@bestucan 万分感谢!感谢赵老师,感谢您!
已经向您邮箱发了邮件zhou_hli@163.com
Henry Zhou
群体平衡模型学习资料求推荐 -
群体平衡模型学习资料求推荐@bestucan 非常感谢您的指点!之前的确没有查到过赵海波的这本书。可是目前新书没卖的了,二手的好贵啊
群体平衡模型学习资料@李东岳 谢谢李老师!
群体平衡模型学习资料求推荐请教下各位老师,最近想详细学习下群体平衡模型,包括模型的构建过程,模型求解方法,聚并、破碎、成核、生长、溶解核函数模型等内容,有哪些中英文学习资料可以学习?恳请各位老师推荐,谢谢!
群体平衡模型学习资料最近想详细学习下群体平衡模型,包括模型的构建,模型求解,聚并、破碎、成核、生长、溶解模型等内容,有哪些中英文学习资料可以看,麻烦各位老师推荐一下,谢谢啦!
分散相体积分数增加,报错!multiphaseEulerfoam,低离散相分数的时候,没问题,离散相增加到0.35,就报错,尝试修改了边界条件、相间作用力模型、离散格式和网格都无果,差别就是跑的时间长短,最终都发散报错如下:
[8] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [8] #1 Foam::sigFpe::sigHandler(int) at ??:? [8] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [8] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [8] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/zhl/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam" [8] #5 Foam::PhaseCompressibleMomentumTransportModel<Foam::phaseModel>::nu() const at ??:? [8] #6 Foam::RASModels::kEpsilon<Foam::PhaseCompressibleMomentumTransportModel<Foam::phaseModel> >::correct() at ??:? [8] #7 Foam::phaseSystem::correctTurbulence() at ??:? [8] #8 ? in "/home/zhl/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam" [8] #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [8] #10 ?[ubuntu:09382] *** Process received signal *** 或者这样: [8] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [8] #1 Foam::sigFpe::sigHandler(int) at ??:? [8] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [8] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [8] #4 Foam::operator/(Foam::tmp<Foam::Field<double> > const&, Foam::UList<double> const&) at ??:? [8] #5 Foam::PhaseCompressibleMomentumTransportModel<Foam::phaseModel>::nu(int) const at ??:? [8] #6 Foam::epsilonWallFunctionFvPatchScalarField::calculate(Foam::momentumTransportModel const&, Foam::List<double> const&, Foam::fvPatch const&, Foam::Field<double>&, Foam::Field<double>&) at ??:? [8] #7 Foam::epsilonWallFunctionFvPatchScalarField::calculateTurbulenceFields(Foam::momentumTransportModel const&, Foam::Field<double>&, Foam::Field<double>&) at ??:? [8] #8 Foam::epsilonWallFunctionFvPatchScalarField::updateCoeffs() at ??:? [8] #9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::updateCoeffs() at ??:? [8] #10 Foam::RASModels::kEpsilon<Foam::PhaseCompressibleMomentumTransportModel<Foam::phaseModel> >::correct() at ??:? [8] #11 Foam::phaseSystem::correctTurbulence() at ??:? [8] #12 ? in "/home/zhl/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam" [8] #13 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [8] #14 ?[ubuntu:07707] *** Process received signal *** 求大神指点一二! -
multiphaseEuler中湍流模型请教下各位老师,在multiphaseEuler中湍流模型设置中,经产看到:
simulationType RAS; RAS { RASModel kEpsilon; turbulence on; printCoeffs on; } LES { LESModel NicenoKEqn; turbulence on; printCoeffs on; delta cubeRootVol; cubeRootVolCoeffs { } }或者:
simulationType laminar; RAS { RASModel continuousGasKEpsilon; turbulence off; printCoeffs on; }类似的设置,不太明白已经是RAS或者 laminar了,下边的LES和RAS有何作用?
非常感谢老师们赐教。 -
初始粒径对结果中平均直径的影响有多大@李东岳 文献中实验结果有平均直径数据,入口处给的是各相的体积分数, 大小范围可以参考结果,不知道初始粒径分布怎们给。另外液滴聚并用的CT模型,破碎用的LuoSvendsen,不知道合理不。非常感谢李老师的解答!
