84 帖子 18 发布者 207.8k 浏览
    我给你手写了一个output.H:
            if (iter % 500 == 0)
                cout<< iter << " loss = " << loss.item<double>() << endl;
                std::ofstream filex("results");
                filex << upred << "\n";
                filex.close();
    chengan.wangC 2 条回复 最后回复
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 谢谢李老师
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 我看了您提供的PINN算例,感觉目前还没有真正跟of结合起来,是吧?只不过用了of的c++编译环境,可以这么理解么?
    是。PINN不需要跟FVM结合,只不过用了of的c++编译环境。想跟OpenFOAM结合,除了画网格能结合一下,其他的也结合不上。
    在 中回复了 chengan.wang 最后由 李东岳 编辑
    #68
    @chengan-wang
    You can use the following code to initialize libtorch tensors from OpenFOAM mesh. It is much easier to generate any kinds of geometries. Please see the following clipped cavity geometry. I am using English since I hope it can be helpful for all the people.
        // openfoam initialization
        vectorField ofMesh = mesh.C();
        auto meshTorch = torch::full({ofMesh.size(),1,2}, 0.0);
        forAll(ofMesh, i)
            double x = ofMesh[i].x();
            double y = ofMesh[i].y();
            auto posi = torch::tensor({x,y}).reshape({1,2});
            meshTorch[i] = posi;
        const surfaceVectorField& Cf = mesh.Cf();
        label topID = mesh.boundaryMesh().findPatchID("top");
        label leftID = mesh.boundaryMesh().findPatchID("left");
        label rightID = mesh.boundaryMesh().findPatchID("right");
        label bottomID = mesh.boundaryMesh().findPatchID("bottom");
        vectorField cfTop = Cf.boundaryField()[topID];
        vectorField cfLeft = Cf.boundaryField()[leftID];
        vectorField cfRight = Cf.boundaryField()[rightID];
        vectorField cfBottom = Cf.boundaryField()[bottomID];
        auto top = torch::full({cfTop.size(),1,2}, 0.0);
        auto left = torch::full({cfLeft.size(),1,2}, 0.0);
        auto right = torch::full({cfRight.size(),1,2}, 0.0);
        auto bottom = torch::full({cfBottom.size(),1,2}, 0.0);
        forAll(cfTop, i)
            double x = cfTop[i].x();
            double y = cfTop[i].y();
            top[i] = posi;
        forAll(cfRight, i)
            double x = cfRight[i].x();
            double y = cfRight[i].y();
            right[i] = posi;
        forAll(cfLeft, i)
            double x = cfLeft[i].x();
            double y = cfLeft[i].y();
            left[i] = posi;
        forAll(cfBottom, i)
            double x = cfBottom[i].x();
            double y = cfBottom[i].y();
            bottom[i] = posi;
        meshTorch = meshTorch.reshape({-1,2});
        top = top.reshape({-1,2});
        left = left.reshape({-1,2});
        right = right.reshape({-1,2});
        bottom = bottom.reshape({-1,2});
        auto u_top = torch::full({cfTop.size()}, vel);
        auto v_top = torch::full({cfTop.size()}, 0.0);
        std::cout<< "top: " << top << std::endl;
        std::cout<< "left: " << left << std::endl;
        std::cout<< "right: " << right << std::endl;
        std::cout<< "bottom: " << bottom << std::endl;
  • 水 离线
    水 离线
    水润晨阳
    @李东岳 在 OpenFOAM libtorch tutorial step by step 中说:
    net.H
    #include <torch/torch.h>
    class NN
        public torch::nn::Module
        torch::nn::Sequential net_;
    public:
        NN();
        torch::Tensor forward(torch::Tensor x);
    net.C
        \\  /    A nd           | Copyright (C) 2022-2023 OpenFOAM Foundation
         \\/     M anipulation  |
    License
        for more details.
    Class
    See also
    SourceFiles
    #include "net.H"
    NN::NN()
        net_ = register_module
            "net",
                torch::nn::Linear(2,20),
                torch::nn::ReLU(),
                torch::nn::Linear(20,30),
                torch::nn::ReLU(),
                torch::nn::Linear(30,30),
                torch::nn::ReLU(),
                torch::nn::Linear(30,20),
                torch::nn::ReLU(),
                torch::nn::Linear(20,20),
                torch::nn::ReLU(),
                torch::nn::Linear(20,1)
    torch::Tensor NN::forward(torch::Tensor x)
        return net_->forward(x);
    这个要编译成库,挂到PINNFoam上面
    李老师 请问这个如何编译并挂载呢 可以详细的指导一下吗
    DJohn1211
    在 中回复了 leaon 最后由 编辑
    #70
    @leaon 您好,我也和您遇到了一样的问题,请问您如何解决的呢
    DJohn1211
    @李东岳 李老师您好,我在看您发的那个顶盖驱动流的代码的时候有个问题,我的电脑安装了openfoam10和11,同样的文件内容为什么在of10下我可以成功编译,但在of11下不可以呢。在11下,一开始提示找不到libtriSurface.so和libsurfMesh.so,然后我在bashrc中添加了,export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/john/OpenFOAM/OpenFOAM-11/platforms/linux64GccDPInt32Opt/lib,随后再次运行出现了这样的问题。
