  3. 低马赫数假设的流动属于可压缩流还是不可压缩流
2 帖子 2 发布者 2.8k 浏览
    Calf.Z-DNS
    大家好,
    我一直对于low-mach-assumption flows 感到困惑。
    论文里面写到:
    using the low-Mach-number assumption, where the acoustic interactions and compressibility effects are eliminated.
    那么被消除的这些东西,会造成哪些影响呢?compressibility effects是否与psi有关呢?有关的话,代码里面是否就不能使用psi?
    从论文给的方程来看,应该是属于可压缩流:
    但我不太确定这种流动的真实属性,或者可以把这样的流动称作variable-density flow.
    附上Wikipadia的一段解释:
    low Mach-number flow / Pseudo-incompressibility:
    The low Mach-number constraint can be derived from the compressible Euler equations using scale analysis of non-dimensional quantities.
    The restraint, like the previous in this section, allows for the removal of acoustic waves, but also allows for large perturbations in density and/or temperature.
    The assumption is that the flow remains within a Mach number limit (normally less than 0.3) for any solution using such a constraint to be valid.
    Again, in accordance with all incompressible flows the pressure deviation must be small in comparison to the pressure base state.
    希望大家能帮忙解答一下,谢谢!
    还没见过教材里面讨论low-Mach-number assumption,气动声学这块我还没研究过 :zoule:
