  4. tmp类使用问题,承接上次的帖子问题
tmp类使用问题,承接上次的帖子问题
13 帖子 3 发布者 17.9k 浏览
    这个问题是某个tmp类型,已经销毁掉了,但是又被继续调用了。tmp类型使用的使用可以后面加()试一下
    风 1 条回复 最后回复
  • 风 离线
    风 离线
    风大仙
    @李东岳 李老师我加了()还是不行啊。。。纠结两天了。。。。
    顺手贴下问题:主要是在of org版本上添加kOmegaSSTIDDES模型,但是org版本只有kOmegaSSTDES,所以我把openfoam +版本的kOmegaSSTIDDES移植过来,涉及到长度尺度dTilda()函数,目前跟露珠遇到的问题一样,编译通过但计算一步就崩,报错信息:
    --> FOAM FATAL ERROR:
    tmp<N4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEE> deallocated
        From function const T& Foam::tmp<T>::operator()() const [with T = Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>]
        in file /home/fxr/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/tmpI.H at line 278.
    FOAM aborting
    #2  Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >::operator()() const at ??:?
    #3  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::mag<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
    #4  Foam::LESModels::kOmegaSSTIDDESTr<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() at ??:?
    #5  ? in "/home/fxr/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/pimpleFoam"
    #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #7  ? in "/home/fxr/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/pimpleFoam"
    Aborted (core dumped)
    dTilda代码:
    tmp<volScalarField> kOmegaSSTIDDESTr<BasicTurbulenceModel>::dTilda
        const volScalarField& magGradU,
        const volScalarField& CDES
    ) const
        const volScalarField& k = this->k_;
        const volScalarField& omega = this->omega_;
        const volScalarField lRAS(sqrt(k)/(this->betaStar_*omega));
        const volScalarField lLES(CDES*this->delta());
        const volScalarField alpha(this->alpha());
        const volScalarField expTerm(exp(sqr(alpha)));
        tmp<volScalarField> fB = min(2*pow(expTerm, -9.0), scalar(1));
        tmp<volScalarField> fe1 =
            2*(pos0(alpha)*pow(expTerm, -11.09) + neg(alpha)*pow(expTerm, -9.0));
        tmp<volScalarField> fe2 = 1 - max(ft(magGradU), fl(magGradU));
        tmp<volScalarField> fe = max(fe1 - 1, scalar(0))*fe2;
        const volScalarField fdTilda(max(1 - fdt(magGradU), fB));
        return max
            fdTilda*(1 + fe)*lRAS + (1 - fdTilda)*lLES,
            dimensionedScalar("SMALL", dimLength, SMALL)
    后面k方程中包含了dTilda的调用:
     // Turbulent kinetic energy equation
        volScalarField CDES(this->CDES(F1));
        tmp<fvScalarMatrix> kEqn
            fvm::ddt(alpha, rho, k_)
          + fvm::div(alphaRhoPhi, k_)
          - fvm::laplacian(alpha*rho*DkEff(F1), k_)
            alpha()*rho()*Pk(G)
          - fvm::SuSp((2.0/3.0)*alpha()*rho()*divU, k_)
          - fvm::Sp(alpha()*rho()*betaStar_*omega_*dTilda(mag(tgradU), CDES)(), k_)
          + kSource()
          + fvOptions(alpha, rho, k_)
    各位老师有没有什么建议啊???谢谢了
    你最好debug到具体某一行(比如这一行去掉就没问题,这一行放进去就有问题)
    风 1 条回复 最后回复
  • 风 离线
    风 离线
    风大仙
    @李东岳 谢谢,按照您的方法试了,就是这行的问题,一去掉就可以算
    tgradU是不是tmp,前面怎么用的
    风 1 条回复 最后回复
  • 风 离线
    风 离线
    风大仙
    @李东岳 李老师,前面有个epsilonByk函数,
    tmp<volScalarField::Internal> kOmegaSSTDES<BasicTurbulenceModel>::epsilonByk
        const volScalarField& F1,
        const volTensorField& gradU
    ) const
        return sqrt(this->k_())/dTilda(mag(gradU), CDES)()();
