洱聿洱
洱聿
@洱聿
  • solids4foam运行算例,流固耦合交界面报错
    洱聿洱 洱聿
    在solids4foam中运行验证算例(孤立波下斜坡上的直墙变形和受力),但是当波浪到固体交界面时,就会出现浮点报错问题,修改了网格和固体交界面的问题,还是没有改善这个问题。请问有大佬们知道怎么解决这个问题吗?
    报错时间步alpha场:(每次到这个地方就出现报错)
    报错部分log文件:
    Time = 8.933, iteration: 9
    Current fsi under-relaxation factor (Aitken) of interface: 3.24861e-06
    Maximal accumulated displacement of interface 0: 2.02709e-06
    GAMG:  Solving for cellMotionUx, Initial residual = 0.27053, Final residual = 4.88471e-05, No Iterations 2
    GAMG:  Solving for cellMotionUz, Initial residual = 0.276424, Final residual = 7.60589e-05, No Iterations 2
    GAMG:  Solving for cellMotionUx, Initial residual = 5.19396e-05, Final residual = 4.62925e-07, No Iterations 4
    GAMG:  Solving for cellMotionUz, Initial residual = 8.68504e-05, Final residual = 8.18649e-07, No Iterations 3
    Evolving fluid model: wave2solids
    PIMPLE: iteration 1
    MULES: Solving for alpha1
    alpha1 BC on patch inlet
    Liquid phase volume fraction = 0.259489  Min(alpha1) = -2191.92  Max(alpha1) = 2360.17
    Liquid phase volume fraction = 0.259489  Min(alpha1) = -158062  Max(alpha1) = 163488
    Velocity BC on patch inlet
    3D_2D Absorption BC on patch outlet
    "Correction Levels" 1( 0 )
    DICPCG:  Solving for pd, Initial residual = 0.10778, Final residual = 0.00369688, No Iterations 8
    DICPCG:  Solving for pd, Initial residual = 6.32049e-06, Final residual = 2.94799e-07, No Iterations 644
    DICPCG:  Solving for pd, Initial residual = 4.65247e-05, Final residual = 2.1618e-06, No Iterations 637
    DICPCG:  Solving for pd, Initial residual = 2.0431e-07, Final residual = 9.74494e-08, No Iterations 110
    DICPCG:  Solving for pd, Initial residual = 4.64318e-05, Final residual = 2.21746e-06, No Iterations 638
    DICPCG:  Solving for pd, Initial residual = 2.16117e-07, Final residual = 8.27667e-08, No Iterations 132
    Setting traction on solid interfaces
    Mapping face values using directMap
    Total force on fluid interface 0: (4.3321e+10 -2.82466e-19 -0.673933)
    Total force on solid interface 0: (-4.3321e+10 2.82466e-19 0.673933)
    Evolving solid solver
    Solving the updated Lagrangian form of the momentum equation for DD
    mpirun noticed that process rank 6 with PID 168600 on node node03 exited on signal 8 (Floating point exception).
  • 固体求解器添加两种材料
    洱聿洱 洱聿
    各位大佬们好,我想在fsifoam流固耦合求解器中添加两种固体材料属性,请问有人做过相关的算例嘛?是否可以直接添加?还是需要修改求解器呢?
  • waves2foam孤立波造波衰减
    洱聿洱 洱聿
    目前在验证孤立波造波,基于waves2foam中自带算例模拟periodicSolitary,和孤立波一阶波形进行对比,但是波峰处出现明显的造波衰减,如图1所示,与理论值差值较大,想问一下是底部边界设置的问题吗?
    5f2316c9-c344-4deb-a3f8-a52623ff6e82-image.png 图1 periodicSolitary算例波形对比
    4f21e17d-2242-49a6-bf13-d3ebba554bc1-image.png 图2 periodicSolitary算例waveProperties.input文件
    自带算例是周期性孤立波,目前设置了单独孤立波造波,波峰还是一样有很大的衰减,底部边界设置的是滑移边界slip(自带算例中也是)。
    998c5df4-450b-45f8-a8c3-2c7acfe6686f-image.png 图3 自己设置单个孤立波波形对比
    a3dd1c9b-1ca0-42cb-b665-4d156d287f32-image.png 图4 自己设置单个孤立波算例waveProperties.input文件
  • 并行计算浮点报错
    洱聿洱 洱聿
    目前基于fe40下的waves2foam设置的算例报错,模型是一个简单的水槽造波,单核可以运算。并行运算到某个时间步库朗数突然增大,造成浮点溢出,报错信息如下:
    集群error文件如下:
    mkdir: cannot create directory 鈥?鈥? File exists
    [node03:197162] 3 more processes have sent help message help-mpi-btl-openib.txt / no device params found
    [node03:197162] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    [node03:197162] 3 more processes have sent help message help-mpi-btl-openib.txt / init-fail-create-q
    [node03:197201] *** Process received signal ***
    [node03:197202] *** Process received signal ***
    [node03:197202] Signal: Floating point exception (8)
    [node03:197202] Signal code:  (-6)
    [node03:197202] Failing at address: 0x3ef00030252
    [node03:197203] *** Process received signal ***
    [node03:197203] Signal: Floating point exception (8)
    [node03:197203] Signal code:  (-6)
    [node03:197203] Failing at address: 0x3ef00030253
    [node03:197204] *** Process received signal ***
    [node03:197204] Signal: Floating point exception (8)
    [node03:197204] Signal code:  (-6)
    [node03:197204] Failing at address: 0x3ef00030254
    [node03:197201] Signal: Floating point exception (8)
    [node03:197201] Signal code:  (-6)
    [node03:197201] Failing at address: 0x3ef00030251
    [node03:197201] [ 0] [node03:197204] [ 0] /lib64/libc.so.6(+0x362f0)[0x2b51232f12f0]
    [node03:197204] [ 1] [node03:197202] [ 0] /lib64/libc.so.6(+0x362f0)[0x2b517e1252f0]
    [node03:197202] [ 1] [node03:197203] [ 0] /lib64/libc.so.6(+0x362f0)[0x2aecd7a942f0]
    [node03:197203] [ 1] /lib64/libc.so.6(+0x362f0)[0x2b6690c022f0]
    [node03:197201] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2b6690c02277]
    [node03:197201] [ 2] /lib64/libc.so.6(gsignal+0x37)[0x2aecd7a94277]
    [node03:197203] [ 2] /lib64/libc.so.6(gsignal+0x37)[0x2b51232f1277]
    [node03:197204] [ 2] /lib64/libc.so.6(gsignal+0x37)[0x2b517e125277]
    [node03:197202] [ 2] /lib64/libc.so.6(+0x362f0)[0x2aecd7a942f0]
    [node03:197203] [ 3] /lib64/libc.so.6(+0x362f0)[0x2b51232f12f0]
    [node03:197204] [ 3] /lib64/libc.so.6(+0x362f0)[0x2b517e1252f0]
    [node03:197202] [ 3] /lib64/libc.so.6(+0x362f0)[0x2b6690c022f0]
    [node03:197201] [ 3] /home/DSQ/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam4Time12adjustDeltaTEv+0x59)[0x2b5121dcc429]
    [node03:197204] [ 4] /home/DSQ/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam4Time12adjustDeltaTEv+0x59)[0x2aecd656f429]
    [node03:197203] [ 4] /home/DSQ/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam4Time12adjustDeltaTEv+0x59)[0x2b668f6dd429]
    [node03:197201] [ 4] /home/DSQ/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam4Time12adjustDeltaTEv+0x59)[0x2b517cc00429]
    [node03:197202] [ 4] waveFoam(main+0x23be)[0x42be2e]
    [node03:197202] [ 5] waveFoam(main+0x23be)[0x42be2e]
    [node03:197201] [ 5] waveFoam(main+0x23be)[0x42be2e]
    [node03:197203] [ 5] waveFoam(main+0x23be)[0x42be2e]
    [node03:197204] [ 5] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b51232dd445]
    [node03:197204] [ 6] waveFoam[0x430b8e]
    [node03:197204] *** End of error message ***
    /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b517e111445]
    [node03:197202] [ 6] waveFoam[0x430b8e]
    [node03:197202] *** End of error message ***
    /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b6690bee445]
    [node03:197201] [ 6] waveFoam[0x430b8e]
    [node03:197201] *** End of error message ***
    /lib64/libc.so.6(__libc_start_main+0xf5)[0x2aecd7a80445]
    [node03:197203] [ 6] waveFoam[0x430b8e]
    [node03:197203] *** End of error message ***
    我用fsifoam计算其他算例也会出现这个问题,有人遇到过类似的问题嘛?
