@李东岳 是的,这里换成T后下面的scalar T = gMax(T)函数也可以正常使用
L
L_LL
@L_LL
openFOAM codedFixedValue边界条件中调用标量场的问题 -
openFOAM codedFixedValue边界条件中调用标量场的问题我尝试将of2306的jouleHeating算例中的jouleHeating::V从恒定电压改为恒定电流设置,因此想要通过电流乘以电阻来计算电压,其中电阻的设置涉及到电导率,而这个电导率是随着温度的变化变化的,所以想要读取标量场中的电导率(sigma)数据。
以下是sigma设置/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // heating { type jouleHeatingSource; active true; jouleHeatingSourceCoeffs { anisotropicElectricalConductivity no; // Optionally specify sigma as a function of temperature //sigma 127599.8469; // sigma table ( (273 59600000) (298 58000000) (500 32000000) ); } } // ************************************************************************* //
下面是我写的codedFixedValue边界条件
boundaryField { inlet { type codedFixedValue; value uniform 0;// 初始值,可以为0或其他合理的数值 name dynamicV; codeInclude #{ #include "mathematicalConstants.H" #include "fvCFD.H" #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; codeLibs #{ -lmeshTools \ -lfiniteVolume #}; code #{ const fvMesh& mesh = this->patch().boundaryMesh().mesh(); dictionary C = mesh.lookupObject<dictionary>("fvOptions"); // 定义常数 scalar I = 0.6; scalar L = 0.007875; scalar A = 1.125e-8; const volScalarField& sigma = mesh.lookupObject<volScalarField>("sigma"); scalar sigma = gMax(sigma); // 计算电阻 scalar R = L / (sigma * A); // 计算电压,确保恒定电流 I scalar V = I * R; Info << "V: " << V << endl; Info << "R: " << R << endl; Info << "sigma: " << sigma << endl; // 将计算出的电压值作为边界条件 operator==(V); #}; } outlet { type fixedValue; value uniform 0; }
这样的写法会出现
Failed wmake "dynamicCode/dynamicV/platforms/linux64GccDPInt32Opt/lib/libdynamicV_c6587780c1810df06b6735b285db38c4418d36ec.so" file: 0/solid/jouleHeatingSource:V.boundaryField.inlet at line 28 to 47. From void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const in file db/dynamicLibrary/codedBase/codedBase.C at line 245. FOAM exiting code_text
但是如果我把上面的sigam换成T又是可以运行的,想问问大家知道我该如何去写这段代码吗
