  4. pointwise划分了地形网格计算域为3000*3000*1000 ,用openFoam中simpleFoam求解计算错误?
9 帖子 4 发布者 15.6k 浏览
  • dybD 离线
    dybD 离线
    dyb
    我在这个问题这儿卡了2个月了,我用pointwise划分了一个复杂地型网格,计算域300030001000,最小网格长宽为30*30,第一层网格高度为50cm,我计算的时候出现如下现象,到最后一行,算例自动停止。
    我最初的想法是将of自带的一个例子里的网格替换成用pointwise生成的网格,进行计算,不知道出了什么问题,希望能得到各位老师的帮助,谢谢!
        \\  /    A nd           | Version:  6
         \\/     M anipulation  |
    Build  : 6-e29811f5dff8
    Exec   : simpleFoam
    Date   : Jun 07 2019
    Time   : 18:39:08
    Host   : "DESKTOP-K2TDLI2"
    PID    : 434
    I/O    : uncollated
    Case   : /home/dyb/turbineSiting
    nProcs : 1
    Create time
    Create mesh for time = 0
    SIMPLE: Convergence criteria found
            p: tolerance 0.001
            U: tolerance 0.0001
            "(k|epsilon)": tolerance 0.0001
    Reading field p
    Reading field U
    kEpsilonCoeffs
        Cmu             0.09;
        C1              1.44;
        C2              1.92;
        sigmaEps        1.11;
        C3              0;
        sigmak          1;
    No MRF models present
    Starting time loop
    Time = 0.5
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.130925946068, No Iterations 1000
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.305787562946, No Iterations 1000
    smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 1.18059515052, No Iterations 1000
    如下是我的一些设置
    fvSolution
         \\/     M anipulation  |
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvSolution;
    solvers
        p
            solver           GAMG;
            tolerance        1e-7;
            relTol           0.1;
            smoother         GaussSeidel;
        U
            solver           smoothSolver;
            tolerance        1e-8;
            relTol           0.1;
            nSweeps          1;
        k
            tolerance        1e-8;
            relTol           0.1;
            nSweeps          1;
        epsilon
            tolerance        1e-8;
            relTol           0.1;
            nSweeps          1;
    SIMPLE
        nNonOrthogonalCorrectors 0;
        residualControl
            p               1e-3;
            U               1e-4;
            "(k|epsilon)"   1e-4;
    relaxationFactors
        fields
            p               0.3;
        equations
            U               0.7;
            k               0.7;
            epsilon         0.7;
    cache
        grad(U);
    fvSchemes
         \\/     M anipulation  |
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvSchemes;
    ddtSchemes
        default             steadyState;
    gradSchemes
        default             Gauss linear;
    divSchemes
        default             none;
        div(phi,U)          bounded Gauss upwind;
        div(phi,epsilon)    bounded Gauss upwind;
        div(phi,k)          bounded Gauss upwind;
        div((nuEff*dev2(T(grad(U)))))    Gauss linear;
    laplacianSchemes
        default             Gauss linear limited corrected 0.33;
    interpolationSchemes
        default             linear;
    snGradSchemes
        default             limited corrected 0.33;
    controlDict
         \\/     M anipulation  |
        version     2.0;
        format      ascii;
        class       dictionary;
        object      controlDict;
    application     simpleFoam;
    startFrom       latestTime;
    startTime       0;
    stopAt          endTime;
    endTime         1000;
    deltaT          0.5;
    writeControl    timeStep;
    writeInterval   50;
    purgeWrite      0;
    writeFormat     binary;
    writePrecision  12;
    writeCompression off;
    timeFormat      general;
    timePrecision   6;
    runTimeModifiable yes;
    libs ("libatmosphericModels.so");
    看起来像是边界条件设置有问题
  • dybD 离线
    dybD 离线
    dyb
    李老师,我把我的边界条件发过来,您帮忙看一下。大概是压力项可能出错了
    epsilon
         \\/     M anipulation  |
        version     2.0;
        format      ascii;
        class       volScalarField;
        location    "0";
        object      epsilon;
    dimensions      [0 2 -3 0 0 0 0];
    #include        "include/initialConditions"
    internalField   uniform $turbulentEpsilon;
    boundaryField
        terrain
            Cmu             0.09;
            kappa           0.4;
            E               9.8;
        outlet
            type            inletOutlet;
            inletValue      uniform $turbulentEpsilon;
        inlet
            type            atmBoundaryLayerInletEpsilon;
            #include        "include/ABLConditions"
        ground
            type            zeroGradient;
        top
