  3. FLuent与OpenFOAM中关于压力限制的区别
20 帖子 2 发布者 3.5k 浏览
  • 打 在线
    打 在线
    打倒小怪兽
    写于 最后由 打倒小怪兽 编辑
    使用compressibleInterFoam计算气泡动力学问题的时候经常会出现液体内的绝对负压,pMin的作用如:https://www.cfd-online.com/Forums/openfoam-solving/218998-influence-pmin-compressibleinterfoam-oscillatory-pressure-boundary.html
    所说,
    是防止出现基于气体状态方程计算密度时不能出现绝对负压导致的负密度,但是在液体中一定的绝对负压是被允许的。
    fluent中在solution limit有关于pressure-limit的设置,但是根据:https://innovationspace.ansys.com/knowledge/forums/topic/how-does-ansys-fluent-handle-negative-absolute-pressure-for-compressible-multiphase-cases/
    中描述的,限制压力只作用于计算材料属性时将其限制为pMin,而正常流场中绝对负压并不作约束。在OpenFOAM中,像是为了限制pMin而将整个流场的压力值全部截断到pMin。
    现在我想通过把涉及到pMin的文件中相关语句注释掉,来消除pMin的影响。在OpenFOAM-9文件夹中使用grep -r pMin得到如下文件
    src/twoPhaseModels/twoPhaseMixture/MPLIC/MPLICcell.C:    const scalar pMin = cmptMin(pCubicAlphas_);
    src/twoPhaseModels/twoPhaseMixture/MPLIC/MPLICcell.C:        if (root < pMax && root > pMin && rootOld != root)
    src/sampling/meshToMesh/calcMethod/meshToMeshMethod/meshToMeshMethod.C:    return overlapEngine.cellCellOverlapMinDecomp
    src/finiteVolume/cfdTools/general/pressureReference/pressureReference.C:        dict.found("pMin")
    src/finiteVolume/cfdTools/general/pressureReference/pressureReference.C:     || dict.found("pMinFactor")
    src/finiteVolume/cfdTools/general/pressureReference/pressureReference.C:        if (dict.found("pMin"))
    src/finiteVolume/cfdTools/general/pressureReference/pressureReference.C:                << "    min        " << dict.lookup<scalar>("pMin")
    src/finiteVolume/cfdTools/general/pressureReference/pressureReference.C:        if (dict.found("pMinFactor"))
    src/finiteVolume/cfdTools/general/pressureReference/pressureReference.C:                << "    minFactor  " << dict.lookup<scalar>("pMinFactor")
    src/meshTools/tetOverlapVolume/tetOverlapVolume.C:bool Foam::tetOverlapVolume::cellCellOverlapMinDecomp
    src/meshTools/tetOverlapVolume/tetOverlapVolume.H:        bool cellCellOverlapMinDecomp
    src/meshTools/edgeFaceCirculator/edgeFaceCirculatorI.H:        label fpMin1 = f.rcIndex(fp);
    src/meshTools/edgeFaceCirculator/edgeFaceCirculatorI.H:        if (f[fpMin1] == v1)
    src/meshTools/edgeFaceCirculator/edgeFaceCirculatorI.H:            fp = fpMin1;
    src/dynamicMesh/polyTopoChange/polyTopoChange/hexRef8/hexRef8.C:                label fpMin1 = f.rcIndex(fp0);
    src/dynamicMesh/polyTopoChange/polyTopoChange/hexRef8/hexRef8.C:                if (pointLevel_[f[fpMin1]] <= cLevel)
    src/dynamicMesh/polyTopoChange/polyTopoChange/hexRef8/hexRef8.C:                    label edgeI = fEdges[fpMin1];
    src/dynamicMesh/polyTopoChange/polyTopoChange/hexRef8/hexRef8.C:                        fpMin1,
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:        label fpMin1 = fpA;
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:        label fp = f.fcIndex(fpMin1);
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:            // See where fp sorts. Make sure it is above fpMin1!
