  4. Openfoam1912编译waves2Foam失败,求教
11 帖子 5 发布者 11.5k 浏览
  • B 离线
    B 离线
    bike-北辰
    在 中回复了 peiyiii_ 最后由 编辑
    看起来还是没有安装好OceanWave3D,你要把
    @peiyiii_ 在 Openfoam1912编译waves2Foam失败,求教 中说:
    waves2Foam\ThirdParty
    中的Allwmake里用github下载OceanWave3D部分注释掉,不然还是要通过github下载,下载不好的话会编译失败
    P 1 条回复 最后回复
  • P 离线
    P 离线
    peiyiii_
    在 中回复了 bike-北辰 最后由 peiyiii_ 编辑
    @bike-北辰 老师您好
    我刚刚去尝试把thirdparty中的allwmake文件修改,源文件如下:
    #!/bin/bash
    ## The script has been modified on 2015.09.08 to reflect the fact that
    #  the svn-repository for OceanWave3D has been discontinued.
    sourceLib="lib"
    settings="settings"
    if [ ! -d "$sourceLib" ]
    then
        mkdir $sourceLib
    fi
    echo "====================================="
    echo "    COMPILE LAPACK-3.3.1"
    compileFlag=0
    if [ ! -f "$sourceLib/libblas.a" ]
    then
        compileFlag=1;
    fi
    if [ ! -f "$sourceLib/liblapack_gfortran.a" ]
    then
        compileFlag=1;
    fi
    if [ ! -f "$sourceLib/libtmglib_gfortran.a" ]
    then
        compileFlag=1;
    fi
    ## COMPILE LAPACK
    if [ "$compileFlag" == "1" ]
    then
        # Unpack lapack-3.3.1
        tar -xzf lapack-3.3.1.tgz
        # Copy the necessary settings
        cp $settings/lapackSettings/* lapack-3.3.1/.
        # Compile lapack
        cd lapack-3.3.1
        make clean
        make all
        cd ..
    else
        echo
        echo "lapack-3.3.1 has already been compiled"
        echo
    fi
    echo "    COMPILE SPARSKIT2"
    compileFlag=0
    if [ ! -f "$sourceLib/libskit_gfortran.a" ]
    then
        compileFlag=1;
    fi
    ## COMPILE SPARSKIT2
    then
        # Unpack SPARSKIT2
        tar -xzf SPARSKIT2.tar.gz
        cp $settings/sparseSettings/makefile SPARSKIT2/.
        # Compile SPARSKIT2
        cd SPARSKIT2
        make clean
        make lib
        mv libskit_gfortran.a ../lib/.
        cd ..
    else
        echo
        echo "SPARSKIT2 has already been compiled"
        echo
    fi
    echo "    COMPILE OCEANWAVE3D"
    # Path for the git-repository
    ocw="OceanWave3D-Fortran90"
    # Create output directory for OceanWave3D
    if [ ! -d "bin" ]
    then
        mkdir bin
    fi
    # Check-out the git-repository
    if [ ! -d "$ocw" ]
    then
        echo ""
        echo "Cloning the OceanWave3D git repository ..."
        git clone https://github.com/boTerpPaulsen/OceanWave3D-Fortran90.git
        # Copy the compilation settings for OCW3D
        cp $settings/oceanWave3DSettings/common.mk $ocw/.
        cp $settings/oceanWave3DSettings/makefile $ocw/.
    else
        echo ""
        echo "Pull changes from the OceanWave3D git repository ..."
