A
Aeronastro
@Aeronastro
  • ICEM对网格进行局部加密之后,可以用mapFields么
    A Aeronastro
    ICEM中对网格进行了局部加密,局部加密了以后,不同block的同一条edge上节点不一样,我在mapFields时会不会出问题?
  • mapFields如何实现并行映射呢
    A Aeronastro
    @李东岳 谢谢啦
    A Aeronastro
    我之前算了一个算例,网格比较大,最近新创建了一个模型(几何稍微不同),想把之间算好的场映射到新的模型中进行并行计算,如何并行处理映射呢?我如果不进行并行映射,由于网格量太大导致mapFields时出现内存不足的问题。mapFields里有-parallel选项,但不太清楚怎么使用:crying:
  • 执行Mach出现not implement的错误
    A Aeronastro
    在后处理求解马赫数的时候,用Mach执行,但出现如下的错误:
    Time = 0.00056
    Selecting thermodynamics package
        type            hePsiThermo;
        mixture         pureMixture;
        transport       sutherland;
        thermo          eConst;
        equationOfState perfectGas;
        specie          specie;
        energy          sensibleInternalEnergy;
    --> FOAM FATAL ERROR:
    Not Implemented
        Trying to construct an genericFvPatchField on patch boundaryInner of field e
        From function genericFvPatchField<Type>::genericFvPatchField(const fvPatch& p, const DimensionedField<Type, volMesh>& iF)
        in file genericFvPatchField/genericFvPatchField.C at line 44.
    FOAM aborting
    #0  Foam::error::printStack(Foam::Ostream&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libOpenFOAM.so"
    #1  Foam::error::abort() in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libOpenFOAM.so"
    #2  Foam::fvPatchField<double>::addpatchConstructorToTable<Foam::genericFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libgenericPatchFields.so"
    #3  Foam::fvPatchField<double>::New(Foam::word const&, Foam::word const&, Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    #4  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::List<Foam::word> const&, Foam::List<Foam::word> const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libfluidThermophysicalModels.so"
    #5  Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::eConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libfluidThermophysicalModels.so"
    #6  Foam::fluidThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::eConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libfluidThermophysicalModels.so"
    #7  Foam::fluidThermo::New(Foam::fvMesh const&, Foam::word const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libfluidThermophysicalModels.so"
    #8  ? in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    #9  ? in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    #10  ? in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    #11  __libc_start_main in "/lib64/libc.so.6"
    #12  ? in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    Aborted (core dumped)
    这种情况我之前是没有遇到过的,于是检查了一下Mach.C的源码:
    #include "calc.H"
    #include "fluidThermo.H"
    void Foam::calc(const argList& args, const Time& runTime, const fvMesh& mesh)
        bool writeResults = !args.optionFound("noWrite");
        IOobject Uheader
            "U",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
        IOobject Theader
            "T",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
        // Check U and T exists
        if (Uheader.headerOk() && Theader.headerOk())
            autoPtr<volScalarField> MachPtr;
            volVectorField U(Uheader, mesh);
            if
                IOobject
                    "thermophysicalProperties",
                    runTime.constant(),
                    mesh
                ).headerOk()
                // thermophysical Mach
                autoPtr<fluidThermo> thermo
                    fluidThermo::New(mesh)
                volScalarField Cp(thermo->Cp());
                volScalarField Cv(thermo->Cv());
                MachPtr.set
                    new volScalarField
                        IOobject
                            "Ma",
                            runTime.timeName(),
                            mesh
                        mag(U)/(sqrt((Cp/Cv)*(Cp - Cv)*thermo->T()))
            else
                // thermodynamic Mach
                   IOdictionary thermoProps
                    IOobject
                        "thermodynamicProperties",
                        runTime.constant(),
                        mesh,
                        IOobject::MUST_READ_IF_MODIFIED,
                        IOobject::NO_WRITE
                dimensionedScalar R(thermoProps.lookup("R"));
                dimensionedScalar Cv(thermoProps.lookup("Cv"));
                volScalarField T(Theader, mesh);
                MachPtr.set
                    new volScalarField
                        IOobject
                            "Ma",
                            runTime.timeName(),
                            mesh
                        mag(U)/(sqrt(((Cv + R)/Cv)*R*T))
            Info<< "Mach max : " << max(MachPtr()).value() << endl;
            if (writeResults)
                MachPtr().write();
        else
            Info<< "    Missing U or T" << endl;
        Info<< "\nEnd\n" << endl;
    代码中只要有U,T 和热力学模型就好了,不知道为什么错误提示要构造e这个场?谢谢各位!
