  4. 利用interPhaseChangeFoam的LES计算空化流动求助
1 帖子 1 发布者 2.1k 浏览
  • 小 离线
    小 离线
    小考拉
    大家好!
    我现在利用interPhaseChangeFoam里面的LES 一方程涡粘模型 计算绕Clark-Y水翼空化流动,计算出的升力系数cl比试验值偏大一倍,总的空穴体积小与实验值。我分析是我计算的 流场压力,出了问题,我感觉主要可能是离散格式 和求解器的问题,请问谁 利用interPhaseChangeFoam里面的LES计算过水翼空化呢? 可以分享一下经验吗?
    谢谢!
    求解器设置
    |  \\    /   O peration     | Version:  4.0                                   |
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      fvSolution;
    solvers
        alpha.water
            nAlphaCorr      1;
            nAlphaSubCycles 1;
            cAlpha          1;
            MULESCorr       yes;
            nLimiterIter    5;
            solver          smoothSolver;
            tolerance       1e-8;
            relTol          0;
            maxIter         100;
        alpha.waterFinal
            nAlphaCorr      1;
            nAlphaSubCycles 1;
            cAlpha          1;
            MULESCorr       yes;
            nLimiterIter    5;
            tolerance       1e-8;
            relTol          0;
            maxIter         100;
        "U.*"
            tolerance       1e-6;
            relTol          0;
        ".*(rho|rhoFinal)"
            solver          diagonal;
        pcorr
            solver          PCG;
            preconditioner
                preconditioner  GAMG;
                tolerance       1e-05;
                relTol          0;
                smoother        DICGaussSeidel;
            tolerance       1e-05;
            relTol          0;
            maxIter         500;
    	pcorrFinal
            solver          PCG;
            preconditioner
                tolerance       1e-05;
                relTol          0;
            tolerance       1e-05;
            relTol          0;
            maxIter         500;
        Phi
            $p_rgh;
            relTol          0;
        p_rgh
            solver          GAMG;
            tolerance       1e-07;
            relTol          0.00001;
            smoother        DIC;
        p_rghFinal
            solver          PCG;
            preconditioner
                tolerance       1e-07;
                relTol          0;
                nVcycles        2;
                nPreSweeps      2;
            tolerance       1e-07;
            relTol          0;
            maxIter         1000;
        U
            smoother        GaussSeidel;
            tolerance       1e-06;
            relTol          0;
            nSweeps         1;
        "(U|k|omega)"
            tolerance       1e-08;
            relTol          0.0001;
        "(T|k|B|nuTilda).*"
            tolerance       1e-08;
            relTol          0;
            maxIter         100;
        "(U|k|omega)Final"
            tolerance       1e-08;
            relTol          0;
    PIMPLE
        momentumPredictor no;
        transonic       no;
        nOuterCorrectors 1;
        nCorrectors     2;
        nNonOrthogonalCorrectors 0;
    离散格式设置
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      fvSchemes;
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
    divSchemes
        default             none;
        div(phi,alpha)  Gauss vanLeer;
        div(phirb,alpha) Gauss linear;
        div(phi,rho)    Gauss limitedLinear 1;
        div(rhoPhi,U)  Gauss linearUpwind grad(U);
        div(phi,thermo:rho.water) Gauss upwind;
        div(phi,thermo:rho.air) Gauss upwind;
        div(rhoPhi,T)  Gauss upwind;
        div(rhoPhi,K)  Gauss upwind;
        div(phi,p)      Gauss upwind;
        div(phi,k)      Gauss upwind;
        div(rhoPhi,omega)  Gauss limitedLinear 1;
        div(phi,omega)   Gauss upwind;
        div(rhoPhi,k)   Gauss upwind;
    laplacianSchemes
        default         Gauss linear limited corrected 0.33;
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         limited corrected 0.33;
    wallDist
        method meshWave;