        cd $ocw
        # Stash the local changes on the settings
        git stash
        # Get an update of the git and report the result
        output=`git pull`
        echo $output
        # Check whether the git was already up to date
        if [[ $output == "Already up-to-date." ]]
        then
            compileFlag=0
        elif [[ $output == "Already up to date." ]]
        then
            compileFlag=0
        else
            compileFlag=1
        fi
        # Re-apply the compilation settings
        git stash pop
        cd $OLDPWD
    fi
    # Check for the correct environmental variables
    if [ -z "$WAVES_LIBBIN" ]
    then
        echo ""
        echo "Set the environmental variables for waves2Foam"
        echo "Exiting compilation process"
        echo ""
        exit 1
    fi
    # Check whether the executable has been deleted
    if [ ! -f "$WAVES_APPBIN/OceanWave3D" ]
    then
        compileFlag=1
    fi
    # Check whether the library has been deleted
    if [ ! -f "$WAVES_LIBBIN/libOceanWave3D.so" ]
    then
        compileFlag=1
    fi
    then
        # Temporary build directory
        mkdir build
        # Compile OceanWave3D input an executable and a dynamic library
        cd $ocw
        make clean
        make Release
        make shared
        cd $OLDPWD
        # Clean up
        rm -rf build
    else
        echo
        echo "OceanWave3D has already been compiled"
        echo
    fi
    pwd
    echo "    COMPILE FENTON4FOAM"
    fentonName="fenton4Foam"
    if [ ! -f "$WAVES_APPBIN/$fentonName" ]
    then
        echo
        echo "Compiling fenton4Foam"
        echo
        cd $fentonName
        gfortran -o $WAVES_APPBIN/$fentonName $fentonName.f fft.f
        cd $OLDPWD
    else
        echo
        echo "fenton4Foam has already been compiled"
        echo
    fi
    exit 0
    我把整个COMPILE OCEANWAVE3D的部分都删掉,重新编译waves2Foam,依然编译失败,输出结果如下:
        ENVIRONMENTAL VARIABLES
    EXTBRANCH=0
    FOAMEXTENDPROJECT=0
    OFPLUSBRANCH=1
    WAVES_APPBIN=/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/bin
    WAVES_DIR=/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam
    WAVES_GSL_INCLUDE=/usr/include
    WAVES_GSL_LIB=/usr/lib64
    WAVES_LIBBIN=/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib
    WAVES_POST=/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/applications/utilities/postProcessing
    WAVES_PRE=/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing
    WAVES_SOL=/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/applications/solvers/solvers1912_PLUS
    WAVES_SRC=/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/src
    WAVES_TUT=/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/tutorials
    WAVES_UTIL=/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/applications/utilities
    WAVES_XVERSION=0
    WM_PROJECT_VERSION_NUMBER=1912
        COMPILE SPARSKIT2
    /home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/ThirdParty
        COMPILE FENTON4FOAM
        COMPILE LIBRARY
    v1912
    wmake libso (waves2Foam)
    g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -DOFVERSION=1912 -DEXTBRANCH=0 -DXVERSION=0 -DOFPLUSBRANCH=1 -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/meshTools/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/sampling/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/lagrangian/basic/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/fileFormats/lnInclude -I/usr/include -IlnInclude -I. -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude   -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/convexPolyhedral/convexPolyhedral.o Make/linux64GccDPInt32Opt/convexPolyhedral/localFace.o Make/linux64GccDPInt32Opt/convexPolyhedral/localCell.o Make/linux64GccDPInt32Opt/convexPolyhedral/localCellNeg.o Make/linux64GccDPInt32Opt/waveTheories/waveTheory/waveTheory.o Make/linux64GccDPInt32Opt/waveTheories/waveTheory/newWaveTheory.o Make/linux64GccDPInt32Opt/waveTheories/current/potentialCurrent/potentialCurrent.o Make/linux64GccDPInt32Opt/waveTheories/solitary/solitaryFirst/solitaryFirst.o Make/linux64GccDPInt32Opt/waveTheories/solitary/chappelear1962/chappelear1962.o Make/linux64GccDPInt32Opt/waveTheories/regular/stokesFirst/stokesFirst.o Make/linux64GccDPInt32Opt/waveTheories/regular/stokesFirstStanding/stokesFirstStanding.o Make/linux64GccDPInt32Opt/waveTheories/regular/stokesSecond/stokesSecond.o Make/linux64GccDPInt32Opt/waveTheories/regular/stokesSecondModulation/stokesSecondModulation.o Make/linux64GccDPInt32Opt/waveTheories/regular/stokesFifth/stokesFifth.o Make/linux64GccDPInt32Opt/waveTheories/regular/cnoidalFirst/cnoidalFirst.o Make/linux64GccDPInt32Opt/waveTheories/regular/streamFunction/streamFunction.o Make/linux64GccDPInt32Opt/waveTheories/irregular/irregular/irregular.o Make/linux64GccDPInt32Opt/waveTheories/irregular/bichromaticFirst/bichromaticFirst.o Make/linux64GccDPInt32Opt/waveTheories/irregular/bichromaticSecond/bichromaticSecond.o Make/linux64GccDPInt32Opt/waveTheories/mixedType/combinedWaves/combinedWaves.o Make/linux64GccDPInt32Opt/waveTheories/externalWaveForcing/externalSource.o Make/linux64GccDPInt32Opt/waveTheories/externalWaveForcing/externalWaveForcing.o Make/linux64GccDPInt32Opt/waveTheories/externalWaveForcing/emptyExternal/emptyExternal.o Make/linux64GccDPInt32Opt/waveTheories/externalWaveForcing/oceanWave3D/oceanWave3D.o Make/linux64GccDPInt32Opt/waveTheories/externalWaveForcing/irregularFast/irregularFast.o Make/linux64GccDPInt32Opt/fvPatchFields/waveAlpha/waveAlphaFvPatchScalarField.o Make/linux64GccDPInt32Opt/fvPatchFields/waveVelocity/waveVelocityFvPatchVectorField.