初始粒径对结果中平均直径的影响有多大各位老师好!我在用multiphaseEulerFoam中pbm模型模拟液滴或者气泡聚并破碎,初始粒径的范围和分布,对平均直径的结果影响有多大?如果没有实验数据,该如何设置初始粒径的范围和分布呢?再有,一般要多少时间流动可以稳定?各位老师有没有好的经验。
液固两相流中颗粒相的粘度模型应该如何设置?在文献中看到一个颗粒相的粘度模型,随着颗粒相的体积分数变化。形式如下:
。请教下各位老师,这个在哪里设置?或者在哪里植入。现在完全没有思路
,请各位老师不吝赐教! -
Thomas slurry粘度模型东岳老师,我最近在做一个类似的模型,颗粒粘度与其体积分数有关的,用的of8的multiphaseEulerFoam,现在完全没有思路,不知道要将其放在哪里
望您指点一二 -
openfoam中可以加入自定义粘度模型吗?请教下各位大神,openfoam中是否可以加入自定义粘度,比如两相流动,某一相的粘度与其相分数相关的粘度模型,是否可以加入,应在哪里加入? thermophysicalProperties中可以定义常数或者与温度相关的粘温模型,但是没有看到与相分数相关。
多组分模型multiComponentPhaseModel,组分的分数分层?非常感谢!我之前把连续相的直径调小,效果好点,但是还是不理想。我一会儿试一下,把Sct调小,看看有变化没。
multiphaseEulerFoam壁面粘附问题求助最近想做一个液固输送,颗粒较多,并且固体颗粒会粘附在壁面上生长。尝试了很多方法,但是都不太理想,固体颗粒总是跑掉,无法在壁面附近聚集,体积分数最多1e-5。
已经设置了壁面类型:FoamFile { version 2.0; format ascii; class volVectorField; object U.particles; } dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); WALL { type JohnsonJacksonParticleSlip; restitutionCoefficient 0.8; specularityCoefficient 0.00001; muF 0.7; sigma 2; value uniform (0 0 0); }颗粒间的作用设置如下:
FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties.particles; } simulationType RAS; RAS { model kineticTheory; turbulence on; printCoeffs on; kineticTheoryCoeffs { equilibrium off; continuousPhase liquid; e 0; alphaMax 0.63; alphaMinFriction 0.5; residualAlpha 1e-4; viscosityModel Gidaspow; conductivityModel Gidaspow; granularPressureModel Lun;/ frictionalStressModel JohnsonJacksonSchaeffer; radialModel SinclairJackson; JohnsonJacksonSchaefferCoeffs { Fr 0.05; eta 2; p 5; phi 28.5; alphaDeltaMin 0.05; } }在thermophysicalProperties中的颗粒相粘度比较小1e-6量级。
同时在运行中,能看到总的体积分数Phase-sum volume fraction, min, max = 1.00007496 0.988884069 1.16288542
最大值超过1的情况,虽然没有发散,但是超过的有点多,很不合理,不知道什么原因。
先在这里感谢各位老师指教,谢谢! -
多组分模型multiComponentPhaseModel,组分的分数分层?大家好,我用multiphaseEulerFoam做一个案例,对某一相使用多组分模型multiComponentPhaseModel,但是相中组分分数分层。因为组分会扩散,正常情况是不应该分层的,调了一段时间,只是换了分层的位置。不知道大家遇到过这种情况不?谢谢各位老师的指点!
openfoam中的沉积大家好,我在做一个算例,用multiphaseEuler模拟管道固液两相流动,其中固相会吸附在管壁上,形成沉积。最近一直在想如何实现,看了很多算例和边界条件都没有找到办法。所以想问下各位大神,openfoam是否有相应的速度壁面类型可以使用?
openfoam的壁面设置大家好,最近我在用双流体模型做一个沉积案例,其中一相由于重力会沉积到壁面,并且附着在上边,想请教一下各位大神,如何设置壁面类型或者某一相的参数,才能出现附着的效果。谢谢!!!
编译出现不能匹配“operator-”@浪迹天大 非常感谢!今天仔细看了下,终于搞定了。
编译出现不能匹配“operator-”@浪迹天大 十分感谢!但是如何获取我需要的分量?初学请指教一下
,或者哪里可以查到? -
编译出现不能匹配“operator-”@李东岳 是的李老师,of8中的PBE,加一个成核模型,就是Y-Csat_这一项出的问题,编译之后出现红色标记,出现上述错误。