            type            slip;
        sides
            type            slip;
    k
         \\/     M anipulation  |
        version     2.0;
        format      ascii;
        object      k;
    internalField   uniform $turbulentKE;
    boundaryField
        outlet
            type            inletOutlet;
            inletValue      uniform $turbulentKE;
        inlet
            type            atmBoundaryLayerInletK;
        terrain
            value           uniform 0.0;
        ground
            type            zeroGradient;
        top
            type            slip;
        sides
            type            slip;
    nut
         \\/     M anipulation  |
        version     2.0;
        format      ascii;
        location    "0";
        object      nut;
    internalField   uniform 0;
    boundaryField
        inlet
            type            calculated;
            value           uniform 0;
        outlet
            type            calculated;
            value           uniform 0;
        terrain
            type            nutkAtmRoughWallFunction;
            z0              $z0;
            value           uniform 0.0;
        ground
            type            calculated;
            value           uniform 0;
        top
            type            slip;
        sides
            type            slip;
    P
         \\/     M anipulation  |
        version     2.0;
        format      ascii;
        object      p;
    internalField   uniform $pressure;
    boundaryField
        inlet
            type            zeroGradient;
        outlet
            type            uniformFixedValue;
            uniformValue    $internalField;
        terrain
            type            zeroGradient;
        ground
            type            zeroGradient;
        top
            type            slip;
        sides
            type            slip;
    u
         \\/     M anipulation  |
        version     2.0;
        format      ascii;
        class       volVectorField;
        location    "0";
        object      U;
    internalField   uniform $flowVelocity;
    boundaryField
        outlet
            type            inletOutlet;
            inletValue      uniform (0 0 0);
        inlet
            type            atmBoundaryLayerInletVelocity;
        terrain
            uniformValue    (0 0 0);
        ground
            uniformValue    constant (0 0 0);
        top
            type            slip;
        sides
            type            slip;
    说明文件ABL
         \\/     M anipulation  |
    Uref                 10.0;
    Zref                 20;
    zDir                 (0 0 1);
    flowDir              (1 0 0);
    z0                   uniform 0.1;
    zGround              uniform 0;
    initialConditions
         \\/     M anipulation  |
    flowVelocity         (0 0 0);
    pressure             0;
    turbulentKE          1.3;
    turbulentEpsilon     0.01;
    fixedInlet
    inlet
        type  fixedValue;
        value $internalField;
  • dybD 离线
    dybD 离线
    dyb
    解决了,不同尺度的网格对应压力求解方法的平滑smoother有问题,初始条件也没有错,
    wsy11
    @dyb 在 pointwise划分了地形网格计算域为3000*3000*1000 ,用openFoam中simpleFoam求解计算错误? 中说:
    大佬您好,
    我最近也在学习复杂地形上风场的模拟,使用的也是turbinesiting这个算例,请问这个算例有没有比较好的教程?
    目前还是小白,总是会报错
    dybD 1 条回复 最后回复
  • dybD 离线
    dybD 离线
    dyb
    在 中回复了 wsy11 最后由 李东岳 编辑
    @wsy11 你好,我最初用的方法比较笨,你可以之直接用pointwise绘制计算域,把边界层加大一些,我最初近地1m高,这个我没有制作教程,一般你只需要改fvSolution,我的主要是这样的,再就是时间步长要小
    code_textsolvers
        p
            solver           GAMG;
            tolerance        1e-8;
            relTol           0.01;
            smoother         DIC;
        pFinal
            $p;
            smoother        DIC;
            tolerance       1e-06;
            relTol          0;
        "(U|k|nuTilda)"
            smoother        DILU;
            tolerance       1e-05;
            relTol          0.1;
        "(U|k|nuTilda)Final"
            $U;
            tolerance       1e-05;
            relTol          0;
    PIMPLE
        nOuterCorrectors 1;
        nCorrectors     2;
        pRefCell        1001;
        pRefValue       0;
    W 2 条回复 最后回复
    wsy11
    在 中回复了 dyb 最后由 编辑
    @dyb 好的好的,谢谢大佬。
    我目前的网格划分还比较简单,是用GlobalMapper裁剪ASTER GDEM地形高程数据,然后用snappyHexMesh工具自动划分网格的,还没学过pointwise,等我尝试一下您的方法再来请教。
    wsy11
    在 中回复了 dyb 最后由 编辑
    大佬您好,我想再请教一个问题
    turbinesiting算例中的地形的stl文件是怎么生成的?我用自己的stl文件(用GlobalMapper裁剪ASTER GDEM地形高程数据)时,会存在两个底面,terrian面和ground面都会存在。
    B 1 条回复 最后回复
  • B 离线
    B 离线
    Banbor
    在 中回复了 wsy11 最后由 编辑
    @wsy11 那就是你的blockmesh 设置 把底面 ground 在设置低一些
