--> FOAM FATAL IO ERROR:
size 12225 is not equal to the given value of 21
file: /home/zcy/OpenFOAM/anli/pitzDaily/0/U from line 18 to line 12272.
From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int]
in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/Field.C at line 302.
FOAM exiting
Segmentation fault (core dumped)
郑澄远
请问下为什么blockMesh运行paraview打不开 -
请问下为什么blockMesh运行paraview打不开/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (-6 0 -1) (-6 1 -1) (0 -1 -1) (0 0 -1) (0 1 -1) (18 -1 -1) (18 0 -1) (18 1 -1) (-6 0 1) (-6 1 1) (0 -1 1) (0 0 1) (0 1 1) (18 -1 1) (18 0 1) (18 1 1) ); blocks ( hex (0 3 4 1 8 11 12 9) (3 1 1) simpleGrading (1 1 1) hex (2 5 6 3 10 13 14 11) (9 1 1) simpleGrading (1 1 1) hex (3 6 7 4 11 14 15 12) (9 1 1) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (0 1 9 8) ); } outlet { type patch; faces ( (5 6 14 13) (6 7 15 14) ); } upperWall { type wall; faces ( (1 4 12 9) (4 7 15 12) ); } lowerWall { type wall; faces ( (0 3 11 8) (3 2 10 11) (2 5 13 10) ); } frontAndBack { type empty; faces ( (0 3 4 1) (2 5 6 3) (3 6 7 4) (8 11 12 9) (10 13 14 11) (11 14 15 12) ); } ); // ************************************************************************* // 报错 Created temporary 'pitzDaily.OpenFOAM' I/O : uncollated ********************************************************** ParaView failed to open using available graphics hardware. Trying fallback to software rendering using MESA. ********************************************************** I/O : uncollated
请问用户指南的这个图是怎么画出来的
我只能画成 -
为什么二维方腔流用pisFoam算出的流线与下方没有涡@东岳 把网格加密后80*80算到time=0.05时就显示
#3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:? #10 Foam::RASModels::kEpsilon<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() at ??:? #11 ? at ??:? #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 ? at ??:? 浮点数例外 (核心已转储)
该怎么解决呢 -
请教一个问题,为什么用pisoFoam算的三维方腔流和实验数据不同按照文献中的案例模拟了一个三维方腔流
我的垂直速度曲线图和水平速度曲线图
和实验结果不一样
是什么原因造成的? -
请问有谁知道在OpenFOAM三维案列中怎么提取面(z=0)的所有速度的数据我想把数据导出来画速度分量时间平均分布
后台阶二维怎么改成三维的在pimpleFoam中算例的后台阶,请问一下,openfoam案例里面二维后台阶模型改成三维是不是只要把边界条件和blockMeshDict改一下就可以了
我openfoam6中的dirToString和wmkdep被误删了,请问这两个该怎么编译@东岳 在编译openfoam6时是输入./Allwmake进行编译,此时终端会输出:
Allwmake /home/zcy/OpenFOAM/OpenFOAM-6 gcc -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -fPIC dirToString.c -o /home/zcy/OpenFOAM/OpenFOAM-6/wmake/platforms/linux64Gcc/dirToString flex wmkdep.l; \ gcc -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -fPIC lex.yy.c -o /home/zcy/OpenFOAM/OpenFOAM-6/wmake/platforms/linux64Gcc/wmkdep lex.yy.c:1264:17: warning: ‘yyunput’ defined but not used [-Wunused-function] static void yyunput (int c, char * yy_bp ) ^ lex.yy.c:1307:16: warning: ‘input’ defined but not used [-Wunused-function] static int input (void) ^ Allwmake: no ThirdParty directory found - skipping Allwmake src
这个时候dirToString和wmkdep应该已经编译好了,我想知道能不能在编译而不是复制这两个,给上Allwmake脚本内容
