  4. OpenFoam定义新边界条件问题---通量边界
13 帖子 3 发布者 20.9k 浏览
  • G 离线
    G 离线
    general
  • G 离线
    G 离线
    general
    这边参考网上陈丽萍老师的教程,但是编译总是出错,是不是版本不支持了?我的是5.0版本
  • G 离线
    G 离线
    general
    尝试编译过程发现提示.C的173行有问题
    wmake libso .
    g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/home/a/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude  -IlnInclude -I. -I/home/a/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude -I/home/a/OpenFOAM/OpenFOAM-5.x/src/OSspecific/POSIX/lnInclude   -fPIC -c flowFvPatchScalarField.C -o Make/linux64GccDPInt32Opt/flowFvPatchScalarField.o
    flowFvPatchScalarField.C: In member function ‘virtual void Foam::flowFvPatchScalarField::updateCoeffs()’:
    flowFvPatchScalarField.C:173:48: error: qualified-id in declaration before ‘(’ token
    /home/a/OpenFOAM/OpenFOAM-5.x/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/flowFvPatchScalarField.o' failed
    make: *** [Make/linux64GccDPInt32Opt/flowFvPatchScalarField.o] Error 1
    对应173行的代码为:
        const volScalarField& C =
            db().lookupObject<volScalarField>(C_);
        gradient_ =5;
        operator==
            this->patchInternalField()
            + gradient_/this->patch().deltaCoeffs
        fixedValueFvPatchScalarField::updateCoeffs();
    @general 在 OpenFoam定义新边界条件问题---通量边界 中说:
    没细看,不过单独看这一句,是版本不支持
  • G 离线
    G 离线
    general
    最近尝试修改,整理完成后边界可以编译了,但是放到计算文件中还是报错,提示错误如下,有人知道这是什么原因吗?
    Unknown patchField type newgrad for patch type wall
    Valid patchField types are :
    (。。。。。(省略)
    file: /home/a/temp/cavity/0/C.boundaryField.wall2flow from line 41 to line 41.
        From function static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = double]
        in file /home/a/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 134.
    FOAM exiting
    H文件
    #ifndef newgradFvPatchScalarField_H
    #define newgradFvPatchScalarField_H
    #include "fixedValueFvPatchFields.H"
    namespace Foam
                 Class newgradFvPatchScalarField Declaration
    class newgradFvPatchScalarField
        public fixedValueFvPatchScalarField
        // Private data
            //- Total pressure
            scalarField gradient_;
    public:
        //- Runtime type information
        TypeName("newgrad");
        // Constructors
            //- Construct from patch and internal field
                const fvPatch&,
                const DimensionedField<scalar, volMesh>&
            //- Construct from patch, internal field and dictionary
                const fvPatch&,
                const DimensionedField<scalar, volMesh>&,
                const dictionary&
            //- Construct by mapping given newgradFvPatchScalarField
            //  onto a new patch
                const newgradFvPatchScalarField&,
                const fvPatch&,
                const fvPatchFieldMapper&
            //- Construct as copy
            //- Construct and return a clone
            virtual tmp<fvPatchScalarField> clone() const
                return tmp<fvPatchScalarField>
                    new newgradFvPatchScalarField(*this)
            //- Construct as copy setting internal field reference
            //- Construct and return a clone setting internal field reference
                const DimensionedField<scalar, volMesh>& iF
            ) const
                    new newgradFvPatchScalarField(*this, iF)
        // Member functions
            // Access
                //- Return the total pressure
                const scalarField& gradient() const
                    return gradient_;
                //- Return reference to the total pressure to allow adjustment
                    return gradient_;
            // Mapping functions
                //- Map (and resize as needed) from self given a mapping object
                virtual void autoMap
                //- Reverse map the given fvPatchField onto this fvPatchField
                virtual void rmap
                    const fvPatchScalarField&,
                    const labelList&
            // Evaluation functions
                //- Update the coefficients associated with the patch field
                virtual void updateCoeffs();
            //- Write
            //virtual void write(Ostream&) const;
    } // End namespace Foam
    #endif
    C文件
    #include "newgradFvPatchScalarField.H"
    #include "addToRunTimeSelectionTable.H"
    #include "fvPatchFieldMapper.H"
    #include "volFields.H"
    #include "surfaceFields.H"
    void Foam::newgradFvPatchScalarField::updateCoeffs()
        if (updated())
            return;
            db().lookupObject<volScalarField>("C");
        gradient_=0.5*C;
        operator==
            this->patchInternalField()+gradient_/this->patch().deltaCoeffs()
    namespace Foam
        makePatchTypeField
            fvPatchScalarField,
  • G 离线
    G 离线
    general
    边界条件编译了, .so文件也添加到字典中了,还是提示Unknown patchField type newgrad for patch type wall,这个好让人困惑。。。
  • G 离线
    G 离线
    general
    检查发现是在字典中少将libs 写成了lib,修改之后还是出错,不过边界条件可以识别了。
    Create time
    Create mesh for time = 0
    PISO: Operating solver in PISO mode
    Reading transportProperties
    Reading field p
    Reading field U
    Reading field C
    Starting time loop
    Time = 5e-05
    Courant Number mean: 7.5e-05 max: 0.194817
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 2.38974e-06, No Iterations 8
    smoothSolver:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
    #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    #4  Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    #5  Foam::newFvPatchScalarField::updateCoeffs() at ??:?