  • mpirun并行显示运算中,但是实际log文件无输出
    洱聿洱 洱聿
    @洱聿 目前主动停止算例运行,会出error文件(但是之前以为是主动停止报的错误,就一直没有注意过),显示错误如下:
    [manage01:228000] [[60655,0],0] tcp_peer_recv_connect_ack: received different version from [[60655,1],1]: 1.8.8 instead of 1.10.2
    目前集群使用的mpi版本是1.10.2,是因为mpi版本太高,所以foam extend4.0不适用嘛?有fe40专门对应的openmpi版本嘛?
    洱聿洱 洱聿
    @xpqiu 我之前运行过这个算例10小时,一直处在run 的状态,但og.waveFoam-d一片空白没有任何信息产生,是不是此账户下mpi命令不能运行,我这几天也在调试。
    洱聿洱 洱聿
    @李东岳 试了之前在其他账户的并行算例也是这个问题,是mpi的问题嘛?
    洱聿洱 洱聿
    在运用集群计算过程中,单核运行算例没问题,但是提交到集群上会显示run的状态,但是log并没有数据,(log.waveFoam-d)如下图:
    提交并行文件如下:
    # Source tutorial run functions
    . $WM_PROJECT_DIR/bin/tools/RunFunctions
    # Set application name
    application="waveFoam"
    # Create the computational mesh
    echo Preparing 0 folder...
    rm -fr 0
    cp -r 0.org 0
    rm -rf constant/polyMesh
    cp -r constant/polyMesh.org constant/polyMesh
    # Create the wave probes
    runApplication waveGaugesNProbes
    # Compute the wave parameters
    runApplication setWaveParameters
    # Set the wave field
    runApplication setWaveField
    #decomosePar
    decomposePar > log.decomposePar
    mpirun -np 20 renumberMesh -overwrite -parallel > log.renumberMesh
    # Run the application
    #runApplication $application
    mpirun -np 20 waveFoam -parallel > log.waveFoam-d
    # To a post-processing analysis
    ln -s postProcessing/surfaceElevationAnyName surfaceElevationAnyName
    runApplication postProcessWaves2Foam
    # Reconstruct
    #runApplication reconstructPar
    rm -f /tmp/nodes.$$
    rm -f /tmp/nodefile.$$
    想问一下,是集群账户下mpirun的路径有问题嘛?
  • 在fsifoam中运行算例报错
    洱聿洱 洱聿
    目前算例移植到计算机集群上计算,模型是水面上漂浮的平板。大约计算到0.8s时出现这个报错,查找原因是内存分配问题;
    有查看了相关的log文件,文件中给出的报错是如下所示
    为什么算例运行中会出现nu不被定义的报错呢?是因为计算过程中,网格出现问题嘛?
  • 在fsifoam中运行算例报错
    洱聿洱 洱聿
    @李东岳 嗯嗯好的,谢谢东岳老师,我好好学习一下。
  • 在fsifoam中运行算例报错
    洱聿洱 洱聿
    @李东岳 这些天主要是查了一些资料,修改了文件中的参数(目前算例已经可以计算,迭代步数较多,大致计算到1s左右)最主要的两个参数如下:
    1.修改solid/system/fvsolution中,在松弛因子中添加一项
    relaxationFactors
    	    fields
    	        D 0.5;
    	    equations
    	         D 1;//添加的这一项
    还是不太能分清fields和equtions代表的含义?
    2.还有一个是最大库朗数的调整
    maxCo           0.2;//3
  • 在fsifoam中运行算例报错
    洱聿洱 洱聿
    @李东岳 东岳老师说的是这里嘛?
    Fluid-to-solid face interpolation error: 2.66686e-15
    这个GGI 错误不太对我也注意到了,调节了一些参数还是没有太大帮住。
    我这个物体的长细比很大,厚度很小,自由液面网格精度不够是不是会影响这个流体对固体的力 ?
  • 在fsifoam中运行算例报错
    洱聿洱 洱聿
    目前基于两相流求解器fsifoam,BeamInCross的案例可以运行。
    在设置新的算例过程中出现问题,检查网格设置没有问题,但在运行到wavefsifoam中的时候总会出现浮点报错,以下是报错的log文件。有大佬知道是什么问题嘛?
