  4. OpenFoam stuff forward from The Visual Room
1 帖子 1 发布者 2.6k 浏览
  • N 离线
    N 离线
    netbuger
    This is the OpenFOAM language.
    http://www.thevisualroom.com/24_openfoam_language/openfoam_language.html
    What are features of C++?
    What is explicit evaluation?
    What is implicit evaluation?
    What are the higher level data types?
    What are fields?
    What are the three types?
    What are the five basic classes?
    What are the three space-time classes?
    What are the three field algebra classes?
    What are the two discretisation classes?
    What is a geometricField<Type>?
    What is the objectRegistry?
    What is the IOobject?
    How is a dictionary object read?
    How is volVectorField read from disk?
    How is volScalarField constructed?
    What are the read and write options?
    How are objects represented in OpenFOAM?
    How is matrix inversion done in fvm?
    What are lists?
    What are fields?
    How is memory accessed?
    How is IO Communication done?
    How are derivatives of fields evaluated?
    What are the functions for discretisation?
    How can are equations translated into code?
    How is the PISO algorithm programmed?
    What are header files?
    What is wmake?
    1.1.1. What are features of C++?
    Feature Meaning
    typedefs Alias for a possibly complex type name
    function Group of statements that perform a task
    pointers Data type that holds addresses to refer to values in memory (e.g. for dynamic memory allocation)
    data structures Data members grouped under one name (e.g. the nodes in a linked list)
    classes Data members and function members grouped under one name
    constructor Function member that initialises the instance of it’s class
    destructor Function member that destroys the instance of it’s class
    friends Allows a function or class access to private or protected members of a class
    inheritance Allows a class to be created based on another class (so code can be reused)
    virtual member functions Member function that will be redefined in a derived class
    abstract class Class that contains at least one virtual function
    template Family of classes (class template), functions (function template), variables (variable template) or alias of a family of types (alias template)
    namespace Prevents name conflicts in large projects
    1.1.2. What is explicit evaluation?
    Evaluate spatial derivatives at the current timestep
    Uses known values
    1.1.3. What is implicit evaluation?
    Evaluate spatial derivatives at future timestep
    Uses unknown values - generates a matrix equation to be solved
    1.1.4. What are the higher level data types?
    Type Meaning
    volScalarField
    scalar, e.g. pressure
    volVectorField
    vector, e.g. velocity
    volTensorField
    tensor, e.g. Reynolds Stress
    surfaceScalarField
    surface scalar, e.g. flux
    dimensionedScalar
    constant, e.g. viscosity
    1.1.5. What are fields?
    Arrays of data stored at cell centres in the mesh
    Include bouundary information
    Three types
    volScalarField
    volVectorField
    volTensorField
    Values are stored in named dictionary files in named timestep directories e.g. case/0/p for pressure
    1.1.6. What are the three types?
    <Type> refers to:
    scalar
    vector
    tensor
    1.1.7. What are the five basic classes?
    Class Meaning
    fvPatchField
    (and derived classes)
    Boundary conditions
    lduMatrix
    fvMatrix
    (and linear solvers)
    Sparse matrices
    1.1.8. What are the three space-time classes?
    Class Meaning
    polyMesh
    Stands for polyhedral mesh
    Most basic mesh class
    Contains:
    pointField
    faceList
    cellList
    polyPatchList
    fvMesh
    Extends polyMesh contains:
    Cell volumes (volScalarField)
    Cell centres (volVectorField)
    Face area vectors (surfaceVectorField)
    Face centres (surfaceVectorField)
    Face area magnitudes (surfaceScalarField)
    Face motion centres (surfaceScalarField)
    Time
    Class to control time during OpenFOAM
    Declared as variable runTime
    Provides list of saved times runTime.times()
    Timestep = deltaT()
    Return current directory name = name()
    Time increments = operator++() operator+=(scalar)
    Write objects to disk = write()
    Start time, end time = startTime(), endTime()
    1.1.9. What are the three field algebra classes?
    Class Meaning
    Field<Type>
    Array template class, e.g. Field<vector> = vectorField
    Renamed using typedef as:
    scalarField
    vectorField
    tensorField
    symmTensorField
    tensorThirdField
    symmTensorThirdField
    dimensionedField
    Combination of:
    Field
    GeometricBoundaryField
    fvMesh
    dimensionSet
    Defines values at all locations in domain with aliases:
    volField<Type>
    surfaceField<Type>
    pointField<Type>
    1.1.10. What are the two discretisation classes?
    Class Meaning
    fvc
    Stands for finite volume calculus
    Explicit derivative evaluation
    Input = known geometricField<Type>
    Output = geometricField<Type> object
    fvm
    Stands for finite volume method
    Implicit derivative evaluation
    Input = unknown geometricField<Type>
    Output = fvMatrix<Type> object, which can be inverted in the matrix equation Mx=y
    1.1.11. What is a geometricField<Type>?
    volField<Type>
    surfaceField<Type>
    pointField<Type>
    1.1.12. What is the objectRegistry?
    Object registry of entities (dictionaries, fields) which are to be read in or written out
    1.1.13. What is the IOobject?
    Defines I/O attributes of entities managed by the object registry.
