  3. openfoam 10 中怎么按某场的特征动态加密网格?
9 帖子 4 发布者 6.0k 浏览
    JqBu
    写于 最后由 JqBu 编辑
    想在of10里做些工作,但是发现of10的动态网格加密和以前版本有很大不同,求助大家一下:
    比如我想按alpha.water的大小加密网格,以前可以写:
    dynamicFvMesh      dynamicRefineFvMesh;
    但是现在of规则变了,不能这样写了,src里没有dynamicfvMesh了,只有这些是和动网格相关的,但是要不是网格是移动的要不就是要topo的,cb46ccb9-3ecb-4785-841a-cd535b0b7d5c-image.png
    请问大家of10里怎么给alpha加密网格呀?:143:
    J 2 条回复 最后回复
    JqBu
    在 中回复了 JqBu 最后由 编辑
    @JqBu 找到个of官方算例动态加密网格的,是下面这样,不过在我的算例里还是跑不了,贴出来记录一下把
    topoChanger
        type            refiner;
        libs            ("libfvMeshTopoChangers.so");
        // How often to refine
        refineInterval  1;
        // Field to be refinement on
        field           alpha.water;
        // Refine field in between lower..upper
        lowerRefineLevel 0.001;
        upperRefineLevel 0.999;
        // Have slower than 2:1 refinement
        nBufferLayers   1;
        // Refine cells only up to maxRefinement levels
        maxRefinement   2;
        // Stop refinement if maxCells reached
        maxCells        200000;
        // Flux field and corresponding velocity field. Fluxes on changed
        // faces get recalculated by interpolating the velocity. Use 'none'
        // on surfaceScalarFields that do not need to be reinterpolated.
        correctFluxes
            (phi none)
            (nHatf none)
            (rhoPhi none)
            (alphaPhi.water none)
            (ghf none)
        // Write the refinement level as a volScalarField
        dumpLevel       true;
    JqBu
    在 中回复了 JqBu 最后由 编辑
    @JqBu 报错如下,贴出来给大家看看,有没有大佬指教一下呢```
    Courant Number mean: 0.0440313 max: 0.39994
    Interface Courant Number mean: 0.00208161 max: 0.39994
    deltaT = 1.54321e-06
    Selected 1971 cells for refinement out of 125250.
    Refined from 125250 to 139047 cells.
    #0 Foam::error::printStack(Foam::Ostream&) at ??:?
    #1 Foam::sigSegv::sigHandler(int) at ??:?
    #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
    #3 Foam::fvMeshTopoChangers::refiner::refineUfs(Foam::HashSet<int, Foam::Hash<int> > const&, Foam::polyTopoChangeMap const&) at ??:?
    #4 Foam::fvMeshTopoChangers::refiner::refine(Foam::List<int> const&) at ??:?
    #5 Foam::fvMeshTopoChangers::refiner::update() at ??:?
    #6 Foam::fvMesh::update() at ??:?
    #7 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/interFoam"
    #8 ? in "/lib/x86_64-linux-gnu/libc.so.6"
    #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #10 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/interFoam"
    尚 1 条回复 最后回复
  • 尚 在线
    尚 在线
    尚善若水
    在 中回复了 JqBu 最后由 编辑
    @JqBu 请问这个问题解决了吗?我最近做了点二维AMR,运行也是如此报错,正在debug
    OpenFOAM没有2D AMR,你是把empty变类型了么,类似一个quasi-2D?
    尚 1 条回复 最后回复
  • 尚 在线
    尚 在线
    尚善若水
    @李东岳 李老师,我根据别人支持2D与3D的 AMR代码更新到了最新版本,3D跑着没问题,2D还是报错了
    我当时好奇你怎么做的2D AMR,就问了你一句。默认的AMR,你要是要跑2D,你把empty面全部改成patch,然后把前后面设置成slip边界,也可以。
    不过你那个发散了我不清楚什么情况。
    jxzs_zy
    请问下现在版本3D四面体可以AMR吗?
    尚 1 条回复 最后回复
  • 尚 在线
    尚 在线
    尚善若水
    在 中回复了 jxzs_zy 最后由 编辑
    @jxzs_zy 在开发,好像还没正式发布。Added dynamicPolyRefinementFvMesh
