  3. 有关calculatedFvPatchField
6 帖子 3 发布者 6.1k 浏览
    某同学来信的错误代码如下:
    Starting time loop
    Courant Number mean: 0 max: 0
    Time = 0.01
    time:0.01 curMotionVel_:(0.001 0 0) curLeft:0.099 curRight:0.1
    No topology change
    Executing mesh motion
    GAMG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
    time step continuity errors : sum local = 0, global = 0, cumulative = 0
    PIMPLE: iteration 1
    DILUPBiCGStab:  Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
    DILUPBiCGStab:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
    --> FOAM FATAL ERROR:
    cannot be called for a calculatedFvPatchField
        on patch bottom of field p in file "/home/sh/OpenFOAM/sh-5.0/run/171109DyM/HH/0/p"
        You are probably trying to solve for a field with a default boundary condition.
        From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = double]
        in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187.
    FOAM aborting
    #2  Foam::calculatedFvPatchField<double>::gradientInternalCoeffs() const at ??:?
    #3  Foam::fv::gaussLaplacianScheme<double, Foam::SymmTensor<double> >::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    #4  Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    #5  Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    #6  Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) at ??:?
    #7  Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    #8  ? at ??:?
    #9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #10  ? at ??:?
    已放弃 (核心已转储)
    原因在于你在求解p压力场,因此你不能给定calculatedFvPatchField边界条件。
  • 北 离线
    北 离线
    北山木鱼
    东岳老师您好:
    上述问题您能再展开说一下嘛?我再求解rho1时遇到了相同的问题。
    在 中回复了 北山木鱼 最后由 编辑
    @北山木鱼 如果存在变量的Eqn需要solve,就不能调用calculated边界条件。不好意思刚看到:136:
    北 1 条回复 最后回复
  • 马乔马 离线
    马乔马 离线
    马乔 大神
    valueInternalCoeffs, valueBoundaryCoeffs, gradientInternalCoeffs, gradientBoundaryCoeffs are all key coeffs for boundary correct.
    In calculatedFvPatchField, those are all:
    tmp<Field<Type> > calculatedFvPatchField<Type>::valueInternalCoeffs
        const tmp<scalarField>&
    ) const
        FatalErrorIn
            "calculatedFvPatchField<Type>::"
            "valueInternalCoeffs(const tmp<scalarField>&) const"
        )   << "\n    "
    when construct convection tern
    fvm.internalCoeffs()[patchI] = patchFlux*psf.valueInternalCoeffs(pw);
    fvm.boundaryCoeffs()[patchI] = -patchFlux*psf.valueBoundaryCoeffs(pw);
    and laplacian term
    fvm.internalCoeffs()[patchI] = patchGamma*psf.gradientInternalCoeffs();
    fvm.boundaryCoeffs()[patchI] = -patchGamma*psf.gradientBoundaryCoeffs();
    so...
    装逼没输过,吵架没赢过!
    Thanks for sharing
  • 北 离线
    北 离线
    北山木鱼
    @东岳 好的东岳老师,谢谢东岳老师,实在不好意思,上次断网没发出去刚发现。
