  2. Meshy
  3. pointwise输出二维网格到openfoam无法计算
已定时 已固定 已锁定 已移动 Meshy
4 帖子 4 发布者 4.7k 浏览
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    大家好,我用pointwise输出了一个翼型的网格,使用checkMesh检查没有错误
    Mesh stats
        internal points:  0
        faces:            56210
        internal faces:   27874
        cells:            14014
        faces per cell:   6
        boundary patches: 3
        point zones:      0
        face zones:       0
        cell zones:       0
        hexahedra:     14014
        prisms:        0
        wedges:        0
        pyramids:      0
        tet wedges:    0
        tetrahedra:    0
        polyhedra:     0
    Checking topology...
        Boundary definition OK.
        Cell to face addressing OK.
        Point usage OK.
        Upper triangular ordering OK.
        Face vertices OK.
        Number of regions: 1 (OK).
        airFoil2D           154      308      ok (non-closed singly connected)
        farfield            154      308      ok (non-closed singly connected)
        frontAndBack        28028    28336    ok (non-closed singly connected)
    Checking geometry...
        Overall domain bounding box (-4.99867 -5.67032 0) (6.78888 5.66637 3)
        Mesh (non-empty, non-wedge) directions (1 1 0)
        Mesh (non-empty) directions (1 1 0)
        All edges aligned with or perpendicular to non-empty directions.
        Boundary openness (-1.85094e-17 2.46792e-17 -2.22841e-16) OK.
        Max cell openness = 4.12267e-15 OK.
        Max aspect ratio = 170.167 OK.
        Minimum face area = 4.43442e-08. Maximum face area = 1.67744.  Face area magnitudes OK.
        Min volume = 1.33032e-07. Max volume = 0.378026.  Total volume = 313.461.  Cell volumes OK.
        Mesh non-orthogonality Max: 17.8429 average: 1.07748
        Non-orthogonality check OK.
        Face pyramids OK.
        Max skewness = 1.9585 OK.
    Mesh OK.
    End
    我用paraFoam打开也没有问题
    但使用simpleFoam运算就会出现问题:
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 156.2, No Iterations 1000
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 4.72215, No Iterations 1000
    GAMG:  Solving for p, Initial residual = 1, Final residual = 2.66928e+147, No Iterations 1000
    time step continuity errors : sum local = 1.37947e+146, global = 9.17194e+129, cumulative = 9.17194e+129
    #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
    #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    #5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    #6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    #7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    #8  Foam::fvMatrix<double>::solve() at ??:?
    #9  Foam::incompressible::RASModels::SpalartAllmaras::correct() at ??:?
    #10  ? at ??:?
    #11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #12  ? at ??:?
    Floating point exception (core dumped)
    我用Construct2D或者snappyHexmesh生成的网格却没有问题,说明求解器设置没有问题,所以错误出自哪里呢?
    谢谢各位!
    这个边界条件设置的有问题,速度压力都没收敛
    zzcfd
    最后解决了吗。我现在还是会遇到这个问题,改变了边界条件还是这样的计算结果。
    Create time
    Create mesh for time = 0
    SIMPLE: convergence criteria
        field p	 tolerance 1e-05
        field U	 tolerance 1e-05
        field nuTilda	 tolerance 1e-05
    Reading field p
    Reading field U
    Selecting turbulence model type RAS
    Selecting RAS turbulence model SpalartAllmaras
    Selecting patchDistMethod meshWave
    RAS
        RASModel        SpalartAllmaras;
        turbulence      on;
        printCoeffs     on;
        sigmaNut        0.666667;
        kappa           0.41;
        Cb1             0.1355;
        Cb2             0.622;
        Cw2             0.3;
        Cw3             2;
        Cv1             7.1;
        Cs              0.3;
    No MRF models present
    Starting time loop
    momentumError momErr:
    turbulenceFields turbulenceFields1: storing fields:
        turbulenceProperties:nut
        turbulenceProperties:nuEff
        turbulenceProperties:k
        turbulenceProperties:R
        turbulenceProperties:I
        turbulenceProperties:L
        turbulenceProperties:devReff
        turbulenceProperties:epsilon
    Time = 0.01
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.00113906, No Iterations 2
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.402392, No Iterations 1000
    #2  ? in /lib/x86_64-linux-gnu/libc.so.6
    #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
    #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    #7  Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
    #8  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:?
    #9  Foam::fvMatrix<double>::solve() in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/simpleFoam
    #10  ? in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/simpleFoam
    #11  ? in /lib/x86_64-linux-gnu/libc.so.6
    #12  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #13  ? in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/simpleFoam
    浮点异常 (核心已转储)
  • A 在线
    A 在线
    Afr1yne
    在 中回复了 zzcfd 最后由 编辑
    @zzcfd 改fvSolution,把p改成这个solver PCG; preconditioner DIC;试试