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationShape/relaxationShape.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationShape/newRelaxationShape.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationShape/frozen/relaxationShapeFrozen.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationShape/rectangular/relaxationShapeRectangular.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationShape/cylindrical/relaxationShapeCylindrical.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationShape/semiCylindrical/relaxationShapeSemiCylindrical.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationShape/line/relaxationShapeLine.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationWeight/relaxationWeight.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationWeight/relaxationWeightCourantCorrection.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationWeight/exponential/relaxationWeightExponential.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationWeight/freePolynomial/relaxationWeightFreePolynomial.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationWeight/thirdOrderPolynomial/relaxationWeightThirdOrderPolynomial.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationScheme/relaxationScheme.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationScheme/newRelaxationScheme.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationScheme/empty/relaxationSchemeEmpty.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationScheme/spatial/relaxationSchemeSpatial.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationScheme/spatialInterpolation/relaxationSchemeSpatialInterpolation.o Make/linux64GccDPInt32Opt/relaxationZone/numericalBeach/numericalBeach.o Make/linux64GccDPInt32Opt/relaxationZone/numericalBeach/newNumericalBeach.o Make/linux64GccDPInt32Opt/relaxationZone/numericalBeach/empty/numericalBeachEmpty.o Make/linux64GccDPInt32Opt/relaxationZone/relaxationZone.o Make/linux64GccDPInt32Opt/setWaveField/setWaveField.o Make/linux64GccDPInt32Opt/include/crossVersionCompatibility.o -L/home/dyfluid/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib \
        -lfiniteVolume -lmeshTools -lsampling -lfileFormats -lstdc++ -lgfortran -L/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib -lOceanWave3D -L/usr/lib64 -lgsl -lgslcblas  -o /home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib/libwaves2Foam.so
    /usr/bin/ld: 找不到 -lgfortran: 没有那个文件或目录
    make: *** [/home/dyfluid/OpenFOAM/OpenFOAM-v1912/wmake/makefiles/general:177:/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib/libwaves2Foam.so] 错误 1
    wmake libso (waves2FoamProcessing)
    g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -DOFVERSION=1912 -DEXTBRANCH=0 -DXVERSION=0 -DOFPLUSBRANCH=1 -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/meshTools/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/sampling/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/lagrangian/basic/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/fileFormats/lnInclude -I/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/usr/include -IlnInclude -I. -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude   -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/setWaveProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/current/potentialCurrentProperties/potentialCurrentProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/solitary/solitaryFirstProperties/solitaryFirstProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/solitary/chappelear1962Properties/chappelear1962Properties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/regular/stokesFirstProperties/stokesFirstProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/regular/stokesFirstStandingProperties/stokesFirstStandingProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/regular/stokesSecondProperties/stokesSecondProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/regular/stokesSecondModulationProperties/stokesSecondModulationProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/regular/stokesFifthProperties/stokesFifthProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/regular/cnoidalFirstProperties/cnoidalFirstProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/regular/streamFunctionProperties/streamFunctionProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/bichromaticFirstProperties/bichromaticFirstProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/bichromaticSecondProperties/bichromaticSecondProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/waveSpectra/waveSpectra.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/waveSpectra/frequencyAxis/frequencyAxis.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/waveSpectra/frequencyAxis/equidistantFrequencyAxis/equidistantFrequencyAxis.