  4. 各位前辈,下面这个OpenFOAM报错是什么原因。内容是圆柱绕流的RANS湍流模型。
6 帖子 5 发布者 7.8k 浏览
    zhuhuanyu1986
    Courant Number mean: 0.0689642 max: 3.51936
    #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
    #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    #5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    #6  ? in "/home/zhu/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
    #7  ? in "/home/zhu/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
    #8  ? in "/home/zhu/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
    #9  ? in "/home/zhu/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
    #10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #11  ? in "/home/zhu/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
    Floating point exception (core dumped)
    时间步长减小一点试试
  • 张 离线
    张 离线
    张文青
    楼主问题解决了么?我也遇到类似问题,求解决办法。谢谢!
    hehaohao2013
    the same issue,how do you solve?
    youhaoyu
    在 中回复了 hehaohao2013 最后由 编辑
    @hehaohao2013 This appears to be because the Coulanger number is too large to calculate. You can step the time to a smaller or check the initial conditions
    hehaohao2013
    yes ,i do and it solve.thank you .
