  4. 原有的湍流模型加上非线性项雷诺应力的问题
38 帖子 5 发布者 56.2k 浏览
    SHUKK
    @李东岳 李老师,我遇到一个wmake的问题。我把我训练完成的神经网络写成一个reynoldsNet库,打算在linearViscousStrees中调用,但是显示了无法识别的问题这是什么导致的?
    wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries:
        unknown option: '-I/home/user3/OpenFOAM/user3-9/reynoldsNet/lnInclude'
    Usage: wmakeLnInclude [OPTION] [dir]
    options:
      -update | -u      update
      -silent | -s      use 'silent' mode (do not echo command)
      -help   | -h      print the usage
        Link all the source files in the <dir> into <dir>/lnInclude
    Note
        The '-u' option forces an update when the lnInclude directory already exists
        and changes the default linking from 'ln -s' to 'ln -sf'.
    SHUKK
    在 中回复了 李东岳 最后由 SHUKK 编辑
    @李东岳 上面的步骤是在编译MomentumTransportModels文件夹时候的。同时,我在simpleNNFoam中修改了我的需要连接的linearViscousStrees中的divDevTau(U, S, R),S跟R都已经在 createFields.H中创建了。
        // Momentum predictor
        tmp<fvVectorMatrix> tUEqn
            fvm::div(phi, U)
          + MRF.DDt(U)
          + turbulence->divDevTau(U, S, R) // Data driven R-S + viscous component
          fvModels.source(U)
        UEqn.relax();
        fvConstraints.constrain(UEqn);
        if (simple.momentumPredictor())
            solve(UEqn == -fvc::grad(p));
            fvConstraints.constrain(U);
    但是我在wmake我的simpleNNFoam中出现了,数据类型不对的问题。
    In file included from /home/user3/libtorch/include/c10/util/Exception.h:7,
                     from /home/user3/libtorch/include/ATen/core/Generator.h:11,
                     from /home/user3/libtorch/include/ATen/CPUGeneratorImpl.h:3,
                     from /home/user3/libtorch/include/ATen/Context.h:3,
                     from /home/user3/libtorch/include/ATen/ATen.h:7,
                     from /home/user3/libtorch/include/torch/csrc/api/include/torch/types.h:3,
                     from /home/user3/libtorch/include/torch/script.h:3,
                     from /home/user3/OpenFOAM/user3-9/reynoldsNet/lnInclude/reynoldsNet.H:42,
                     from /home/user3/OpenFOAM/user3-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/linearViscousStress.H:38,
                     from /home/user3/OpenFOAM/user3-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/Stokes.H:39,
                     from /home/user3/OpenFOAM/user3-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/laminarModel.C:27,
                     from /home/user3/OpenFOAM/user3-9/src/MomentumTransportModels/momentumTransportModels/lnInclude/laminarModel.H:193,
                     from /home/user3/OpenFOAM/user3-9/src/MomentumTransportModels/incompressible/lnInclude/kinematicMomentumTransportModel.H:47,
                     from simpleNNFoam.C:66:
    /home/user3/libtorch/include/c10/util/variant.h:1204:11: error: no matching function for call to 'Foam::data::data(const c10::detail_::impl<c10::SmallVector<c10::SymInt, 5>, at::Tensor>&)'
     1204 |           data(lib::forward<V>(v)),
    我查看了 Foam::data::data(const objectRegistry& obr),要的是objectRegistry类,但是在我的reynoldsNet库中已经将libtorch输出的torch::Tensor转换成std::vector<float>然后带入输出,没有将是torch的数据直接带入OF中。这是有数据没按要求来转换吗?:135:
    J 1 条回复 最后回复
    SHUKK
    libtorch跟OF耦合的问题已解决,纯粹是一个.so文件的名字大小写打错了:136: 。目前1w步跑完结果与LES相似
    那面CFD+pytorch的全部时间,跟纯LES跑,二者时间差的大么。这个是不是主要取决于硬件。
    SHUKK
    @李东岳 并行16线程,CFD+pytorch一共花了1个半小时左右,LES的并行36线程大概要10小时左右。CFD+pytorch的本质还是用RANS去跑,pytorch就是提供一个隐式方程,与原RANS湍流方程的时间差不多。当然硬件越好跑的越快。我们组的服务器还是从李老师你那里买的:146:
    就是说CFD+pytorch跑出来的是最终的稳态结果?
    SHUKK
    @李东岳 目前跑出来的结果,有个小范围的浮动。也有可能是我在雷诺应力修正时候做了类似于DES那种,RANS跟LES的混合。
    屌爆了,文章发出来之后我学习学习
  • 李东岳李 李东岳 被引用 于这个主题
    在 中回复了 SHUKK 最后由 李东岳 编辑
    @SHUKK 老铁这个工作做的怎么样了
    另外我这段时间也关注这些东西。初步有个这个结论,这个是我自己想的:
    目前都是openfoam+pytorch而不是openfoam+libtorch,但是我测试openfoam+libtorch完全可以混编,并且编译起来很简单。如果openfoam+pytorch,这里面等于添加了个python的API。我就没太理解大家为什么用的都是openfoam+pytorch而不是openfoam+libtorch。后来我捉摸应该是机器学习那面好多人都是python程序员,然后就专门写了个python版本的pytorch,对于他们那一圈人,pytorch比较好用... 只有这一个原因。
    因为我最近要试一下PINN求解PDE。对于那面来说,用纯粹的pytorch就可以。但是pytorch写起来比较麻烦。好多人就用了个接口交deepxde。
    那对于为什么用的都是openfoam+pytorch而不是openfoam+libtorch,纯粹是用户习惯的原因,不知道我理解的对不对。
    If you would prefer to write Python, and can afford to write Python, we recommend using the Python interface to PyTorch. However, if you would prefer to write C++, or need to write C++ (because of multithreading, latency or deployment requirements), the C++ frontend to PyTorch provides an API that is approximately as convenient, flexible, friendly and intuitive as its Python counterpart. The two frontends serve different use cases, work hand in hand, and neither is meant to unconditionally replace the other.
    我理解的应该是对的。pytorch,libtorch看个人爱好
    https://pytorch.org/cppdocs/frontend.html
  • B 离线
    B 离线
    biaowai
    看完大佬们讨论,对OpenFOAM+神经网络模型有初步了解了,还有些疑问,想请教下各位老师:
    用神经网络来确定非线性模型中的一些参数,并在每一步计算都调用神经网络,对初场的敏感性高吗?如果初场不同,神经网络更新的参数有很大区别,感觉可能导致收敛到不同结果?
    感谢感谢!
    对初场的敏感性高吗?
    什么初场?
    B 1 条回复 最后回复
  • B 离线
    B 离线
    biaowai
    @李东岳 李老师,就是初始流场,比如均匀初始化或者用一个RANS收敛的流场初始化
    在 中回复了 biaowai 最后由 编辑
    #37
    @biaowai 不会,跟那个没关系
    jokers148
    在 中回复了 SHUKK 最后由 编辑
    #38
    @SHUKK 你好,我也在求解器编译中遇到类似的问题,想问下具体是如何解决的
