  4. 请问.msh的2维旋转轴对称网格如何转换到OpenFOAM
32 帖子 11 发布者 55.2k 浏览
    LYD
    在 中回复了 浪迹天大 最后由 李东岳 编辑
    @浪迹天大 您好,我按照您提供的方法进行网格转化的时候出现了这种情况
    frontAndBack
            type            empty;
            inGroups        1(empty);
            nFaces          0;
            startFace       949841;
        frontAndBack_pos
            type            wedge;
            inGroups        1(wedge);
            nFaces          474627;
            startFace       949841;
        frontAndBack_neg
            type            wedge;
            inGroups        1(wedge);
            nFaces          474627;
            startFace       1424468;
    frontAndBack没被融合掉;我没有写blockdictionary,直接用fluent.msh转化的。、
    shampoo
    在 中回复了 LYD 最后由 编辑
    @LYD 我最近也在搞轴对称网格,我这里遇到这种情况是ok的,可以计算。感觉留着frontAndBack也没啥大问题。反正在设温度、压力的边界条件的时候都带上,给成empty的type就行
    E 1 条回复 最后回复
    对,frontAndBack的面数是0,无所谓
  • E 离线
    E 离线
    Exthan
    在 中回复了 shampoo 最后由 编辑
    @shampoo @LYD @D-Benjamin 我在OF5上下载了Benjamin的OF7版本的makeAxialMesh,编译通过也没报错,网格生成时有warnning,但是不是链接中指出的Either correct the patch or split it into planar parts,该warnning会在计算的时候出现,请指出的错误
    makeAxialMesh -overwrite时
    Create time
    --> FOAM Warning :
        From function void *Foam::dlOpen(const Foam::fileName &, bool)
        in file POSIX.C at line 1210
        dlopen error : /home2/snst/gzh1/OpenFOAM/gzh1-5.0/platforms/linux64IccDPInt32Opt/lib/libtabularThermophysicalModels.so: undefined symbol: _ZTIN4Foam29mixedEnergyFvPatchScalarFieldE
    --> FOAM Warning :
        From function bool Foam::dlLibraryTable::open(const Foam::fileName &, bool)
        in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 105
        could not load "libtabularThermophysicalModels.so"
    Create mesh for time = 0
    Plane of the grid: (0 0 1) (0.5 0.000169685 5.95636e-21)
    The rotation-axis: ((0 0 0) (1 0 0))
    Creating wedge with an opening angle of 5 degrees
    Projecting nodes
    Radius to axis: min = 0 max = 0.00035
     Calculated Distance of center to axis is 0.000350333
    Distance of axis to patch is 0.000350333 -> not changing the patch type
    Splitting patch frontAndBack
     Copying patches
     Creating Patches
     Creating Pos-patch
     Creating Neg-patch
     Changing patches
    Changing patch types
     Changing frontAndBack_pos to wedge
     Changing frontAndBack_neg to wedge
    Writing mesh to time 0
    End
    Now use collapseEdges to clean grid
    --> FOAM Warning :
    --> FOAM Warning :
    Reading collapseDict
    Time = 0
    Read faceSet indirectPatchFaces with 0 faces
    Merging:
        edges with length less than 1e-06 metres
        edges split by a point with edges in line to within 179 degrees
        Minimum edge length reduction factor = -1
    Face collapsing is on
        Initial face length factor = -1
    Control mesh quality = false
    Selectively disabling wanted collapses until resulting quality satisfies constraints in system/meshQualityDict
    Outer Iteration = 0
        "Edge Filter Factor": min = 1e-06 av = 1e-06 max = 1e-06
            484693 / 484693 elements used
        Inner iteration = 0
            Collapsing 4503 small edges
            Collapsing 0 in line edges
                Uncollapsed edges = 4502 / 484693
                Uncollapsed edges = 0 / 484693
            Collapsing 1 edges after synchronisation and PointEdgeWave
                Number of points : 195130
                Not visited      : 0
                Not collapsed    : 195128
                Collapsed        : 2
            Collapsing 0 cells
            Apply changes to the current mesh
        Inner iteration = 1
            Collapsing 4502 small edges
                Uncollapsed edges = 4502 / 484692
                Uncollapsed edges = 0 / 484692
            Collapsing 0 edges after synchronisation and PointEdgeWave
    Writing collapsed mesh to time 0
    ExecutionTime = 1.68 s  ClockTime = 1 s
    运行时
    --> FOAM Warning :
     From function void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBuffers &)
    in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 70
    Wedge patch 'frontAndBack_pos' is not planar.