    1.1.14. How is a dictionary object read?
    Code Meaning
    Info << "Reading transportProperties" << endl;
    Send message to screen
    IOdictionary transportProperties
    "transportProperties",
    runTime.constant(),
    mesh,
    IOobject::MUST_READ
    IOobject::NO_WRITE
    Read in at creation
    dimensionedScalar nu
    transportProperties.lookup("nu")
    Lookup viscosity in dictionary
    1.1.15. How is volVectorField read from disk?
    Code Meaning
    volVectorField U
    "U",
    Times[i].name(),
    runTime,
    IOobject::MUST_READ
    mesh
    volVectorField read in from disk
    Associated with runTime database
    Must be read
    1.1.16. How is volScalarField constructed?
    Code Meaning
    volVectorField magU
    "magU",
    Times[i].name(),
    runTime,
    IOobject::NO_READ
    IOobject::AUTO_WRITE
    ::mag(U)
    magU.write();
    construct mag(U) object of type volScalarField called magU
    write it out
    1.1.17. What are the read and write options?
    Class Meaning
    NO_READ
    Object created
    MUST_READ
    READ_IF_PRESENT
    Object asked to read
    NO_WRITE
    Object destroyed
    AUTO_WRITE
    Object asked to write
    1.1.18. How are objects represented in OpenFOAM?
    How to create an object that writes the magnitude of a velocity vector?
    Class Meaning
    #include "fvCFD.H"
    int main(int argc, char argv[])
    include "addTimeOptions.H"
    include "setRootCase.H"
    include "createTime.H"
    instantList Times = runTime.times();
    include "createMesh.H"
    One block called main is needed
    #include to store commonly used code
    runTime is a variable of the OpenFOAM Time class - for timestepping through code
    for(label i=0; i<runTime.size(); i++)
    runTime.setTime(Times[i],i);
    Info << "Time: " << runTime.value() << endl
    volVectorField U
    "U",
    Times[i].name(),
    runTime,
    IOobject::MUST READ
    mesh
    Loop over all possible times
    Read in a volVectorField U
    volScalarField magU
    "magU",
    Times[i].name(),
    runTime,
    IOobject::NO READ,
    IOobject::AUTO WRITE
    ::mag(U)
    magU.write();
    } return 0;}
    Construct a volScalarField magU
    Write out the velocity
    1.1.19. How is matrix inversion done in fvm?
    Each operator in fvm constructs particular entries in known M and y as a fvMatrix object
    fvMatrix is a template class (actual classes are fvScalarMatrix etc)
    fvMatrix handles storage via lduMatrix class
    fvMatrix class also handles solution
    1.1.20. What are lists?
    Class Meaning
    List<Type>
    Allows creation of a list of any object of a class e.g. List<vector>
    PtrList<Type>
    List of pointers
    SLList<Type>
    Non-intrusive singly-linked list
    1.1.21. What are fields?
    Class Meaning
    Field<Type>
    Renamed as scalarField, vectorField, tensorField, symmTensorField,
    tensorThirdField and symmTensorThirdField
    1.1.22. How is memory accessed?
    Arrays
    Pointers
    References
    1.1.23. How is IO Communication done?
    Code Meaning
    Info << "Time = " << runTime.timeName() << nl << endl;
    Info object is output to the screen
    1.1.24. How are derivatives of fields evaluated?
    Time derivative
    Divergence (div)
    Spatial derivative
    Discretised using the flux at the faces
    e.g. ∇⋅(uq) (the advection term)
    Gradient (grad)
