<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[关于网格局部加密问题]]></title><description><![CDATA[<p dir="auto">在ICEM中局部加密使用了<br />
<img src="/assets/uploads/files/1592555301913-f00a8079-1bcb-419f-af18-f7e2376c299d-image.png" alt="f00a8079-1bcb-419f-af18-f7e2376c299d-image.png" class=" img-fluid img-markdown" /><br />
这样生成的网格并不是点对点，而是一边对应多点<br />
<img src="/assets/uploads/files/1592555333542-323eb693-2224-4f09-a768-0cbceeb349b3-image.png" alt="323eb693-2224-4f09-a768-0cbceeb349b3-image.png" class=" img-fluid img-markdown" /><br />
在OpenFOAM中的paraview中显示效果<br />
<img src="/assets/uploads/files/1592555363550-c00320e5-5893-4a47-b0ed-87b5ec8aaf97-image.png" alt="c00320e5-5893-4a47-b0ed-87b5ec8aaf97-image.png" class=" img-fluid img-markdown" /><br />
请教下，这样的网格，在OpenFOAM计算的时候，是否可行呢？<br />
谢谢~~</p>
]]></description><link>https://cfd-china.com/topic/3685/关于网格局部加密问题</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 22:19:50 GMT</lastBuildDate><atom:link href="https://cfd-china.com/topic/3685.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Jun 2020 08:32:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 关于网格局部加密问题 on Mon, 12 Dec 2022 14:21:56 GMT]]></title><description><![CDATA[<p dir="auto">周老师，这里我测试发现好像这种结构网格的加密方式对于三维模型可以，对于二维网格，在经过局部加密后再导入到OF里面是会报错的，错误是：--&gt; FOAM FATAL ERROR:<br />
face 11528151 does not belong to cell 210100. Face owner: -1 neighbour: 210099</p>
<pre><code>From Foam::cellShape Foam::extrudedQuadCellShape(Foam::label, const labelList&amp;, const faceList&amp;, const labelList&amp;, const labelList&amp;, Foam::label, Foam::faceList&amp;)
in file extrudedQuadCellShape.C at line 105.
</code></pre>
<p dir="auto">FOAM aborting<br />
感觉好像是在z方向拉伸出来的面没有识别到具体的cell中</p>
]]></description><link>https://cfd-china.com/post/33142</link><guid isPermaLink="true">https://cfd-china.com/post/33142</guid><dc:creator><![CDATA[WangGH]]></dc:creator><pubDate>Mon, 12 Dec 2022 14:21:56 GMT</pubDate></item><item><title><![CDATA[Reply to 关于网格局部加密问题 on Sun, 21 Jun 2020 00:01:24 GMT]]></title><description><![CDATA[<p dir="auto">@东岳 谢谢老师</p>
]]></description><link>https://cfd-china.com/post/20033</link><guid isPermaLink="true">https://cfd-china.com/post/20033</guid><dc:creator><![CDATA[Zhoujq]]></dc:creator><pubDate>Sun, 21 Jun 2020 00:01:24 GMT</pubDate></item><item><title><![CDATA[Reply to 关于网格局部加密问题 on Sat, 20 Jun 2020 12:57:55 GMT]]></title><description><![CDATA[<p dir="auto">这不好说，个人认为不需要改为1</p>
]]></description><link>https://cfd-china.com/post/20031</link><guid isPermaLink="true">https://cfd-china.com/post/20031</guid><dc:creator><![CDATA[李东岳]]></dc:creator><pubDate>Sat, 20 Jun 2020 12:57:55 GMT</pubDate></item><item><title><![CDATA[Reply to 关于网格局部加密问题 on Sat, 20 Jun 2020 08:29:11 GMT]]></title><description><![CDATA[<p dir="auto">@东岳<br />
老师，已经进行了对网格的1对2改进：<br />
<img src="/assets/uploads/files/1592640969441-1592640955-1.jpg" alt="1592640955(1).jpg" class=" img-fluid img-markdown" /><br />
在ICEM转化到OpenFOAM中时，在<code>ployMesh</code>文件夹中出现了<code>set</code>文件夹里面是一个<code>nonOrthoFaces</code>文件</p>
<p dir="auto"><img src="/assets/uploads/files/1592641089004-2f9e8f66-ef5b-49e9-8a76-ab6507f8729f-image.png" alt="2f9e8f66-ef5b-49e9-8a76-ab6507f8729f-image.png" class=" img-fluid img-markdown" /><br />
出现这种文件，是由于1对2网格导致的，和下图这种网格非正交的是不同的<br />
<img src="/assets/uploads/files/1592641582951-a262e836-9e44-4399-8255-2b270336b97e-image.png" alt="a262e836-9e44-4399-8255-2b270336b97e-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">所以在我这个案例的<code>fvSolution</code>文件中</p>
<pre><code>PIMPLE
    momentumPredictor   no;
    nOuterCorrectors    1;
    nCorrectors         2;
    nNonOrthogonalCorrectors 0;
    maxCo               10;
    maxAlphaCo          5;
    rDeltaTSmoothingCoeff 0.05;
    rDeltaTDampingCoeff 0.5;
    nAlphaSpreadIter    0;
    nAlphaSweepIter     0;
    maxDeltaT           1;
</code></pre>
<p dir="auto">是否需要把<code>nNonOrthogonalCorrectors 0</code>改为<code>nNonOrthogonalCorrectors 1</code>，或者其它地方需要进行改动呢？</p>
]]></description><link>https://cfd-china.com/post/20027</link><guid isPermaLink="true">https://cfd-china.com/post/20027</guid><dc:creator><![CDATA[Zhoujq]]></dc:creator><pubDate>Sat, 20 Jun 2020 08:29:11 GMT</pubDate></item><item><title><![CDATA[Reply to 关于网格局部加密问题 on Fri, 19 Jun 2020 08:43:27 GMT]]></title><description><![CDATA[<p dir="auto">@东岳 谢谢老师~~</p>
]]></description><link>https://cfd-china.com/post/20011</link><guid isPermaLink="true">https://cfd-china.com/post/20011</guid><dc:creator><![CDATA[Zhoujq]]></dc:creator><pubDate>Fri, 19 Jun 2020 08:43:27 GMT</pubDate></item><item><title><![CDATA[Reply to 关于网格局部加密问题 on Fri, 19 Jun 2020 08:42:06 GMT]]></title><description><![CDATA[<p dir="auto">是可行的，<br />
但是可能会引起很大误差，通常建议1对2，逐步过渡</p>
]]></description><link>https://cfd-china.com/post/20010</link><guid isPermaLink="true">https://cfd-china.com/post/20010</guid><dc:creator><![CDATA[李东岳]]></dc:creator><pubDate>Fri, 19 Jun 2020 08:42:06 GMT</pubDate></item></channel></rss>