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:            if (w <= dist[fpMin1])
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:                w = dist[fpMin1] + 1e-6*(dist[fpB] - dist[fpA]);
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:            fpMin1 = fp;
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:            fp = f.fcIndex(fpMin1);
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:        fpMin1 = fpA;
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:        fp = f.rcIndex(fpMin1);
    src/dynamicMesh/polyTopoChange/polyTopoChange/faceCollapser.C:            // See where fp sorts. Make sure it is below fpMin1!
    src/lagrangian/molecularDynamics/potential/tetherPotential/derived/pitchForkRing/pitchForkRing.C:    scalar pMinusRSqr = sqr(p - rOrbit_);
    src/lagrangian/molecularDynamics/potential/tetherPotential/derived/pitchForkRing/pitchForkRing.C:       -0.5 * mu_ * pMinusRSqr
    src/lagrangian/molecularDynamics/potential/tetherPotential/derived/pitchForkRing/pitchForkRing.C:      + 0.25 * pMinusRSqr * pMinusRSqr
    src/lagrangian/molecularDynamics/potential/tetherPotential/derived/pitchForkRing/pitchForkRing.C:    scalar pMinusR = (p - rOrbit_);
    src/lagrangian/molecularDynamics/potential/tetherPotential/derived/pitchForkRing/pitchForkRing.C:        (mu_ - sqr(pMinusR)) * pMinusR * r.x()/(p + vSmall),
    src/lagrangian/molecularDynamics/potential/tetherPotential/derived/pitchForkRing/pitchForkRing.C:        (mu_ - sqr(pMinusR)) * pMinusR * r.y()/(p + vSmall),
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcel.H:            demandDrivenEntry<scalar> pMin_;
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcel.H:            inline scalar pMin() const;
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcel.C:    if (td.pc() < cloud.constProps().pMin())
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcel.C:                << " to " << cloud.constProps().pMin() <<  nl << endl;
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcel.C:        td.pc() = cloud.constProps().pMin();
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcelI.H:    pMin_(this->dict_, 0.0),
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcelI.H:    pMin_(cp.pMin_),
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcelI.H:    pMin_(this->dict_, "pMin", 1000.0),
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcelI.H:Foam::ReactingParcel<ParcelType>::constantProperties::pMin() const
    src/lagrangian/parcel/parcels/Templates/ReactingParcel/ReactingParcelI.H:    return pMin_.value();
    src/lagrangian/parcel/parcels/Templates/SprayParcel/SprayParcel.H:                const scalar pMin,
    src/lagrangian/parcel/parcels/Templates/SprayParcel/SprayParcelI.H:    const scalar pMin,
    src/lagrangian/parcel/parcels/Templates/SprayParcel/SprayParcelI.H:        pMin,
    src/OpenFOAM/meshes/primitiveMesh/primitiveMeshCheck/primitiveMeshCheck.C:                    label fpMin1  = curFace.rcIndex(fp);
    src/OpenFOAM/meshes/primitiveMesh/primitiveMeshCheck/primitiveMeshCheck.C:                    else if (nbFace[nbPlus1] == curFace[fpMin1])
    src/OpenFOAM/meshes/primitiveMesh/primitiveMeshCheck/primitiveMeshCheck.C:                    else if (nbFace[nbMin1] == curFace[fpMin1])
    src/fvConstraints/limitPressure/limitPressure.H:        dimensionedScalar pMin_;
    src/fvConstraints/limitPressure/limitPressure.C:        pMin_.value() = dict.lookup<scalar>("min");
    src/fvConstraints/limitPressure/limitPressure.C:        scalar pMin = vGreat;
    src/fvConstraints/limitPressure/limitPressure.C:                pMin = min(pMin, min(pbf[patchi]));
