  4. 离心式压缩机周期性边界问题
离心式压缩机周期性边界问题
3 帖子 2 发布者 981 浏览
  • Y 在线
    Y 在线
    yingqing
    各位大佬,我在做压缩机并行运算的时候遇到周期性边界条件的问题。
    这是我压缩机单流道模型
    对于交界面的处理如下:
    |  \\    /   O peration     | Version:  2206                                  |
    FoamFile
        version     2.0;
        format      ascii;
        arch        "LSB;label=32;scalar=64";
        class       polyBoundaryMesh;
        location    "constant/polyMesh";
        object      boundary;
    14
        PASSAGE-HUB
            type            wall;
            inGroups        1(wall);
            nFaces          10375;
            startFace       1756179;
        PASSAGE-SHROUD
            type            wall;
            inGroups        1(wall);
            nFaces          10375;
            startFace       1766554;
        PASSAGE-INFLOW
            type            patch;
            nFaces          1330;
            startFace       1776929;
        PASSAGE-OUTFLOW
            type            cyclicAMI;
            nFaces          5005;
            startFace       1778259;
            matchTolerance  10;
            transform       noOrdering;
            neighbourPatch  OUTBLOCK-INFLOW;
            AMIMethod       faceAreaWeightAMI;
            restartUncoveredSourceFace 1;
        MAIN-BLADE
            type            wall;
            inGroups        1(wall);
            nFaces          9065;
            startFace       1783264;
        SPLITTER-BLADE
            type            wall;
            inGroups        1(wall);
            nFaces          5880;
            startFace       1792329;
        PASSAGE-PER1
            type            cyclicAMI;
            nFaces          4515;
            startFace       1798209;
            matchTolerance  10;
            transform       unknown;
            rotationAxis    (0 0 1);
            rotationAngle   45;
            rotationCentre  (0 0 0);
            neighbourPatch  PASSAGE-PER2;
            AMIMethod       partialFaceAreaWeightAMI;
        PASSAGE-PER2
            type            cyclicAMI;
            nFaces          4515;
            startFace       1802724;
            matchTolerance  10;
            transform       unknown;
            rotationAngle   45;
            neighbourPatch  PASSAGE-PER1;
        OUTBLOCK-HUB
            type            wall;
            inGroups        1(wall);
            nFaces          6721;
            startFace       1807239;
        OUTBLOCK-SHROUD
            type            wall;
            inGroups        1(wall);
            nFaces          6721;
            startFace       1813960;
        OUTBLOCK-INFLOW
            type            cyclicAMI;
            nFaces          5005;
            startFace       1820681;
            matchTolerance  10;
            neighbourPatch  PASSAGE-OUTFLOW;
        OUTBLOCK-OUTFLOW
            type            patch;
            nFaces          5005;
            startFace       1825686;
        OUTBLOCK-PER1
            type            cyclicAMI;
            nFaces          1645;
            startFace       1830691;
            matchTolerance  10;
            transform       unknown;
            rotationAngle   45;
            neighbourPatch  OUTBLOCK-PER2;
        OUTBLOCK-PER2
            type            cyclicAMI;
            nFaces          1645;
            startFace       1832336;
            matchTolerance  10;
            transform       unknown;
            rotationAngle   45;
            neighbourPatch  OUTBLOCK-PER1;
    但是在进行并行运行decomposePar命令时,给出如下错误报告
    Create time
    Decomposing mesh
    Create mesh
    Using [v2012] 'partialFaceAreaWeightAMI' instead of 'faceAreaWeightAMI' in selection table: AMIInterpolation
        This lookup is 18 months old.