    #6  Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:?
    #7  Foam::fv::gaussLaplacianScheme<double, Foam::SymmTensor<double> >::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    #8  Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    #9  ? at ??:?
    #10  ? at ??:?
    #11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #12  ? at ??:?
    浮点数例外 (核心已转储)
    C文件
       \\    /   O peration     |
        \\  /    A nd           | Copyright (C) 2011-2017 OpenFOAM Foundation
         \\/     M anipulation  |
    License
        for more details.
    #include "newFvPatchScalarField.H"
    // * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
    Foam::newFvPatchScalarField::newFvPatchScalarField
        const fvPatch& p,
        fixedValueFvPatchScalarField(p, iF)
        const newFvPatchScalarField& ptf,
        const fvPatch& p,
        const DimensionedField<scalar, volMesh>& iF,
        const fvPatchFieldMapper& mapper
        fixedValueFvPatchScalarField(ptf, p, iF, mapper)
        const fvPatch& p,
        const dictionary& dict
        fixedValueFvPatchScalarField(p, iF, dict, false)
        const newFvPatchScalarField& tppsf
        fixedValueFvPatchScalarField(tppsf)
        const newFvPatchScalarField& tppsf,
        fixedValueFvPatchScalarField(tppsf, iF)
    void Foam::newFvPatchScalarField::autoMap
        fixedValueFvPatchScalarField::autoMap(m);
    void Foam::newFvPatchScalarField::rmap
        const fvPatchScalarField& ptf,
        const labelList& addr
        fixedValueFvPatchScalarField::rmap(ptf, addr);
    void Foam::newFvPatchScalarField::updateCoeffs()
        if (updated())
            return;
        gradient_=0.5*C;
        operator==
    //void Foam::newFvPatchScalarField::write(Ostream& os) const
    //    fvPatchScalarField::write(os);
    namespace Foam
        makePatchTypeField
            fvPatchScalarField,
    H文件
       \\    /   O peration     |
        \\  /    A nd           | Copyright (C) 2011-2016 OpenFOAM Foundation
         \\/     M anipulation  |
    License
        for more details.
    Class
    Group
        grpInletBoundaryConditions grpOutletBoundaryConditions
    Description
        This boundary condition provides a total temperature condition.
    Usage
        \table
            Property     | Description             | Required    | Default value
            U            | Velocity field name     | no          | U
            phi          | Flux field name         | no          | phi
            psi          | Compressibility field name | no       | thermo:psi
            gamma        | ratio of specific heats (Cp/Cv) | yes |
            T0           | reference temperature   | yes         |
        \endtable
        Example of the boundary condition specification:
        \verbatim
        <patchName>
            type            new;
            T0              uniform 300;
        \endverbatim
    SourceFiles
        newFvPatchScalarField.C
    See also
        Foam::fixedValueFvPatchField
    #ifndef newFvPatchScalarField_H
    #define newFvPatchScalarField_H
    namespace Foam
                 Class newFvPatchScalarField Declaration
    class newFvPatchScalarField
        // Private data
    public:
        TypeName("new");
        // Constructors
                const fvPatch&,
                const fvPatch&,
                const dictionary&
            //- Construct by mapping given newFvPatchScalarField
            //  onto a new patch
                const newFvPatchScalarField&,
                const fvPatch&,
                    new newFvPatchScalarField(*this)
            ) const
                    new newFvPatchScalarField(*this, iF)
        // Member functions
            // Access
                    return gradient_;
                    return gradient_;
                virtual void rmap
                    const labelList&
            //- Write
    #endif
  • G 离线
    G 离线
    general
    有人知道下面这种错误的原因吗?
    myicoFoam: symbol lookup error: /home/a/OpenFOAM/a-5.x/platforms/linux64GccDPInt32Opt/lib/libnewFvPatchScalarField.so: undefined symbol: _ZN4Foam21newFvPatchScalarFieldC1ERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE
    看起来像是调用了一个过时的lib,库和求解器全部重新编译一下
    G 1 条回复 最后回复
  • G 离线
    G 离线
    general
    @东岳 好的谢谢东岳老师,我试一下
    Jhhu
    您好,您最后这个边界条件成功了吗?是变通量边界条件吗?谢谢!
    G 1 条回复 最后回复
  • G 离线
    G 离线
    general
    在 中回复了 Jhhu 最后由 编辑
    @Jhhu 你好,我最后没有成功,由于时间很紧张,还是使用了商用软件。