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/waveSpectra/frequencyAxis/cosineStretchedFrequencyAxis/cosineStretchedFrequencyAxis.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/waveSpectra/spectra/JONSWAP/JONSWAP.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/waveSpectra/spectra/PiersonMoskowitz/PiersonMoskowitz.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/waveSpectra/phases/phases.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/waveSpectra/phases/randomPhase/randomPhase.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/waveSpectra/phases/focusingPhase/focusingPhase.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/irregular/irregularProperties/irregularProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/mixedType/combinedWavesProperties/combinedWavesProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/externalWaveForcing/externalSourceProperties/externalSourceProperties.o Make/linux64GccDPInt32Opt/preProcessing/setWaveProperties/externalWaveForcing/oceanWave3DProperties/oceanWave3DProperties.o Make/linux64GccDPInt32Opt/preProcessing/probes/waveGauges/waveGauges.o Make/linux64GccDPInt32Opt/preProcessing/probes/probeGauges/probeGauges.o Make/linux64GccDPInt32Opt/preProcessing/probes/pointDistributions/pointDistributions.o Make/linux64GccDPInt32Opt/preProcessing/probes/pointDistributions/userDefinedDistribution/userDefinedDistribution.o Make/linux64GccDPInt32Opt/preProcessing/probes/pointDistributions/lineDistribution/lineDistribution.o Make/linux64GccDPInt32Opt/preProcessing/probes/pointDistributions/circularDistribution/circularDistribution.o Make/linux64GccDPInt32Opt/preProcessing/probes/pointDistributions/quadrilateralDistribution/quadrilateralDistribution.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/postProcessingWaves.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeRawData/rawSurfaceElevation/rawSurfaceElevation.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeRawData/rawVelocityProbes/rawVelocityProbes.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeRawData/rawForcesAndMoments/rawForcesAndMoments.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeRawData/rawAlphaProbes/rawAlphaProbes.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeRawData/rawOvertopping/rawOvertopping.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/write2Ascii/write2Ascii.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeIndexLocation/writeIndexLocation.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/cleaningUtil/removeData/removeData.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/cleaningUtil/removeSubDirs/removeSubDirs.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeInterpolatedData/interpolateSurfaceElevation/interpolateSurfaceElevation.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeInterpolatedData/interpolateVelocityProbes/interpolateVelocityProbes.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeInterpolatedData/interpolateForcesAndMoments/interpolateForcesAndMoments.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeInterpolatedData/interpolateAlphaProbes/interpolateAlphaProbes.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/writeInterpolatedData/interpolateOvertopping/interpolateOvertopping.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/spectralAnalysis/spectralMethods/complexExp.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/spectralAnalysis/spectralMethods/spectralMethodsFFTBased.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/spectralAnalysis/spectralMethods/spectralMethodsLeastSquaresBased.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/spectralAnalysis/fftBasedMethods/powerSpectraFFT/powerSpectraFFT.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/spectralAnalysis/fftBasedMethods/reflectionAnalysis2DFFT/reflectionAnalysis2DFFT.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/spectralAnalysis/leastSquareBasedMethods/powerSpectraLS/powerSpectraLS.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/spectralAnalysis/leastSquareBasedMethods/reflectionAnalysis2DLS/reflectionAnalysis2DLS.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/miscOperations/ensembleAverage/ensembleAverage.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/miscOperations/trapz/trapz.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/miscOperations/cumTrapz/cumTrapz.o Make/linux64GccDPInt32Opt/postProcessing/postProcessingWaves/miscOperations/zeroCrossing/zeroCrossing.o -L/home/dyfluid/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib \
        -lfiniteVolume -lmeshTools -lsampling -lfileFormats -L/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam -L/usr/lib64 -lgsl -lgslcblas  -o /home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib/libwaves2FoamProcessing.so
    /usr/bin/ld: 找不到 -lwaves2Foam: 没有那个文件或目录
    make: *** [/home/dyfluid/OpenFOAM/OpenFOAM-v1912/wmake/makefiles/general:177:/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib/libwaves2FoamProcessing.so] 错误 1
    wmake libso (waves2FoamSamplingNew)
    g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -DOFVERSION=1912 -DEXTBRANCH=0 -DXVERSION=0 -DOFPLUSBRANCH=1 -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/fileFormats/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/surfMesh/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/meshTools/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/conversion/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/dynamicMesh/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/sampling/lnInclude -I/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -IlnInclude -I. -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude   -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/surfaceElevation/sampledSurfaceElevation.o Make/linux64GccDPInt32Opt/overtopping/overtopping.o -L/home/dyfluid/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib \
        -lfiniteVolume -lmeshTools -lconversion -ldynamicMesh -lsampling -L/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam  -o /home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib/libwaves2FoamSampling.so
    make: *** [/home/dyfluid/OpenFOAM/OpenFOAM-v1912/wmake/makefiles/general:177:/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib/libwaves2FoamSampling.so] 错误 1
    wmake libso (waves2FoamPorosity)
        COMPILE SOLVERS
    g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/applications/solvers/multiphase/VoF -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/meshTools/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/sampling/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/dynamicFvMesh/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/transportModels -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/transportModels/incompressible/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/transportModels/interfaceProperties/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/transportModels/twoPhaseMixture/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/TurbulenceModels/incompressible/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/src/waves2FoamSamplingNew/lnInclude -I/usr/include -DOFVERSION=1912 -DEXTBRANCH=0 -DOFPLUSBRANCH=1 -DXVERSION=0  -IlnInclude -I. -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/waveFoam.o -L/home/dyfluid/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib \
        -lfiniteVolume -lfvOptions -lmeshTools -lsampling -ldynamicFvMesh -lincompressibleTransportModels -linterfaceProperties -limmiscibleIncompressibleTwoPhaseMixture -lturbulenceModels -lincompressibleTurbulenceModels -L/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam -lwaves2FoamSampling -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl  \
         -lm -o /home/dyfluid/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin/waveFoam
    /usr/bin/ld: 找不到 -lwaves2FoamSampling: 没有那个文件或目录
    make: *** [/home/dyfluid/OpenFOAM/OpenFOAM-v1912/wmake/makefiles/general:143:/home/dyfluid/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin/waveFoam] 错误 1
        COMPILE PRE-PROCESSING
    wmake faceSetToSTL
    make[1]: 进入目录“/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing/faceSetToSTL”
    make[1]: 离开目录“/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing/faceSetToSTL”
    wmake relaxationZoneLayout
    make[1]: 进入目录“/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout”
    g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/meshTools/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -DOFVERSION=1912 -DEXTBRANCH=0 -I/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/usr/include -IlnInclude -I. -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/relaxationZoneLayout.o -L/home/dyfluid/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib \
        -lfiniteVolume -L/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl  \
         -lm -o /home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/bin/relaxationZoneLayout
    make[1]: *** [/home/dyfluid/OpenFOAM/OpenFOAM-v1912/wmake/makefiles/general:143:/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/bin/relaxationZoneLayout] 错误 1
    make[1]: 离开目录“/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout”
    make: *** [/home/dyfluid/OpenFOAM/OpenFOAM-v1912/wmake/makefiles/apps:29:relaxationZoneLayout] 错误 2
        COMPILE POST-PROCESSING
    g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/meshTools/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -I/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/src/waves2Foam/src/lnInclude -I/home/dyfluid/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam/src/waves2FoamProcessing/lnInclude -I/usr/include -DOFVERSION=1912 -DEXTBRANCH=0 -IlnInclude -I. -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/postProcessWaves2Foam.o -L/home/dyfluid/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib \
        -lOpenFOAM -lfiniteVolume -L/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam -lwaves2FoamProcessing -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl  \
         -lm -o /home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/bin/postProcessWaves2Foam
    /usr/bin/ld: 找不到 -lwaves2FoamProcessing: 没有那个文件或目录
    make: *** [/home/dyfluid/OpenFOAM/OpenFOAM-v1912/wmake/makefiles/general:143:/home/dyfluid/OpenFOAM/dyfluid-v1912/platforms/linux64GccDPInt32Opt/bin/postProcessWaves2Foam] 错误 1
        COMPILE BREEDER
    Nothing available for compilation in the breeder
    directory.