  • LES模型中delta的选择
    A Aeronastro
    delta可以选择cubeRootVol, vanDriest等,有没有谁比较过采用不同的delta,会对结果产生什么影响吗?
  • OF中的TVD与NVD格式
    A Aeronastro
    最近计算一个可压流算例,用的是rhoCentralFoam,发现interpolationSchemes中的reconstruct(rho)等用tutorials默认的VanLeer格式,得到的结果过耗散,而采用Gamma得到比较清晰的云图。难道TVD格式与NVD格式相比有比较大的数值耗散吗?
    另外我看了一下Gamma.H代码,limiter返回的是phict/k,这个我猜测是Jasak文章中的blending factor吧?OF中的Gamma格式和Jasak这篇文章中说的应该是一样的吧?但我不太清楚最后是如何计算面心的值,没有找到相关的代码,请各位大神指点一下。
    reference
    Jasak H, Weller H G, Gosman A D. High resolution NVD differencing scheme for arbitrarily unstructured meshes[J]. International Journal for Numerical Methods in Fluids, 1999, 31(2):431–449.
  • decomposePar运行时出现问题
    A Aeronastro
    @wwzhao 好的,这个是我速度入口的边界条件
    boundaryField
        inlet
            type        syntheticVelocity;
            Ma          2.3;
            Tinf        104;
            Prt         0.9;
            nmodes      200;
            dxmin       0.01e-03;
            Uinf        552;
            pInf        3998.63;
            pathName    "/home/Ubuntu/WORKPLACE4/syntheticCase-test/data";
            value       uniform (552 0 0);
       other boundaries ......
    由于刚开始计算的时候不知道Ubar,ReynoldStress和deltaInlet,在边条构造时需要通过那个calculateProfiles函数计算。
    其中的data文件中的数据是一列一列排布的,
    0_1479171527178_data
    A Aeronastro
    可能我描述的问题不够准确,下面附上我的部分代码:
    在.H文件中,定义了一些私有变量与私有变量的接口:
    // private perameters
      //- freestream Ma
            scalar Ma_;
            //- freestream T
            scalar Tinf_;
            scalar gamma_;
            scalar Prt_;
            //- munber of modes
            scalar nmodes_;
            //- smallest wavenumber
            scalar dxmin_;
            //- ratio of ke and kmin (in wavenumber)
            scalar wew1fct_;
            scalar amp_;
            //- kinetic viscosity of the smallest eddy
            scalar visc_;
            //- delta Inlet
            scalar deltaInlet_;
            //- freestream Velocity
            scalar Uinf_;
            //- freestream pressure
            scalar pInf_;
            //- read file
            IFstream IF_;
            //- rows of file data
            label ny_;
            //- MeanField
            vectorField Ubar_;
            //- primeField
            vectorField UPrime_;
            //- ReynoldStress tensor
            symmTensorField  ReynoldStress_;
            label curTimeIndex_;
            // member function
            void calculateProfiles(IFstream&, vectorField&, symmTensorField&, scalar&);
    // Access
    	    scalar nmodes() const
    	    	return nmodes_;
    	    scalar deltaInlet() const
    	    	return deltaInlet_;
    	    scalar& deltaInlet()
    	    	return deltaInlet_;
    	    scalar amp() const
    	    	return amp_;
    	    scalar dxmin() const
    	    	return dxmin_;
    	    scalar visc() const
    	    	return visc_;
    	    scalar wew1fct() const
    	    	return wew1fct_;
    	    scalar Ma() const
    	    	return Ma_;
    	    scalar Tinf() const
    	    	return Tinf_;
    	    scalar gamma() const
    	    	return gamma_;
    	    scalar Prt() const
    	    	return Prt_;
    	    scalar Uinf() const
    	    	return Uinf_;
    	    scalar pInf() const
    	    	return pInf_;
    	    IFstream IF() const
    	    	return IF_;
    	    IFstream& IF()
    	    	return IF_;
    	    vectorField& Ubar()
    	    	return Ubar_;
    	    vectorField Ubar() const
    	    	return Ubar_;
    	    symmTensorField& ReynoldStress()
    	    	return ReynoldStress_;
    	    symmTensorField ReynoldStress() const
    	    label ny()
    	    	return ny_;