    但是我把tgradU换成gradU,编译报错:
    kOmegaSSTIDDESTr.C: In member function ‘virtual void Foam::LESModels::kOmegaSSTIDDESTr<BasicTurbulenceModel>::correct()’:
    kOmegaSSTIDDESTr.C:1248:59: error: ‘gradU’ was not declared in this scope
           - fvm::Sp(alpha()*rho()*betaStar_*omega_*dTilda(mag(gradU), CDES)(), k_)
    kOmegaSSTIDDESTr.C:1248:59: note: suggested alternative: ‘tgradU’
                                                               tgradU
    /home/fxr/OpenFOAM/OpenFOAM-7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt64Opt/IDDESturbulentTransportModels.o' failed
    make: *** [Make/linux64GccDPInt64Opt/IDDESturbulentTransportModels.o] Error 1
    前面的tgradU怎么用的,把涉及到tgradU的代码贴一下
    风 1 条回复 最后回复
  • 风 离线
    风 离线
    风大仙
    @李东岳 感谢李老师,前面整个correct函数是这样的
    void kOmegaSSTIDDESTr<BasicTurbulenceModel>::correct()
        if (!this->turbulence_)
            return;
        // Local references
        const alphaField& alpha = this->alpha_;
        const rhoField& rho = this->rho_;
        const surfaceScalarField& alphaRhoPhi = this->alphaRhoPhi_;
        const volVectorField& U = this->U_;
        volScalarField& nut = this->nut_;
        fv::options& fvOptions(fv::options::New(this->mesh_));
        BasicTurbulenceModel::correct();
        volScalarField::Internal divU
            fvc::div(fvc::absolute(this->phi(), U))()()
        tmp<volTensorField> tgradU = fvc::grad(U);
        volScalarField S2(2*magSqr(symm(tgradU())));
        volScalarField::Internal GbyNu(dev(twoSymm(tgradU()())) && tgradU()());
        volScalarField::Internal G(this->GName(), nut()*GbyNu);
        tgradU.clear();
        // Update omega and G at the wall
        omega_.boundaryFieldRef().updateCoeffs();
        volScalarField CDkOmega
            (2*alphaOmega2_)*(fvc::grad(k_) & fvc::grad(omega_))/omega_
        volScalarField F1(this->F1(CDkOmega));
        volScalarField F23(this->F23());
            volScalarField::Internal gamma(this->gamma(F1));
            volScalarField::Internal beta(this->beta(F1));
            // Turbulent frequency equation
            tmp<fvScalarMatrix> omegaEqn
                fvm::ddt(alpha, rho, omega_)
              + fvm::div(alphaRhoPhi, omega_)
              - fvm::laplacian(alpha*rho*DomegaEff(F1), omega_)
                alpha()*rho()*gamma
               *min
                    GbyNu,
                    (c1_/a1_)*betaStar_*omega_()
                   *max(a1_*omega_(), b1_*F23()*sqrt(S2()))
              - fvm::SuSp((2.0/3.0)*alpha()*rho()*gamma*divU, omega_)
              - fvm::Sp(alpha()*rho()*beta*omega_(), omega_)
              - fvm::SuSp
                    alpha()*rho()*(F1() - scalar(1))*CDkOmega()/omega_(),
                    omega_
              + Qsas(S2(), gamma, beta)
              + omegaSource()
              + fvOptions(alpha, rho, omega_)
            omegaEqn.ref().relax();
            fvOptions.constrain(omegaEqn.ref());
            omegaEqn.ref().boundaryManipulate(omega_.boundaryFieldRef());
            solve(omegaEqn);
            fvOptions.correct(omega_);
            bound(omega_, this->omegaMin_);
    k方程。。。
    • 你把tgradU.clear();去掉,
    • 然后使用的时候用tgradU()()
    风 1 条回复 最后回复
  • 风 离线
    风 离线
    风大仙
    @李东岳 非常感谢李老师不厌其烦的指导!!tmp的问题已经解决了,不过又出现了量纲的问题,我自己再看看。