        COMPILATION DONE
    看起来跟上次存在同样的一个问题,Nothing available for compilation in the breeder directory.,不知道这个是否是编译失败的主要问题呢,还是有其他问题导致的呢
    B 1 条回复 最后回复
    @peiyiii_
    你的机器没有装fortran
    P 1 条回复 最后回复
  • P 离线
    P 离线
    peiyiii_
    @李东岳 李老师好,
    我用命令查找
    find /usr/lib /usr/local/lib -name "libgfortran.so*"
    dyfluid@dyfluid-virtual-machine:~/OpenFOAM/dyfluid-v1912/applications/utilities/waves2Foam$ find /usr/lib /usr/local/lib -name "libgfortran.so*"
    /usr/lib/x86_64-linux-gnu/libgfortran.so.5
    /usr/lib/x86_64-linux-gnu/libgfortran.so.5.0.0
    /usr/lib/x86_64-linux-gnu/libgfortran.so.3
    /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
    /usr/lib/gcc/x86_64-linux-gnu/9/libgfortran.so
    /usr/lib/gcc/x86_64-linux-gnu/4.7/libgfortran.so
    /usr/lib/gcc/x86_64-linux-gnu/11/libgfortran.so
    看起来系统中已经安装了多个版本的 libgfortran,但是链接错误提示 ld 找不到该库。
    为了让编译器找到 libgfortran,我将其所在目录添加到 LD_LIBRARY_PATH 环境变量中。
    export LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu:$LD_LIBRARY_PATH
    输出的结果并没有任何区别.....
    那应该是你的wave2foam没有找到libfortran
  • B 离线
    B 离线
    bike-北辰
    @peiyiii_ emmmm,也不是都删掉,你参考一下这个试试吧https://blog.csdn.net/Killig_1/article/details/135386466
    chenboyao
    还有一个问题,就是你编译的时候,在ThirdParty/settings/ 里边的三个文件中都包含这个语句-fallow-argument-mismatch,你只需要把这三个对应的setting里边这段话找到删除就行,这一段话我没记错的话是前面这个waves2Foam作者添加进去的,我以前23年时编译waves2Foam的时候是没有这个语句的,而在24年11月底我重新编译的时候就会报错,说找不到gfortran,但是电脑又很多的版本的gfortran。后面我重新查找waves2Foam的代码,发现了这一行语句以前是没有的,而现在添加进去了,后面删除了就可以编译成功了。
    因此,你的解决方案最好是把ThirdParty/settings/ 里边的三个文件中都包含这个语句-fallow-argument-mismatch这一段话删除就行。
    P 1 条回复 最后回复
  • P 离线
    P 离线
    peiyiii_
    在 中回复了 chenboyao 最后由 编辑
    @chenboyao 老师您好,我检查了一遍,我三个文件里都没有这行代码,重新编译也还是不行:143:
    chenboyao
    @peiyiii_ 你编译的输出结果能展示展示吗
    lizhisongsjtu
    https://www.cfd-china.com/topic/7301/waves2foam的一键安装解决方案?_=1738765131135