    然后在.C中,我的构造函数:
    // constrctor
    Foam::syntheticVelocityFixedValueFvPatchField::syntheticVelocityFixedValueFvPatchField
        const fvPatch& p,
        const DimensionedField<vector, volMesh>& iF,
        const dictionary& dict
        fixedValueFvPatchVectorField(p, iF),
        Ma_(readScalar(dict.lookup("Ma"))),
        Tinf_(readScalar(dict.lookup("Tinf"))),
        gamma_(dict.lookupOrDefault("gamma", 1.4)),
        Prt_(dict.lookupOrDefault("Prt", 0.9)),
        nmodes_(readScalar(dict.lookup("nmodes"))),
        dxmin_(readScalar(dict.lookup("dxmin"))),
        wew1fct_(dict.lookupOrDefault("wew1fct", 2.0)),
        amp_(dict.lookupOrDefault("amp", 1.452762113)),
        visc_(dict.lookupOrDefault("visc", 15.2e-6)),
        Uinf_(readScalar(dict.lookup("Uinf"))),
        pInf_(readScalar(dict.lookup("pInf"))),
        IF_(dict.lookup("pathName")),	// stored meanStreamVelocity and ReynoldStress profile data
        ny_(dict.lookupOrDefault("ny", 535)),
        curTimeIndex_(-1)
        if (dict.found("Ubar") && dict.found("ReynoldStress") && dict.found("deltaInlet"))
        	deltaInlet_= scalar(readScalar(dict.lookup("deltaInlet")));
        	Ubar_ = vectorField("Ubar", dict, p.size());
        	ReynoldStress_ = symmTensorField("ReynoldStress", dict, p.size());
        else
        	calculateProfiles(IF(), Ubar(), ReynoldStress(), deltaInlet());
        if (dict.found("UPrime"))
        	UPrime_ = vectorField("UPrime", dict, p.size());
        else
        	UPrime_ = vectorField(p.size(), vector::zero);
        if (dict.found("value"))
            fvPatchField<vector>::operator=
                vectorField("value", dict, p.size())
        else
            fvPatchField<vector>::operator=(Ubar());
    这里调用的成员函数calculateProperties如下:
    // member function
    void Foam::syntheticVelocityFixedValueFvPatchField::calculateProfiles
        IFstream& IF,
        vectorField& Ubar,
        symmTensorField& ReynoldStress,
        scalar& deltaInlet
        if (!IF)
        	FatalErrorIn("void Foam::syntheticVelocityFixedValueFvPatchField::calculateMeanVelocity")
        	 << "can not find " << IF.name() << exit(FatalError);
        else
        	scalarField UvdPlus(ny()), vPlus(ny()), wPlus(ny()), Ux(ny()), Uy(ny()), Uz(ny());
        	symmTensorField stressPlus(ny(), symmTensor::zero);
        	scalarField yPlus(ny()), y(ny());
        	scalar yInf, ySup;
        	scalar R(287.0), max_UvdPlus(26.457427), As(1.512e-06), Ts(120.0);
        	scalar r=pow(Prt(), 1.0/3.0);
        	//- calculate nuwInlet and Utao
        	scalar Taw = Tinf()*(1.0+(gamma()-1.0)/2.0*r*sqr(Ma()));
        	scalar Tw = (Taw - Tinf())/r + Tinf();
        	scalar rhow = pInf()/(R*Tw);
        	scalar muw = As*sqrt(Tw)/(1.0+Ts/Tw);
        	scalar nuwInlet = muw/rhow;
        	scalar A = sqrt((gamma()-1.0)/2.0*Prt()*sqr(Ma())*Tinf()/Tw);
        	scalar B = (1.0+sqrt(Prt())*(gamma()-1.0)/2.0*sqr(Ma()))*Tinf()/Tw - 1.0;
        	scalar Utao = Uinf()/A*(
        	                           asin((2.0*sqr(A)-B)/sqrt(sqr(B)+4.0*sqr(A)))
        	                         + asin(B/sqrt(sqr(B)+4.0*sqr(A)))
        	                       )/max_UvdPlus;	// max(Uvd+) = 25.6803733;
        	const scalarField T = this->patch().lookupPatchField<volScalarField, scalar>("T");
        	//- flag to decide whether to calculate deltaInlet
        	bool delta=true;
        	forAll(UvdPlus, patchI)
        	    IF >> yPlus[patchI] >> UvdPlus[patchI] >> vPlus[patchI] >> wPlus[patchI]
        	       >> stressPlus[patchI].xx() >> stressPlus[patchI].yy() >> stressPlus[patchI].zz() >> stressPlus[patchI].xy();