#!/bin/sh cd ${0%/*} || exit 1 # Run from this directory # Parse arguments for library compilation . wmake/scripts/AllwmakeParseArguments # Perform various checks wmakeCheckPwd "$WM_PROJECT_DIR" || { echo "Allwmake error: Current directory is not \$WM_PROJECT_DIR" echo " The environment variables are inconsistent with the installation." echo " Check the OpenFOAM entries in your dot-files and source them." exit 1 } [ -n "$FOAM_EXT_LIBBIN" ] || { echo "Allwmake error: FOAM_EXT_LIBBIN not set" echo " Check the OpenFOAM entries in your dot-files and source them." exit 1 } # Compile wmake support applications (cd wmake/src && make) # Compile ThirdParty libraries and applications if [ -d "$WM_THIRD_PARTY_DIR" ] then $WM_THIRD_PARTY_DIR/Allwmake else echo "Allwmake: no ThirdParty directory found - skipping" fi # Compile OpenFOAM libraries and applications src/Allwmake $targetType $* # Compile OpenFOAM libraries and applications applications/Allwmake $targetType $*
我openfoam6中的dirToString和wmkdep被误删了,请问这两个该怎么编译路径是home/zcy/OpenFOAM/OpenFOAM-6/wmake/platforms/linux64Gcc
在其他虚拟机中OpenFOAM显示的样子
这是什么问题导致的?@星星星星晴 pisoFoam
这是什么问题导致的?@东岳 我做一个简单的渠道流,
U: internalField uniform (0.0335 0 0); boundaryField { IN { type fixedValue; value uniform (10 0 0); } OUT { type zeroGradient; } WALL { type noSlip; } } P: dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { IN { type zeroGradient; } OUT { type fixedValue; value uniform 0; } WALL { type zeroGradient; } }
没有发现错误
这是什么问题导致的?运算时报错,应该怎么修改呢
--> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 1.19645e-07 Specified mass inflow : 0.0032961 Specified mass outflow : 0.00261459 Adjustable mass outflow : 0
postProcess工具我在controlDict里面出现添加了
#includeFunc mag(U)
用pisoFoam运行后输入postProcess -func "mag(U)"
,出现functionObjects::mag mag(U) cannot find required object U of type volScalarField
这该怎么解决
请问下三维方腔流可以用icoFoam求解吗@东岳 成功了,谢谢东岳老师了
请问下三维方腔流可以用icoFoam求解吗我将算例cavity网格(20 20 1)变为(20 20 20)的情况icoFoam会算不出来
以前没有研究过不太清楚Time = 0.065 Courant Number mean: 31.0395 max: 154.167 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? 浮点数例外 (核心已转储)
Make/linux64GccDPInt32Opt/options:55: *** missing separator。 停止。这是我的options:
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude EXE_LIBS = \ -L</home/zcy/OpenFOAM/zcy-6/platforms/linux64GccDPInt32Opt/lib> \ -l<myfiniteVolume> \ -lmeshTools
我用wmake编译时生成文件Make/linux64GccDPInt32Opt时出现
停止。
请问我该怎么修改呢 -
请问一下这种情况该怎么写options我自己编写了一个小型数据库fin,里面有cfdTools finiteVolume fvMesh lnInclude surfaceMesh fields fvMatrices interpolation Make volMesh。其中wmake文件最后一句写成LIB = $(FOAM_USUER_LIBBIN)/libmyfiniteVolume,现在我想把库链接到icoFoam
中,请问他的options我该怎么修改呢
icoFoam的options文件
EXE_INC =
-I$(LIB_SRC)/meshTools/lnIncludeEXE_LIBS =
-lfiniteVolume
-lmeshTools -
编译icoFoam时出现没有发现fvCFD.H@sibo fin文件里面有一个lnInclude文件,不是在finiteVolume中
编译icoFoam时出现没有发现fvCFD.HEXE_INC = \ -I$/home/zcy/openfoam/fin/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude EXE_LIBS = \ -lmyfiniteVolume \ -lmeshTools
这是我的InInclude
