@炎冰灬灬 我没有使用过foam-extend 3.2 ,foam-extend4.0并行计算的方式与其他版本的openfoam设置相同
buaa_hgj
FsiFoam并行问题 -
TopoSet关于action的疑问@D-Benjamin 求交集的意思
怎么用paraview画出streamlines inside bubble? -
OpenFOAM中SliceData输出的不同时间步上的切面vtk场如何统一做成动画?@aiweimo
1、vtk文件一些命名方式可以被paraview自动识别为不同时刻的数据,比如,a1.vtk a2.vtk a3.vtk
所以你把这些vtk文件命名成这种形式然后用paraview读入就可以输出视频了
2、怎么将这些vtk文件的名称改成这种形式,写个脚本根据文件夹的名称修改该文件夹下vtk文件的名称 -
OpenFOAM中SliceData输出的不同时间步上的切面vtk场如何统一做成动画?现在你有了一系列vtk文件然后输出视频是吗?
OpenFOAMv1806跨节点计算出错软件版本:openfoam-v1806
硬件信息:超算(x86_64架构)
系统:centos 6.6
问题描述:openfoam编译完成后在登录结点串行并行计算都无报错,但是通过bsub命令提交任务计算出现下面的报错:[m5605:28439] Signal: Segmentation fault (11) [m5605:28439] Signal code: Address not mapped (1) [m5605:28439] Failing at address: 0x29c38a0 [m5605:28442] [ 0] /lib64/libc.so.6(+0x326a0)[0x2b582a1406a0] [m5605:28442] [ 1] /home/daiyut/tools/openmpi215/lib/openmpi/mca_btl_openib.so(+0xf380)[0x2b583afbf380] [m5605:28442] [ 2] /home/daiyut/tools/openmpi215/lib/libopen-pal.so.20(mca_btl_base_select+0x156)[0x2b582b7370f6] [m5605:28442] [ 3] /home/daiyut/tools/openmpi215/lib/openmpi/mca_bml_r2.so(mca_bml_r2_component_init+0x11)[0x2b583adaf251] [m5605:28442] [ 4] /home/daiyut/tools/openmpi215/lib/libmpi.so.20(mca_bml_base_init+0x7c)[0x2b582aefc0ec] [m5605:28442] [ 5] /home/daiyut/tools/openmpi215/lib/libmpi.so.20(ompi_mpi_init+0x3ad)[0x2b582aebf59d] [m5605:28442] [ 6] /home/daiyut/tools/openmpi215/lib/libmpi.so.20(MPI_Init_thread+0x46)[0x2b582aede3f6] [m5605:28442] [ 7] /home/daiyut/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x67)[0x2b582a4a90c7] [m5605:28442] [ 8] /home/daiyut/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x67c)[0x2b5828e2489c] [m5605:28442] [ 9] icoFoam[0x453149] [m5605:28442] [10] /lib64/libc.so.6(__libc_start_main+0xfd)[0x2b582a12cd5d] [m5605:28442] [11] icoFoam[0x41c6c9] [m5605:28442] *** End of error message ***请问有前辈知道这个是什么原因造成的吗?以及有什么解决办法吗?
三维大变形问题用fluent动网格计算是否合适@渤文 您好,问一下如果做流固耦合结构会发生很大的柔性变形可以使用overset计算吗?我找到的overset的算例基本上结构都是刚体运动。
求助如何在HPC Cluster上安装OF5.0(1)应该可以在自己的用户文件夹中进行编译,etc/bashrc里面的安装路径最好改一下,免得和原来的冲突;
(2)icc也可以成功编译openfoam,之前用gcc编译openfoam3.0的时候,gcc编译openfoam的源码编译不成功(可能是gcc版本太低吧),就用icc替代了gcc;
(3)感觉主要注意一下环境变量的配置。 -
超算平台上多版本编译OF,串行无误并行出错?@aiweimo 非常感谢。
超算平台上多版本编译OF,串行无误并行出错?@aiweimo 您好,请问怎么在red hat系统的超算平台上编译foam-extend-4.0,是否方便分享一些参考资料或者经验?
FsiFoam并行问题@影川风 已加QQ好友
FsiFoam并行问题@影川风 foam-extend-4.0目前是可以使用并行的,这个错误是计算了一段时间之后出现的。
FsiFoam并行问题在使用fsifoam并行计算二维流固耦合问题时,计算一段时间后就会出现如下图所示的报错:
[14] --> FOAM FATAL ERROR: [14] Some processors detect different empty (2-D) directions. Probably using empty patches on a bad parallel decomposition. Please check your geometry and empty patches [14] [14] From function void polyMesh::calcDirections() const [14] in file meshes/polyMesh/polyMesh.C at line 101. [14] FOAM parallel run aborting各位大佬,有遇到这种问题的吗?报错中的不同的empty方向是什么意思?