        	    // calculate dimensional y
        	    y[patchI] = yPlus[patchI]*nuwInlet/Utao;
        	    // calculate dimensional Ux
        	    scalar tmp = A*(UvdPlus[patchI]*Utao)/Uinf() - asin(B/sqrt(sqr(B)+4.0*sqr(A)));
        	    Ux[patchI] = (sin(tmp)*sqrt(sqr(B)+4.0*sqr(A)) + B)/(2.0*sqr(A))*Uinf();
        	    Uy[patchI] = vPlus[patchI]*Utao;
        	    Uz[patchI] = wPlus[patchI]*Utao;
        	    if (Ux[patchI] > 0.99*Uinf() && delta)
        	    	deltaInlet = y[patchI];
        	    	delta = false;	// deltaInlet calculated only once;
        	vectorField Cf = this->patch().Cf();
        	Ubar = vectorField(Cf.size());
        	symmTensorField Reynold(Cf.size(), symmTensor::zero);
        	ReynoldStress = symmTensorField(Cf.size(), symmTensor::zero);
        	// interpolate at the cell
        	forAll(Cf, faceI)
        	    for(label patchI=0; patchI < y.size()-1; patchI++)
        	    	yInf = Cf[faceI][1]-y[patchI];
        	    	ySup = Cf[faceI][1]-y[patchI+1];
        	    	if(yInf*ySup <= 0)
        	    	    Ubar[faceI][0] = yInf/(yInf-ySup)*Ux[patchI+1] - ySup/(yInf-ySup)*Ux[patchI];
        	    	    Ubar[faceI][1] = yInf/(yInf-ySup)*Uy[patchI+1] - ySup/(yInf-ySup)*Uy[patchI];
        	    	    Ubar[faceI][2] = yInf/(yInf-ySup)*Uz[patchI+1] - ySup/(yInf-ySup)*Uz[patchI];
        	    	    Reynold[faceI] = yInf/(yInf-ySup)*stressPlus[patchI+1] - ySup/(yInf-ySup)*stressPlus[patchI];
        	    	    // calculate dimensional Reynold stress
        	    	    scalar ksi = sqrt(Tw/T[faceI]);
        	    	    ReynoldStress[faceI].xx() = sqr(Reynold[faceI].xx()/ksi)*Utao;
        	    	    ReynoldStress[faceI].xy() = -sqr(Reynold[faceI].xy()/ksi)*Utao;
        	    	    ReynoldStress[faceI].yy() = sqr(Reynold[faceI].yy()/ksi)*Utao;
        	    	    ReynoldStress[faceI].zz() = sqr(Reynold[faceI].zz()/ksi)*Utao;
        	    	    break;
        	    	else	// Cf.component(1) is higher than y.last()
        	    	    Ubar[faceI][0] = Ux.last();
        	    	    Ubar[faceI][1] = Uy.last();
        	    	    Ubar[faceI][2] = Uz.last();
        	    	    ReynoldStress[faceI].xx() = sqr(stressPlus.last().xx()/ksi)*Utao;
        	    	    ReynoldStress[faceI].xy() = -sqr(stressPlus.last().xy()/ksi)*Utao;
        	    	    ReynoldStress[faceI].yy() = sqr(stressPlus.last().yy()/ksi)*Utao;
        	    	    ReynoldStress[faceI].zz() = sqr(stressPlus.last().zz()/ksi)*Utao;
        	scalar ymin = min(Cf.component(1));
        	scalar Uxmin = min(Ubar.component(0));
        	scalar dUxdy = Uxmin/ymin;
        	scalar dUdy = sqr(Utao)/nuwInlet;
        	Info << "dUxdy (from case simulation)	=" << dUxdy << nl
        	     << "dUdy (from theory calculation)	=" << dUdy << nl
        	     << "Utao				=" << Utao << nl
        	     << "nuwInlet			=" << nuwInlet << nl
        	     << "deltaInlet			=" << deltaInlet << endl;
    我在单核下测试时时可以计算的,但是想并行计算的时候,decomposePar过不去,终端输出信息如下:
    |  \\    /   O peration     | Version:  2.4.0                                 |
    |   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
    Build  : 2.4.0-dcea1e13ff76
    Exec   : decomposePar
    Date   : Nov 13 2016
    Time   : 10:59:43
    Host   : "zwk"
    PID    : 12485
    Case   : /home/Ubuntu/WORKPLACE4/SyntheticCase-test
    nProcs : 1
    sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
    fileModificationChecking : Monitoring run-time modified files using timeStampMaster
    allowSystemOperations : Allowing user-supplied system call operations
    Create time
    Decomposing mesh region0
