@李东岳 非常感谢李老师不厌其烦的指导!!tmp的问题已经解决了,不过又出现了量纲的问题,我自己再看看。
风大仙
 tmp类使用问题,承接上次的帖子问题
 tmp类使用问题,承接上次的帖子问题@李东岳 感谢李老师,前面整个correct函数是这样的 template<class BasicTurbulenceModel> void kOmegaSSTIDDESTr<BasicTurbulenceModel>::correct() { if (!this->turbulence_) { return; } // Local references const alphaField& alpha = this->alpha_; const rhoField& rho = this->rho_; const surfaceScalarField& alphaRhoPhi = this->alphaRhoPhi_; const volVectorField& U = this->U_; volScalarField& nut = this->nut_; fv::options& fvOptions(fv::options::New(this->mesh_)); BasicTurbulenceModel::correct(); volScalarField::Internal divU ( fvc::div(fvc::absolute(this->phi(), U))()() ); tmp<volTensorField> tgradU = fvc::grad(U); volScalarField S2(2*magSqr(symm(tgradU()))); volScalarField::Internal GbyNu(dev(twoSymm(tgradU()())) && tgradU()()); volScalarField::Internal G(this->GName(), nut()*GbyNu); tgradU.clear(); // Update omega and G at the wall omega_.boundaryFieldRef().updateCoeffs(); volScalarField CDkOmega ( (2*alphaOmega2_)*(fvc::grad(k_) & fvc::grad(omega_))/omega_ ); volScalarField F1(this->F1(CDkOmega)); volScalarField F23(this->F23()); { volScalarField::Internal gamma(this->gamma(F1)); volScalarField::Internal beta(this->beta(F1)); // Turbulent frequency equation tmp<fvScalarMatrix> omegaEqn ( fvm::ddt(alpha, rho, omega_) + fvm::div(alphaRhoPhi, omega_) - fvm::laplacian(alpha*rho*DomegaEff(F1), omega_) == alpha()*rho()*gamma *min ( GbyNu, (c1_/a1_)*betaStar_*omega_() *max(a1_*omega_(), b1_*F23()*sqrt(S2())) ) - fvm::SuSp((2.0/3.0)*alpha()*rho()*gamma*divU, omega_) - fvm::Sp(alpha()*rho()*beta*omega_(), omega_) - fvm::SuSp ( alpha()*rho()*(F1() - scalar(1))*CDkOmega()/omega_(), omega_ ) + Qsas(S2(), gamma, beta) + omegaSource() + fvOptions(alpha, rho, omega_) ); omegaEqn.ref().relax(); fvOptions.constrain(omegaEqn.ref()); omegaEqn.ref().boundaryManipulate(omega_.boundaryFieldRef()); solve(omegaEqn); fvOptions.correct(omega_); bound(omega_, this->omegaMin_); } k方程。。。
 tmp类使用问题,承接上次的帖子问题@李东岳 李老师,前面有个epsilonByk函数, template<class BasicTurbulenceModel> tmp<volScalarField::Internal> kOmegaSSTDES<BasicTurbulenceModel>::epsilonByk ( const volScalarField& F1, const volTensorField& gradU ) const { volScalarField CDES(this->CDES(F1)); return sqrt(this->k_())/dTilda(mag(gradU), CDES)()(); }但是我把tgradU换成gradU,编译报错: kOmegaSSTIDDESTr.C: In member function ‘virtual void Foam::LESModels::kOmegaSSTIDDESTr<BasicTurbulenceModel>::correct()’: kOmegaSSTIDDESTr.C:1248:59: error: ‘gradU’ was not declared in this scope - fvm::Sp(alpha()*rho()*betaStar_*omega_*dTilda(mag(gradU), CDES)(), k_) ^~~~~ kOmegaSSTIDDESTr.C:1248:59: note: suggested alternative: ‘tgradU’ - fvm::Sp(alpha()*rho()*betaStar_*omega_*dTilda(mag(gradU), CDES)(), k_) ^~~~~ tgradU /home/fxr/OpenFOAM/OpenFOAM-7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt64Opt/IDDESturbulentTransportModels.o' failed make: *** [Make/linux64GccDPInt64Opt/IDDESturbulentTransportModels.o] Error 1
 tmp类使用问题,承接上次的帖子问题@李东岳 谢谢,按照您的方法试了,就是这行的问题,一去掉就可以算 - fvm::Sp(alpha()*rho()*betaStar_*omega_*dTilda(mag(tgradU), CDES)(), k_)
 tmp类使用问题,承接上次的帖子问题@李东岳 李老师我加了()还是不行啊。。。纠结两天了。。。。
 顺手贴下问题:主要是在of org版本上添加kOmegaSSTIDDES模型,但是org版本只有kOmegaSSTDES,所以我把openfoam +版本的kOmegaSSTIDDES移植过来,涉及到长度尺度dTilda()函数,目前跟露珠遇到的问题一样,编译通过但计算一步就崩,报错信息:--> FOAM FATAL ERROR: tmp<N4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEE> deallocated From function const T& Foam::tmp<T>::operator()() const [with T = Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>] in file /home/fxr/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/tmpI.H at line 278. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >::operator()() const at ??:? #3 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::mag<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #4 Foam::LESModels::kOmegaSSTIDDESTr<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() at ??:? #5 ? in "/home/fxr/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/pimpleFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? in "/home/fxr/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/pimpleFoam" Aborted (core dumped)dTilda代码: template<class BasicTurbulenceModel> tmp<volScalarField> kOmegaSSTIDDESTr<BasicTurbulenceModel>::dTilda ( const volScalarField& magGradU, const volScalarField& CDES ) const { const volScalarField& k = this->k_; const volScalarField& omega = this->omega_; const volScalarField lRAS(sqrt(k)/(this->betaStar_*omega)); const volScalarField lLES(CDES*this->delta()); const volScalarField alpha(this->alpha()); const volScalarField expTerm(exp(sqr(alpha))); tmp<volScalarField> fB = min(2*pow(expTerm, -9.0), scalar(1)); tmp<volScalarField> fe1 = 2*(pos0(alpha)*pow(expTerm, -11.09) + neg(alpha)*pow(expTerm, -9.0)); tmp<volScalarField> fe2 = 1 - max(ft(magGradU), fl(magGradU)); tmp<volScalarField> fe = max(fe1 - 1, scalar(0))*fe2; const volScalarField fdTilda(max(1 - fdt(magGradU), fB)); return max ( fdTilda*(1 + fe)*lRAS + (1 - fdTilda)*lLES, dimensionedScalar("SMALL", dimLength, SMALL) ); }后面k方程中包含了dTilda的调用: // Turbulent kinetic energy equation volScalarField CDES(this->CDES(F1)); tmp<fvScalarMatrix> kEqn ( fvm::ddt(alpha, rho, k_) + fvm::div(alphaRhoPhi, k_) - fvm::laplacian(alpha*rho*DkEff(F1), k_) == alpha()*rho()*Pk(G) - fvm::SuSp((2.0/3.0)*alpha()*rho()*divU, k_) - fvm::Sp(alpha()*rho()*betaStar_*omega_*dTilda(mag(tgradU), CDES)(), k_) + kSource() + fvOptions(alpha, rho, k_) );各位老师有没有什么建议啊???谢谢了
 tmp类使用问题,承接上次的帖子问题@悬浮的猪 请问楼主解决了么?我修改湍流模型也遇到了一样的问题
 湍流模型编译通过但是在计算的时候显示不能加载动态库@李东岳 谢谢李老师,计算之前controlDict已经事先挂载过了 libs ("test1_libIncompressibleTurbulenceModels.so");
 湍流模型编译通过但是在计算的时候显示不能加载动态库请教各位老师,在DES模型的基础上做了修改,wmake后: wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file myTurbulentTransportModels.C g++ -std=c++11 -m64 -DOPENFOAM=1806 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I../turbulenceModels/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/transportModels -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/finiteVolume/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/meshTools/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/TurbulenceModels/incompressible/lnInclude -IlnInclude -I. -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/OSspecific/POSIX/lnInclude -fPIC -c turbulentTransportModels/myTurbulentTransportModels.C -o Make/linux64GccDPInt64Opt/turbulentTransportModels/myTurbulentTransportModels.o g++ -std=c++11 -m64 -DOPENFOAM=1806 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I../turbulenceModels/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/transportModels -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/finiteVolume/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/meshTools/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/TurbulenceModels/incompressible/lnInclude -IlnInclude -I. -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/OpenFOAM/lnInclude -I/home/fxr/OpenFOAM/OpenFOAM-v1806/src/OSspecific/POSIX/lnInclude -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/turbulentTransportModels/myTurbulentTransportModels.o -L/home/fxr/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt64Opt/lib \ -lincompressibleTransportModels -lturbulenceModels -lfiniteVolume -lmeshTools -lincompressibleTurbulenceModels -o /home/fxr/OpenFOAM/fxr-v1806/platforms/linux64GccDPInt64Opt/lib/test1_libIncompressibleTurbulenceModels.so以上编译应该是没问题的,但是当我在算例中调用新的湍流模型后就报错: Create time --> FOAM Warning : From function void* Foam::dlOpen(const Foam::fileName&, bool) in file POSIX.C at line 1516 dlopen error : /home/fxr/OpenFOAM/fxr-v1806/platforms/linux64GccDPInt64Opt/lib/test1_libIncompressibleTurbulenceModels.so: undefined symbol: _ZNK4Foam9LESModels17kOmegaSSTIDDES_TrINS_29IncompressibleTurbulenceModelINS_14transportModelEEEE5GbyNuERKNS_16DimensionedFieldIdNS_7volMeshEEESA_SA_ --> FOAM Warning : From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 109 could not load "test1_libIncompressibleTurbulenceModels.so" Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 5 corrector loops Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type LES [0] [0] [0] --> FOAM FATAL ERROR: [0] Unknown LESModel type banana Valid LESModel types: 12 ( DeardorffDiffStress Smagorinsky SpalartAllmarasDDES SpalartAllmarasDES SpalartAllmarasIDDES WALE dynamicKEqn dynamicLagrangian kEqn kOmegaSSTDDES kOmegaSSTDES kOmegaSSTIDDES )而且可以看到有效模型里面并没有出现自己修改的湍流模型,请问各位老师是什么原因???
