  4. 多线程这个错误怎么解决
多线程这个错误怎么解决
17 帖子 5 发布者 22.8k 浏览
    shrine
    [DESKTOP-CHOIST:01362] 3 more processes have sent help message help-btl-vader.txt / cma-permission-denied
    [DESKTOP-CHOIST:01362] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    CFD-online上有相关帖子,
    https://www.cfd-online.com/Forums/openfoam-solving/229816-cma-permission-denied-message-parallel-running.html
    转到油管,但是没看懂
    李东岳李 W 2 条回复 最后回复
    在 中回复了 shrine 最后由 编辑
    @shrine
    类似我这种吧:?
    [30] #17  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    [30] #18  ? in "/home/dyfluid/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
    [59] #17  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    [59] #18  ? in "/home/dyfluid/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
    [15] #17  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    [15] #18  ? in "/home/dyfluid/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
    [dyfluid-Super-Server:93809] 59 more processes have sent help message help-mpi-api.txt / mpi-abort
    [dyfluid-Super-Server:93809] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    发散了而已。具体原因要看上面的信息,你给出的是最后俩行。
    shrine
    不拆分线程不发散,拆分了线程一步都算不下去
    我还以为是在windows下用Ubuntu的原因(不是虚拟机)
    No MRF models present
    DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
    time step continuity errors : sum local = 0, global = 0, cumulative = 0
    Courant Number mean: 0 max: 0
    Starting time loop
    Interface Courant Number mean: 0 max: 0
    deltaT = 0.000119999
    Time = 0.000119999
    [DESKTOP-719V74U:00266] 15 more processes have sent help message help-btl-vader.txt / cma-permission-denied
    [DESKTOP-719V74U:00266] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    李东岳李 胡 2 条回复 最后回复
    @shrine
    那就不是发散的问题咯。我看了下你的事cma-permission-denied,目前还没遇到过这个问题,你找找cma-permission-denied吧..:xinlei:
  • 胡 离线
    胡 离线
    胡同小巷
    @shrine 是不是环境配置的问题,可以留个QQ或微信探讨吗?有时候不是很方便
    wsxfyy
    @shrine 不知道你解决没有,我之前遇到过,已解决。应该是Windows下面的子系统Linux使用多线程运行问题,不仅限于openfoam。解决方案,root用户下端运行
    主要是将其文件里面的1改为0,也可手动更改。
    S 3 条回复 最后回复
    shrine
    在 中回复了 wsxfyy 最后由 编辑
    @wsxfyy 感谢分享
    我感觉分多了就会发散,少分点就没事了
    你说的这个我试试
    shrine
    @wsxfyy 前面那个回复错了是另外一个问题
    这个Windows下的一直没解决,只好老实用回虚拟机了
    shrine
    @wsxfyy 请问在哪里把什么参数1改为0
    wsxfyy
    @shrine 那个图没贴上来,我打一下吧 root 下运行 echo 0 > /proc/sys/kernel/yama/ptrace_scope, 就可以了
    shrine
    @wsxfyy 到了/proc/sys/kernel/下面就没有yama这个目录了
    wsxfyy
    @shrine 你直接终端运行啊 切换到root用户 然后上面那行命令,然后有些时候关机以后又会遇到这个问题 这个解决办法我以前用到的就是这样
    shrine
    @wsxfyy 我切换到root了,/proc/sys/kernel/下面没有yama这个目录
    wsxfyy
    @shrine !(39d8691d-9c21-4520-aa6d-58864c3517f4-image.png 图片地址)如图这样就行,我是这么输入的,我不知道你说的没有那个文件的意思,你可以贴图上来看看
    shrine
    wsxfyy
    这个YAMA这个文件应该是有的 我不知道你为啥没有:143:
    Maoqiang
    类似的案例,我也遇到过,我的案例是在跑别人的代码时出错的,在出现的“No MRF models present/n No finite volume options present"报错,且后面出现了”Kill“字祥时,其中“Kill”字样很重要。
    到后面我发现:我的案例文件放错的位置,原先我放在与OF整体文件的所在的主文件夹内,我的解决是通过将案例放在OF的主文件夹内,而不是在OF主文件夹外,这成功。
    首先说我为什么这么做:
    1. 出现MRF警告时,我也以为时MRF链接出了问题,但事实是其他案例是正常的,故排除MRF问题;
    2. 我看到所引用的案例包内有:platfrom文件且内部为”linux64GccDPint32Opt“,这与OF主文件一致,我猜测事路径出了问题,最终事实如此。