    src/fvConstraints/limitPressure/limitPressure.C:            reduce(pMin, minOp<scalar>());
    src/fvConstraints/limitPressure/limitPressure.C:            const scalar pMinFactor(dict.lookup<scalar>("minFactor"));
    src/fvConstraints/limitPressure/limitPressure.C:            pMin_.value() = pMinFactor*pMin;
    src/fvConstraints/limitPressure/limitPressure.C:            Info<< "    min " << pMin_.value() << nl;
    src/fvConstraints/limitPressure/limitPressure.C:    pMin_("pMin", dimPressure, 0),
    src/fvConstraints/limitPressure/limitPressure.C:            const scalar pMin = min(p).value();
    src/fvConstraints/limitPressure/limitPressure.C:            if (pMin < pMin_.value())
    src/fvConstraints/limitPressure/limitPressure.C:                Info<< "limitPressure: p min " << pMin << endl;
    src/fvConstraints/limitPressure/limitPressure.C:                p = min(p, pMin_);
    applications/solvers/multiphase/compressibleInterFoam/pEqn.H:            p = min(p_rgh + (alpha1*rho1 + alpha2*rho2)*gh, pMin);
    applications/solvers/multiphase/compressibleInterFoam/createFields.H:dimensionedScalar pMin
    applications/solvers/multiphase/compressibleInterFoam/createFields.H:    "pMin",
    applications/solvers/multiphase/compressibleMultiphaseInterFoam/pEqn.H:            p = max(p_rgh + mixture.rho()*gh, pMin);
    applications/solvers/multiphase/compressibleMultiphaseInterFoam/createFields.H:dimensionedScalar pMin("pMin", dimPressure, mixture);
    applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam/createFields.H:if (fluid.found("pMin"))
    applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam/createFields.H:        << "Pressure limits, pMin and pMax, are now read from "
    applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/diameterModels/velocityGroup/sizeGroup/shapeModels/fractal/sinteringModels/KochFriedlander/KochFriedlander.C:    dpMin_(dict_.lookupOrDefault<scalar>("dpMin", 0))
    applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/diameterModels/velocityGroup/sizeGroup/shapeModels/fractal/sinteringModels/KochFriedlander/KochFriedlander.C:            Cs_*pow(dp, n_)*pow(T[celli], m_)*exp(Ta_/T[celli]*(1 - dpMin_/dp));
    applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/diameterModels/velocityGroup/sizeGroup/shapeModels/fractal/sinteringModels/KochFriedlander/KochFriedlander.H:        dpMin    | Minimum primary particle diameter | no   | 0
    applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/diameterModels/velocityGroup/sizeGroup/shapeModels/fractal/sinteringModels/KochFriedlander/KochFriedlander.H:        scalar dpMin_;
    tutorials/multiphase/compressibleInterFoam/laminar/plateFilm/constant/thermophysicalProperties:pMin        10000;
    tutorials/multiphase/compressibleInterFoam/laminar/cylinder/constant/thermophysicalProperties:pMin        10000;
    tutorials/multiphase/compressibleInterFoam/laminar/sloshingTank2D/constant/thermophysicalProperties:pMin            1000;
    tutorials/multiphase/compressibleInterFoam/laminar/depthCharge2D/constant/thermophysicalProperties:pMin        10000;
    tutorials/multiphase/compressibleInterFoam/laminar/climbingRod/constant/thermophysicalProperties:pMin        10000;
    tutorials/multiphase/compressibleInterFoam/laminar/depthCharge3D/constant/thermophysicalProperties:pMin        10000;
    tutorials/multiphase/compressibleMultiphaseInterFoam/laminar/damBreak4phase/constant/thermophysicalProperties:pMin            10000;
    tutorials/multiphase/multiphaseEulerFoam/laminar/mixerVesselAMI2D/constant/phasePropertiesAll:pMin            10000;
