  4. 关于nOuterCorrectors影响计算速度和计算精度的问题
15 帖子 8 发布者 21.0k 浏览
  • wuyukaiW 离线
    wuyukaiW 离线
    wuyukai
    在 中回复了 波流力 最后由 编辑
    @波流力 网格差不多长这样
    Joann
    参考DTCHullMoving算例中nOuterCorrectors为3,每个时间步里迭代3次,获得3个模型中心的运动坐标,那么如果要获得时间-运动的曲线,是不是选择最后一次迭代的坐标比较好呢?
    Hello, CFD. Hello, OpenFOAM.
    log文件贴一下
    J 1 条回复 最后回复
    Joann
    @李东岳 比如这个时间步里,PIMPLE迭代了3次,分别有三个旋转中心,如果一个时间步就取一个值,是不是迭代最后一次的旋转中心较好?
    Courant Number mean: 0.00758176 max: 1.02562
    Interface Courant Number mean: 8.04602e-05 max: 0.732939
    Time = 8.89
    PIMPLE: Iteration 1
    forces forces:
        Not including porosity effects
    Rigid-body motion of the hull
        Centre of rotation: (3 0 0.189302)
        Orientation: (0.999758 0 -0.0219868 0 1 0 0.0219868 0 0.999758)
        Linear velocity: (0 0 -0.0427599)
        Angular velocity: (0 -0.0134282 0)
    GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.000933377, No Iterations 20
    time step continuity errors : sum local = 1.87363e-10, global = 7.57308e-13, cumulative = -3.15194e-09
    smoothSolver:  Solving for alpha.water, Initial residual = 2.27988e-05, Final residual = 6.44668e-12, No Iterations 3
    Phase-1 volume fraction = 0.803336  Min(alpha.water) = -3.41348e-13  Max(alpha.water) = 1
    Applying the previous iteration compression flux
    MULES: Correcting alpha.water
    Phase-1 volume fraction = 0.803336  Min(alpha.water) = -9.55996e-09  Max(alpha.water) = 1
    GAMG:  Solving for p_rgh, Initial residual = 0.00721682, Final residual = 4.55154e-08, No Iterations 17
    time step continuity errors : sum local = 1.0765e-09, global = -2.39228e-12, cumulative = -3.15433e-09
    PIMPLE: Iteration 2
    forces forces:
        Linear velocity: (0 0 -0.0427459)
        Angular velocity: (0 -0.0134156 0)
    GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.000949765, No Iterations 19
    time step continuity errors : sum local = 1.34488e-10, global = -1.2392e-13, cumulative = -3.15445e-09
    smoothSolver:  Solving for alpha.water, Initial residual = 1.58142e-05, Final residual = 6.39378e-12, No Iterations 3
    Phase-1 volume fraction = 0.803336  Min(alpha.water) = -3.4121e-13  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.803336  Min(alpha.water) = -8.31726e-10  Max(alpha.water) = 1
    GAMG:  Solving for p_rgh, Initial residual = 0.000213947, Final residual = 4.56853e-08, No Iterations 19
    time step continuity errors : sum local = 1.07998e-09, global = -2.92566e-12, cumulative = -3.15738e-09
    PIMPLE: Iteration 3
    forces forces:
        Linear velocity: (0 0 -0.0427505)
        Angular velocity: (0 -0.0134234 0)
    GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.000923356, No Iterations 22
    time step continuity errors : sum local = 1.36977e-10, global = -1.34327e-13, cumulative = -3.15751e-09
    smoothSolver:  Solving for alpha.water, Initial residual = 1.57985e-05, Final residual = 6.20267e-12, No Iterations 3
    Phase-1 volume fraction = 0.803336  Min(alpha.water) = -3.412e-13  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.803336  Min(alpha.water) = -5.01932e-08  Max(alpha.water) = 1
    GAMG:  Solving for p_rgh, Initial residual = 0.000101498, Final residual = 4.62009e-08, No Iterations 19
    time step continuity errors : sum local = 1.09272e-09, global = 4.09503e-12, cumulative = -3.15342e-09
    smoothSolver:  Solving for omega, Initial residual =2.53013e-05, Final residual = 7.65699e-09, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 5.87558e-05, Final residual = 2.49652e-08, No Iterations 3
    ExecutionTime = 27536.4 s  ClockTime = 27737 s
    多贴几个时间步,完整的,我再看下。
    咦,看错了, @wuyukai 你的log文件贴下
    luofq-sysu
    @李东岳 李老师,借楼问一下:滑移网格计算,每三个时间步会出现pcorr iteration 1000,可能出现的原因在哪方面?网格checkMesh无问题,可能会是GAMGPCG这些格式吗?
    在 中回复了 luofq-sysu 最后由 编辑
    @luofq-sysu 对,你换一下PCG,很有可能会改善
    luofq-sysu
    @李东岳 谢谢李老师。1. solver.pcorr改成PCG,虽然还是出现iteration 1000,但确实快了很多。2.尝试将pcorr的tolerance从 1e-06改成1e-05,还是会出现 iteration 1000。这个有没有可能跟网格有关呢?整体计算速度慢的原因还有P_rgh也挺费事的
    李东岳李 zhanghanZ 2 条回复 最后回复
    @luofq-sysu
    这个有没有可能跟网格有关呢
    有关。
    网格多少。网格多的话就是那么慢咯
  • zhanghanZ 离线
    zhanghanZ 离线
    zhanghan
    在 中回复了 luofq-sysu 最后由 李东岳 编辑
    fvSolution中修改每一项的tolerance,我的case是bubbleColumnEvaporatingReacting,自带的tolerance是1e-20,我修改为1e-10后计算的非常快,而且计算结果几乎相同。
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      fvSolution;
    solvers
        "alpha.*"
            nAlphaCorr      1;
            nAlphaSubCycles 3;
        p_rgh
            solver          GAMG;
            smoother        DIC;
            tolerance       1e-10;
            relTol          0.001;
        p_rghFinal
            $p_rgh;
            relTol          0;
        "U.*"
            solver          smoothSolver;
            tolerance       1e-10;
            relTol          0;
            minIter         1;
        "(e|h).*"
            tolerance       1e-10;
            relTol          0;
            minIter         1;
        "(k|epsilon|Theta).*"
            tolerance       1e-10;
            relTol          0;
            minIter         1;
        Yi
            tolerance       1e-10;
            relTol          0;
            minIter         1;
            residualAlpha   1e-8;
    PIMPLE
        nOuterCorrectors 1;
        nCorrectors      1;
        nNonOrthogonalCorrectors 0;
    relaxationFactors
        equations
            ".*"            0.3;
    jxzs_zy
    此回复已被删除!