    Create mesh
    Calculating distribution of cells
    Selecting decompositionMethod simple
    Finished decomposition in 0.04 s
    Calculating original mesh data
    Distributing cells to processors
    Distributing faces to processors
    Distributing points to processors
    Constructing processor meshes
    Processor 0
        Number of cells = 23686
        Number of faces shared with processor 1 = 1997
        Number of faces shared with processor 1 = 58
        Number of processor patches = 2
        Number of processor faces = 2055
        Number of boundary faces = 4243
    Processor 1
        Number of faces shared with processor 0 = 1997
        Number of faces shared with processor 0 = 58
        Number of faces shared with processor 2 = 1978
        Number of faces shared with processor 2 = 52
        Number of processor patches = 4
        Number of processor faces = 4085
        Number of boundary faces = 2189
    Processor 2
        Number of faces shared with processor 1 = 1978
        Number of faces shared with processor 1 = 52
        Number of faces shared with processor 3 = 1954
        Number of faces shared with processor 3 = 11
        Number of processor faces = 3995
        Number of boundary faces = 2329
    Processor 3
        Number of faces shared with processor 2 = 1954
        Number of faces shared with processor 2 = 11
        Number of faces shared with processor 4 = 1992
        Number of faces shared with processor 4 = 57
        Number of processor faces = 4014
        Number of boundary faces = 2276
    Processor 4
        Number of faces shared with processor 3 = 1992
        Number of faces shared with processor 3 = 57
        Number of faces shared with processor 5 = 1964
        Number of faces shared with processor 5 = 43
        Number of processor faces = 4056
        Number of boundary faces = 2208
    Processor 5
        Number of faces shared with processor 4 = 1964
        Number of faces shared with processor 4 = 43
        Number of faces shared with processor 6 = 1984
        Number of faces shared with processor 6 = 41
        Number of processor faces = 4032
        Number of boundary faces = 2330
    Processor 6
        Number of cells = 23685
        Number of faces shared with processor 5 = 1984
        Number of faces shared with processor 5 = 41
        Number of faces shared with processor 7 = 1986
        Number of faces shared with processor 7 = 55
        Number of processor faces = 4066
        Number of boundary faces = 2218
    Processor 7
        Number of faces shared with processor 6 = 1986
        Number of faces shared with processor 6 = 55
        Number of processor faces = 2041
        Number of boundary faces = 4211
    Number of processor faces = 14172
    Max number of cells = 23686 (0.00105549% above average 23685.8)
    Max number of processor patches = 4 (14.2857% above average 3.5)
    Max number of faces between processors = 4085 (15.2978% above average 3543)
    Time = 0
    dUxdy (from case simulation)	=2.46405e+06
    dUdy (from theory calculation)	=2.46471e+06
    Utao				=23.1659
    nuwInlet			=0.000217736
    deltaInlet			=0.0144036
    Processor 0: field transfer
    terminate called after throwing an instance of 'std::logic_error'
      what():  basic_string::_S_construct null not valid
    还麻烦各位可以给个意见,这个问题就是这个边条造成的,但不知道如何解决,谢谢各位了
    A Aeronastro
    不知道有没有哪位遇到过这样的情况,我在decomposePar的时候,出现这样的错误提示:
    _what(): basic_string::_S_consturct null not valid
    入口边界条件是我自己定义的,功能是读取一个文件数据,进行运算之后赋值给这个边界条件的私有变量。我用的是simple分块,不破坏这个入口。哪里出错了呢可以给点建议吗?
