明白了,谢谢前辈
C
cfd-cxb
@cfd-cxb
关于数值模拟离心泵过程中发散的一些问题 -
关于数值模拟离心泵过程中发散的一些问题谢谢您的回复,我用的是foam-extend版本,里面有同时调用的例子的
关于数值模拟离心泵过程中发散的一些问题恩恩,是的,交界面处理使用的是GGI
关于数值模拟离心泵过程中发散的一些问题首先,非常感谢您的回复
我调整了k以及epsilon,但是还是不可以,当我将div(phi,U)调为upwind或者linearUpwind Gauss时,div(phi,k)与div(phi,epsilon)不管是那种格式都能算,但是若是我将div(phi,U)设为limitedlinearV 1格式,div(phi,k)与div(phi,epsilon)不管那种格式都不行,算例都只算一步。 -
关于数值模拟离心泵过程中发散的一些问题我换用linearUpwind后到200多步还是发散了,谢谢您!
关于数值模拟离心泵过程中发散的一些问题您好,算例运行不起来,只能跑一步
Create time Create mesh for time = 0 Initializing the GGI interpolator between master/shadow patches: GUIDE-OUTLET/IMPELLER-INLET Initializing the GGI interpolator between master/shadow patches: IMPELLER-OUTLET/VOLUTE-INLET SIMPLE: no convergence criteria found. Calculations will run for 1400 steps. Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model RNGkEpsilon RNGkEpsilonCoeffs { Cmu 0.0845; C1 1.42; C2 1.68; alphak 1.39; alphaEps 1.39; eta0 4.38; beta 0.012; sigmak 0.71942; sigmaEps 0.71942; } Creating MRF for cell zone IMPELLER. rpm = 2900 Excluded patches: 2(3 4) Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0108375, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0104409, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0104084, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.027634, No Iterations 6 GAMG: Solving for p, Initial residual = 0.0357851, Final residual = 0.000575861, No Iterations 2 time step continuity errors : sum local = 7.76946, global = 0.352411, cumulative = 0.352411 smoothSolver: Solving for epsilon, Initial residual = 0.13384, Final residual = 0.00135303, No Iterations 2 bounding epsilon, min: -2.55034 max: 52.4243 average: 2.34921 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0250789, No Iterations 2 ExecutionTime = 12.85 s ClockTime = 13 s Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.20708, Final residual = 0.00402441, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.249236, Final residual = 0.0056065, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.222885, Final residual = 0.00479877, No Iterations 2 -
关于数值模拟离心泵过程中发散的一些问题边界条件:
进口:速度进口,压力零梯度
出口:速度零梯度,压力固定值0
壁面:速度固定值(0 0 0),压力零梯度 -
关于数值模拟离心泵过程中发散的一些问题谢谢前辈,下面是网格质量检查的log文件,用的是非结构网格
Create time Create polyMesh for time = 0 Time = 0 Mesh stats all points: 249875 live points: 249875 all faces: 2796614 live faces: 2796614 internal faces: 2718602 cells: 1378804 boundary patches: 10 point zones: 0 face zones: 3 cell zones: 3 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 1378804 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 3 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" Nuumber of cells per region: 0 192712 1 282795 2 903297 Checking patch topology for multiply connected surfaces ... Patch Faces Points Area [m^2] Surface topology GUIDE-INLET 1454 777 0.00621397 ok (non-closed singly connected) GUIDE-OUTLET 1444 771 0.00621367 ok (non-closed singly connected) GUIDE-BIMIAN 5252 2723 0.0167709 ok (non-closed singly connected) IMPELLER-INLET 1866 985 0.00621398 ok (non-closed singly connected) IMPELLER-OUTLET 3747 2037 0.0122964 ok (non-closed singly connected) IMPELLER-BIMIAN 9398 5365 0.0300004 ok (non-closed singly connected) IMPELLER-BLADE 11873 6399 0.0358377 ok (non-closed singly connected) VOLUTE-OUTLET 1238 665 0.00502107 ok (non-closed singly connected) VOLUTE-INLET 3708 2041 0.0122965 ok (non-closed singly connected) VOLUTE-BIMIAN 38032 19247 0.110309 ok (non-closed singly connected) Checking geometry... This is a 3-D mesh Overall domain bounding box (-0.0994947 -0.12194 -0.105381) (0.0399865 0.18 0.134736) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Mesh (non-empty, non-wedge) dimensions 3 Boundary openness (1.39036e-16 7.89536e-17 1.26213e-17) Threshold = 1e-06 OK. Max cell openness = 3.12848e-16 OK. Max aspect ratio = 4.28896 OK. Minumum face area = 7.24618e-07. Maximum face area = 7.48018e-06. Face area magnitudes OK. Min volume = 3.60661e-10. Max volume = 5.62725e-09. Total volume = 0.00266114. Cell volumes OK. Mesh non-orthogonality Max: 50.7974 average: 7.4258 Threshold = 70 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.52081 OK. Mesh OK. End -
关于数值模拟离心泵过程中发散的一些问题在用MRFSimpleFoam求解离心泵过程中当divSchemes采用一阶的upwind时计算可以收敛,没问题,但是采用如下的高阶格式时计算基本不能进行下去,只能算一两步,这个问题出在哪里? 请帮忙解决,谢谢
divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; div(phi,k) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div((nuEff*dev(T(grad(U))))) Gauss linear; } fvSolution 文件如下 solvers { p { solver GAMG; tolerance 1e-6; relTol 0.05; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 800; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-5; relTol 0.1; } k { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-5; relTol 0.1; } epsilon { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-5; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; } relaxationFactors { p 0.3; U 0.5; k 0.5; epsilon 0.5; } -
关于MRFSimpleFoam求解离心泵的一些问题多谢前辈,我正在用probes监测
关于MRFSimpleFoam求解离心泵的一些问题@赵一铭 您好,我想在计算的过程中监测进出口压力,该怎么做,就如同监测残差那样,谢谢您。
关于MRFSimpleFoam求解离心泵的一些问题@赵一铭 谢谢您,只要进出口压力得到,扭矩我已输出,就可以算出效率了。再次谢谢您!
关于MRFSimpleFoam求解离心泵的一些问题大家好,我正在用MRFSimpleFoam求解离心泵,但是我不知道怎么样将其进出口压力及效率计算出来,请大家帮忙解答,谢谢
