E
Emrys
@Emrys
  • interFoam + 周期边界条件的压力问题
    E Emrys
    @学流体的小明 我想请问一下,这里的体积源项假定了一个平均流速 这个平均流速是怎么计算出来的,可以和重力挂钩嘛
  • openfoam动网格加密后 计算很慢
    E Emrys
    @李东岳 谢谢李老师回复,可是全场加密下1000w网格跑的比局部加密67w网格快是不是不太合理:135:
    E Emrys
    网格是需要接近1:1:1加密吗?整个区域尺寸的比例约为1:300:100
    E Emrys
    各位老师好,我在计算三维多相流流动时采用界面局部加密的动网格,发现时间步长特别小,界面局部加密后的网格67w时间步长1e-7 1e-8左右;
    而在全场加密1000w网格情况下计算是正常的时间步长1e-5;
    请问是局部加密非结构化网格的原因导致步长很小? 四面是周期性边界条件,因此采用了cyclicAMI的边界。
        \\  /    A nd           | Version:  8
         \\/     M anipulation  |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "constant";
        object      dynamicMeshDict;
    dynamicFvMesh   dynamicRefineFvMesh;
    // How often to refine
    refineInterval  1;
    // Field to be refinement on
    field           alpha.water;
    // Refine field in between lower..upper
    lowerRefineLevel 0.001;
    upperRefineLevel 0.999;
    // If value < unrefineLevel unrefine
    unrefineLevel   10;
    // Have slower than 2:1 refinement
    nBufferLayers   1;
    // Refine cells only up to maxRefinement levels
    maxRefinement   2;
    // Stop refinement if maxCells reached
    maxCells        20000000;
    // Flux field and corresponding velocity field. Fluxes on changed
    // faces get recalculated by interpolating the velocity. Use 'none'
    // on surfaceScalarFields that do not need to be reinterpolated.
    correctFluxes
        (phi none)
        (nHatf none)
        (rhoPhi none)
        (alphaPhi0.water none)
        (ghf none)
    // Write the refinement level as a volScalarField
    dumpLevel       true;
    |  \\    /   O peration     | Version:  2212                                     |
    |   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      blockMeshDict;
    convertToMeters 1;
    hN  1.01e-4;
    L   #calc "100*$hN";
    D   #calc "1.0*$hN";
    H   #calc "3.0*$hN";
    z   #calc "M_PI*$L";
    nX  100;
    nY  50;
    nZ  100;
    vertices
        (0  0  0) //0
        ($L 0  0) //1
        ($L $H 0) //2
        (0  $H 0) //3
        (0  0  $z) //4
        ($L 0  $z) //5
        ($L $H $z) //6
        (0  $H $z) //7
    blocks
        hex (0 1 2 3 4 5 6 7) ($nX $nY $nZ) simpleGrading (1 1 1)
    edges
    boundary
        movingWall
            type wall;
            faces
                (0 1 5 4)
        inlet
            type                  cyclicAMI;
            neighbourPatch        outlet;
            transform       translational;
            separationVector ($L 0 0);
            faces
                (0 4 7 3)
        outlet
            type                  cyclicAMI;
            neighbourPatch        inlet;
            separationVector (-$L 0 0);
            faces
                (1 5 6 2)
          atmosphere
            type patch;
            faces
                (3 2 6 7)
        front
            type cyclicAMI;
            neighbourPatch        back;
            separationVector (0 0 $z);
            faces
                (0 1 2 3)
        back
            type cyclicAMI;
            neighbourPatch        front;
            separationVector (0 0 -$z);
            faces
                (4 5 6 7)
    mergePatchPairs
  • openfoam如何不设压力边界条件?只给参考压力
    E Emrys
    各位老师好,在求解NS方程的时候,理论上压力只是一个过程量,不需要设置边界条件,只需要给定一个参考点压强就可以。openfoam能否实现这个操作呢?
    比如一个自由界面上的边界,只设置计算网格上一点压力为0
  • 弯曲壁面网格
    E Emrys
    blockMesh里面的edge可以解决
  • 弯曲壁面网格
    E Emrys
    各位老师好,请问openfoam需要用弯曲的壁面,比如正弦函数,用什么工具或者方法
    E Emrys
    @学流体的小明 是的,因为p_rgh不是周期的。你的方法我也想尝试一下
    E Emrys
    @李东岳 看到李东岳老师的推送了 没有这么邪乎哈哈哈
    E Emrys
    @学流体的小明 不是,我直接在interFoam求解器里修改,动量方程里把rgh单独拿出来计算了。
  • interFoam,边界条件,发散
    E Emrys
    @User0221 你具体做的什么东西我不太清楚,不好评价,但是个人觉得和网格细化没有多大的关系。
  • interFoam,边界条件,发散
    E Emrys
    @User0221 入口速度流量小 就应该变薄吧
  • interFoam平板薄膜周期性流动模拟
    E Emrys
    问题已解决, 是interFoam和周期性边界条件的问题,参考:
    https://www.cfd-china.com/topic/6577/interfoam-周期边界条件的压力问题/4
    E Emrys
    更新,已解决。 将重力在interFoam中当成体积力拿出单独计算,结果如图所示
    E Emrys
    各位老师好,最近在研究在有重力作用下的interFoam周期性边界条件,如气泡上升,液膜降落等,
    看到几个论坛交流的帖子,有fixedJump设置压力梯度的,但是不适合所有的情况 https://www.cfd-china.com/topic/1992/cyclic周期性边界条件
    在这篇论坛里提到
    https://www.cfd-online.com/Forums/openfoam-solving/79300-interfoam-cyclic-boundary-condition-issue.html
    interFoam求解器求解的时候把重力放到了压力计算的过程中,$p_{\rho g h}=p-\rho gh$。 请问有老师做过相似的问题可以交流一下吗
  • interFoam,边界条件,发散
    E Emrys
    你把速度放大试试
    E Emrys
    @李东岳 太感谢李老师了!https://core.ac.uk/reader/36634570
    interFoamHF在这篇论文里有提及。74页提及了一些参数设定。
    E Emrys
    @李东岳 我的程序就是最简单的interFoam,求解器文献中有对比,没有液膜厚度。但是我算的结果液膜没有流动,实在找不到原因了。文献中优化后的interFoamHF有厚度方程。 :135:
    E Emrys
    E Emrys
    初始薄膜厚度$h_0=200\mu m$的速度为半抛物线速度分布$u_{water}=\frac{g}{\nu}(h_0y-y^2/2)$,$u_{Air}=\frac{g}{\nu}\frac{h_0^2}{2}$,初始速度示意图如下98ad89b4-46d9-4aa8-9d30-06dfd659975a-image.png
    初始相场:
    初始条件设置如下
    137b3b64-9f83-4531-a0c9-4cff1077e93a-image.png d2a4e03a-df1b-4b89-8fbd-6dea77e60c3b-image.png
    运行结果如下
    film.avi
    结果好像液膜没有按照重力方向沿着x流动,左右两边向中间收了。重力设置确定没有问题,有老师可以帮忙看看哪里出了问题吗。非常感谢!
    参考文献:Rohlfs, W., Scheid, B., 2015. Phase diagram for the onset of circulating waves and flow reversal in inclined falling films. J. Fluid Mech. 763, 322–351. https://doi.org/10.1017/jfm.2014.684
    我的程序代码
    ultracyclic4.zip 再次感谢!
