  4. 编译求解器,原始某些功能无法使用问题
编译求解器,原始某些功能无法使用问题
2 帖子 2 发布者 1.6k 浏览
  • Y 在线
    Y 在线
    youhaoyu
    最近编写了一个拉格朗日DPMFoam下面的颗粒长大的求解器,在OpenFOAM/OpenFOAM-3.0.0/src/lagrangian/intermediate/lnInclude对源文件进行了修改。
    源文件,求解器均编译成功,使用新求解器时候不能运行stochasticDispersionRAS的随机游走模型,有如下报错
    Starting time loop
    Courant Number mean: 0 max: 0
    Time = 0.01
    Evolving kinematicCloud
    Solving 3-D cloud kinematicCloud
    #1  Foam::sigSegv::sigHandler(int) at ??:?
    #2  ? in "/lib64/libc.so.6"
    #3  std::string::rfind(char, unsigned long) const in "/lib64/libstdc++.so.6"
    #4  Foam::IOobject::group() const at ??:?
    #5  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::kModel() const at ??:?
    #6  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::cacheFields(bool) at ??:?
    #7  ? at ??:?
    #8  ? at ??:?
    #9  ? at ??:?
    #10  __libc_start_main in "/lib64/libc.so.6"
    #11  ? at ??:?
    Segmentation fault (core dumped)
    修改了一下算法,算简单一点也有报错
    Time = 0.001
    [2] #[3] #0  0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)[1] #0  Foam::error::printStack(Foam::Ostream&)[0] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
     at ??:?
     at ??:?
     at ??:?
    [3] #1  [1] #[2] #1  Foam::sigSegv::sigHandler(int)1  Foam::sigSegv::sigHandler(int)Foam::sigSegv::sigHandler(int)[0] #1  Foam::sigSegv::sigHandler(int) at ??:?
    [3] #2  ? at ??:?
    [2] #2   at ??:?
    [1] #2  ?? at ??:?
    [0] #2  ? in "/lib64/libc.so.6"
    [1] #3  std::string::rfind(char, unsigned long) const in "/lib64/libc.so.6"
    [3] #3  std::string::rfind(char, unsigned long) const in "/lib64/libc.so.6"
    [2] #3  std::string::rfind(char, unsigned long) const in "/lib64/libc.so.6"
    [0] #3  std::string::rfind(char, unsigned long) const in "/lib64/libstdc++.so.6"
    [1] #4  Foam::IOobject::group() const[3] #4  Foam::IOobject::group() const in "/lib64/libstdc++.so.6"
    [2] #4  Foam::IOobject::group() const in "/lib64/libstdc++.so.6"
    [0] #4  Foam::IOobject::group() const at ??:?
    [1] #5  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::kModel() const at ??:?
    [3] #5  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::kModel() const at ??:?
    [2] #5  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::kModel() const at ??:?
    [0] #5  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::kModel() const at ??:?
    [1] #6  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::cacheFields(bool) at ??:?
    [3] #6  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::cacheFields(bool) at ??:?
    [2] #6  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::cacheFields(bool) at ??:?
    [0] #6  Foam::DispersionRASModel<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::cacheFields(bool) at ??:?
    [1] #7   at ??:?
    [2] #7   at ??:?
    [3] #7   at ??:?
    [0] #7  ???? at ??:?
    [1] #8   at ??:?
    [2] #8   at ??:?
    [3] #8   at ??:?
    [0] #8  ???? at ??:?
    [1] #9   at ??:?
    [2] #9   at ??:?
    [3] #9   at ??:?
    [0] #9  ???? at ??:?
    [1] #10  __libc_start_main at ??:?
    [3] #10  __libc_start_main at ??:?
    [2] #10  __libc_start_main at ??:?
    [0] #10  __libc_start_main in "/lib64/libc.so.6"
    [1] #11   in "/lib64/libc.so.6"
    [3] #11   in "/lib64/libc.so.6"
    [2] #11   in "/lib64/libc.so.6"
    [0] #11  ???? at ??:?
     at ??:?
     at ??:?
     at ??:?
    看起来是和Collisionparcel文件有关系?????为什么我改一下颗粒直接变化还和碰撞模型的文件产生了影响??我修改完了之后,不用随机游走模型倒是能跑,但是之后我是算例是需要运动随机游走模型的,所以我想搞想清楚原因,是不是我还要对CollisonParcel文件进行修改
  • A 在线
    A 在线
    Afr1yne
    楼主解决了吗