    Spatial derivative
    e.g. ∇p in the momentum equation
    Laplacian
    Spatial derivative
    Discretised as ∇⋅μ∇q
    gradient scheme for ∇q
    interpolation for μ
    discretisation for ∇⋅
    e.g. μ∇2q in the momentum equation
    1.1.25. What are the functions for discretisation?
    Function Meaning
    fvc::ddt(A)
    fvm::ddt(A)
    Time derivative
    ∂A/∂t
    A can be a scalar, vector or tensor
    fvc::ddt(rho,A)
    fvm::ddt(rho,A)
    Density weighted time derivative
    ∂ρA/∂t
    ρ can be any scalar field
    fvc::d2dt2(rho,A)
    fvm::d2dt2(rho,A)
    Second density weighted time derivative
    ∂/∂t(ρ∂A/∂t)
    fvc::grad(A)
    fvm::grad(A)
    Gradient
    A can be a scalar or a vector
    Result is a volVectorField (from scalar) or a volTensorField (from vector)
    fvc::div(A)
    fvm::div(A)
    Divergence
    A can be a vector or a tensor
    Result is a volScalarField (from vector) or a volVectorField (from tensor)
    fvc::laplacian(A)
    fvm::laplacian(A)
    Laplacian
    ∇2A
    fvc::laplacian(mu, A)
    fvm::laplacian(mu, A)
    Laplacian
    ∇⋅(μ∇A)
    fvc::curl(A)
    fvm::curl(A)
    Curl
    ∇×A
    fvm::div(phi,A)
    Divergence using flux to evaluate this
    A can be a scalar, vector or a tensor
    fvm::Sp(rho,A)
    Implicit evaulation of source term
    fvm::SuSp(rho,A)
    Implicit or explicit evaulation of source term (depending on sign of rho
    1.1.26. How can are equations translated into code?
    Equation Code
    ∂q∂t+∇⋅qu=μ∇2q
    fvScalarMatrix transport
    fvm::ddt(q)
    + fvm::div(phi,q)
    - fvm::laplacian(mu,q)
    // phi is the flux from the momentum equation
    ∂T∂t=κ∇2T
    solve(fvm::ddt(T) == kappa*fvc::laplacian(T))
    // T is a volScalarField defined on the mesh
    // A discretised representation of the field variable T
    // solve performs matrix inversion for one step
    ∂k∂t+∇⋅ku−∇⋅[(ν+νt)∇k]=νt[1/2(∇u+∇uT]2−ε/k
    solve(
    fvm::ddt(k)
    + fvm::div(phi,k)
    - fvm::laplacian(nu()+nut,k)
    == nut*magSqr(symm(fvc::grad(U)))
    - fvm::Sp(epsilon/k,k)
    1.1.27. How is the PISO algorithm programmed?
    The PISO (Pressure Implicit with Splitting of Operators) is an efficient method to solve the Navier-Stokes equations
    The algorithm can be summed up as follows:
    Set the boundary conditions.
    Solve the discretized momentum equation to compute an intermediate velocity field.
    Compute the mass fluxes at the cells faces.
    Solve the pressure equation.
    Correct the mass fluxes at the cell faces.
    Correct the velocities on the basis of the new pressure field.
    Update the boundary conditions.
    Repeat from 3 for the prescribed number of times.
    Increase the time step and repeat from 1.
    The implementation:
    Define the equation for U
    fvVectorMatrix UEqn
    fvm::ddt(U)
    • fvm::div(phi, U)
    • fvm::laplacian(nu, U)
      Solve the momentum predictor
      solve (UEqn == -fvc::grad(p));
      Calculate the ap coefficient and calculate U
      volScalarField rUA = 1.0/UEqn().A();
      U = rUA*UEqn().H();
      Calculate the flux
      phi = (fvc::interpolate(U) & mesh.Sf())
      • fvc::ddtPhiCorr(rUA, U, phi);
        adjustPhi(phi, U, p);
        Define and solve the pressure equation and repeat for the prescribed number of non-orthogonal corrector steps
        fvScalarMatrix pEqn
        fvm::laplacian(rUA, p) == fvc::div(phi)
        pEqn.setReference(pRefCell, pRefValue);
        pEqn.solve();
        Correct the flux
        if (nonOrth == nNonOrthCorr)
        phi -= pEqn.flux();
        Calculate continuity errors
    include "continuityErrs.H"
    Perform the momentum corrector step
    U -= rUA*fvc::grad(p);
    The following is from the OpenFOAM UK Users Group:
    1.1.28. What are header files?
    Sections of code in separate files that are widely used - all function prototypes in a header file
    Equation Code
    #include "CourantNumber.H"
    File containing code for calculating Courant number
    1.1.29. What is wmake?
    wmake is a make system – directs the compiler to compile specific files in particular ways.
    Controlled through files in Make:
    files – specifies which user-written files to compile and what to call the result
    options – specifies additional header files/libraries to be included in the compilation.