    Create time
    Create dynamic mesh for time = 0
    Selecting dynamicFvMesh dynamicMotionSolverFvMesh
    Selecting motion solver: velocityLaplacian
    Selecting motion diffusion: quadratic
    Selecting motion diffusion: inverseDistance
     Reading stress mesh
    Selecting incompressible transport model Newtonian
    Selecting turbulence model type laminar
    PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
    Creating traction displacement boundary conditions
    Creating fixed displacement boundary condition
    Selecting rheology model linearElastic
    Creating constitutive model
    Selecting coupling scheme IQN-ILS
    Starting time loop
    Time = 0.0005 (dt = 0.0005)
    Create extended GGI zone-to-zone interpolator
    Checking fluid-to-solid face interpolator
    Checking solid-to-fluid point interpolator (GGI)
    calcMasterPointAddressing() const
    Extended GGI, master point distance, max: 0, avg: 0, min: 0
    Solid-to-fluid point interpolation error (GGI): 1.78004e-15
    Number of uncovered master faces: 0
    Number of uncovered slave faces: 0
    calcSlavePointAddressing() const
    Extended GGI, slave point distance, max: 0, avg: 0, min: 0
    Extended GGI, slave point orientation (<0), max: -0.707107, min: -1, nIncorrectPoints: 0/416
    Setting traction on solid patch
    Total force (fluid) = (9.09051e-13 -10310.3 0)
    Total force (solid) = (-9.17932e-13 10310.3 0)
    Evolving solid solver: unsTotalLagrangianSolid
    DICPCG: Solving for D, Initial residula = 1, Final residual = 0.00139832, No outer iterations = 46
    Max relative residual = 1, Relative residual = 8.57078e-05, enforceLinear = 0
    Current fsi relative residual norm: 1
    Alternative fsi residual: 1
    Time = 0.0005, iteration: 1
    Modes before clean-up : 0, modes after clean-up : 0
    Current fsi under-relaxation factor: 0.4
    Creating accumulated fluid interface displacement
    Maximal accumulated displacement of interface points: 0.0176225
    GAMG:  Solving for cellMotionUx, Initial residual = 1, Final residual = 0.000274813, No Iterations 1
    GAMG:  Solving for cellMotionUy, Initial residual = 1, Final residual = 3.40719e-06, No Iterations 1
    GAMG:  Solving for cellMotionUz, Initial residual = 0, Final residual = 0, No Iterations 1
    Evolving fluid solver
    Courant Number mean: 0 max: 0 velocity magnitude: 0
    volume continuity errors : volume = 1.798, max error = 7.41202e-10, sum local = 3.34731e-14, global = 3.74747e-17
    time step continuity errors : sum local = 6.76086e-06, global = -4.79613e-09, cumulative = -4.79613e-09
    GAMGPCG:  Solving for pcorr:  solution singularity
    time step continuity errors : sum local = 0, global = 0, cumulative = -4.79613e-09
    PIMPLE: iteration 1
    Liquid phase volume fraction = 0.333151  Min(alpha1_) = 0  Max(alpha1_) = 1
    Liquid phase volume fraction = 0.33315  Min(alpha1_) = -5.43647e-12  Max(alpha1_) = 1
    Liquid phase volume fraction = 0.333149  Min(alpha1_) = -1.63119e-11  Max(alpha1_) = 1
    Relaxing time: 0.13 s
    DILUPBiCG:  Solving for Ux, Initial residual = 0.0139054, Final residual = 5.6888e-10, No Iterations 1
    DILUPBiCG:  Solving for Uy, Initial residual = 0.90048, Final residual = 7.68278e-08, No Iterations 1
    DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 3.12111e-08, No Iterations 1
    GAMG:  Solving for pd, Initial residual = 0.000490799, Final residual = 3.64458e-07, No Iterations 6
    GAMG:  Solving for pd, Initial residual = 5.23309e-07, Final residual = 1.71699e-07, No Iterations 2
    time step continuity errors : sum local = 6.15505e-08, global = 2.24553e-08, cumulative = 1.76592e-08
    PIMPLE: iteration 2
    Liquid phase volume fraction = 0.33315  Min(alpha1_) = -1.87448e-09  Max(alpha1_) = 1
    Liquid phase volume fraction = 0.333149  Min(alpha1_) = -1.87447e-09  Max(alpha1_) = 1
    Liquid phase volume fraction = 0.333148  Min(alpha1_) = -1.87447e-09  Max(alpha1_) = 1.00001
    Relaxing time: 0.06 s
    DILUPBiCG:  Solving for Ux, Initial residual = 0.00171359, Final residual = 7.95819e-09, No Iterations 1
    DILUPBiCG:  Solving for Uy, Initial residual = 0.00229415, Final residual = 1.1053e-08, No Iterations 1
    DILUPBiCG:  Solving for Uz, Initial residual = 0.971192, Final residual = 3.40668e-10, No Iterations 2
    GAMG:  Solving for pd, Initial residual = 0.000164208, Final residual = 8.28008e-07, No Iterations 1
    GAMGPCG:  Solving for pd, Initial residual = 8.28209e-07, Final residual = 3.38658e-09, No Iterations 5
    time step continuity errors : sum local = 1.20621e-09, global = -9.02852e-12, cumulative = 1.76502e-08
    Total force (fluid) = (-0.05684 4.2698e+06 0.000283692)
    Total force (solid) = (0.0568298 -4.2698e+06 -0.000283692)
    DICPCG: Solving for D, Initial residula = 0.99665, Final residual = 0.00109644, No outer iterations = 44
    Max relative residual = 1.01269, Relative residual = 9.25099e-05, enforceLinear = 0
    Alternative fsi residual: 1.00254
    Time = 0.0005, iteration: 2
    Maximal accumulated displacement of interface points: 3.28076
    GAMG:  Solving for cellMotionUx, Initial residual = 0.993157, Final residual = 0.000144068, No Iterations 1
    GAMG:  Solving for cellMotionUy, Initial residual = 1, Final residual = 8.88797e-06, No Iterations 1
    GAMG:  Solving for cellMotionUz, Initial residual = 6.05144e-07, Final residual = 3.33872e-07, No Iterations 1
    Courant Number mean: 0.00051952 max: 0.0335853 velocity magnitude: 0.33609
    volume continuity errors : volume = 1.79801, max error = 8.29118e-10, sum local = 3.35534e-14, global = 3.66141e-17
    time step continuity errors : sum local = 0.00099525, global = 3.75254e-06, cumulative = 3.75254e-06
    GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 6.62621e-05, No Iterations 8
    GAMGPCG:  Solving for pcorr, Initial residual = 2.80297e-05, Final residual = 1.4592e-06, No Iterations 2
    time step continuity errors : sum local = 9.21979e-12, global = -8.2965e-14, cumulative = 3.75254e-06
    Courant Number mean: 0.000181841 max: 0.0268574 velocity magnitude: 0.26901
    PIMPLE: iteration 1
    Liquid phase volume fraction = 0.332773  Min(alpha1_) = -4.11526e-33  Max(alpha1_) = 1.00385
    Liquid phase volume fraction = 0.332869  Min(alpha1_) = 0  Max(alpha1_) = 1.00315
