  4. DPMFoam 计算时出现奇怪报错
DPMFoam 计算时出现奇怪报错
7 帖子 2 发布者 9.6k 浏览
  • ZYjZ 离线
    ZYjZ 离线
    ZYj
    最近在计算DPMFfoam时,出现了如下的报错
    Evolving kinematicCloud
    Solving 2-D cloud kinematicCloud
        23 move-collide subCycles
    --> FOAM FATAL ERROR:
    Patch data was requested for a particle that isn't on a patch
        From function void Foam::particle::patchData(Foam::vector&, Foam::vector&) const
        in file particle/particle.C at line 941.
    FOAM exiting
    我在kinematicCloudProperties中设置了粒子间的碰撞和一些cloudFunctions,具体如下
    pairCollisionCoeffs
            maxInteractionDistance  1e-5;
            writeReferredParticleCloud no;
            pairModel pairSpringSliderDashpot;
            pairSpringSliderDashpotCoeffs
                useEquivalentSize   no;
                alpha               0.12;
                b                   1.5;
                mu                  0.52;
                cohesionEnergyDensity 0;
                collisionResolutionSteps 12;
            wallModel wallLocalSpringSliderDashpot;
            wallLocalSpringSliderDashpotCoeffs
                walls
                    youngsModulus   2e10;
                    poissonsRatio   0.28;
                    alpha           0.12;
                    b               1.5;
                    mu              0.43;
                frontAndBack
                    youngsModulus   2e10;
                    poissonsRatio   0.28;
                    alpha           0.12;
                    b               1.5;
                    mu              0.1;
            U     U.water;
    和
    cloudFunctions
        patchPostProcessing1
            type            patchPostProcessing;
            maxStoredParcels 100000;
            patches         ( outlet inlet walls);
        particleTracks1
            type            particleTracks;
            trackInterval   10;
            maxSamples      1000000;
            resetOnWrite    yes;
        particleErosion1
        type            particleErosion;
        p               11000000; //yield stress for aluminium = 11000000 Pa or 11 MPa
        psi             2;//Ratio of the depth of contact to the depth of cut (default value = 2 )
        K               2; //Ratio of vertical to horizontal force components (2 for angular abrassive grains)
        patches
          ( walls);
    我如果这两个均不设置,则没有问题。报错部分的源代码如下
    void Foam::particle::patchData(vector& n, vector& U) const
        if (!onBoundaryFace())
            FatalErrorInFunction
                << "Patch data was requested for a particle that isn't on a patch"
                << exit(FatalError);
    请问有人知道这是什么问题吗?万分感谢!
  • ZYjZ 离线
    ZYjZ 离线
    ZYj
    后来我发现我的这个cloudFunctions和pairCollisionCoeffs 2选1的话就不会报错,但是有人能解释下为什么吗?如果两个都想要的话又该怎么设置呢?
    你把cloudFunctions取消没问题是吧?
    然后你把碰collision去掉,保留cloudFunction也没问题?
    ZYjZ 1 条回复 最后回复
  • ZYjZ 离线
    ZYjZ 离线
    ZYj
    @东岳 对的
    更改下wall的壁面类型解决问题么,改成stick合适么?
    感觉是你的粒子腐蚀方面的问题,去掉后怎样
    ZYjZ 1 条回复 最后回复
  • ZYjZ 离线
    ZYjZ 离线
    ZYj
    腐蚀不能去掉,目的就是算腐蚀。改成stick后会不会不符合实际呢?总之,我先改了试试。
  • ZYjZ 离线
    ZYjZ 离线
    ZYj
    @东岳 wo我把除了inlet和outlet的patch都改为stick,然而一样的结果,一样的报错信息。
