  4. paraview安装好了但无法使用
paraview安装好了但无法使用
14 帖子 6 发布者 14.3k 浏览
    楼上说的是对的。如果是ubuntu系统应该没问题。如果是cent,需要装qt
    yyyy
    谢谢两位老师的回答,我的是ubuntu20.04.6LTS,qt应该是有的,我又根据网上的教程查了查,发现还是无法打开,具体如下:qmake --version后显示
    QMake version 3.1
    Using Qt version 5.12.8 in /usr/lib/x86_64-linux-gnu
    export QT_DEBUG_PLUGINS=1后还是报错
    Got keys from plugin meta data ("xcb")
    QFactoryLoader::QFactoryLoader() checking directory path "/home/yl/OpenFOAM/v2206/ThirdParty-v2206/platforms/linux64Gcc/ParaView-5.10.1/bin/platforms" ...
    loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so"
    qt.qpa.xcb: could not connect to display
    qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
    This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
    Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
    Aborted
    然后又查了依赖
     ldd /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so
    显示
      linux-vdso.so.1 (0x00007ffdc1e72000)
            libQt5XcbQpa.so.5 => /lib/x86_64-linux-gnu/libQt5XcbQpa.so.5 (0x00007f8ff53f7000)
            libQt5Gui.so.5 => /lib/x86_64-linux-gnu/libQt5Gui.so.5 (0x00007f8ff4e0c000)
            libQt5Core.so.5 => /lib/x86_64-linux-gnu/libQt5Core.so.5 (0x00007f8ff48c3000)
            libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f8ff46e1000)
            libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f8ff44ed000)
            libfontconfig.so.1 => /lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f8ff44a6000)
            libfreetype.so.6 => /lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f8ff43e7000)
            libQt5DBus.so.5 => /lib/x86_64-linux-gnu/libQt5DBus.so.5 (0x00007f8ff434b000)
            libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f8ff4328000)
            libX11-xcb.so.1 => /lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007f8ff4323000)
            libxcb-xinput.so.0 => /lib/x86_64-linux-gnu/libxcb-xinput.so.0 (0x00007f8ff42fd000)
            libxcb-icccm.so.4 => /lib/x86_64-linux-gnu/libxcb-icccm.so.4 (0x00007f8ff42f6000)
            libxcb-image.so.0 => /lib/x86_64-linux-gnu/libxcb-image.so.0 (0x00007f8ff40f1000)
            libxcb-shm.so.0 => /lib/x86_64-linux-gnu/libxcb-shm.so.0 (0x00007f8ff40ec000)
            libxcb-keysyms.so.1 => /lib/x86_64-linux-gnu/libxcb-keysyms.so.1 (0x00007f8ff40e7000)
            libxcb-randr.so.0 => /lib/x86_64-linux-gnu/libxcb-randr.so.0 (0x00007f8ff40d4000)
            libxcb-render-util.so.0 => /lib/x86_64-linux-gnu/libxcb-render-util.so.0 (0x00007f8ff40cb000)
            libxcb-render.so.0 => /lib/x86_64-linux-gnu/libxcb-render.so.0 (0x00007f8ff40bc000)
            libxcb-shape.so.0 => /lib/x86_64-linux-gnu/libxcb-shape.so.0 (0x00007f8ff40b7000)
            libxcb-sync.so.1 => /lib/x86_64-linux-gnu/libxcb-sync.so.1 (0x00007f8ff40ad000)
            libxcb-xfixes.so.0 => /lib/x86_64-linux-gnu/libxcb-xfixes.so.0 (0x00007f8ff40a3000)
            libxcb-xinerama.so.0 => /lib/x86_64-linux-gnu/libxcb-xinerama.so.0 (0x00007f8ff409e000)
            libxcb-xkb.so.1 => /lib/x86_64-linux-gnu/libxcb-xkb.so.1 (0x00007f8ff407e000)
            libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f8ff4054000)
            libXrender.so.1 => /lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f8ff3e4a000)
            libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007f8ff3d0d000)
            libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f8ff3bbe000)
            libSM.so.6 => /lib/x86_64-linux-gnu/libSM.so.6 (0x00007f8ff3bb3000)
            libICE.so.6 => /lib/x86_64-linux-gnu/libICE.so.6 (0x00007f8ff3b93000)
            libxkbcommon-x11.so.0 => /lib/x86_64-linux-gnu/libxkbcommon-x11.so.0 (0x00007f8ff3b88000)
            libxkbcommon.so.0 => /lib/x86_64-linux-gnu/libxkbcommon.so.0 (0x00007f8ff3b46000)
            libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f8ff3a1c000)
            libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f8ff3a01000)
            libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007f8ff3977000)
            libpng16.so.16 => /lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f8ff393f000)
            libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f8ff3923000)
            libharfbuzz.so.0 => /lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007f8ff381f000)