    Liquid phase volume fraction = 0.332965  Min(alpha1_) = 0  Max(alpha1_) = 1.00257
    Relaxing time: 0.07 s
    DILUPBiCG:  Solving for Ux, Initial residual = 0.00750013, Final residual = 1.9279e-09, No Iterations 2
    DILUPBiCG:  Solving for Uy, Initial residual = 0.476658, Final residual = 6.03497e-09, No Iterations 2
    DILUPBiCG:  Solving for Uz, Initial residual = 0.363964, Final residual = 1.19961e-09, No Iterations 2
    GAMG:  Solving for pd, Initial residual = 0.0552688, Final residual = 4.74688e-07, No Iterations 21
    GAMG:  Solving for pd, Initial residual = 1.30893e-09, Final residual = 1.80425e-09, No Iterations 1
    time step continuity errors : sum local = 6.42096e-08, global = -1.01415e-09, cumulative = 3.75153e-06
    PIMPLE: iteration 2
    Liquid phase volume fraction = 0.332835  Min(alpha1_) = 0  Max(alpha1_) = 1.00023
    Liquid phase volume fraction = 0.332993  Min(alpha1_) = 0  Max(alpha1_) = 1.22181
    Liquid phase volume fraction = 0.333151  Min(alpha1_) = 0  Max(alpha1_) = 1.40207
    DILUPBiCG:  Solving for Ux, Initial residual = 0.164439, Final residual = 8.32138e-08, No Iterations 5
    DILUPBiCG:  Solving for Uy, Initial residual = 0.201356, Final residual = 6.76597e-07, No Iterations 4
    DILUPBiCG:  Solving for Uz, Initial residual = 0.834862, Final residual = 8.61714e-07, No Iterations 5
    GAMG:  Solving for pd, Initial residual = 3.4311e-05, Final residual = 9.63653e-07, No Iterations 8
    GAMGPCG:  Solving for pd, Initial residual = 1.72276e-06, Final residual = 3.34751e-09, No Iterations 4
    time step continuity errors : sum local = 6.58196e-08, global = 1.14823e-10, cumulative = 3.75164e-06
    Total force (fluid) = (44895.8 -5.16199e+08 -0.04222)
    Total force (solid) = (-44895 5.16233e+08 0.0422304)
    det: -6.35377, 1.44569
    DICPCG: Solving for D, Initial residula = 0.981674, Final residual = 0.000998539, No outer iterations = 46
    Max relative residual = 1.04638, Relative residual = 0.000100841, enforceLinear = 0
    Alternative fsi residual: 1.00299
    Time = 0.0005, iteration: 3
    Maximal accumulated displacement of interface points: 468.826
    GAMG:  Solving for cellMotionUx, Initial residual = 0.999092, Final residual = 0.000110299, No Iterations 1
    GAMG:  Solving for cellMotionUy, Initial residual = 1, Final residual = 9.9143e-06, No Iterations 1
    GAMG:  Solving for cellMotionUz, Initial residual = 0.00878954, Final residual = 5.34767e-06, No Iterations 7
    Courant Number mean: 0.177766 max: 809.001 velocity magnitude: 163.989
    volume continuity errors : volume = 1.79747, max error = 2.69711e-06, sum local = 3.54005e-14, global = 2.8054e-17
    time step continuity errors : sum local = 0.136847, global = -0.00030095, cumulative = -0.00030095
    GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 8.68671e-05, No Iterations 67
    GAMGPCG:  Solving for pcorr, Initial residual = 0.478654, Final residual = 0.00915489, No Iterations 100
    time step continuity errors : sum local = -1.61429e-05, global = -1.66005e-06, cumulative = -0.00030261
    Courant Number mean: 6.3896 max: 548138 velocity magnitude: 12675.3
    PIMPLE: iteration 1
    Liquid phase volume fraction = 0.376351  Min(alpha1_) = -13.5602  Max(alpha1_) = 7.08985
    Liquid phase volume fraction = 0.361769  Min(alpha1_) = -295.669  Max(alpha1_) = 154.958
    Liquid phase volume fraction = 0.345683  Min(alpha1_) = -6379.38  Max(alpha1_) = 5395.01
    DILUPBiCG:  Solving for Ux, Initial residual = 0.580998, Final residual = 2.92065e-07, No Iterations 17
    DILUPBiCG:  Solving for Uy, Initial residual = 0.977539, Final residual = 9.94289e-07, No Iterations 14
    DILUPBiCG:  Solving for Uz, Initial residual = 0.972502, Final residual = 9.01328e-08, No Iterations 6
    Floating point exception (core dumped)
  • 在集群上foam-extend-4.0以及extend-bazaar中流固耦合包的安装问题
    洱聿洱 洱聿
    @TINGHAIK 你好,这个编译完的第三方安装包是只包括fe40中的嘛?fsifoam安装好的能不能一起打包上传?从ubuntu18到centos系统?
  • 关于internalField nonuniform List<scalar>如何定义
    洱聿洱 洱聿
    @疏影横斜水清浅 万分感谢,是我在0.org/p文件中没加“;”,导致结果报错。
    洱聿洱 洱聿
    @李东岳 我把bubbleColumn/0/p文件中
    改成了
    internalField   uniform 0
    这个是报错原因:
    --> Error from: primitiveEntry::readEntry(const dictionary&, Istream&)
    --> Fatal error reading input from: /home/thia/foam/thia-4.0/run/bubbleColumn/0/p
    --> FOAM FATAL IO ERROR:
    ill defined primitiveEntry starting at keyword 'internalField' on line 19 and ending at line 48
    file: /home/thia/foam/thia-4.0/run/bubbleColumn/0/p at line 48.
        From function primitiveEntry::readEntry(const dictionary&, Istream&)
        in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 229.
    FOAM exiting
    我尝试找了报错原因后的文件primitiveEntry/primitiveEntryIO.C,但是源代码没看懂:
    void Foam::primitiveEntry::readEntry(const dictionary& dict, Istream& is)
        label keywordLineNumber = is.lineNumber();
        tokenIndex() = 0;
        if (read(dict, is))
            setSize(tokenIndex());
            tokenIndex() = 0;
        else
            // When reading an invalid global controlDict file, the following call
            // to FatalIOErrorIn will crash with a "Segmentation Fault", and will
            // fail to generate any useful error message to the console.
            // This additional error message will at least leave a minimal trace.
            // The cause of the Seg. fault is still unknown, but seems to be related
            // to the initialization of the string member attributes of the global
            // object FatalIOError. (MB 05/2011)
            std::cerr << "--> Error from: "
                << "primitiveEntry::readEntry(const dictionary&, Istream&)"
                << std::endl;
            std::cerr << "--> Fatal error reading input from: "
                << is.name() << std::endl;
            FatalIOErrorIn
                "primitiveEntry::readEntry(const dictionary&, Istream&)",
                is
            )   << "ill defined primitiveEntry starting at keyword '"
                << keyword() << '\''
                << " on line " << keywordLineNumber
                << " and ending at line " << is.lineNumber()
                << exit(FatalIOError);
    洱聿洱 洱聿
    @李东岳 应该是按照算好的数据来的,归0之后会报错。东岳老师,如果把internalField修改成均一场,之后调整一下可行嘛?
    洱聿洱 洱聿
    在/multiphase/bubbleFoam/bubbleColumn/0/p/ 的文件夹下,关于内部场的定义采用如下方式:
    1875
    1875代表的是模型的网格数量,但是不知道()括号中的数据是如何产生的?