    Calculating distribution of cells
    Decomposition method scotch [32] (region region0)
    Finished decomposition in 3.32 s
    Calculating original mesh data
    Distributing cells to processors
    Distributing faces to processors
    Distributing points to processors
    Constructing processor meshes
    Processor 0
        Number of cells = 18879
        Number of points = 21302
        Number of faces shared with processor 7 = 772
        Number of faces shared with processor 8 = 140
        Number of faces shared with processor 10 = 248
        Number of faces shared with processor 16 = 757
        Number of faces shared with processor 24 = 772
        Number of faces shared with processor 26 = 84
        Number of processor patches = 6
        Number of processor faces = 2773
        Number of boundary faces = 1897
    Processor 1
        Number of cells = 18685
        Number of points = 21243
        Number of faces shared with processor 3 = 134
        Number of faces shared with processor 9 = 391
        Number of faces shared with processor 11 = 175
        Number of faces shared with processor 13 = 35
        Number of faces shared with processor 15 = 16
        Number of faces shared with processor 17 = 1002
        Number of faces shared with processor 19 = 429
        Number of faces shared with processor 21 = 89
        Number of faces shared with processor 25 = 10
        Number of faces shared with processor 27 = 34
        Number of faces shared with processor 29 = 841
        Number of processor patches = 11
        Number of processor faces = 3156
        Number of boundary faces = 1766
    Processor 2
        Number of cells = 18514
        Number of points = 20845
        Number of faces shared with processor 10 = 240
        Number of faces shared with processor 18 = 912
        Number of faces shared with processor 22 = 640
        Number of faces shared with processor 26 = 716
        Number of processor patches = 4
        Number of processor faces = 2508
        Number of boundary faces = 1980
    Processor 3
        Number of cells = 18648
        Number of points = 21261
        Number of faces shared with processor 1 = 134
        Number of faces shared with processor 15 = 388
        Number of faces shared with processor 19 = 734
        Number of faces shared with processor 27 = 1075
        Number of faces shared with processor 29 = 474
        Number of processor patches = 5
        Number of processor faces = 2805
        Number of boundary faces = 2223
    Processor 4
        Number of cells = 18884
        Number of points = 21280
        Number of faces shared with processor 20 = 945
        Number of faces shared with processor 30 = 897
        Number of processor patches = 2
        Number of processor faces = 1842
        Number of boundary faces = 2778
    Processor 5
        Number of cells = 18512
        Number of points = 21003
        Number of faces shared with processor 13 = 1004
        Number of faces shared with processor 17 = 115
        Number of faces shared with processor 21 = 657
        Number of faces shared with processor 25 = 919
        Number of processor faces = 2695
        Number of boundary faces = 2097
    Processor 6
        Number of points = 21264
        Number of faces shared with processor 14 = 982
        Number of faces shared with processor 22 = 912
        Number of processor faces = 1894
        Number of boundary faces = 2692
    Processor 7
        Number of points = 21214
        Number of faces shared with processor 0 = 772
        Number of faces shared with processor 10 = 386
        Number of faces shared with processor 23 = 819
        Number of processor patches = 3
        Number of processor faces = 1977
        Number of boundary faces = 2511
    Processor 8
        Number of cells = 18523
        Number of points = 21152
        Number of faces shared with processor 0 = 140
        Number of faces shared with processor 12 = 940
        Number of faces shared with processor 16 = 834
        Number of faces shared with processor 24 = 1180
        Number of faces shared with processor 28 = 55
        Number of processor faces = 3149
        Number of boundary faces = 1903
    Processor 9
        Number of cells = 18802
        Number of points = 21444
        Number of faces shared with processor 1 = 391
        Number of faces shared with processor 13 = 790
        Number of faces shared with processor 17 = 136
        Number of faces shared with processor 25 = 1159
        Number of faces shared with processor 29 = 87
        Number of processor faces = 2563
        Number of boundary faces = 2529
    Processor 10
        Number of cells = 18878
        Number of points = 21365
        Number of faces shared with processor 0 = 248
        Number of faces shared with processor 2 = 240
        Number of faces shared with processor 7 = 386
        Number of faces shared with processor 18 = 785
        Number of faces shared with processor 24 = 93
        Number of faces shared with processor 26 = 992
        Number of processor faces = 2744
        Number of boundary faces = 2046
    Processor 11
        Number of points = 20961
        Number of faces shared with processor 1 = 175
        Number of faces shared with processor 15 = 296
        Number of faces shared with processor 17 = 322
        Number of faces shared with processor 19 = 904
        Number of faces shared with processor 27 = 714
        Number of processor faces = 2411
        Number of boundary faces = 2303
    Processor 12
        Number of cells = 18520
        Number of points = 21507
        Number of faces shared with processor 8 = 940
        Number of faces shared with processor 16 = 217
        Number of faces shared with processor 20 = 271
        Number of faces shared with processor 28 = 557