    of10跟of11的Make下面的options不一样,我先用of10吧。等过段时间再debug
  • I 离线
    I 离线
    iaasoqhu
    写于 最后由 iaasoqhu 编辑
    #73
    torchFoam.C:1:10: fatal error: torch/torch.h: 没有那个文件或目录
    1 | #include <torch/torch.h>
    我是小白,请教一下,我提示这个错误是怎么回事?wmake的时候提示的,用的用的of2212
    在 中回复了 iaasoqhu 最后由 编辑
    #74
    @iaasoqhu 今天才看见,你的基础环境没有配好。
    I 1 条回复 最后回复
    在本帖12楼我贴出了原生PINN求解对流方程的方法,存在数值震荡。最近我开源了PINN + TVD格式的代码,请参考: http://dyfluid.com/pinn4.html
    在画图的时候,需要原生PINN预测的速度数据。在此: U-PINN-V
  • I 离线
    I 离线
    iaasoqhu
    @李东岳 谢谢李博士,已经搞定了
  • 剑 离线
    剑 离线
    剑金锋
    李老师,有没有尝试过使用GPU的libtorch+openfoam,我配置完,编译通过了,但用的还是CPU,感觉挺难搞的。
    DJohn1211
    在 中回复了 李东岳 最后由 DJohn1211 编辑
    #78
    @李东岳 李老师您好,我在复现您这个例子的时候有一些细节有些糊涂?想请问您具体是怎么做的呢,能分享一下您的算例吗
    代码越来越复杂。这是执行一系列的卷积、池化操作等输出的8个通道的流场结果:
    http://dyfluid.com/cnn.html#id6
    下图是自编码器进行重组的流场:
    CNN处理的时候,你需要生成不同的OpenFOAM网格,http://dyfluid.com/cnn.html#id6 我在这里面做了4次池化,那你就需要4套openfoam网格
    autoDecoder_cavity.tar.xz
    我有这个算例,但是代码都是课堂现写,之前都是计划LCO课堂给大家讲的算例,写完了代码之后用我准备的算例去验证,后来大家一听一个不吱声,太难不讲了。目前我对CNN这方面也没有之前那么高涨,还没有重写代码的计划。
    CTC
    在 中回复了 水润晨阳 最后由 编辑
    #80
    @水润晨阳 你好, 你知道怎么编译和挂载了吗
    xyl308120
    在 中回复了 剑金锋 最后由 编辑
    #81
    @剑金锋
    老哥,我把东岳老师那个1D槽道流的代码用AI改成了CUDA版本。然后在https://download.pytorch.org/libtorch/cu117 (我的cuda版本是11.7)下载的gpu版本的libtorch。现在发现已经可以用gpu训练了,但是训练速度还不如cpu,慢不少。 准备后续再捣鼓一下。 我机器配置 GPU: nvidia T400 4G, CPU:I7-12700,供参考
    #include <torch/cuda.h> // 添加CUDA支持
    using namespace std;
    class NN : public torch::nn::Module {
    public:
        NN() {
            net_ = register_module("net", torch::nn::Sequential(
                torch::nn::Linear(1,8),
                torch::nn::Tanh(),
                torch::nn::Linear(8,1)
        torch::Tensor forward(torch::Tensor x) {
    int main() {
        // 设备检测与设置
        torch::Device device = torch::kCPU;
        if (torch::cuda::is_available()) {
            std::cout << "CUDA可用,使用GPU加速训练" << std::endl;
            device = torch::kCUDA;
        int iter = 1;
        int IterationNum = 1000000;
        double learning_rate = 0.001;
        double dy = 0.00125;
        int cellN = static_cast<int>(0.05/dy);
        // 模型迁移至GPU
        auto model = std::make_shared<NN>();
        model->to(device);
        // 优化器
        auto opti = std::make_shared<torch::optim::AdamW>(
            model->parameters(),
            torch::optim::AdamWOptions(learning_rate)
        // 数据迁移至GPU (关键步骤!)
        auto init = torch::full({}, 1.0).to(device);
        auto mesh = torch::arange(-0.05, 0, dy, torch::requires_grad())
                    .unsqueeze(1).to(device);
        auto dpdxByNu = torch::ones({cellN, 1}, torch::kFloat).to(device);
        auto nut = torch::zeros({cellN}).to(device);
        for (int i = 0; i < IterationNum; i++) {
            opti->zero_grad();
            auto upred = model->forward(mesh);
            // 梯度计算(确保权重张量在GPU)
            auto dudy = torch::autograd::grad(
                {upred}, {mesh},
                {torch::ones_like(upred).to(device)}, true, true
            )[0];
            auto dudyy = torch::autograd::grad(
                {dudy}, {mesh},
            )[0];
            auto dudyTop = dudy[cellN - 1][0];
            auto meanU = torch::mean(upred);
            auto ubottom = torch::full_like(upred[0], 0.0375).to(device); // 边界条件迁移
            auto dpdxByNu = torch::full({cellN}, 1.2e-05/1e-08).to(device);
            // 损失计算
            auto loss_bottom = torch::mse_loss(upred[0], ubottom);
            auto loss_top = torch::mse_loss(dudyTop, torch::zeros_like(dudyTop));
            auto loss_bd = loss_bottom + 1000*loss_top;
            auto loss_ini = 1000*torch::mse_loss(meanU, init);
            auto loss_pde = torch::mse_loss(-dudyy.reshape({cellN}), dpdxByNu);
            auto loss = loss_pde + loss_bd + loss_ini;
            // 反向传播
            loss.backward();
            opti->step();
            // 输出需同步到CPU
            if (iter % 500 == 0) {
                double loss_value = loss.item<double>();
                cout << iter << " loss = " << loss_value << endl;
            iter++;
        torch::save(model, "model.pth");
        std::cout << "训练完成!" << std::endl;
        return 0;
    看你GPU占用多少。
    xyl308120
    在 中回复了 李东岳 最后由 xyl308120 编辑
    #83
    东岳老师你好,我训练的时候GPU占比%38左右。 我还想顺便请教一下
    loss_ini = 1000*crit(meanU, init)
    这个损失的意义。 因为我发现1D槽道流openfoam基准数据的平均值差不多就是1左右,而这里相当于是要对训练添加一个整体约束之类的东西吗。
