B
buaa_hgj
@buaa_hgj
  • FsiFoam并行问题
    B buaa_hgj
    @炎冰灬灬 我没有使用过foam-extend 3.2 ,foam-extend4.0并行计算的方式与其他版本的openfoam设置相同
  • TopoSet关于action的疑问
    B buaa_hgj
    @D-Benjamin 求交集的意思
  • 怎么用paraview画出streamlines inside bubble?
    B buaa_hgj
    @CYW http://xiaopingqiu.github.io/2016/08/27/ParaviewStreamLineOnSlice/
    不知道这个对你有没有帮助
  • OpenFOAM中SliceData输出的不同时间步上的切面vtk场如何统一做成动画?
    B buaa_hgj
    @aiweimo
    1、vtk文件一些命名方式可以被paraview自动识别为不同时刻的数据,比如,a1.vtk a2.vtk a3.vtk
    所以你把这些vtk文件命名成这种形式然后用paraview读入就可以输出视频了
    2、怎么将这些vtk文件的名称改成这种形式,写个脚本根据文件夹的名称修改该文件夹下vtk文件的名称
    B buaa_hgj
    现在你有了一系列vtk文件然后输出视频是吗?
  • OpenFOAMv1806跨节点计算出错
    B buaa_hgj
    软件版本:openfoam-v1806
    硬件信息:超算(x86_64架构)
    系统:centos 6.6
    问题描述:openfoam编译完成后在登录结点串行并行计算都无报错,但是通过bsub命令提交任务计算出现下面的报错:
    [m5605:28439] Signal: Segmentation fault (11)
    [m5605:28439] Signal code: Address not mapped (1)
    [m5605:28439] Failing at address: 0x29c38a0
    [m5605:28442] [ 0] /lib64/libc.so.6(+0x326a0)[0x2b582a1406a0]
    [m5605:28442] [ 1] /home/daiyut/tools/openmpi215/lib/openmpi/mca_btl_openib.so(+0xf380)[0x2b583afbf380]
    [m5605:28442] [ 2] /home/daiyut/tools/openmpi215/lib/libopen-pal.so.20(mca_btl_base_select+0x156)[0x2b582b7370f6]
    [m5605:28442] [ 3] /home/daiyut/tools/openmpi215/lib/openmpi/mca_bml_r2.so(mca_bml_r2_component_init+0x11)[0x2b583adaf251]
    [m5605:28442] [ 4] /home/daiyut/tools/openmpi215/lib/libmpi.so.20(mca_bml_base_init+0x7c)[0x2b582aefc0ec]
    [m5605:28442] [ 5] /home/daiyut/tools/openmpi215/lib/libmpi.so.20(ompi_mpi_init+0x3ad)[0x2b582aebf59d]
    [m5605:28442] [ 6] /home/daiyut/tools/openmpi215/lib/libmpi.so.20(MPI_Init_thread+0x46)[0x2b582aede3f6]
    [m5605:28442] [ 7] /home/daiyut/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x67)[0x2b582a4a90c7]
    [m5605:28442] [ 8] /home/daiyut/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x67c)[0x2b5828e2489c]
    [m5605:28442] [ 9] icoFoam[0x453149]
    [m5605:28442] [10] /lib64/libc.so.6(__libc_start_main+0xfd)[0x2b582a12cd5d]
    [m5605:28442] [11] icoFoam[0x41c6c9]
    [m5605:28442] *** End of error message ***
    请问有前辈知道这个是什么原因造成的吗?以及有什么解决办法吗?
  • 三维大变形问题用fluent动网格计算是否合适
    B buaa_hgj
    @渤文 您好,问一下如果做流固耦合结构会发生很大的柔性变形可以使用overset计算吗?我找到的overset的算例基本上结构都是刚体运动。
  • 求助如何在HPC Cluster上安装OF5.0
    B buaa_hgj
    (1)应该可以在自己的用户文件夹中进行编译,etc/bashrc里面的安装路径最好改一下,免得和原来的冲突;
    (2)icc也可以成功编译openfoam,之前用gcc编译openfoam3.0的时候,gcc编译openfoam的源码编译不成功(可能是gcc版本太低吧),就用icc替代了gcc;
    (3)感觉主要注意一下环境变量的配置。
  • 超算平台上多版本编译OF,串行无误并行出错?
    B buaa_hgj
    @aiweimo 非常感谢。
    B buaa_hgj
    @aiweimo 您好,请问怎么在red hat系统的超算平台上编译foam-extend-4.0,是否方便分享一些参考资料或者经验?
  • FsiFoam并行问题
    B buaa_hgj
    @影川风 已加QQ好友
  • FsiFoam并行问题
    B buaa_hgj
    @影川风 foam-extend-4.0目前是可以使用并行的,这个错误是计算了一段时间之后出现的。
  • FsiFoam并行问题
    B buaa_hgj
    在使用fsifoam并行计算二维流固耦合问题时,计算一段时间后就会出现如下图所示的报错:
    [14] --> FOAM FATAL ERROR:
    [14] Some processors detect different empty (2-D) directions.  Probably using empty patches on a bad parallel decomposition.
    Please check your geometry and empty patches
    [14]
    [14]     From function void polyMesh::calcDirections() const
    [14]     in file meshes/polyMesh/polyMesh.C at line 101.
    [14]
    FOAM parallel run aborting
    各位大佬,有遇到这种问题的吗?报错中的不同的empty方向是什么意思?