        Number of processor faces = 1985
        Number of boundary faces = 3767
    Processor 13
        Number of cells = 18690
        Number of points = 21228
        Number of faces shared with processor 1 = 35
        Number of faces shared with processor 5 = 1004
        Number of faces shared with processor 9 = 790
        Number of faces shared with processor 17 = 22
        Number of faces shared with processor 21 = 181
        Number of faces shared with processor 25 = 194
        Number of faces shared with processor 29 = 498
        Number of processor patches = 7
        Number of processor faces = 2724
        Number of boundary faces = 2158
    Processor 14
        Number of points = 21287
        Number of faces shared with processor 6 = 982
        Number of faces shared with processor 30 = 915
        Number of processor faces = 1897
        Number of boundary faces = 2731
    Processor 15
        Number of cells = 18742
        Number of points = 21822
        Number of faces shared with processor 1 = 16
        Number of faces shared with processor 3 = 388
        Number of faces shared with processor 11 = 296
        Number of faces shared with processor 17 = 124
        Number of faces shared with processor 21 = 463
        Number of faces shared with processor 23 = 408
        Number of faces shared with processor 27 = 728
        Number of faces shared with processor 29 = 173
        Number of faces shared with processor 31 = 759
        Number of processor patches = 9
        Number of processor faces = 3355
        Number of boundary faces = 2521
    Processor 16
        Number of cells = 18820
        Number of points = 21189
        Number of faces shared with processor 0 = 757
        Number of faces shared with processor 8 = 834
        Number of faces shared with processor 12 = 217
        Number of faces shared with processor 24 = 117
        Number of faces shared with processor 28 = 666
        Number of processor faces = 2591
        Number of boundary faces = 1969
    Processor 17
        Number of points = 21000
        Number of faces shared with processor 1 = 1002
        Number of faces shared with processor 5 = 115
        Number of faces shared with processor 9 = 136
        Number of faces shared with processor 11 = 322
        Number of faces shared with processor 13 = 22
        Number of faces shared with processor 15 = 124
        Number of faces shared with processor 21 = 719
        Number of faces shared with processor 25 = 391
        Number of processor patches = 8
        Number of processor faces = 2831
        Number of boundary faces = 1955
    Processor 18
        Number of cells = 18779
        Number of points = 21403
        Number of faces shared with processor 2 = 912
        Number of faces shared with processor 10 = 785
        Number of faces shared with processor 22 = 296
        Number of faces shared with processor 26 = 122
        Number of processor faces = 2115
        Number of boundary faces = 2939
    Processor 19
        Number of points = 20978
        Number of faces shared with processor 1 = 429
        Number of faces shared with processor 3 = 734
        Number of faces shared with processor 11 = 904
        Number of faces shared with processor 27 = 352
        Number of processor faces = 2419
        Number of boundary faces = 2325
    Processor 20
        Number of points = 21151
        Number of faces shared with processor 4 = 945
        Number of faces shared with processor 12 = 271
        Number of processor faces = 1216
        Number of boundary faces = 3150
    Processor 21
        Number of points = 21057
        Number of faces shared with processor 1 = 89
        Number of faces shared with processor 5 = 657
        Number of faces shared with processor 13 = 181
        Number of faces shared with processor 15 = 463
        Number of faces shared with processor 17 = 719
        Number of faces shared with processor 29 = 942
        Number of processor faces = 3051
        Number of boundary faces = 1843
    Processor 22
        Number of points = 21297
        Number of faces shared with processor 2 = 640
        Number of faces shared with processor 6 = 912
        Number of faces shared with processor 18 = 296
        Number of processor faces = 1848
        Number of boundary faces = 2802
    Processor 23
        Number of points = 21260
        Number of faces shared with processor 7 = 819
        Number of faces shared with processor 15 = 408
        Number of faces shared with processor 31 = 328
        Number of processor faces = 1555
        Number of boundary faces = 3019
    Processor 24
        Number of cells = 18540
        Number of points = 21032
        Number of faces shared with processor 8 = 1180
        Number of faces shared with processor 10 = 93
        Number of faces shared with processor 16 = 117
        Number of faces shared with processor 26 = 765
        Number of processor faces = 2927
        Number of boundary faces = 1869
    Processor 25
        Number of cells = 18720
        Number of points = 21266
        Number of faces shared with processor 5 = 919
        Number of faces shared with processor 9 = 1159
        Number of faces shared with processor 13 = 194
        Number of faces shared with processor 17 = 391
        Number of processor faces = 2673
        Number of boundary faces = 2219
    Processor 26
        Number of cells = 18527
        Number of points = 20937
        Number of faces shared with processor 0 = 84
        Number of faces shared with processor 2 = 716
        Number of faces shared with processor 10 = 992
        Number of faces shared with processor 18 = 122
        Number of faces shared with processor 24 = 765
        Number of processor faces = 2679
        Number of boundary faces = 1959
    Processor 27
        Number of cells = 18537