 make/files如下turbulentTransportModels/myTurbulentTransportModels.C LIB = $(FOAM_USER_LIBBIN)/test1_libIncompressibleTurbulenceModelsmake/options如下 EXE_INC = \ -I../turbulenceModels/lnInclude \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude LIB_LIBS = \ -lincompressibleTransportModels \ -lturbulenceModels \ -lfiniteVolume \ -lmeshTools \ -lincompressibleTurbulenceModels用的openfoam1806,感谢
 在pimpleFoam中加入solidparticle,编译错误,请问如何处理?@星星星星晴 好的,感谢您的指点!
 在pimpleFoam中加入solidparticle,编译错误,请问如何处理?@星星星星晴 谢谢您的回复!
 我打算在单相求解器上添加solidparticle实现粒子运动,还不涉及界面问题,所以选了pimpleFoam。
 还有个问题想请教您,假如不考虑粒子的重力,那么该怎么调用粒子运动函数?
 还是这样吗particles.move(g);
 在pimpleFoam中加入solidparticle,编译错误,请问如何处理?根据chalmers教程在interFoam的基础上添加solidparticle可以编译通过,但是换成pimpleFoam之后就会报错: pimpleFoam.C:99:24: error: 'g' was not declared in this scope particles.move(g);以下个人理解,这里particles是solidParticleCloud类的实例化对象,但是看了solidParticleCloud.H源码,g好像已经声明过了,不知道对不对,请大佬指点一下,谢谢!!! public: // Constructors //- Construct given mesh solidParticleCloud ( const fvMesh&, const word& cloudName = "defaultCloud", bool readFields = true ); // Member Functions // Access bool hasWallImpactDistance() const; inline const fvMesh& mesh() const; inline scalar rhop() const; inline scalar e() const; inline scalar mu() const; // Edit //- Move the particles under the influence of the given // gravitational acceleration void move(const dimensionedVector& g);
 OF7中LPT耦合interPhaseChangeFoam编译报错各位老师好!
 报错信息:
  solidParticleCloud.C的代码: solidParticle::trackingData td(*this, rhoInterp, UInterp, nuInterp, g.value()); Cloud<solidParticle>::move(*this, td, mesh_.time().deltaTValue()); if(mesh_.time().value()> td.cloud().tInjStart_ && // mesh_.time().value()< td.cloud().tInjEnd_) {this->inject(td);} void Foam::solidParticleCloud::inject(solidParticle::trackingData &td) //. { //. label cellI = -1; //. label tetFaceI = -1; label tetPtI = -1; mesh_.findCellFacePt(td.cloud().posB_, cellI, tetFaceI, tetPtI); if(cellI > 0){ solidParticle* ptr1 = new solidParticle(mesh_, td.cloud().posB_, cellI, tetFaceI, tetPtI,td.cloud().dB_, td.cloud().UB_); Cloud<solidParticle>::addParticle(ptr1); } }
 用fluent做了LES计算,如何得到脉动速度的RMS?雷诺应力?等湍流统计参数不应该是亚格子应力吗
 Fluent meshing totorials@ibelief 多谢!
 平面叶栅计算,采用sst湍流模型,吸力面分离过小cfx计算用的SST?
