用fluent Meshing划分的多面体网格转换成OpenFOAM格式出现错误
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: v1912 |
| \ / A nd | Website: www.openfoam.com |
| \/ M anipulation | |
Build : _f3950763fe-20191219 OPENFOAM=1912
Arch : "LSB;label=32;scalar=64"
Exec : fluent3DMeshToFoam 000.msh
Date : Jul 03 2020
Time : 09:25:27
Host : King
PID : 514
I/O : uncollated
Case : /mnt/d/OpenFOAM/run/test
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Reading header: "ANSYS(R) TGrid(TM) 3D, parallel 18.1.0"
Dimension of grid: 3
Number of points: 34807
--> FOAM Warning : Found unknown block of type: "11"
on line 16
Number of faces: 39160
Number of cells: 6053
PointGroup: 1 start: 0 end: 15. Reading points...done.
PointGroup: 8 start: 16 end: 23. Reading points...done.
PointGroup: 216 start: 24 end: 307. Reading points...done.
PointGroup: 218 start: 308 end: 3281. Reading points...done.
PointGroup: 59 start: 3282 end: 9500. Reading points...done.
PointGroup: 61 start: 9501 end: 34806. Reading points...done.
on line 34838
on line 34852
on line 34866
on line 35156
FaceGroup: 2 start: 39148 end: 39159. Reading uniform faces...done.
FaceGroup: 7 start: 0 end: 3253. Reading mixed faces...done.
FaceGroup: 62 start: 3254 end: 39147. Reading mixed faces...done.
CellGroup: 63 start: 0 end: 6052 type: 1
--> FOAM Warning : Found unknown block of type: "316"
on line 74613
--> FOAM Warning : Found unknown block of type: "71"
on line 74632
Zone: 63 name: zone000:000--- type: fluid. Reading zone data...done.
Zone: 62 name: interior-p-62 type: interior. Reading zone data...done.
Zone: 7 name: geom-zone000:000---:7 type: wall. Reading zone data...done.
Zone: 2 name: geom-zone000:000--- type: geometry. Reading zone data...done.
Zone: 64 name: edge-p-64 type: boundary-edge. Reading zone data...done.
Zone: 214 name: edge-p-214 type: boundary-edge. Reading zone data...done.
Zone: 9 name: _zone000:000---:feature:9 type: boundary-edge. Reading zone data...done.
Zone: 3 name: _zone000:000---:feature type: boundary-edge. Reading zone data...done.
--> FOAM Warning : Found unknown block of type: "73"
on line 78743
FINISHED LEXING
Creating patch 0 for zone: 2 name: geom-zone000:000--- type: geometry
Adding polyPatch for unknown Fluent type geometry
Creating patch 1 for zone: 7 name: geom-zone000:000---:7 type: wall
Creating cellZone 0 name: zone000:000--- type: fluid
Creating faceZone 0 name: interior-p-62 type: interior
faceZone from Fluent indices: 3254 to: 39147 type: interior
patch 0 from Fluent indices: 39148 to: 39159 type: geometry
patch 1 from Fluent indices: 0 to: 3253 type: wall
--> FOAM FATAL ERROR:
Illegal cell label -1 in neighbour addressing for face 39148
From function void Foam::polyMesh::initMesh()
in file meshes/polyMesh/polyMeshInitMesh.C at line 67.
FOAM exiting