    At local face at (0.999667 0.000347009 1.51363e-05) the normal (-7.75524e-19 -0.043578 0.99905) differs from the average normal (1.35466e-08 -0.0435779 0.99905) b       y 6.36941e-15
     SIMPLE: convergence criteria
         field p_rgh  tolerance 1e-05
         field U      tolerance 1e-06
         field h      tolerance 1e-09
         field "(k|epsilon|omega)"    tolerance 1e-07
       type            hTabularThermo;
  • E 离线
    E 离线
    Exthan
    在 中回复了 浪迹天大 最后由 编辑
    @dzw05 @浪迹天大 两位老师好,上一个问题已经解决,我觉得应该是网格质量问题导致,目前已经checkMesh通过了,但还有个问题,想请老师们指导。我首先用blockMesh画了一个前后面empty的2D网格,下底面刚好在x轴上,然后绕x轴旋转成一个圆柱,所以将旋转轴设置为了(1 0 0),将上边界设置为了center,最后生成的几何原先empty的frontAndBack变成了frontAndBack_pos和frontAndBack_neg, bottom面由于变成了对称轴所以face就为0(即一条线),top面就变成了圆柱体的外表面,但是因为将其边界类型设为了symmetryPlane,所以如果想实现等热流或者等温,边界条件该如何给定?在哪改?
    S F 2 条回复 最后回复
    shampoo
    在 中回复了 Exthan 最后由 编辑
    @Exthan top面是圆柱的顶面吗还是圆柱的圆柱面?为啥会用的symmetry呢?一般设等温就在boundary里把类型改成patch,然后温度的边界条件里设成fixed value,应该就可以了
    E 1 条回复 最后回复
  • E 离线
    E 离线
    Exthan
    @shampoo 你好,我想算个半径为0.35的圆管,壁面等温,top面其实就是圆柱面,下壁面也就是对称轴所以应该设为symmetry,之所以用symmetry是因为在makeAxisMesh中定义的,如果用blockMeshDict则是empty,两者对对称轴生成的网格数都是0,这样对于top面,类型为Wall,确实可以用fixedValue边界,但是插值发现壁面处的温度不是固定的温度,而且用foamMeshToFluent发现,网格是个楔形网格,不是圆弧,也就是说径向上的尺寸最大不是0.35,如果整个楔形为5°,一般是2.5°,那最大的y应该只是0.35*cos2.5°,边界条件y=0.35的圆柱面的边界如何跟它对应呢?
    shampoo
    @Exthan 不吧,如果2D网格画的时候半径画到了0.35,转换完成的楔形网格最大的y应该有0.35啊。
    E 1 条回复 最后回复
  • E 离线
    E 离线
    Exthan
    @shampoo QQ图片20200331151114.png 不是圆弧
    S Y 2 条回复 最后回复
    shampoo
    @Exthan 啊我懂你的意思,但我一般就把那个平面近似当成圆弧面设边界条件。网格的单元也画不出圆弧的边啊,我觉得不用特纠结。如果一定要在那个圆弧面上设条件的话,不如单开个帖问问吧,这个我的确没考虑过,不好意思
    E 1 条回复 最后回复
  • E 离线
    E 离线
    Exthan
    @shampoo 是因为我用postProcess取值发现边界的速度本应为0,但是非0,其次边界温度本应等于fixedValue,但也不等,所以就很疑惑
    shampoo
    @Exthan 你取的是半径为0.35位置的速度和温度吧?其实那个并不是边界?
    E 1 条回复 最后回复
  • E 离线
    E 离线
    Exthan
    @shampoo 我用网格Cell取过,也有用Cloud取边界实际值,均不对
  • F 离线
    F 离线
    freeman
    @Exthan 你好,请问你运行makeAxialMesh出现warinning的问题是怎么解决的呢?
    在 中回复了 freeman 最后由 编辑
    @freeman 你画的是什么,你说的求解器非常老了后续也没有更新,几何很复杂么?可以用blockMesh直接画啊。
    Yu_Tian
    @exthan 你好,我想画一个这样的网格,但是目前没有参考的例子,您放不方便上传一个简单的案例提供参考,谢谢
    永远学习,永远进步
    WangGH
    @exthan 您好,我刚刚也下载了OF7版本的makeAxialmesh,但好像没找到编译文件,没有Allmake文件或者wmake文件,请问您是怎么编译的呢d27bf862-45db-4120-8ba1-050e18d46128-image.png
    B 1 条回复 最后回复
  • B 离线
    B 离线
    bit_hypersonic
    在 中回复了 WangGH 最后由 编辑
    @WangGH 直接wmake就行,在那个C++代码所在的文件夹中
