  4. 400w 网格计算 水翼空化问题
400w 网格计算 水翼空化问题
4 帖子 2 发布者 5.4k 浏览
  • 小 离线
    小 离线
    小考拉
    大家好!
    最近再尝试用LES模拟水翼空化流动,用了400W的网格和interPhaseChangeFoam求解器,前期计算发现比较稳定,到0.3s之后就突然不正常了,有没有人用比较密的网格计算过水翼空化?
    我原始设置的是固定时间步2.5*e-06,我感觉可能是时间步有点大了,但更改之后效果也不是很明显
    ps:我之前用200w网格计算,效果很好,并没有出现类似的问题
    下图是监控的 云空化空穴体积随时间变化图,前面好好地,后面就有问题了。。。
    controlDict文件代码
    // Foam Application Class
    application interPhaseChangeFoam;
    // Start point of run
    //startFrom       latestTime;
    // Calculation start time
    startTime       0;//0.399;//0;
    // End point of run
    stopAt          endTime;
    // Calculation end time
    endTime         0.5;//0.9;//5.0e-2;
    // Calculation time step
    deltaT          2.5e-06;//2.0e-5;//
    // Type of write output control
    writeControl    adjustableRunTime;
    // Interval with which the results are output
    writeInterval   1.0e-3;
    // Limits number of time directories before overwriting
    cycleWrite      0;
    // Write Format
    writeFormat     ascii;
    // Significant figures of written ASCII data
    writePrecision  6;
    // Write Compression
    writeCompression uncompressed;
    // Time directories name format
    timeFormat      general;
    // Decimal precision of time directory names
    timePrecision   6;
    // Can parameters be modified during run time?
    runTimeModifiable yes;
    // Automatic adjustment of time step?
    adjustTimeStep  off;
    // maxCo
    maxAlphaCo         0.99; // 0.2; Victor Changes to remain with courant number < 1
    // maxDeltaT
    maxDeltaT     1e-2; // 1; Control the changes of delta calculation for a courant number < 1
    fvSchemes文件
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
    divSchemes
        default             none;
        div(phi,alpha)  Gauss upwind;
        div(phirb,alpha) Gauss linear;
        div(phi,rho)    Gauss limitedLinear 1;
        div(rhoPhi,U)  Gauss upwind;
        div(phi,thermo:rho.water) Gauss upwind;
        div(phi,thermo:rho.air) Gauss upwind;
        div(rhoPhi,T)  Gauss upwind;
        div(rhoPhi,K)  Gauss upwind;
        div(phi,p)      Gauss upwind;
        div(phi,k)      Gauss upwind;
        div(rhoPhi,omega)  Gauss limitedLinear 1;
        div(phi,omega)   Gauss upwind;
        div(rhoPhi,k)   Gauss upwind;
    laplacianSchemes
        default         Gauss linear uncorrected;
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         uncorrected;
    wallDist
        method meshWave;
    一般这样 网格量很大的情况,用LES计算非定常问题,需要注意什么呢?
    求各位指点!
    把你log文件信息贴一下,
  • 小 离线
    小 离线
    小考拉
    .log文件最前面的参数
    Create time
    Create mesh for time = 0.195
    Reading field p_rgh
    Reading field U
    AMI: Creating addressing and weights between 43430 source faces and 43430 target faces
    AMI: Patch source sum(weights) min/max/average = 0.999998, 1, 1
    AMI: Patch target sum(weights) min/max/average = 0.999994, 1, 1
    Creating phaseChangeTwoPhaseMixture
    Selecting phaseChange model SchnerrSauer
    Selecting turbulence model type LES
    Selecting LES turbulence model WALE
    Selecting LES delta type cubeRootVol
    LES
        LESModel        WALE;
        turbulence      on;
        printCoeffs     on;
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        PrandtlCoeffs
            delta           cubeRootVol;
            cubeRootVolCoeffs
                deltaCoeff      1;
            smoothCoeffs
                delta           cubeRootVol;
                cubeRootVolCoeffs
                    deltaCoeff      1;
                maxDeltaRatio   1.1;
            Cdelta          0.158;
        vanDriestCoeffs
            delta           cubeRootVol;
            cubeRootVolCoeffs
                deltaCoeff      1;
            smoothCoeffs
                delta           cubeRootVol;
                cubeRootVolCoeffs
                    deltaCoeff      1;
                maxDeltaRatio   1.1;
            Aplus           26;
            Cdelta          0.158;
        smoothCoeffs
            delta           cubeRootVol;
            cubeRootVolCoeffs
                deltaCoeff      1;
            maxDeltaRatio   1.1;
        Ce              1.048;
        Ck              0.094;
        Cw              0.325;
    Reading g
    Reading hRef
    Calculating field g.h
    Courant Number mean: 0.00975387 max: 1.87647
    Starting time loop
    forces forceCoeffs1:
    forceCoeffs forceCoeffs1:
    fieldAverage fieldAverage1:
        Restarting averaging for fields:
            U iters = 78001 time = 0.195002
            alpha.water iters = 78001 time = 0.195002
            p iters = 78001 time = 0.195002
    surfaceFieldValue patchAverage:
        total faces  = 9879
        total area   = 0.003969
    发散之后输出的内容
    Courant Number mean: 0.00975777 max: 2.3062
    Time = 0.34437
    smoothSolver:  Solving for alpha.water, Initial residual = 2.45197e-06, Final residual = 4.99732e-09, No Iterations 1
    Phase-1 volume fraction = 0.997016  Min(alpha.water) = 8.9353e-06  Max(alpha.water) = 1
    MULES: Correcting alpha.water
    Liquid phase volume fraction = 0.997016  Min(alpha.water) = 8.9353e-06  Max(alpha.water) = 1
    GAMG:  Solving for p_rgh, Initial residual = 1.23064e-05, Final residual = 6.14351e-08, No Iterations 1
    GAMGPCG:  Solving for p_rgh, Initial residual = 1.53786e-06, Final residual = 9.23801e-09, No Iterations 1
    ExecutionTime = 184925 s  ClockTime = 186563 s
    fieldAverage fieldAverage1 write:
        Calculating averages
    Courant Number mean: 0.00975777 max: 2.30292
    Time = 0.344373
    smoothSolver:  Solving for alpha.water, Initial residual = 2.45241e-06, Final residual = 5.00226e-09, No Iterations 1
    Phase-1 volume fraction = 0.997016  Min(alpha.water) = 8.93479e-06  Max(alpha.water) = 1
    Liquid phase volume fraction = 0.997016  Min(alpha.water) = 8.93479e-06  Max(alpha.water) = 1
    GAMG:  Solving for p_rgh, Initial residual = 1.21562e-05, Final residual = 6.58046e-08, No Iterations 1
    GAMGPCG:  Solving for p_rgh, Initial residual = 1.52149e-06, Final residual = 1.02397e-08, No Iterations 1
    ExecutionTime = 184928 s  ClockTime = 186566 s
    刚才和别人交流,感觉自己的离散格式都是一阶的,可能耗散有点大,感觉自己还要去试一试。。
    一阶格式更加稳定,在发散的情况下追求高阶格式会更加发散,为何不把可调节时间不长开启?