    /multiphase/bubbleFoam/bubbleColumn/0/p/的代码如下:
    | \\      /  F ield         | foam-extend: Open Source CFD                    |
    |  \\    /   O peration     | Version:     4.0                                |
    |   \\  /    A nd           | Web:         http://www.foam-extend.org         |
    FoamFile
        version     2.0;
        format      ascii;
        class       volScalarField;
        object      p;
    1875
    6296.13
    6183.25
    6130.53
    6102.97
    6085.59
    6070.83
    6056.52
    6042.12
    6032.24
    6023.39
    6020
    6019.35
    6022.8
    6035.92
    6058.4
    6096.69
    6151.53
    6194.63
    6220.36
    6227.39
    6190.28
    6200.25
    6159.79
    6145.34
    6239.45
    5932.88
    5894.83
    5896
    5896.13
    5896.42
    5893.93
    5892.58
    5888.84
    5884.44
    5877.96
    5872.77
    5864.16
    5858.72
    5859.75
    5863.29
    5874.06
    5903.63
    5933.39
    5949.13
    5948.76
    5936.64
    5920.16
    5894.61
    5887.73
    5904.59
    5829.55
    5827.28
    5827.17
    5826.79
    5820.6
    5810.48
    5802.08
    5795.34
    5787.03
    5775.04
    5773.95
    5776.62
    5774.94
    5777.31
    5779.57
    5787.46
    5807.7
    5827.9
    5860.51
    5895.43
    5910.03
    5904.37
    5908.12
    5902.27
    5915.81
    5680.23
    5677.28
    5676.59
    5674.62
    5670.55
    5664.23
    5662.59
    5662.65
    5654.98
    5651.9
    5655.82
    5654.19
    5660.21
    5667.38
    5675.59
    5686.03
    5699.99
    5707.47
    5731.06
    5747.04
    5757.95
    5746.13
    5751.94
    5752.54
    5756.48
    5596.51
    5594.34
    5595.28
    5587.93
    5584.85
    5580.19
    5581.94
    5583.69
    5581.75
    5582.87
    5588.62
    5593.54
    5600.08
    5606.28
    5613.47
    5620.91
    5626.09
    5639.9
    5656.52
    5690.9
    5692.53
    5685.55
    5691.46
    5690.28
    5692.68
    5500.77
    5499.4
    5498.12
    5490.19
    5484.73
    5481.73
    5483.39
    5482.97
    5483.81
    5486.56
    5489.45
    5492.85
    5498.29
    5502.79
    5509.32
    5513.74
    5523.43
    5538.03
    5541.75
    5560.77
    5558.05
    5558.63
    5564.38
    5561.96
    5569.11
    5429.77
    5429.37
    5425.69
    5419.15
    5415.38
    5412.85
    5412.65
    5411.07
    5410.11
    5408.78
    5409.05
    5408.7
    5412.7
    5415.54
    5421.1
    5425.72
    5431.77
    5440.25
    5439.18
    5444.29
    5457.33
    5463.86
    5472.09
    5470.76
    5481.47
    5339.81
    5337.93
    5335.2
    5328.01
    5325.1
    5320.24
    5318.66
    5315.69
    5313.67
    5312.31
    5310.7
    5311.52
    5313.88
    5317.44
    5323.51
    5333.7
    5347.39
    5349.64
    5342.77
    5322.66
    5327.03
    5336.54
    5355.71
    5357.95
    5365.12
    5251.22
    5257.02
    5245.19
    5241.32
    5235.96
    5230.82
    5224.79
    5220.71
    5215.58
    5212.63
    5208.81
    5207.86
    5209.49
    5211.23
    5215.25
    5217.38
    5227.33
    5236.75
    5234.3
    5218.38
    5221.33
    5238.35
    5270.98
    5297.32
    5285.38
    5134.78
    5141.28
    5129.11
    5125.34
    5118.41
    5113.56
    5104.26
    5098.63
    5091.73
    5085.87
    5080.29
    5076.67
    5075.57
    5074.74
    5078.38
    5083.91
    5093.59
    5100.11
    5107.38
    5107.94
    5122.84
    5155.95
    5184.47
    5216.19
    5206.06
    5029.85
    5023.59
    5029.5
    5013.09
    5006.47
    5001.87
    4991.19
    4982.46
    4973.99
    4966.68
    4961.15
    4956.84
    4956.99
    4958.22
    4962.14
    4968.3
    4976.1
    4986.28
    4991.41
    4991.3
    4995.3
    5013.36
    5037.47
    5054.9
    5054.19
    4890.06
    4882.82
    4894.45
    4873.06
    4880.32
    4867.96
    4857.91
    4849.54
    4841.6
    4834.95
    4830.57
    4826.25
    4825.98
    4826
    4828.43
    4831.83
    4833.12
    4837.79
    4826.5
    4809.86
    4805.99
    4807.58
    4826.08
    4838.35
    4849.96
    4714.62
    4711.97
    4714.51
    4705
    4712.73
    4717.07
    4710.49
    4705.38
    4701.03
    4698.8
    4697.36
    4696.05
    4695.76
    4695.5
    4695.28
    4694.77
    4692.61
    4684.45
    4666.01
    4637.19
    4617.3
    4609.3
    4624.85
    4629.39
    4642.5
    4523.06
    4524.71
    4511.18
    4518.2
    4532.12
    4535.39
    4532.36
    4536.62
    4540.76
    4541.39
    4546.94
    4550.14
    4553.57
    4554.46
    4552.79
    4548.86
    4539.3
    4524.99
    4496.6
    4460.83
    4442.56
    4425.45
    4434.71
    4439.78
    4450.38
    4371.81
    4372.7
    4361.27
    4367.5
    4369.38
    4376.32
    4375.22
    4378.42
    4383.14
    4389.68
    4398.4
    4408.96
    4416.32
    4420.86
    4420.99
    4416.68
    4401.43
    4378.84
    4354.01
    4322.2
    4302.78
    4293.71
    4296.25
    4303.54
    4305.22
    4239.77
    4240.95
    4230.58
    4241.42
    4249.56
    4255.4
    4253.65
    4259.03
    4262.5
    4269.1
    4276.6
    4286.18
    4297.58
    4303.77
    4311.08
    4299.92
    4285.78
    4267.75
    4237.04
    4223.55
    4200.59
    4202.11
    4196.31
    4204.32
    4206.45
    4146.5
    4145.49
    4139.78
    4144.33
    4155.96
    4170.77
    4169.64
    4166.97
    4162.64
    4164.54
    4168.33
    4176.24
    4182.78
    4189.55
    4185.86
    4184.88
    4173.3
    4158.6
    4140.45
    4133.47
    4115.66
    4121.51
    4116.35
    4120.3
    4121.23
    4102.95
    4103.86
    4099.71
    4102.17
    4104.47
    4111.01
    4105.54
    4100.41
    4083.36
    4078.2
    4069.78
    4064.79
    4065.88
    4070.09
    4072.82
    4073.35
    4070.25
    4064.82
    4062.31
    4042.21
    4043.05
    4042.59
    4045.18
    4046.01
    4048.13
    4032.15
    4035.14
    4028.68
    4028.22
    4014.15
    3997.14
    3996.25
    3976.92
    3959.31
    3938.8
    3934.92
    3934.92
    3946.84
    3949.95
    3958.19
    3964.72
    3973.8
    3972.13
    3963.12
    3956.34
    3965.47
    3964.16
    3969.75
    3970.48
    3972.74
