  4. twoPhaseMixture类修改,编译通过,运行出错
5 帖子 2 发布者 4.6k 浏览
    Rachel0096
    写于 最后由 Rachel0096 编辑
    各位老师,下午好
    我目前尝试在compressibleInterFoam添加组分方程,将twoPhaseMixture类做了以下修改:
    thermo1_ = rhoThermo::New(U.mesh(), phase1Name());
    thermo2_ = rhoReactionThermo::New(U.mesh(), phase2Name());
    只修改thermo2的原因是假设液相为单组分系统,气相为多组分系统。
    目前编译正常通过,在运行算例时会遇到下面的问题:
    #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
    #3  Foam::multiComponentMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::patchFaceVolMixture(double, double, int, int) const at ??:?
    #4  Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::singleStepReactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) at ??:?
    #5  Foam::rhoReactionThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::singleStepReactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
    #6  Foam::autoPtr<Foam::rhoReactionThermo> Foam::basicThermo::New<Foam::rhoReactionThermo>(Foam::fvMesh const&, Foam::word const&) at ??:?
    #7  Foam::rhoReactionThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
    #8  Foam::twoPhaseMixtureThermo::twoPhaseMixtureThermo(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
    #9  ? in ~/OpenFOAM/dyfluid-v2012/platforms/linux64GccDPInt32Opt/bin/atomizationFoam
    #10  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #11  ? in ~/OpenFOAM/dyfluid-v2012/platforms/linux64GccDPInt32Opt/bin/atomizationFoam
    Floating point exception (core dumped)
    我通过逐行插入输出语句发现运行卡顿在下面这一句:
        Info<<"     twoPhaseMixtureThermo::debug2222222"<<endl;
        Info<<"     twoPhaseMixtureThermo::debug3333333"<<endl;
    输出如下:
    debug0000000
    Constructing twoPhaseMixtureThermo
    Selecting surfaceTensionModel constant
         twoPhaseMixtureThermo::debug00000000
             phase1Name:water
         twoPhaseMixtureThermo::debug111111111
             phase2Name:air
    use rhoThermo::New->basicThermo::New
          into basicThermo::New
          into lookupThermo
            actually into lookupThermo
        type            heRhoThermo;
        mixture         pureMixture;
        transport       const;
        thermo          hConst;
        equationOfState rhoConst;
        specie          specie;
        energy          sensibleEnthalpy;
        debug::into rhoReactionThermo1111111111
          into lookupThermo
        type            heRhoThermo;
        mixture         singleStepReactingMixture;
        transport       sutherland;
        thermo          janaf;
        equationOfState perfectGas;
        specie          specie;
    Selecting chemistryReader foamChemistryReader
    chemistryReader::debug111111111
        foamChemistryReader::debug22222222222
    Fuel heat of combustion :46447948
    stoichiometric air-fuel ratio :15.602043
    stoichiometric oxygen-fuel ratio :3.635401
    Maximum products mass concentrations:
        H2O: 0.098613587
        CO2: 0.18067909
        N2: 0.72070733
    而后再对multiComponentMixture进行逐行输出,发现卡顿在下面这段循环语句:d1e75f1c-a9fd-445f-8575-52d3370b37d2-image.png
    想问一下,有没有老师遇到过类似的情况,或者出现这个错误可能出现的原因?
    此外,液体入口处是通过snapyyHexMesh生成的,如图所示,这会不会也对case的运行有影响呢?
  • W 在线
    W 在线
    wangfei9088 大神
    在 中回复了 Rachel0096 最后由 编辑
    @Rachel0096 在 twoPhaseMixture类修改,编译通过,运行出错 中说:
    好像碰到过这个问题。临时的解决的办法是初始化密度的倒数为极小数,不要初始化为0。
    scalar rhoInv = VSMALL;
    先试试这个,具体的问题可能还要想其他办法。也有可能你的问题不是这个原因。
    R 2 条回复 最后回复
    Rachel0096
    在 中回复了 wangfei9088 最后由 编辑
    @wangfei9088 您是指在createField.H中初始化为极小数嘛?
    Rachel0096
    @wangfei9088
    您好,我尝试将其修改为scalar rhoInv = VSMALL,但还其还是卡在了下面的for循环当中,不知道您还有什么建议嘛?
    输出:
    celli:516314.............
    into cellVolMixture
       into forAll(speciesData_, i)
        rhoInv:0.71703454
        rhoInv:0.71703454
        rhoInv:0.71703454
        rhoInv:0.71703454
        rhoInv:3.4130544
          into mixtureVol_
          into for(label n=1; n<Y_.size(); n++)
    celli:516315.............
    into cellVolMixture
        rhoInv:0.71703454
        rhoInv:0.71703454
        rhoInv:0.71703454
        rhoInv:0.71703454
        rhoInv:3.4130544
          into mixtureVol_
  • W 在线
    W 在线
    wangfei9088 大神
    还是卡在了下面的for循环当中
    没瞧出有啥问题。看输出的信息就是遍历网格,计算每个网格内的密度倒数。
    如果猜测是卡在for循环里了,这个cellVolMixture函数在heRhoThermo.C文件里也有调用,那里面也有一个for循环,瞅瞅是不是那里边有问题。