    grep: platforms/linux64GccDPInt32Opt/bin/compressibleInterFoam: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/bin/compressibleMultiphaseInterFoam: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/src/sampling/meshToMesh/calcMethod/meshToMeshMethod/meshToMeshMethod.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/src/finiteVolume/cfdTools/general/pressureReference/pressureReference.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/src/meshTools/tetOverlapVolume/tetOverlapVolume.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/src/lagrangian/parcel/clouds/derived/sprayCloud/sprayCloud.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/src/lagrangian/parcel/clouds/derived/reactingMultiphaseCloud/reactingMultiphaseCloud.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/src/lagrangian/parcel/clouds/derived/reactingCloud/reactingCloud.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/src/fvConstraints/limitPressure/limitPressure.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/compressibleInterFoam/compressibleInterFoam.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/compressibleMultiphaseInterFoam/compressibleMultiphaseInterFoam.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam/multiphaseEulerFoam.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/diameterModels/velocityGroup/sizeGroup/shapeModels/fractal/sinteringModels/KochFriedlander/KochFriedlander.o: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/lib/libphaseSystem.so: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/lib/libsampling.so: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/lib/libfvConstraints.so: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/lib/liblagrangianParcel.so: 匹配到二进制文件
    grep: platforms/linux64GccDPInt32Opt/lib/libmeshTools.so: 匹配到二进制文件
    etc/templates/compressibleInflowOutflow/system/fvSolution:    pMinFactor      0.1;
    etc/templates/singleFluidCHT/templates/system/fluid/fvSolution://    pMinFactor      0.1;
    其中相关的文件应该只有
    而pressureReference这一文件的作用应该是识别pMin并将其指向fvConstraints的,我只更改了pEqn和limitPressure这两个文件,将其中pMin的语句注释掉。
    但是同样的算例文件,更改前能够计算,更改后迭代几个计算步后就会报负温度停止计算。
    求助,第一次尝试更改求解器,担心是不是有其他相关的文件没有更改?我这个思路有没有问题?如果我想消除pMin的限制,应该怎么做,我希望的是能够在OpenFOAM实现与fluent相同的处理方式,而不是直接将最终结果也直接截断。
    在液体中一定的绝对负压是被允许的
    这个怎么理解
    打 1 条回复 最后回复
  • 打 在线
    打 在线
    打倒小怪兽
    @李东岳 李老师感谢您的及时回复
    在OpenFOAM中液体属性的adiabaticPerfectFluid模型,使用的是Tait状态方程这个模型
    其中B的值通过实验测得为3e8,在这种情况下如果绝对负压不超过B的值,就不会出现负密度,这样应该也不会影响到计算吧?我不知道这样理解对不对
    也有相关领域的液相绝对负压的文献:CAUPIN, F. & HERBERT, E. 2006 Cavitation in water: a review. C. R. Phys. 7 (9–10), 1000–1017.
    openfoam的adiabaticPerfectFluid模型,是更新密度的,跟你写的不一样。你确认一下,openfoam中的adiabaticPerfectFluid模型在压力为负的时候,密度可以是正的么
    打 1 条回复 最后回复
    我第一次看到负压的讨论,值得深入研究一下
  • 打 在线
    打 在线
    打倒小怪兽
    @李东岳 老师,这是of2312版本中的adiabaticPerfectFluid公式
    我上面给出的公式里面,V表示的是1/ρ,这两个公式应该是一样的。
    那个密度公式,不会出现负的密度。
    不过p倒是允许出现一定的负值,看起来没做限制,但要保证密度不是负值。
    你得问题是什么?OpenFOAM里面的pMin的作用么?
    打 1 条回复 最后回复
  • 打 在线
    打 在线
    打倒小怪兽
    @李东岳 老师,我现在在尝试取消pMin对流场压力的限制,来达到允许流场出现绝对负压的计算结果。
    想请教一下老师您,如果我想消除pMin的限制,下面两个方法是否可行?如果思路没问题的话,您觉得有没有可能是存在其他关联文件没有修改的缘故导致的报错?或者,您能花时间指点一下,如何修改求解器来取消pMin限制?
    目前我尝试了两种方法:
    • 直接将compressibleInterFoam求解器文件夹中的压力文件中,将关于pMin的语句直接注释掉的方法(同时在createField中取消pMin的声明),但是重新编译后的求解器运行修改前能正常计算的算例会很快报错(大概三四个时间步)——这个方法不知道该如何再继续推进下去了
    • OpenFOAM-11中是通过fvConstrains-limitPressure来限制压力的,我对这个文件对压力的语句也进行了修改——将max(p,pMin),改为min(p,pMin),然后提供一个巨大的pMin值(1e12)。这样应该也能消除压力下限的限制,但算例的结果也会发现压力和温度计算有问题。
    那个文章里面说确实可以存在负压。但是不表明OpenFOAM允许负压的存在。你把pMin取消掉,存在很大的风险。
    打 1 条回复 最后回复
  • 打 在线
    打 在线
    打倒小怪兽
    @李东岳 老师,我还有一个疑问,pMin的值可以设置为负值吗?会有文件对pMin的值必须为非负值的限制吗?
