次修改后前几天在情人节Accept了
    在 中回复了 Tens 最后由 编辑
    @Tens 恭喜恭喜!!!!隔壁师兄又要嫉妒死了!:mihu: :mihu: :mihu:
