  4. ofv2212版本里的rigidbodyhull案例的一些疑问
8 帖子 3 发布者 9.7k 浏览
    csj1246957849
    写于 最后由 csj1246957849 编辑
    在verInterPhaseChangeDyMFoam的rigidbodyhull这个案例里面,移动的船速是怎么确定的,或者是在dynamicmeshdict中给了船舶一个推力让船动起来,这个案例也不像dtchull里面给了流场一个入射速度,以下是这个案例的U和dynamicmeshdict
    U:
    dimensions [0 1 -1 0 0 0 0];
    internalField uniform (0 0 0);
    boundaryField
    #includeEtc "caseDicts/setConstraintTypes"
    "(BLADES|HUB_DISK|HUB|HUB_COVER|HULL*.*)"
        type            movingWallVelocity;
    inlet
        type            fixedValue;
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0 );
    "(atmosphere)"
    "(overset-1|oversetPatch)"
        type           overset;
    dynamicmeshdict如下:
    dynamicFvMesh dynamicOversetFvMesh;
    solvers
    VF
    motionSolverLibs (libfvMotionSolvers);
    motionSolver solidBody;
    solidBodyMotionFunction drivenLinearMotion;
    cellSet c0;
    cOfGdisplacement CofG;
    boat_propeller
        motionSolverLibs    (librigidBodyMeshMotion);
        motionSolver         rigidBodyMotion;
        report              on;
        cellSet             cHullProp;
        bodyIdCofG      1;
        solver
            type Newmark;
        accelerationRelaxation 0.8;
        accelerationDamping    0.9;
        nIter   3;
        bodies
            hull
                type            rigidBody;
                parent          root;
                mass            2787;
                centreOfMass     (0.178 0 0.3323);
                inertia         (564 0 0 8535 0 8535);
                // Transformation tensor and centre of rotation
                transform       (1 0 0 0 1 0 0 0 1)  (0.178 0 0.3323);
                joint
                    type            composite;
                    joints
                            type Pxyz;
                            type Ry;
                patches
                    HULL
                    HULL_DISK
                innerDistance   100;
                outerDistance   200;
            propeller
                type            rigidBody;
                parent          hull;
                centreOfMass    (-3.405396 -0.000044 0.129544);
                mass            0.3;
                transform       (1 0 0 0 1 0 0 0 1) (-3.583 -0.000044 -0.202706);
                inertia         (0.000556833 0 0 0.36905863 0 0.36858374);
                patches
                    BLADES
                    HUB
                    HUB_DISK
                innerDistance   100;
                outerDistance   200;
                joint
                    type        Rx;
        restraints
            force
                type        externalForce;
                body        hull;
                location    (-3.386 0 0.21);
                force       table
                    (0    (500 0 0))
                    (10   (2000 0 0))
                    (20   (2000 0 0))
    有了解这个案例的朋友希望帮忙解读以下,非常感谢!
    wangwang
                type        externalForce;
                body        hull;
                force       table
                    (0    (500 0 0))
                    (10   (2000 0 0))
                    (20   (2000 0 0))
    看起来像是这个table起的作用
    csj1246957849
    在 中回复了 wangwang 最后由 编辑
    @wangwang 在 ofv2212版本里的rigidbodyhull案例的一些疑问 中说:
                type        externalForce;
                body        hull;
                force       table
                    (0    (500 0 0))
                    (10   (2000 0 0))
                    (20   (2000 0 0))
    看起来像是这个table起的作用
    下方的force table下的参数是怎样的运行逻辑呢
    wangwang
    在 中回复了 csj1246957849 最后由 编辑
    @csj1246957849 你好,我猜可能是这样,我没用过这个,仅供参考。
    csj1246957849
    @wangwang 谢谢,这个force有可能是螺旋桨给予船舶的推力吗
    wangwang
    @csj1246957849 这个力在x方向上,大概就是推力了
    hachikoi
    你好 还有一个问题不知道你有没有注意到:rigidBodyHull算例似乎是把螺旋桨overset嵌在船体overset中,这样不会导致背景网格在与船体overset插值时认为螺旋桨内存在水体吗
    csj1246957849
    在 中回复了 hachikoi 最后由 编辑
    @hachikoi 注意到了,似乎在螺旋桨与船连接处存在了一个disk薄片,