    这样是否可以避免直接取消pMin带来的风险?
    在你提到那个绝对负压之前,我从来没见过设置为负值的压力。从状态方程来看,基于可压缩性的算法psiThermo,p是负值是完全不可能的。rhoThermo中p和rho的关系可能更复杂,比如绝热理想液体,可能一个负的压力可以预测一个正的速度。但是听起来基本挑战之前的CFD数值常识。
    你要想尝试绝热理想液体能否允许负压的存在,你需要做个算例做个测试。比如rhoPimpleFoam算一个特别简单的算例。
    打 1 条回复 最后回复
  • 打 在线
    打 在线
    打倒小怪兽
    @李东岳 好的,谢谢老师指点迷津,我再自己研究一下。
    刚刚尝试了一下,相同的算例使用compressibleInterFoam求解器计算,将pMin值设置为负值后很快就会报错负温度。看来不能简单的直接设置为负
    是。对于理想气体,负的温度、压力、密度都不合理。不过你那个绝热理想液体,在p为负的时候,密度确实为正。在结合那个review说的绝对负压的存在,应该需要详细研究下。
    不过如果没看到那个review,过去10多年我一直以为绝对压力一直为正。需要好好看看这个。
    我在无痛苦ns方程笔记里面更新了密度、温度的更新流程,应该有点关系
    打 1 条回复 最后回复
  • 打 在线
    打 在线
    打倒小怪兽
    @李东岳 好的,李老师,我去看一下。
    我最近看了一下foam-extend版本的compressibleInterFoam求解器,没有耦合温度方程。他直接在pEqn.H文件里面给出的压力、密度的闭合方程——ρ=psi*p,如果是弱可压缩性的计算,是不是影响不大?也可以用来计算弱可压两相流动?
    是的,强弱都可以,你可以试试,那个不会出现负温度。
    https://cfd-china.com/topic/677/fluent-空化两相流数值模拟结果绝对压力为负值
    这个帖子的绝对压力,fluent那面确实出现了负值。
    我对负的绝对压力,目前理论上理解不上去。不过也没时间详细看了。我先看看能不能把org那面的compressibleInterFoam的能量方程去掉
    打 1 条回复 最后回复
  • 打 在线
    打 在线
    打倒小怪兽
    @李东岳 是的,李老师。
    我在使用Fluent计算相同设置的算例时,层流模型、没开能量方程、液体属性设置为可压缩流体。也会出现绝对负压(背压101325Pa,Solution中的限制压力1Pa),流场中会出现几倍于大气压的负值。
    如果针对这个问题,在OpenFOAM中去掉能量方程的计算应该会稳定很多。不过,我能力有限,对org版本thermo那块复杂的,我看起来还很吃力,李老师辛苦研究一下!
    foam-extend的compressibleInterFoam本身就没耦合能量方程,但是他的液体状态方程也没有Tait方程的形式,这两天我把这个方程整进去了,计算tut算例没啥问题,但是算我那个算例就发散,可能稳定性还是有点问题,还需要再调试一下。
    我用rhoPimpleFoam、rhoSimpleFoam测试了一下,直接把EEqn.H注释掉就好了。你试一下。在新版OpenFOAM中,原本的fluid模块,替换成isothermalFluid,等同于上面的效果。不过我测试NACA算例,注释掉能量方程之后收敛性比较差。流场结果出来倒是没有问题。
    你试一下直接把compressibleInterFoam的TEqn.H注释掉
    打 1 条回复 最后回复
  • 打 在线
    打 在线
    打倒小怪兽
    @李东岳 老师我尝试了一下将温度注释掉应该就可以了,不过也如您所说,注释掉能量方程后收敛性不是很好,可能要提高很多精度来计算,我再调试一下。
    感谢李老师热心指导