    3971.33
    3971.63
    3969.38
    3967.06
    3968.39
    3943.28
    3910.35
    3884.37
    3861.89
    3837.93
    3827.63
    3826.91
    3837.33
    3850.34
    3860.21
    3865.31
    3871.77
    3866.62
    3871.02
    3875.25
    3884.01
    3887.22
    3893.04
    3893.8
    3896.7
    3917.09
    3913.8
    3913.32
    3912.68
    3912.47
    3896.81
    3850.81
    3796.7
    3778.85
    3771.98
    3774.64
    3779.2
    3787.05
    3791.83
    3794.09
    3791.58
    3795.13
    3799.01
    3801.91
    3808.11
    3808.81
    3814.53
    3815.73
    3818.71
    3819.36
    3828.46
    3820.53
    3819.93
    3814.39
    3808.93
    3766.04
    3739.6
    3724.01
    3718.07
    3712.81
    3714.72
    3721.59
    3733.84
    3739.77
    3740.59
    3734.56
    3737.28
    3743.07
    3745.23
    3751.77
    3749.9
    3751.12
    3747.66
    3749.18
    3748.73
    3723.23
    3711.43
    3717.34
    3704.45
    3691.91
    3677.36
    3662.34
    3653.8
    3648.59
    3646.73
    3652.46
    3662.08
    3676.04
    3684.36
    3684.74
    3678.21
    3672.87
    3671.25
    3667.14
    3666.07
    3660.68
    3657.48
    3655.93
    3655.47
    3655.5
    3586.18
    3578.34
    3582.86
    3572.31
    3567.65
    3550.99
    3537.87
    3525.19
    3518.27
    3514.63
    3520.79
    3525.1
    3534.78
    3538.86
    3539.29
    3543.13
    3550.55
    3556.94
    3559.06
    3560.38
    3555.81
    3556.85
    3555.01
    3557.07
    3556.94
    3476.58
    3473.6
    3467.31
    3457.76
    3442.56
    3431.12
    3420.39
    3411.43
    3407.71
    3404.13
    3401.26
    3396.55
    3393.36
    3401.61
    3406.07
    3412.62
    3422.58
    3432.15
    3440.88
    3445.51
    3446.08
    3449.24
    3451.23
    3453.74
    3454.4
    3386.34
    3401.96
    3377.92
    3367.15
    3351.35
    3343.8
    3330.12
    3321.91
    3312.27
    3306.28
    3300.42
    3296.61
    3292.69
    3293.58
    3289.36
    3294.53
    3300.53
    3308.72
    3317.27
    3322.27
    3328.25
    3333.22
    3337.59
    3341.61
    3342.04
    3270.33
    3282.79
    3257
    3254.74
    3237.46
    3236.79
    3224.97
    3223.1
    3214.92
    3209.14
    3204.8
    3201.41
    3198.47
    3196.71
    3195.02
    3193.94
    3194.86
    3199.83
    3210.11
    3216.96
    3222.33
    3226
    3228.96
    3231.36
    3231.97
    3145.06
    3139.47
    3141.64
    3132.87
    3117.15
    3108
    3107.7
    3103.41
    3104.14
    3103.49
    3103.4
    3102.11
    3100.75
    3100.69
    3100.05
    3100.91
    3102.12
    3104
    3108.52
    3112.94
    3117.37
    3120.48
    3123.25
    3125.06
    3125.64
    3039.03
    3034.71
    3044.89
    3028.17
    3014.83
    2998.54
    2991.82
    2988.31
    2990.89
    2990.76
    2992.82
    2992.71
    2992.91
    2993.55
    2993.93
    2996.52
    2998.77
    3001.81
    3003.8
    3006.3
    3008.47
    3010.71
    3013.02
    3013.98
    3014.73
    2908.73
    2907.67
    2915.01
    2902.96
    2883.11
    2870.53
    2861.82
    2861.77
    2858.11
    2866.01
    2868.24
    2871.95
    2874.15
    2877.48
    2879.23
    2881.94
    2885.54
    2888.54
    2889.22
    2891.04
    2892.59
    2894.76
    2896.72
    2897.24
    2898.08
    2743.7
    2742.01
    2738.5
    2725.55
    2717.81
    2712.86
    2711.05
    2715.87
    2724.18
    2734.62
    2743.94
    2749.05
    2753.75
    2756.91
    2760.57
    2764.19
    2768.42
    2770.96
    2772.39
    2774.26
    2775.19
    2776.7
    2779.08
    2778.79
    2779.65
    2565.53
    2560.37
    2552.02
    2536.37
    2538.07
    2543.7
    2562.95
    2577.19
    2589.69
    2603.57
    2622.53
    2629.62
    2635.93
    2638.27
    2641.85
    2646.21
    2650.1
    2652.23
    2654.12
    2654.38
    2656.38
    2656.95
    2658.31
    2658.33
    2659
    2389.07
    2379.85
    2367.53
    2354.3
    2366.15
    2384.52
    2405.82
    2433.43
    2462.89
    2488.05
    2504.2
    2511.52
    2516.4
    2518.23
    2521.69
    2525.69
    2529.22
    2531.56
    2533.69
    2534.55
    2536.77
    2538.52
    2538.07
    2539.44
    2539.43
    2273.44
    2271.89
    2265.88
    2258.46
    2270.69
    2284.82
    2303.38
    2320.92
    2344.94
    2368.77
    2388.71
    2394.95
    2400.64
    2402.63
    2405.76
    2407.81
    2409.72
    2410.94
    2410.53
    2414.6
    2417.09
    2418.33
    2418.34
    2420.27
    2419.98
    2185.65
    2185.04
    2177.85
    2185.4
    2179.64
    2198.58
    2203.6
    2217.85
    2237.88
    2261.45
    2281.47
    2286.63
    2291.77
    2295.98
    2295.29
    2295
    2293.4
    2291.66
    2293.09
    2294.87
    2299.02
    2301.11
    2301.98
    2303.28
    2302.96
    2091.49
    2091.8
    2084.97
    2086.93
    2079.18
    2084.09
    2087.53
    2100.32
    2126.33
    2149.78
    2166.81
    2172.17
    2178.09
    2182.93
    2181.73
    2179.44
    2176.5
    2174.1
    2177.42
    2178.54
    2180.89
    2182.27
    2186.01
    2185.47
    2186.4
    2019.46
    2019.6
    2015.77
    2015.14
    2013.82
    2011.58
    2012.35
    2017.51
    2024.81
    2034.17
    2042.04
    2045.58
    2054.16
    2056.02
    2060.91
    2061.06
    2061.84
    2065.31
    2067.03
    2067.91
    2068.01
    2069.22
    2074.55
    2072.99
    2075.21
    1941.72
    1942.55
    1944.6
    1944.6
    1943.14
    1940.45
    1935.96
    1930.74
    1921.85
    1910.23
    1906.16
    1907.96
    1916.47
    1922.35
    1930.54
    1936.69
    1942.73
    1948.6
    1953.45
    1955.74
    1957.09
    1958.79
    1964.58
    1962.03
    1967.35
    1859.93
    1862.27
    1867.44
    1868.49
    1871.4
    1864.79
    1856.13
    1837.86
    1816.62
    1792.52
    1776.69
    1780.67
    1786.01
    1795.7
    1805.76
    1816.65
    1826.23
    1832.42
    1841.3
    1846.17
    1853.55
    1857.44
    1862.73
    1864.65
    1867.63
    1742.2
    1743.56
    1744.86
    1750.46
    1751.86
    1752.18
    1744.94
    1730.61
    1713.95
    1693.05
    1674.63
    1672.45
