  4. 修改boundary文件中的类型导致错误
3 帖子 2 发布者 3.3k 浏览
  • 杜 离线
    杜 离线
    杜浚平
    各位佬,本人初学openfoam,网格划分采用ICEM,做的算例是NACA0018的升阻力系数计算,画的是一个三维网格,想要导入of后将front和back设为empty,以此来进行二维翼型的运算,报错为:
    Number of edges not aligned with or perpendicular to non-empty directions: 8191
    Writing 16382 points on non-aligned edges to set nonAlignedEdges
    网格展向0.01m,划分为一个网格,网格如下:
    在导入后boundary文件如下:
    | \\      /  F ield         | foam-extend: Open Source CFD                    |
    |  \\    /   O peration     | Version:     3.2                                |
    |   \\  /    A nd           | Web:         http://www.foam-extend.org         |
    |    \\/     M anipulation  | For copyright notice see file Copyright         |
    FoamFile
        version     2.0;
        format      ascii;
        class       polyBoundaryMesh;
        location    "constant/polyMesh";
        object      boundary;
    4
        AIRFOIL
            type            wall;
            nFaces          488;
            startFace       124440;
        BACK
            nFaces          62464;
            startFace       124928;
        FRONT
            nFaces          62464;
            startFace       187392;
        FAR
            type            patch;
            nFaces          488;
            startFace       249856;
    checkMesh的结果如下:
    Build    : 3.2-0b2838935026
    Exec     : checkMesh
    Date     : Jul 24 2024
    Time     : 13:00:35
    Host     : ad
    PID      : 24129
    CtrlDict : "/home/ad/foam/ad-3.2/run/try4/18/system/controlDict"
    Case     : /home/ad/foam/ad-3.2/run/try4/18
    nProcs   : 1
    SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
    Create time
    Create polyMesh for time = 0
    Time = 0
    Mesh stats
        all points:           125904
        live points:          125904
        all faces:            250344
        live faces:           250344
        internal faces:       124440
        cells:                62464
        boundary patches:     4
        point zones:          0
        face zones:           1
        cell zones:           1
        hexahedra:     62464
        prisms:        0
        wedges:        0
        pyramids:      0
        tet wedges:    0
        tetrahedra:    0
        polyhedra:     0
    Checking topology...
        Boundary definition OK.
        Point usage OK.
        Upper triangular ordering OK.
        Face vertices OK.
        Number of regions: 1 (OK).
    Checking patch topology for multiply connected surfaces ...
        Patch               Faces    Points   Area [m^2]  Surface topology
        AIRFOIL             488      976      0.0207938   ok (non-closed singly connected)
        BACK                62464    62952    737.046     ok (non-closed singly connected)
        FRONT               62464    62952    737.046     ok (non-closed singly connected)
        FAR                 488      976      0.962719    ok (non-closed singly connected)
    Checking geometry...
        This is a 3-D mesh
        Overall domain bounding box (-14.9955 -15.3298 -1.43395e-42) (15.9509 14.9979 0.01)
        Mesh (non-empty, non-wedge) directions (1 1 1)
        Mesh (non-empty) directions (1 1 1)
        Mesh (non-empty, non-wedge) dimensions 3
        Boundary openness (-1.86694e-20 -1.04152e-19 -4.57649e-15) Threshold = 1e-06 OK.
        Max cell openness = 2.46007e-15 OK.
        Max aspect ratio = 381.414 OK.
        Minumum face area = 3.3198e-09. Maximum face area = 0.100407.  Face area magnitudes OK.
        Min volume = 3.3198e-11. Max volume = 0.00100407.  Total volume = 7.37046.  Cell volumes OK.
        Mesh non-orthogonality Max: 44.6101 average: 9.96793 Threshold = 70
        Non-orthogonality check OK.
        Face pyramids OK.
        Max skewness = 0.733611 OK.
    Mesh OK.
    End
    将boundary文件修改为:
    FoamFile
        version     2.0;
        format      ascii;
        object      boundary;
    4
        AIRFOIL
            type            wall;
            nFaces          488;
            startFace       124440;
        BACK
            type            empty;
            nFaces          62464;
            startFace       124928;
        FRONT
            type            empty;
            nFaces          62464;
            startFace       187392;
        FAR
            type            patch;
            nFaces          488;
            startFace       249856;
    checkMesh得到:
    Exec     : checkMesh
    Date     : Jul 24 2024
    Time     : 13:02:01
    Host     : ad
    PID      : 24163
    nProcs   : 1
    Create time
    Time = 0
    Mesh stats
        all points:           125904
        live points:          125904
        all faces:            250344
        live faces:           250344
        cells:                62464
        boundary patches:     4
        point zones:          0
        face zones:           1
        cell zones:           1
        hexahedra:     62464
        prisms:        0
        wedges:        0
        pyramids:      0
        tet wedges:    0
        tetrahedra:    0
        polyhedra:     0
        Point usage OK.
        Face vertices OK.
        This is a 2-D mesh
        Mesh (non-empty, non-wedge) directions (1 1 0)
        Mesh (non-empty) directions (1 1 0)
        Mesh (non-empty, non-wedge) dimensions 2
     ***Number of edges not aligned with or perpendicular to non-empty directions: 8191
        Face pyramids OK.
    Failed 1 mesh checks.
    End
    我该如何修改?:haqi:
    你用symmetryPlane;算没问题,不用改
    杜 1 条回复 最后回复
  • 杜 离线
    杜 离线
    杜浚平
    @李东岳 好的,谢谢东岳老师!
