<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[浮点数例外（核心已转储） 问题]]></title><description><![CDATA[<p dir="auto">先对路过的大佬表示下感谢！在运行overOlaDyMFlow时没一会就出现了如下问题，看了网上的大部分解答，也没清楚自己的原因在哪，</p>
<pre><code>PIMPLE: Operating solver in PISO mode
Reading field porosityIndex
Porosity NOT activated
Reading field p_rgh
Reading field U
Creating cellMask field to block out hole cells
Creating interpolatedCells field
Reading transportProperties
RAS
    RASModel        kOmegaSST;
    turbulence      on;
    printCoeffs     on;
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555555555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
    decayControl    false;
    kInf            0;
    omegaInf        0;
Reading g
Reading hRef
Calculating field g.h
No MRF models present
DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Reading/calculating face velocity Uf
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 1.19997600048e-05
Time = 1.19998e-05
PIMPLE: iteration 1
forces forces:
--&gt; FOAM Warning :
    From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList&lt;Foam::wordRe&gt;&amp;, bool, bool) const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 868
    Cannot find any patch or group names matching floatingObject
    rho: rho
6-DoF rigid body motion
    Centre of rotation: (2 0.5 0.999999999647)
    Centre of mass: (2 0.5 0.999999999647)
    Orientation: (1 0 0 0 1 0 0 0 1)
    Linear velocity: (0 0 -5.88588228235e-05)
    Angular velocity: (0 0 0)
inverseDistance : detected 1 mesh regions
    zone:0 nCells:2096472  voxels:(127 127 127) bb:(-4.472135955e-06 -0.100004472136 -4.472135955e-06) (4.00000447214 1.10000447214 1.60000447214)
Overset analysis : nCells : 2096472
    calculated   : 1800000
    interpolated : 0 (interpolated from local:0  mixed local/remote:0  remote:0)
    hole         : 296472
Execution time for mesh.update() = 7.21 s
smoothSolver:  Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 0
Phase-1 volume fraction = 0  Min(alpha.water) = 0  Max(alpha.water) = 0
MULES: Correcting alpha.water
alpha.water BC on patch inlet
#0  Foam::error::printStack(Foam::Ostream&amp;) addr2line failed
#1  Foam::sigFpe::sigHandler(int) addr2line failed
#2  ? addr2line failed
#3  StokesIFun::waveLength(double, double) addr2line failed
#4  Foam::waveAlphaFvPatchScalarField::updateCoeffs() addr2line failed
#5  Foam::GeometricField&lt;double, Foam::fvPatchField, Foam::volMesh&gt;::Boundary::evaluate()
#6  ?
#7  ?
#8  ?
#9  __libc_start_main addr2line failed
#10  ?
浮点数例外 (核心已转储)
</code></pre>
<p dir="auto">此前还存有一个warning</p>
<pre><code>--&gt; FOAM Warning :
</code></pre>
<p dir="auto">不知道是否对求解造成了影响</p>
]]></description><link>https://cfd-china.com/topic/3130/浮点数例外-核心已转储-问题</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 02:24:15 GMT</lastBuildDate><atom:link href="https://cfd-china.com/topic/3130.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Nov 2019 07:02:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 浮点数例外（核心已转储） 问题 on Fri, 22 Nov 2019 11:27:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://cfd-china.com/uid/2864">@一颗鸭蛋</a> 谢谢你的回答，我用的重叠网格，贴体网格和背景网格的长宽都是1:1且一样大，然后就不知道问题出在哪里了<img src="https://cfd-china.com/assets/plugins/nodebb-plugin-emoji/emoji/customizations/3bb52208-0334-4a4f-b00b-10af7f80b44a-6f9587ea79464fd653058d977c355d76.png?v=eedi85amb0g" class="not-responsive emoji emoji-customizations emoji--zoule" style="height:23px;width:auto;vertical-align:middle" title=":zoule:" alt=":zoule:" /></p>
]]></description><link>https://cfd-china.com/post/16715</link><guid isPermaLink="true">https://cfd-china.com/post/16715</guid><dc:creator><![CDATA[七辆战车]]></dc:creator><pubDate>Fri, 22 Nov 2019 11:27:10 GMT</pubDate></item><item><title><![CDATA[Reply to 浮点数例外（核心已转储） 问题 on Fri, 22 Nov 2019 08:55:20 GMT]]></title><description><![CDATA[<p dir="auto">浮点数溢出（核心已转储）应该是你网格有问题，刚开始做的时候我也经常遇到，到，可以先查查网格，长宽比不要太大。warning 的话一般没有问题的，只要不出现错误。</p>
]]></description><link>https://cfd-china.com/post/16712</link><guid isPermaLink="true">https://cfd-china.com/post/16712</guid><dc:creator><![CDATA[一颗鸭蛋]]></dc:creator><pubDate>Fri, 22 Nov 2019 08:55:20 GMT</pubDate></item></channel></rss>