    1671.49
    1678.13
    1685.56
    1695.24
    1704.8
    1715.69
    1731.89
    1744.37
    1749.79
    1759.79
    1761.02
    1770.11
    1765.85
    1624.33
    1621.69
    1621.28
    1623.55
    1629.86
    1634.84
    1629.82
    1625.27
    1615.57
    1605.67
    1593.17
    1587.41
    1583.62
    1584.26
    1588.12
    1596.64
    1605.76
    1628.49
    1642.54
    1656.53
    1655.76
    1659.92
    1648.25
    1661.23
    1652.41
    1502.84
    1498.24
    1494.11
    1489.61
    1491.48
    1495.03
    1499.24
    1513.36
    1522.63
    1525.6
    1522.69
    1517.07
    1510.85
    1506.74
    1505.54
    1505.4
    1510.6
    1521.74
    1541.45
    1558.61
    1552.85
    1551.76
    1535.75
    1530.96
    1532.7
    1438.35
    1431.98
    1423.78
    1418.2
    1414.02
    1410.95
    1421.88
    1440.09
    1454.87
    1458.63
    1455.01
    1445.78
    1434.66
    1425.7
    1419.12
    1415.68
    1415.72
    1417.64
    1423.6
    1431.4
    1433.84
    1435.92
    1428.46
    1424.99
    1425.27
    1387.36
    1391.52
    1382.5
    1371.77
    1362.64
    1361.03
    1365.55
    1375.58
    1381.01
    1381.31
    1373.07
    1361.69
    1345.78
    1330.35
    1319.62
    1310.89
    1308.23
    1306.43
    1305.91
    1307.7
    1313.27
    1327.02
    1336.01
    1327.81
    1331.15
    1271.79
    1273.08
    1271.98
    1264.17
    1251.26
    1244.99
    1245.76
    1252.42
    1257
    1256.72
    1250.08
    1237.94
    1222.68
    1208.14
    1196.98
    1192.02
    1186.21
    1184.68
    1188.51
    1191.85
    1205.01
    1215.73
    1233.25
    1224.72
    1226.75
    1127.1
    1125.64
    1124.39
    1121.85
    1113.42
    1103.67
    1098.39
    1099.57
    1105.61
    1109.52
    1106.77
    1098.48
    1089
    1080.43
    1073.92
    1073.24
    1072.25
    1071.29
    1071.75
    1074.4
    1078.62
    1085.51
    1095.53
    1095.67
    1096.26
    992.294
    991.13
    986.281
    990.794
    983.274
    976.232
    971.001
    968.971
    970.743
    974.382
    967.38
    958.104
    950.768
    948.08
    946.549
    948.871
    950.382
    951.44
    951.025
    953.739
    950.888
    963.575
    953.716
    963.393
    962.334
    890.836
    890.007
    886.517
    889.188
    888.797
    887.558
    882.258
    875.452
    866.168
    854.814
    842.425
    829.034
    823.448
    825.3
    826.065
    829.316
    832.018
    831.086
    828.139
    829.794
    822.199
    832.926
    830.89
    834.839
    836.224
    798.119
    798.959
    798.146
    794.879
    795.855
    790.952
    790.489
    782.988
    775.087
    756.826
    738.278
    726.414
    724.974
    724.246
    723.204
    723.369
    721.642
    719.099
    710.316
    697.385
    679.975
    674.28
    688.78
    688.589
    696.624
    694.405
    693.345
    698.272
    689.258
    690.501
    687.553
    687.301
    681.852
    671.592
    659.784
    649.31
    644.201
    642.081
    639.871
    634.96
    632.393
    627.156
    622.901
    613.168
    598.754
    587.397
    580.568
    587.953
    589.947
    592.531
    575.596
    574.55
    578.335
    571.262
    575.126
    570.818
    571.44
    565.333
    563.994
    557.653
    557.057
    557.073
    557.351
    557.971
    555.384
    555.633
    552.015
    548.591
    537.679
    522.905
    508.967
    504.995
    501.762
    502.865
    506.834
    448.634
    446.606
    441.379
    444.536
    445.296
    443.761
    444.059
    445.756
    447.579
    450.807
    450.866
    455.388
    461.553
    467.52
    474.518
    479.626
    477.622
    471.502
    455.883
    440.965
    425.702
    419.971
    419.591
    421.465
    426.135
    327.686
    323.738
    318.303
    321.504
    324.04
    322.727
    325.782
    330.743
    336.641
    341.885
    344.784
    352.115
    359.02
    367.046
    375.031
    383.301
    386.722
    384.298
    377.603
    369.778
    365.622
    363.641
    369.767
    373.676
    379.99
    241.456
    237.463
    233.772
    236.247
    235.733
    232.785
    232.205
    235.193
    239.329
    242.543
    242.908
    243.094
    245.917
    250.612
    255.394
    256.106
    257.516
    253.698
    252.154
    259.734
    270.969
    277.671
    284.418
    288.332
    290.567
    170.45
    169.594
    168.777
    170.885
    170.431
    166.804
    162.034
    160.137
    158.841
    159.069
    159.23
    158.955
    159.443
    159.867
    163.016
    164.058
    164.345
    161.325
    163.141
    170.599
    175.042
    179.359
    182.47
    184.371
    184.848
    69.1085
    73.6312
    78.3502
    83.8631
    83.2866
    79.7069
    70.8607
    65.196
    58.0552
    52.5698
    47.5432
    44.4013
    40.9971
    39.2168
    44.3652
    48.4222
    52.8974
    55.6685
    63.8615
    70.3526
    77.103
    79.0083
    80.6254
    78.5936
    78.1597
    5.21762
    5.54303
    6.21406
    6.5862
    6.97536
    6.04707
    5.1582
    4.67529
    3.96973
    3.91805
    3.85068
    3.97955
    4.24419
    4.60187
    4.58482
    4.73677
    4.97607
    5.56779
    5.98771
    6.44586
    7.31777
    7.4187
    7.38624
    6.79915
    6.2811
    2.60843
    2.60082
    2.59544
    2.574
    2.56327
    2.53915
    2.52407
    2.51319
    2.50267
    2.50354
    2.50313
    2.51034
    2.51996
    2.53785
    2.55085
    2.5752
    2.5913
    2.61602
    2.6272
    2.64475
    2.66551
    2.6892
    2.70386
    2.72564
    2.73192
    2.17545
    2.17432
    2.17254
    2.17118
    2.16971
    2.16884
    2.16875
    2.16917
    2.17074
    2.17198
    2.17338
    2.17488
    2.17495
    2.17499
    2.17384
    2.17487
    2.17478
    2.17659
    2.17631
    2.17759
    2.17752
    2.17913
    2.17829
    2.1787
    2.17787
    2.04089
    2.04068
    2.04118
    2.04152
    2.04136
    2.04222
    2.04304
    2.04335
    2.04473
    2.0445
    2.04444
    2.04311
    2.04132
    2.03846
    2.03706
    2.03531
    2.03452
    2.03333
    2.03303
    2.03251
    2.03159
    2.03142
    2.03102