            libicui18n.so.66 => /lib/x86_64-linux-gnu/libicui18n.so.66 (0x00007f8ff3520000)
            libicuuc.so.66 => /lib/x86_64-linux-gnu/libicuuc.so.66 (0x00007f8ff333a000)
            libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f8ff3332000)
            libpcre2-16.so.0 => /lib/x86_64-linux-gnu/libpcre2-16.so.0 (0x00007f8ff32ae000)
            libdouble-conversion.so.3 => /lib/x86_64-linux-gnu/libdouble-conversion.so.3 (0x00007f8ff3298000)
            /lib64/ld-linux-x86-64.so.2 (0x00007f8ff55a9000)
            libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f8ff326a000)
            libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f8ff3261000)
            libdbus-1.so.3 => /lib/x86_64-linux-gnu/libdbus-1.so.3 (0x00007f8ff320e000)
            libxcb-util.so.1 => /lib/x86_64-linux-gnu/libxcb-util.so.1 (0x00007f8ff3008000)
            libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007f8ff3002000)
            libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f8ff2ffa000)
            libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f8ff2fe0000)
            libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f8ff2f6b000)
            libGLdispatch.so.0 => /lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f8ff2eb3000)
            libGLX.so.0 => /lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f8ff2e7f000)
            libgraphite2.so.3 => /lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007f8ff2e52000)
            libicudata.so.66 => /lib/x86_64-linux-gnu/libicudata.so.66 (0x00007f8ff1391000)
            libsystemd.so.0 => /lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007f8ff12e0000)
            librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f8ff12d6000)
            liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f8ff12ad000)
            liblz4.so.1 => /lib/x86_64-linux-gnu/liblz4.so.1 (0x00007f8ff128c000)
            libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007f8ff116e000)
            libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007f8ff1149000)
     ldd /lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
     linux-vdso.so.1 (0x00007ffe54dce000)
            libfontconfig.so.1 => /lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f7452b40000)
            libfreetype.so.6 => /lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f7452a81000)
            libQt5Gui.so.5 => /lib/x86_64-linux-gnu/libQt5Gui.so.5 (0x00007f7452496000)
            libQt5DBus.so.5 => /lib/x86_64-linux-gnu/libQt5DBus.so.5 (0x00007f74523fa000)
            libQt5Core.so.5 => /lib/x86_64-linux-gnu/libQt5Core.so.5 (0x00007f7451eaf000)
            libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7451e8c000)
            libX11-xcb.so.1 => /lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007f7451e87000)
            libxcb-xinput.so.0 => /lib/x86_64-linux-gnu/libxcb-xinput.so.0 (0x00007f7451e63000)
            libxcb-icccm.so.4 => /lib/x86_64-linux-gnu/libxcb-icccm.so.4 (0x00007f7451e5c000)
            libxcb-image.so.0 => /lib/x86_64-linux-gnu/libxcb-image.so.0 (0x00007f7451c57000)
            libxcb-shm.so.0 => /lib/x86_64-linux-gnu/libxcb-shm.so.0 (0x00007f7451c50000)
            libxcb-keysyms.so.1 => /lib/x86_64-linux-gnu/libxcb-keysyms.so.1 (0x00007f7451c4b000)
            libxcb-randr.so.0 => /lib/x86_64-linux-gnu/libxcb-randr.so.0 (0x00007f7451c38000)
            libxcb-render-util.so.0 => /lib/x86_64-linux-gnu/libxcb-render-util.so.0 (0x00007f7451c31000)
            libxcb-render.so.0 => /lib/x86_64-linux-gnu/libxcb-render.so.0 (0x00007f7451c22000)
            libxcb-shape.so.0 => /lib/x86_64-linux-gnu/libxcb-shape.so.0 (0x00007f7451c1d000)
            libxcb-sync.so.1 => /lib/x86_64-linux-gnu/libxcb-sync.so.1 (0x00007f7451c11000)
            libxcb-xfixes.so.0 => /lib/x86_64-linux-gnu/libxcb-xfixes.so.0 (0x00007f7451c07000)
            libxcb-xinerama.so.0 => /lib/x86_64-linux-gnu/libxcb-xinerama.so.0 (0x00007f7451c02000)
            libxcb-xkb.so.1 => /lib/x86_64-linux-gnu/libxcb-xkb.so.1 (0x00007f7451be4000)
            libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f7451bba000)
            libXrender.so.1 => /lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f74519b0000)
            libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007f7451871000)
            libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7451722000)
            libSM.so.6 => /lib/x86_64-linux-gnu/libSM.so.6 (0x00007f7451717000)
            libICE.so.6 => /lib/x86_64-linux-gnu/libICE.so.6 (0x00007f74516f9000)
            libxkbcommon-x11.so.0 => /lib/x86_64-linux-gnu/libxkbcommon-x11.so.0 (0x00007f74516ee000)
            libxkbcommon.so.0 => /lib/x86_64-linux-gnu/libxkbcommon.so.0 (0x00007f74516ac000)
            libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f7451580000)
            libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f745139e000)
            libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f7451383000)
            libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7451191000)
            libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f7451163000)
            libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f745115a000)
            libpng16.so.16 => /lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f7451120000)
            libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f7451104000)
            libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007f745107c000)
            libharfbuzz.so.0 => /lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007f7450f78000)
            libdbus-1.so.3 => /lib/x86_64-linux-gnu/libdbus-1.so.3 (0x00007f7450f27000)
            libicui18n.so.66 => /lib/x86_64-linux-gnu/libicui18n.so.66 (0x00007f7450c28000)
            libicuuc.so.66 => /lib/x86_64-linux-gnu/libicuuc.so.66 (0x00007f7450a40000)
            libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f7450a3a000)
            libpcre2-16.so.0 => /lib/x86_64-linux-gnu/libpcre2-16.so.0 (0x00007f74509b6000)
            libdouble-conversion.so.3 => /lib/x86_64-linux-gnu/libdouble-conversion.so.3 (0x00007f74509a0000)
            /lib64/ld-linux-x86-64.so.2 (0x00007f7452d33000)
            libxcb-util.so.1 => /lib/x86_64-linux-gnu/libxcb-util.so.1 (0x00007f745079a000)
            libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007f7450792000)
            libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f745078a000)
            libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f7450770000)
            libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f74506fd000)
            libGLdispatch.so.0 => /lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f7450645000)
            libGLX.so.0 => /lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f745060f000)
            libgraphite2.so.3 => /lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007f74505e2000)
            libsystemd.so.0 => /lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007f7450533000)
            libicudata.so.66 => /lib/x86_64-linux-gnu/libicudata.so.66 (0x00007f744ea72000)
            librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f744ea68000)
            liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f744ea3d000)
            liblz4.so.1 => /lib/x86_64-linux-gnu/liblz4.so.1 (0x00007f744ea1c000)
            libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007f744e8fe000)
            libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007f744e8db000)
    依赖也没有缺少的,但是依然打不开。
    是原生界面还是ssh过去的
    输入gedit之类的能打开么
    yyyy
    用的wsl安装的Ubuntu,gedit确实打不开
    yl@yl:~$ sudo gedit ~/.bashrc
    sudo: gedit: command not found
    你换windows的paraview吧。不要再wsl下面装paraview
    yyyy
    好的 再次谢谢李老师,其实Windows已经下了paraview就是更改bashrc文件让linux能调用的时候也出错了,只能复制粘贴文件太麻烦了。没事 改天我再重下次!
    是的,所以我感觉wsl的体验也不是特别好。你再研究研究
    chon01
    楼主您好,请问您的问题解决了嘛,我在wsl下的ubutu也出现了同样的问题
    longsheng
    之前遇到了同样的问题,最后选择调用windows下的paraview,这个链接https://www.cnblogs.com/liusuanyatong/p/11259638.html的方法还是比较简单有效的,就是打开paraview可能会稍微有点慢
    chon01
    在 中回复了 longsheng 最后由 编辑
    @longsheng 谢谢您
    R 1 条回复 最后回复
    rhzhang
    在 中回复了 chon01 最后由 编辑
    @chon01
    我也遇到了一样的问题,然后找到了这个视频
    https://www.bilibili.com/video/BV1qq4y1S7DJ/?share_source=copy_web&vd_source=b8e30eb5b15079ed88d8e05423e7edf3
    视频里跟着楼主上面发的帖子里的步骤进行的更改,比较详细(原帖省略了一些说明,我第一次跟着做没有成功T-T),个人感觉很有用!
    chon01
    在 中回复了 rhzhang 最后由 编辑
    @rhzhang 谢谢您
