  4. 计算钝体涡激振动时发散(pimpleDyMFoam)
21 帖子 3 发布者 26.1k 浏览
    WYing
    各位老师好,我使用pimpleDyMFoam计算钝体涡激振动时,算例的CFL越来越大并计算一段时间后发散。通过查看速度和压力场,发现一开始就不太正常,然后随着时间推移,误差逐渐积累最后发散。报错如下:
    #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
    #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    #7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/ying/OpenFOAM41/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/pimpleDyMFoam"
    #8  ? in "/home/ying/OpenFOAM41/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/pimpleDyMFoam"
    #9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #10  ? in "/home/ying/OpenFOAM41/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/pimpleDyMFoam"
    我查了一下有人说很可能是网格或边界条件的问题。我的边界条件是比较基础的速度入口/压力出口,感觉应该没问题;我也使用了refine的网格重新计算,发现crash的时间延长了,但速度场和压力场还是一开始就不正确。两种网格质量都没问题。
    我附加了我的算例设置文件,和流场图以供参考。
    1. 粗网格及流场
    2. 细网格及流场
    3. 边界条件(U/p/pointDisplacement)
        version     2.0;
        format      ascii;
        class       volVectorField;
        location    "0";
        object      U;
    boundaryField
        INLET
            type            fixedValue;
            value           uniform (1 0 0);
        OUTLET
            type            zeroGradient;
        TOP
            type            symmetry;
        BOTTOM
            type            symmetry;
        CYLINDER
            type            movingWallVelocity;
        frontAndBackPlanes
            type            empty;
        version     2.0;
        format      ascii;
        class       volScalarField;
        location    "0";
        object      p;
    internalField   uniform 0;
    boundaryField
        INLET
            type            zeroGradient;
        OUTLET
            type            fixedValue;
            value           uniform 0;
        TOP
            type            symmetry;
        BOTTOM
            type            symmetry;
        CYLINDER
            type            zeroGradient;
        frontAndBackPlanes
            type            empty;
        version     2.0;
        format      ascii;
        class       pointVectorField;
        location    "0";
        object      pointDisplacement;
    dimensions      [0 1 0 0 0 0 0];
    boundaryField
        INLET
            type            fixedValue;
        OUTLET
            type            fixedValue;
        TOP
            type            symmetry;
        BOTTOM
            type            symmetry;
        CYLINDER
            type            calculated;
        frontAndBackPlanes
            type            empty;
    1. fvScheme & fvSolution
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvSchemes;
    ddtSchemes
        default         backward;
    gradSchemes
        default         Gauss linear;
        grad(p)         Gauss linear;
        grad(U)         Gauss linear;
    divSchemes
        default         none;
        div(phi,U)      Gauss linearUpwind grad(U);
        div(div(phi,U)) Gauss linear;
        div(phi,k)      Gauss limitedLinear 1;
        div(phi,omega)  Gauss limitedLinear 1;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    wallDist
        method meshWave;
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvSolution;
    solvers
        "pcorr.*"
            solver           GAMG;
            tolerance        0.02;
            relTol           0;
            smoother         GaussSeidel;
        "(p|Phi)"
            $pcorr;
            tolerance        1e-7;
            relTol           0.01;
        pFinal
            $p;
            tolerance        1e-7;
            relTol           0;
        "(U|k|omega)"
            solver          smoothSolver;
            tolerance       1e-06;
            relTol          0.1;
        "(U|k|omega)Final"
            $U;
            tolerance       1e-06;
            relTol          0;
        cellDisplacement
            solver          GAMG;
            tolerance       1e-5;
            relTol          0;
    PIMPLE
        correctPhi          yes;
        nOuterCorrectors    2;
        nCorrectors         2;
        nNonOrthogonalCorrectors 1;
    relaxationFactors
        fields
            p                  0.3;
        equations
            "(U|k|omega)"      0.7;
            "(U|k|omega)Final" 1.0;
    potentialFlow
        nNonOrthogonalCorrectors 15;
    cache
        grad(U);
    1. dynamicMeshDict
        version         2;
        format          ascii;
        class           dictionary;
        object          dynamicMeshDict;
    dynamicFvMesh   dynamicMotionSolverFvMesh;
    motionSolverLibs ( "libsixDoFRigidBodyMotion.so" );
    solver          sixDoFRigidBodyMotion;
    sixDoFRigidBodyMotionCoeffs
        patches         ( CYLINDER );
        innerDistance   2.5;
        outerDistance   20;
        mass            11.4586;
        centreOfMass    ( 0.280485 0 0 );
        momentOfInertia ( 0.6414 0.6414 0.24 );
        g               ( 0 0 0 );
        rho             rhoInf;
        rhoInf          1.225;
        report          on;
        solver
            type            Newmark;
            gamma           0.5;
            beta            0.25;
        constraints
            yLine
                sixDoFRigidBodyMotionConstraint line;
                centreOfRotation ( 0.280485 0 0 );
                direction       ( 0 1 0 );
            noRotation
                sixDoFRigidBodyMotionConstraint orientation;
        restraints
            verticalSpring
                sixDoFRigidBodyMotionRestraint linearSpring;
                anchor          ( 0.280485 0 0 );
                refAttachmentPt ( 0.280485 0 0 );
                stiffness       10.70694631;
                damping         0;
                restLength      0;
    请各位老师帮忙看看是什么问题,困扰好久了。。。谢谢!
