  3. snappyHexMesh画网格
snappyHexMesh画网格
9 帖子 2 发布者 3.3k 浏览
    HIT_lly
    使用snappyHexMesh画网格时,画出网格时没有什么问题但是在计算的时候会报错。有没有大佬知道这种情况该怎么解决
    FOAM Warning :
        From void Foam::cutFaceAdvect::cutPoints(Foam::label, Foam::scalar, Foam::DynamicList<Foam::Vector<double> >&)
        in file cellCuts/cutFace/cutFaceAdvect.C at line 927
        cutPoints = 4((0 0.0449362922089 0.385062422146) (0 0.0436853188202 0.385062441697) (0.01 0.0436853188202 0.385062441697) (0.01 0.0449362922089 0.385062422146)) for pts = 4((0 0.0449362922089 0.385062422146) (0 0.0436853188202 0.385062441697) (0.01 0.0436853188202 0.385062441697) (0.01 0.0449362922089 0.385062422146)), f - f0 = 4(23405 23403 38935 38937) and f0 = 2.22618323362e-13
    这是个warning。看起来好像是isoAdvector那面的算法?这个算法我不是太熟悉。回答也是乏力了。:135:
    http://dyfluid.com/index.html
    HIT_lly
    @李东岳 谢谢东岳老师,这个我用interFoam也会报错,应该是snappyHexMesh切分网格的时候产生的问题。
    interFoam不需要cutFaceAdvect.C,你interFoam用的界面压缩的格式么?
    HIT_lly
    @李东岳 东岳老师,上面那个报错是因为使用了isoAdvector算法。
    使用interFoam进行计算也会进行报错,报错是这样的
    FOAM Warning :
        From Foam::triFace Foam::tetIndices::faceTriIs(const Foam::polyMesh&, bool) const
        in file meshes/polyMesh/polyMeshTetDecomposition/tetIndicesI.H at line 70
        No base point for face 7847, 4(5577 25968 25969 5578), produces a valid tet decomposition.
    你的interfoam的fvScheme怎么设置的
    HIT_lly
    |  \\    /   O peration     | Version:  v2312                                 |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvSchemes;
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
    divSchemes
    default         Gauss upwind;
        div(rhoPhi,U)   Gauss upwind;
        div(U)          Gauss linear;
        div(phi,alpha)  Gauss vanLeer;
        div(phirb,alpha) Gauss linear;
         div(phi,thermo:rho.water) Gauss upwind;
        div(phi,thermo:rho.air) Gauss upwind;
           div(rhoPhi,T)  Gauss upwind;
        div(rhoPhi,K)  Gauss upwind;
            div(phi,p)      Gauss upwind;
        div(phi,epsilon) Gauss upwind;
        div(phi,omega) Gauss upwind;
        div(phi,U)      Gauss linearUpwind limited;
        energy          Gauss linearUpwind limited;
        div(phi,e)      $energy;
        div(phi,K)      $energy;
        div(phi,Ekp)    $energy;
        turbulence      Gauss linearUpwind limited;
        div(phi,k)      $turbulence;
        div(phi,omega)  $turbulence;
        div(rhoPhi,omega)  $turbulence;
    div(rhoPhi,k)  $turbulence;
        div(phiv,p)     Gauss upwind;
        div((phi|interpolate(rho)),p) Gauss upwind;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    wallDist
        method          meshWave;
    oversetInterpolation
        method              inverseDistance;
        holeLayers          6;
        useLayer            3;
    oversetInterpolationSuppressed
        grad(p_rgh);
        surfaceIntegrate(phiHbyA);
    fluxRequired
        default         no;
        p_rgh;
        pcorr;
        alpha.water;
    HIT_lly
    @李东岳 感谢东岳老师的回复,我的fvScheme是这样设置的,这用的是重叠网格技术。开始的isoadvector是我耦合的重叠网格算法,然后后面的compressibleinterFoam是openfoam 中自带的算法。
    HIT_lly
    之前snappyHexMesh画的3D网格进行重叠网格计算没有问题。后来为了节省计算成本用的2D网格,用的snappyHexMesh画的网格,然后使用extrudeMesh将3D网格变成2D网格后就出现问题了