        Number of points = 21158
        Number of faces shared with processor 1 = 34
        Number of faces shared with processor 3 = 1075
        Number of faces shared with processor 11 = 714
        Number of faces shared with processor 15 = 728
        Number of faces shared with processor 19 = 352
        Number of faces shared with processor 29 = 22
        Number of processor faces = 2925
        Number of boundary faces = 2101
    Processor 28
        Number of cells = 18526
        Number of points = 20963
        Number of faces shared with processor 8 = 55
        Number of faces shared with processor 12 = 557
        Number of faces shared with processor 16 = 666
        Number of faces shared with processor 31 = 234
        Number of processor faces = 1512
        Number of boundary faces = 3178
    Processor 29
        Number of points = 21051
        Number of faces shared with processor 1 = 841
        Number of faces shared with processor 3 = 474
        Number of faces shared with processor 9 = 87
        Number of faces shared with processor 13 = 498
        Number of faces shared with processor 15 = 173
        Number of faces shared with processor 21 = 942
        Number of faces shared with processor 27 = 22
        Number of processor faces = 3037
        Number of boundary faces = 1841
    Processor 30
        Number of points = 21229
        Number of faces shared with processor 4 = 897
        Number of faces shared with processor 14 = 915
        Number of processor faces = 1812
        Number of boundary faces = 2706
    Processor 31
        Number of points = 21660
        Number of faces shared with processor 15 = 759
        Number of faces shared with processor 23 = 328
        Number of faces shared with processor 28 = 234
        Number of processor faces = 1321
        Number of boundary faces = 4025
    Number of processor faces = 38495
    Max number of cells = 18884 (0.990708% above average 18698.8)
    Max number of processor patches = 11 (131.579% above average 4.75)
    Max number of faces between processors = 3355 (39.4467% above average 2405.94)
    Time = 0
    AMI: Creating addressing and weights between 4515 source faces and 4515 target faces
    --> FOAM Warning :
        From void Foam::advancingFrontAMI::checkPatches() const
        in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 71
        Source and target patch bounding boxes are not similar
        source box span     : (0.0420091 0.0511361 0.0349999)
        target box span     : (0.0186894 0.064626 0.0349999)
        source box          : (0.0208063 -0.00369368 0) (0.0628154 0.0474424 0.0349999)
        target box          : (0.0099481 0.0127 0) (0.0286375 0.077326 0.0349999)
        inflated target box : (0.0061564 0.00890831 -0.0037917) (0.0324292 0.0811177 0.0387916)
    --> FOAM FATAL ERROR: (openfoam-2206)
    Unable to set target face for source face 4514
        From virtual bool Foam::faceAreaWeightAMI::setNextFaces(Foam::label&, Foam::label&, Foam::label&, const Foam::bitSet&, Foam::labelList&, const Foam::DynamicList<int>&, bool) const
        in file AMIInterpolation/AMIInterpolation/faceAreaWeightAMI/faceAreaWeightAMI.C at line 363.
    FOAM aborting
    #1  Foam::error::simpleExit(int, bool) at ??:?
    #2  Foam::error::exiting(int, bool) at ??:?
    #3  Foam::faceAreaWeightAMI::setNextFaces(int&, int&, int&, Foam::bitSet const&, Foam::List<int>&, Foam::DynamicList<int, 16> const&, bool) const at ??:?
    #4  Foam::faceAreaWeightAMI::calcAddressing(Foam::List<Foam::DynamicList<int, 16> >&, Foam::List<Foam::DynamicList<double, 16> >&, Foam::List<Foam::DynamicList<Foam::Vector<double>, 16> >&, Foam::List<Foam::DynamicList<int, 16> >&, Foam::List<Foam::DynamicList<double, 16> >&, int, int) at ??:?
    #5  Foam::faceAreaWeightAMI::calculate(Foam::PrimitivePatch<Foam::SubList<Foam::face>, Foam::Field<Foam::Vector<double> > const&> const&, Foam::PrimitivePatch<Foam::SubList<Foam::face>, Foam::Field<Foam::Vector<double> > const&> const&, Foam::autoPtr<Foam::searchableSurface> const&) at ??:?
    #6  Foam::cyclicAMIPolyPatch::resetAMI(Foam::UList<Foam::Vector<double> > const&) const at ??:?
    #7  Foam::cyclicAMIPolyPatch::AMI() const at ??:?
    #8  Foam::cyclicAMIPolyPatch::applyLowWeightCorrection() const at ??:?
    #9  Foam::cyclicAMIFvPatchField<double>::patchNeighbourField() const at ??:?
    #10  Foam::coupledFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) at ??:?
    #11  Foam::cyclicAMIFvPatchField<double>::cyclicAMIFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
    #12  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::cyclicAMIFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
    #13  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/decomposePar
    #14  Foam::GeometricBoundaryField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/decomposePar
    #15  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/decomposePar
    #16  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/decomposePar
    #17  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&, bool) in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/decomposePar
    #18  void Foam::fieldsDistributor::readFields<double, Foam::fvPatchField, Foam::volMesh>(Foam::volMesh::Mesh const&, Foam::IOobjectList const&, Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&, bool) at ??:?
    #19  Foam::fvFieldDecomposer::fieldsCache::readAllFields(Foam::fvMesh const&, Foam::IOobjectList const&) at ??:?
    #20  ? in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/decomposePar
    #21  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #22  ? in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/decomposePar
    请问各位老师有没有什么解决方案🙏
    你可以尝试用preservePatches来让decompose不分AMI边界来试试
  • Y 在线
    Y 在线
    yingqing
    问题解决!在使用旋转周期性交界面的时候把 rotationAngle 45去掉