    W C 2 条回复 最后回复
    WYing
    在 中回复了 WYing 最后由 编辑
    @wying 没有人看嘛。。。救救孩子。。。
    在 中回复了 WYing 最后由 编辑
    @wying 动网格这面最大的问题就是网格变形过大导致的库朗数特别大,需要大幅度降低时间步长保证收敛。你需要保证时间步长充分的小。
    debug的时候要检查边界条件是否有问题可以先忽略网格变形,先直接算看能不能算出大体的结果。如果正确的话说明不是边界条件的问题。
    WYing
    @李东岳 感谢李老师的回复!我按照您的建议,先计算了钝体绕流(不加动网格)的情况,发现能够得到合理的流场和大致结果,这应该说明了边界条件设置没有问题。那么就是动网格的设置出错了?我计算的是圆柱+不同长度分流板的流致振动,奇怪的是,大部分算例可以正常计算,只有某些长度的分流板会导致结果发散。所有算例的网格划分方式和参数设置都一样的,真是百思不得其解。。。
    在 中回复了 WYing 最后由 编辑
    @wying 可能某些长度的板子网格变形太大了
    WYing
    @李东岳 我也想过这个可能性。如果是因为网格变形增大导致的发散,那么至少在开始一段时间内变形较小的时候计算能正常进行。但是这些发散的case从一开始的流场就有问题,而不是说随着网格变形增大,逐渐发散。。
    在 中回复了 WYing 最后由 编辑
    @wying 如果发散的算例网格比较少、也不涉密、可以发上来我给你看看
    WYing
    @李东岳 感谢您的回复! crash.zip 这是我的case文件,由于大小限制,文件夹内没有包含最后一个时间步,但是大概在time=1.8所有停止计算。欢迎您提出的任何意见或建议!
    在 中回复了 WYing 最后由 编辑
    @wying 不好意思明天我就要去杭州了... 国庆后回来 只能看看有没有其他大佬能给你看看了,:135:
    WYing
    @李东岳 谢谢李老师的回复!我尝试使用高版本的OF计算,发现相同设置下算例可以正常计算,不确定这是不是低版本的OF涉及动网格时存在bug。不过有个case在所有版本OF下都发散。。。能麻烦李老师有空的话帮忙看一下吗?算例文件case.zip (大约在time=1.43发散)十分感谢!!
    在 中回复了 WYing 最后由 编辑
    好的 我给你瞅瞅最新的这个case.zip
    cresendo
    在 中回复了 WYing 最后由 编辑
    @wying 试试看对p不要进行松弛
    WYing
    在 中回复了 cresendo 最后由 编辑
    @cresendo 谢谢您的建议!去掉p松弛之后,算例确实可以计算下去,但是CFL保持在20左右,且速度场和压力场也明显有问题。所以还是不太对,不过还是感谢您的帮助!
    cresendo
    在 中回复了 WYing 最后由 编辑
    @wying 那应该就是动网格的问题了,试试在dynamicMeshDict里将松弛因子调成0.4试试
    WYing
    @cresendo 请问您说的dynamicMeshDict里的松弛因子是 accelerationRelaxation 0.9 和 accelerationDamping 0.95 吗?
    cresendo
    在 中回复了 WYing 最后由 编辑
    @wying 前者
    WYing
    #17
    @cresendo 我按照您的建议,调整了accelerationRelaxation 0.4,计算可以正常进行,CFL数小于1, 流场看上去也正常。
    但有一个小疑问,通过查询dynamicMeshDict文件的官方描述,得知accelerationRelaxation直接减小刚体的加速度,比如在某时间步solver求出的加速度为10m/s^2,如果设置accelerationRelaxation=0.4,那么实际应用的加速为4m/s^2,这是一个很大的松弛。而官方描述中建议的accelerationRelaxation范围是0.9-1,并且提到 “Be careful with this accelerationRelaxation. Too low of a value will mean that the Body does not respond to the fluid forces correctly”。因此我担心设置较小的加速度松弛会不会对结果产生太大影响?因为没有实验结果作为参照,所以无法判断结果的准确性。不知道您一般是如何处理这种误差的?谢谢!
    cresendo
    在 中回复了 WYing 最后由 编辑
    #18
    @wying 你说的这种松弛方式是不正确的,应该是上一时间步的0.6加上当前时间步的0.4,这样松弛以后获得最终的加速度。至于wikidict上说的这个建议,松弛应该影响是的最终稳定的速度,但是可能的确会导致响应运动不是那么准确。因此,还是建议你寻找一个标模实验验证一下(这种实验很多):146:
    WYing
    #19
    @cresendo 我重新查看了source code,aRel的松弛方式确实如您所说,感谢指出错误!我对比了不同aRel的结果,发现Rel = 0.4-0.8都可以正常运行且结果几乎相同,但是aRel >0.8之后会发散。我不确定为什么wikidict上说太小的aRel会造成不准确的响应,至少我的结果并不受aRel取值的影响。相反,恰当的aRel可以使本来发散的case收敛。我之前没有指定过aRel,也就是取默认值1.0,因此比较好奇为什么您会设定aRel=0.4而不是其他值,是根据模拟的经验吗?谢谢!
    cresendo
    在 中回复了 WYing 最后由 编辑
    #20
    @wying 0.4是比较保守的设置,我也是根据自带的DTCHull算例参考的。但是对于涡激运动问题,以我个人2D的尝试,0.9是可以跑的。我本人是做涡激运动的,这是我的songtao.chen@sjtu.edu.cn,有问题可以一起交流~