    PS:单核验证可以计算
  • 关于湍流边界层入口给定的一些疑问
    A Aeronastro
    最近在用LES计算湍流入口,为了得到一个入口的平均速度场,我想用DNS的数据,也就是用到标准的壁面律曲线(y+ ~ U+),由于我用的求解器是求解有量纲的参数,因此需要对标准的壁面律曲线进行有量纲处理。根据我来流的参数,比如自由来流速度Uinf,温度Tinf,采用绝热壁温,是不是就可以得到有量纲的速度分布了?但我看到有人要给定入口的壁面摩擦速度Utao,边界层厚度等,这些都是没有必要的吧?谢谢!
  • OF如何实现二维场到三维场的建立
    A Aeronastro
    @李东岳 这个三维稍微比二维的在流向长了一点点(很小),mapField不是完全consistent,二维的z坐标是对称的,我的三维则不然,z的最小值是0,所以还得写mapFieldsDict。我之前的做法映射的值都是零,不知道是不是我的mapFieldsDict写错了
  • OF如何实现二维场到三维场的建立
    A Aeronastro
    @李东岳 我之前出现的问题就是值都为零,不知道怎么解决。我的2D展向拉长3D,展向还是一层网格,只是尺寸变大而已。
    看来只能写一个后处理小程序了。
  • OF中关于tmp类型变量的运算和使用
    A Aeronastro
    @wwzhao 好贴:cheeky:
  • Foam::sigSegv::sigHandler(int)错误
    A Aeronastro
    我在自定义边界条件时,出现Foam::sigSegv::sigHandler(int)错误,用了Debug模式运行,定位到了我C文件的这几句:
    const scalarField muEffb = muEff.boundaryField()[patchId];
    const scalarField rhob = rho.boundaryField()[patchId];
    在前面已经用lookupObject把muEff和rho这两个场读进来了,而且找到了要提取的边界patchId,不知道为什么这两句有问题?
    下面是错误输出:
    在#5定位到C文件的位置
  • 用RANS计算发现壁面处的边界层偏厚
    A Aeronastro
    @wwzhao 好的,我之前描述得太过简单了,sorry:sad:
    A Aeronastro
    PS:我的第一层网格分辨率y+在0.7左右,基本是LES的网格要求,没有采用壁面函数,我用LES计算之前,想先用RANS计算一下,用的求解器是rhoCentralFoam,不知道是不是这个求解器所用的格式耗散过大造成的。OF里有Roe求解和AUSM等,想换换这几个试试不知道是否可行
    A Aeronastro
    我用OF的RANS模型计算一个有壁面的流动,发现计算出来的附面层明显偏厚,而用fluent计算了一下,发现并不是很厚,不知道我哪里设置错了,我用的是kOmegaSST模型,和fluent用的一样
  • 关于数值粘性和湍流粘性
    A Aeronastro
    @cfd-china 好的,2.2的任何版本都可以是吧?
  • 关于数值粘性和湍流粘性
    A Aeronastro
    @cfd-china 2.2那个版本没有这个问题是吗?对于你的算例而言?
  • 关于数值粘性和湍流粘性
    A Aeronastro
    我在求解超声速平板的时候,发现近壁流动没有来流的快,导致我求解出来的壁面摩擦速度偏小,平板前缘靠近入口的附面层比来流指定的附面层要厚一些,好像是流动受到“粘性”的制约,这个粘性要么是数值粘性,要么就是湍流粘性大了,不知道可以有什么办法解决这个问题呢,谢谢