    2.03115
    2.0311
    1.8995
    1.89922
    1.89946
    1.89964
    1.89961
    1.89979
    1.89968
    1.89943
    1.89907
    1.89835
    1.8975
    1.89651
    1.89491
    1.89377
    1.8926
    1.89154
    1.8906
    1.88973
    1.88905
    1.88848
    1.88785
    1.88711
    1.88686
    1.88627
    1.88633
    1.77653
    1.77666
    1.77687
    1.77695
    1.77713
    1.77716
    1.77724
    1.7771
    1.77697
    1.77662
    1.77613
    1.7756
    1.77522
    1.77457
    1.77389
    1.77326
    1.77257
    1.77208
    1.7714
    1.77091
    1.77041
    1.77005
    1.76976
    1.76958
    1.76941
    1.63781
    1.6378
    1.6377
    1.63767
    1.63752
    1.63738
    1.63715
    1.63682
    1.63643
    1.6359
    1.63542
    1.63483
    1.63445
    1.6338
    1.63323
    1.63265
    1.63219
    1.63165
    1.63134
    1.63099
    1.63071
    1.63038
    1.63013
    1.62993
    1.62988
    1.51282
    1.51284
    1.51282
    1.51284
    1.5128
    1.51277
    1.51267
    1.51255
    1.51241
    1.51221
    1.51213
    1.5117
    1.51131
    1.51112
    1.5109
    1.5106
    1.51038
    1.51
    1.50972
    1.50943
    1.50929
    1.50912
    1.50903
    1.50887
    1.5088
    1.37554
    1.37557
    1.37551
    1.37547
    1.37539
    1.37526
    1.37511
    1.37491
    1.37471
    1.37446
    1.37428
    1.37409
    1.37381
    1.3733
    1.37291
    1.37262
    1.37229
    1.37216
    1.37199
    1.37189
    1.37176
    1.37161
    1.37142
    1.37128
    1.37126
    1.24919
    1.24912
    1.24913
    1.24911
    1.24907
    1.24905
    1.24895
    1.2489
    1.24877
    1.24873
    1.24852
    1.24843
    1.24825
    1.24816
    1.24797
    1.24776
    1.24766
    1.24758
    1.24758
    1.24756
    1.24764
    1.2476
    1.24764
    1.2475
    1.24748
    1.11318
    1.1132
    1.1132
    1.11315
    1.1131
    1.113
    1.11293
    1.1128
    1.11269
    1.11263
    1.11246
    1.11222
    1.11212
    1.1119
    1.1119
    1.11173
    1.11166
    1.11156
    1.11144
    1.11144
    1.11139
    1.1114
    1.11126
    1.11117
    1.11112
    0.986047
    0.98605
    0.986021
    0.985994
    0.985958
    0.985953
    0.985902
    0.985882
    0.985862
    0.985753
    0.985696
    0.985757
    0.985718
    0.985741
    0.985653
    0.985684
    0.985621
    0.985668
    0.985679
    0.985742
    0.985764
    0.985816
    0.985801
    0.985722
    0.985683
    0.850852
    0.850828
    0.850842
    0.850796
    0.850764
    0.850715
    0.850595
    0.850523
    0.850386
    0.850218
    0.850163
    0.850059
    0.850021
    0.849933
    0.849904
    0.849827
    0.849897
    0.849844
    0.849967
    0.849956
    0.850129
    0.850129
    0.850119
    0.850004
    0.849993
    0.72322
    0.723219
    0.723168
    0.723188
    0.723205
    0.72319
    0.723291
    0.723312
    0.723289
    0.723364
    0.723374
    0.723393
    0.723413
    0.723427
    0.723469
    0.723464
    0.723433
    0.723435
    0.72342
    0.723495
    0.723593
    0.723675
    0.72367
    0.723614
    0.723624
    0.588544
    0.588553
    0.588524
    0.58856
    0.588456
    0.588381
    0.588228
    0.588079
    0.588023
    0.587939
    0.587933
    0.587901
    0.587847
    0.58787
    0.587778
    0.587892
    0.58775
    0.58788
    0.587929
    0.587983
    0.588115
    0.588224
    0.588247
    0.588184
    0.588176
    0.460733
    0.460707
    0.460783
    0.460706
    0.460777
    0.460789
    0.460852
    0.4609
    0.460948
    0.461034
    0.461033
    0.460993
    0.46101
    0.460953
    0.46097
    0.460876
    0.46099
    0.460862
    0.46089
    0.460867
    0.461056
    0.461141
    0.461208
    0.4611
    0.461116
    0.3263
    0.32631
    0.326259
    0.326284
    0.326204
    0.326162
    0.326065
    0.32599
    0.325944
    0.325867
    0.3258
    0.325803
    0.325782
    0.325739
    0.325783
    0.325732
    0.325814
    0.325752
    0.325748
    0.325634
    0.325831
    0.325858
    0.325945
    0.325862
    0.325925
    0.198387
    0.198387
    0.19838
    0.198379
    0.19838
    0.198385
    0.198408
    0.198401
    0.198452
    0.198453
    0.198529
    0.198519
    0.198553
    0.198528
    0.198507
    0.198412
    0.198322
    0.198197
    0.198173
    0.198015
    0.198055
    0.198112
    0.198217
    0.198335
    0.198368
    0.0639617
    0.0639706
    0.0639747
    0.0639733
    0.0639593
    0.0639489
    0.0639239
    0.0639184
    0.0638669
    0.0638353
    0.0637998
    0.0637847
    0.0637588
    0.0637369
    0.0637026
    0.063645
    0.0636016
    0.0635269
    0.06342
    0.0632935
    0.0631483
    0.0632062
    0.063256
    0.0633831
    0.0634023
    boundaryField
        inlet
            type            zeroGradient;
        outlet
            type            fixedValue;
            value           uniform 0;
        walls
            type            zeroGradient;
        defaultFaces
            type            empty;
  • 在fe40上安装waves2foam环境变量出错
    洱聿洱 洱聿
    简单记录一下,两个问题
    1.ocean-wave3d这个安装包没有下载好
    2.fe40需要gcc5版本,虚拟机里没有统一成一个版本。
    洱聿洱 洱聿
    foam-extend4.0已经安装成功,下载的是waves2foam r2104版本,但是运行waves2foam/ThirdParty/Allwamke时出现环境变量报错:
        COMPILE OCEANWAVE3D
    Cloning the OceanWave3D git repository ...
    Cloning into 'OceanWave3D-Fortran90'...
    remote: Enumerating objects: 5024, done.
    remote: Total 5024 (delta 0), reused 0 (delta 0), pack-reused 5024
    Receiving objects: 100% (5024/5024), 16.61 MiB | 10.43 MiB/s, done.
    Resolving deltas: 100% (3755/3755), done.
    Set the environmental variables for waves2Foam
    Exiting compilation process
    waves2foam在fe40中的路径在
    /home/thia/foam/thia-4.0/applications/utilities/waves2Foam/
    在waves2foam/bin/bashrc.org文件中环境变量是显示如下:
    ### USER DEFINED ENVIRONMENTAL VARIABLES
    export WAVES_DIR=$WM_PROJECT_USER_DIR/applications/utilities/waves2Foam
    export WAVES_APPBIN=$FOAM_USER_APPBIN
    export WAVES_LIBBIN=$FOAM_USER_LIBBIN
    export WAVES_GSL_INCLUDE=/usr/include
    export WAVES_GSL_LIB=/usr/lib64
    我修改了几次环境变量都是同样的问题,想问一下大家有什么建议:134: ?
